Re: Zigate Hue gu10 white ambiance
Posted: Sunday 13 June 2021 21:20
The Decode8000 error is something else for which we don't have a solution for the moment.
Join 16,000+ members discussing home automation with Domoticz. Get help with Zigbee, ZWave, MQTT, scripting, and 150+ integrations
https://forum.domoticz.com/
Okay. It doesn't look like it gives problems.keros wrote: Sunday 13 June 2021 21:20 The Decode8000 error is something else for which we don't have a solution for the moment.
Hi,pipiche wrote: Monday 14 June 2021 10:31 Unfortunately it seems that there is not the all logs that I'm expecting. I just see the Status and Errors here, so may be you have disable Log in the Domoticz Hardware Plugin settings.
That looks okay, the log settings.pipiche wrote: Monday 14 June 2021 19:17 No , you need to go to the Plugin Web Ui, Tools -> Debug (Advanced)
debugInput
debugCluster
debugPairing
So I need to do a new paring, and what logs do you need?pipiche wrote: Monday 14 June 2021 21:32 what you attached, seems to be an export.json, not the log file when doing the pairing ?
Update done, and the log attached.pipiche wrote: Monday 14 June 2021 22:03 Basically with the debug that you have enabled now, just redo a full pairing , and then you give me the log.
if possible, please do update the beta branch
2021-06-15 13:42:43.488 Sunrise: 05:10:00 SunSet: 21:56:00
2021-06-15 13:42:43.488 Day length: 16:46:00 Sun at south: 13:33:00
2021-06-15 13:42:43.488 Civil twilight start: 04:21:00 Civil twilight end: 22:45:00
2021-06-15 13:42:43.488 Nautical twilight start: 03:00:00 Nautical twilight end: 00:06:00
2021-06-15 13:42:43.488 There is no astronomical twilight in the space of 24 hours
2021-06-15 13:42:54.396 Active notification Subsystems: email, fcm, telegram (3/13)
2021-06-15 13:42:54.527 Starting shared server on: :::7979
2021-06-15 13:42:56.568 Zigate hardware started.
2021-06-15 13:42:56.569 Shelly hardware started.
2021-06-15 13:42:56.569 Google devices hardware started.
2021-06-15 13:42:56.904 Shelly: (Shelly) New hardware creation enabled
2021-06-15 13:42:57.679 Status: Zigate: (Zigate) [ MainThread] Plugin Database: DeviceList-16.txt
2021-06-15 13:42:57.689 Status: Zigate: (Zigate) [ MainThread] DeviceConf loaded
2021-06-15 13:42:57.692 Status: RFLink: Controller Initialized!...
2021-06-15 13:42:57.768 Status: RFLink: RFLink Detected, Version: 1.1 Revision: 48 Build: 4
2021-06-15 13:42:57.770 Status: MQTT: MQTT: connected to: 192.168.1.5:1883
2021-06-15 13:42:57.943 Status: Zigate: (Zigate) [ MainThread] load ListOfDevice
2021-06-15 13:42:57.971 Status: MQTT: MQTT: Subscribed
2021-06-15 13:42:58.790 Status: Zigate: (Zigate) [ MainThread] 37 Entries loaded from /home/pi/domoticz/plugins/Domoticz-Zigate/Data/DeviceList-16.txt
2021-06-15 13:42:58.887 Status: Zigate: (Zigate) [ MainThread] Transport mode: USB
2021-06-15 13:42:58.888 Status: Zigate: (Zigate) Connection Name: Zigate, Transport: Serial, Address: /dev/serial/by-id/usb-Silicon_Labs_ZiGate_0001-if00-port0
2021-06-15 13:42:58.905 Status: Zigate: (Zigate) [ MainThread] ZigateTransport: Serial Connection open: Serial<id=0x664ee5f0, open=True>(port='/dev/serial/by-id/usb-Silicon_Labs_ZiGate_0001-if00-port0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=None, xonxoff=False, rtscts=False, dsrdtr=False)
2021-06-15 13:42:58.906 Status: Zigate: (Zigate) [ZiGateWriter_16] ZigateTransport: writer_thread Thread start.
2021-06-15 13:42:58.907 Status: Zigate: (Zigate) [ZiGateForwarder_16] ZigateTransport: thread_processing_and_sending Thread start.
2021-06-15 13:42:58.907 Status: Zigate: (Zigate) Connection open: Serial<id=0x664ee5f0, open=True>(port='/dev/serial/by-id/usb-Silicon_Labs_ZiGate_0001-if00-port0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=None, xonxoff=False, rtscts=False, dsrdtr=False)
2021-06-15 13:42:58.994 Status: Python EventSystem: Initalizing event module.
2021-06-15 13:42:58.999 Status: EventSystem: Started
2021-06-15 13:42:58.999 Status: EventSystem: Queue thread started...
2021-06-15 13:43:01.333 Shelly: (Shelly) Connected to MQTT Server: 192.168.1.5:1883
2021-06-15 13:43:01.344 Status: Zigate: (Zigate) [ZiGateSerial_16] ==> Transport Mode switch to: 31d
2021-06-15 13:43:01.349 Status: Zigate: (Zigate) [ZiGateForwarder_16] ZiGate Classic
2021-06-15 13:43:01.349 Status: Zigate: (Zigate) [ZiGateForwarder_16] Installer Version Number: 031d
2021-06-15 13:43:09.165 Status: Zigate: (Zigate) [ZiGateForwarder_16] Zigate addresses ieee: 00158d0001ee040a , short addr: 0000
2021-06-15 13:43:09.165 Status: Zigate: (Zigate) [ZiGateForwarder_16] Network state UP, PANID: 5889 extPANID: 0x2fe14f25179533d9 Channel: 11
2021-06-15 13:43:13.731 Dummy: Light/Switch (Bel voordeur PIR)
2021-06-15 13:43:14.060 Status: Zigate: (Zigate) [ MainThread] Request Disabling Accepting new Hardware
2021-06-15 13:43:14.121 Status: Incoming connection from: 192.168.1.81
2021-06-15 13:43:14.980 Status: Zigate: (Zigate) [ZiGateForwarder_16] Accepting new Hardware: Disable
2021-06-15 13:43:15.321 Status: Zigate: (Zigate) [ZiGateForwarder_16] Number of devices recently active in Zigate = 26
2021-06-15 13:43:15.322 Status: Zigate: (Zigate) [ZiGateForwarder_16] [00] DevID = 00 Network addr = bfdf IEEE = 00158d000636a25e LQI = 118 Power = 00 Model = lumi.sensor_motion ( PIR Woonkamer )
2021-06-15 13:43:15.322 Status: Zigate: (Zigate) [ZiGateForwarder_16] [01] DevID = 01 Network addr = 557a IEEE = 00158d0003fb0366 LQI = 125 Power = 00 Model = lumi.sensor_motion.aq2 ( Pir voordeur )
2021-06-15 13:43:15.322 Status: Zigate: (Zigate) [ZiGateForwarder_16] [02] DevID = 02 Network addr = 4e7b IEEE = 00158d0004096d67 LