Scraping only the temperature from WeatherUnderground sensor
myozone
Re: Scraping only the temperature from WeatherUnderground se
If this the correct way to control via the temperature
- blockly-newtemp.jpg (24.67 KiB) Viewed 7327 times
TallGuy212
I am wondering what the syntax is to scrape the humidity from the same device. Getting the temperature was no problem but it proves difficult to scrape the next value. I guess it has to do with being a % instead of a temperature.
What is correct syntax?
DutchHans
Hi Tallguy,
Did you figure it out? I am very interested and struggling with the same.
Regards,
Hans
Regards,
Hans
- jcjames13009
- Domoticz version: 2023.2
Hi Hans,
I used the following command in my lua script to scrap Temperature and Hulidity from my WU sensor
And I have this in my Domoticz
Hope it'll help
JC
sWeatherTemp, sWeatherHumidity, sWeatherHumidityStat, sWeatherBarometer, sWeatherBarometerFor = otherdevices_svalues[capteurwu1]:match("([^;]+);([^;]+);([^;]+);([^;]+);([^;]+)")
commandArray[1]={['UpdateDevice'] = idx1 .. '|0|' .. tostring(sWeatherTemp)}
commandArray[2]={['UpdateDevice'] = idx2 .. '|' .. tostring(sWeatherHumidity) .. '|' .. '|' .. tostring(sWeatherHumidityStat) .. '|'}
Hope it'll help
JC
DutchHans
Hello all,
There is something strange.. when I look in the Logfile the lua script is not triggered.
I am not a programmer, I try to read code and understand it. I have tried to change the WU script for my needs... but I have no idea
But am I missing something?
The WU script is triggered, thats what the log says, but my Cresta lua file isnt.
What am i doing wrong?
Hope someone can help me out.
Kind regards, Hans
--script_device_tempCresta.lua
local sensorLR = 'ThermoRFXCOM' --Original sensor of wunderground carrying the 0001 ID
local idx = 102 --idx of your manual created virtual temp sensor
if devicechanged[sensorLR] then
sWeatherTemp, sWeatherHumidity = otherdevices_svalues[sensorLR]:match("([^;]+);([^;]+)")
--sWeatherTemp = tonumber(sWeatherTemp)
commandArray['UpdateDevice'] = idx .. '|0|' .. tostring(sWeatherTemp)
Kind regards, Hans
- Domosapiens
- Domoticz version: V3.5981
Are you sure that this is the correct IDX of your dummy temp sensor ?
It looks exact like the number from the Wiki
Domosapiens
local idx = 102 --idx of the virtual temperature sensor you created above
Domosapiens
- Siewert308SW
- Domoticz version: Stable
Added a cresta sensor from my neighbors to DomoticzDutchHans wrote:Hello all,
Hope someone can help me out.Code: Select all
--script_device_tempCresta.lua local sensorLR = 'ThermoRFXCOM' --Original sensor of wunderground carrying the 0001 ID local idx = 102 --idx of your manual created virtual temp sensor commandArray = {} if devicechanged[sensorLR] then sWeatherTemp, sWeatherHumidity = otherdevices_svalues[sensorLR]:match("([^;]+);([^;]+)") --sWeatherTemp = tonumber(sWeatherTemp) commandArray['UpdateDevice'] = idx .. '|0|' .. tostring(sWeatherTemp) end return commandArray
Kind regards, Hans
Added a new virtual temp sensor
and adjusted the current names in de SensorWU script for testing.
Seems it just works fine, you could test it.
--script_device_sensorCR.lua
local sensorcr = 'Weerstation' --name of the sensor that gets created when you add the Cresta device (and that contains multiple values like temperature, humidity, barometer etc)
local idx = 327 --idx of the virtual temperature sensor you created for scrapping the temperature
if devicechanged[sensorcr] then
sCrestaTemp, sCrestaHumidity, sCrestaPressure = otherdevices_svalues[sensorcr]:match("([^;]+);([^;]+);([^;]+)")
sCrestaTemp = tonumber(sCrestaTemp)
commandArray['UpdateDevice'] = idx .. '|0|' .. tostring(sCrestaTemp)
Setup:
- DS923+ Docker
Domoticz Latest Stable
Mosquitto / ZwaveJSUI @ Aeotec Z-Stick Gen5+ / PiHole Unbound
P1 USB Gas/Power, HW watermeter
- A lot of Zwave switches, contacts, plugs, smoke/Co2 ect
- DiY 7.5kWh Solar Storage @ GitHuB
- DS923+ Docker
DutchHans
Hello Siewert308SW
FANTASTIC!
It works perfectly
Im starting to understand how it works now.
Thank you very much.
FANTASTIC!
It works perfectly
h143
how can i scraping the humidity to a virtual humidity sensor?
the value is always 0 i have the following script:
local idx = 435 --idx of the virtual temperature sensor you created for scrapping the temperature
sCrestaHumidity = tonumber(sCrestaHumidity)
commandArray['UpdateDevice'] = idx .. '|0|' .. tostring(sCrestaHumidity)
tlpeter
Why define a new name instead of using the real device name in the script?
jannl
- Domoticz version: 2025.5.x
Like Peter says.
Start using the actual device name.
Print the value to the log in domoticz and check if it works first. (should work)
spudgunman
note sure what I am missing here - new to this whole project and wondering where to troubleshoot next, I have also tried this on the SVN build with same results (the results that my virtual temp device wont update)
version 2.2492
version 2.2492
2015-05-27 21:10:00.430 EventSystem: Script event triggered: /home/pi/domoticz/scripts/lua/script_device_sensorWU.lua
2015-05-27 21:10:00.420 (WeatherUnderground) Temp + Humidity + Baro (WUCombo)
2015-05-27 21:10:00.440 Hardware Monitor: Fetching data (System sensors)
2015-05-27 21:10:00.437 (WeatherUnderground) Wind (Wind)
2015-05-27 21:10:00.450 (WeatherUnderground) UV (UV)
2015-05-27 21:10:00.476 (WeatherUnderground) Rain (Rain)Code: Select all
local sensorwu = 'WUCombo' --name of the sensor that gets created when you add the WU device (and that contains multiple values like $
local idx = 14065 --idx of the virtual temperature sensor you created above
if devicechanged[sensorwu] then
sWeatherTemp, sWeatherHumidity, sWeatherPressure = otherdevices_svalues[sensorwu]:match("([^;]+);([^;]+);([^;]+)")
spudgunman
AI hacked up the scrip to pull all data.
updated May 28
updated May 28
--Script To Parse WeatherUnderground Multi-Value Sensor, Additionally using PWS: system from WU with a new output format
--This script assumes the output (which can be viewed in events show current state button) is like this 19.5;79;3;1019;3 (temp;humidity;null;pressure;null)
--more details at this wiki http://www.domoticz.com/wiki/Virtual_weather_devices
--The following need updated for your enviroment get the 'Idx' or 'Name' off the Device tab. By default only the Temp is 'uncommented or enabled' in this script.
local sensorwu = 'ChangeME' --name of the sensor that gets created when you add the WU device (and that contains multiple values like temperature, humidity, barometer etc)
local idxt = 999 --idx of the virtual temperature sensor you need to change this to your own Device ID
local idxh = 999 --idx of the virtual humidity sensor you need to change this to your own Device ID
local idxp = 999 --idx of the virtual pressure sensor you need to change this to your own Device ID
sWeatherTemp, sWeatherHumidity, sHumFeelsLike, sWeatherPressure = otherdevices_svalues[sensorwu]:match("([^;]+);([^;]+);([^;]+);([^;]+);([^;]+)")
sWeatherHumidity = tonumber(sWeatherHumidity)
sWeatherPressure = tonumber(sWeatherPressure)
--parseDebug = ('WU Script Parsed Temp=' .. sWeatherTemp .. ' Humidity=' .. sWeatherHumidity .. ' Pressure=' .. sWeatherPressure)
--print(parseDebug)
commandArray[1] = {['UpdateDevice'] = idxt .. '|0|' .. sWeatherTemp}
--commandArray[2] = {['UpdateDevice'] = idxh .. '|' .. tostring(sWeatherHumidity) .. '|' .. tostring(sHumFeelsLike)}
--commandArray[3] = {['UpdateDevice'] = idxp .. '|0|' .. sWeatherPressure}
spudgunman
found my error I was using the ID and not the idxspudgunman wrote:note sure what I am missing here - new to this whole project and wondering where to troubleshoot next, I have also tried this on the SVN build with same results (the results that my virtual temp device wont update)
spudgunman
So my script 2 posts up to parse all the data (humidity and pressure) the script is working but I think there is a bug now..
I see all values in the events show current states screen but the virtual humidity and pressure are at 0 on the device tab and wacky on the dash
Jem101
I have to say, I've tried many variations of these scripts and finally managed to get one to run properly without logging errors, but I get the same results as spudgunman above. The temperature scrapes and works OK, the virtual humidity sensor gets reset to 0 (and stays at 0), the pressure appears to work OK but i have the same dashboard problem as above.
I've tried deleting and recreating the virtual sensors many times but I always get the same results.
I firmly believe in having an open mind - although not so open that your brain falls out!
- sometimes attributed to Carl Sagan, but the original quote is much older than that
- G3rard
- Target OS: -
- Domoticz version: No
You have to change to script a bit for the humidity, see the last line from (a part of) my code below. I am not using it for the pressure, so I can't help you with that, but maybe it works the same way.
sWeatherTempwu, sWeatherHumiditywu, sWeatherPressurewu = otherdevices_svalues[sensorwu]:match("([^;]+);([^;]+);([^;]+)")
sWeatherTempwu = tonumber(sWeatherTempwu)
sWeatherHumiditywu = tonumber(sWeatherHumiditywu)
if (sWeatherHumiditywu > 60 ) then
verw = 3 -->60 = 3 wet
elseif (sWeatherHumiditywu < 25 ) then
verw = 2 --<25 = 2 dry
verw = 1 -->=25 of <=60 = 1 comfortable
commandArray[2]={['UpdateDevice'] = idxwut .. '|0|' .. tostring(sWeatherTempwu)}
commandArray[3]={['UpdateDevice'] = idxwuh .. '|' .. tostring(sWeatherHumiditywu) .. '|' .. tostring(verw)}
Not using Domoticz anymore
spudgunman
ok that helps a ton - i updated my script to work with humidity now.. all that is remaining is to figure out pressure and what it expects.. so far the same trick of using 1,2,3 gave funny results
--print(parseDebug)
return commandArray-
Jem101
Yes indeed using the code above, I've also managed to get the virtual Humidity sensor working and giving the proper values but just like spudgunman the Pressure value is still giving problems.
So far, I've created a virtual 'Barometer' sensor which appears in devices, I've setup the script to scrape the value for 'pressure' from WU and this runs without showing any errors. In the 'devices' tab, I can see that the value has updated and does show the correct figure, which, I assume, means that the scraping is working OK. However I get the exact same odd value in the Dashboard as spudgunman posted earlier.
It looks as if the dashboard code is expecting different data (or a different format) to what it is receiving. Oddly enough I tried creating a virtual generic 'Pressure' sensor, plugged the idx for this into the script and this worked properly. The only problem is that this sensor appears in the 'Utilities' tab rather than the Weather one.
I'm wondering if the issue is something to do with the forecast field. I've notice that the output from WU will be something like 1004 (the pressure value) followed by a forecast, wet for example. So might the Barometer virtual sensor be expecting additional data (which isn't being scraped properly so it just doesn't display correctly) - or maybe I'm just talking complete rubbish!
Any help or suggestions would be gratefully received.
spudgunman
I have the device updating with the following but the graphic is still messed up and wont display on the dash at all, I tried a ton of different combos' according to the git-source the prediction text should not matter in the web.js it should take it either way but its not?
void SendBaroSensor(const int NodeID, const int ChildID, const int BatteryLevel, const float pressure, const int forecast);
But this isnt decoding still...
sPressiureFeelsLike = 3 --basically just a placeholder I dont know what this should be
commandArray[3] = {['UpdateDevice'] = idxp .. '|' .. sPressiureFeelsLike .. '|' .. sWeatherPressure}
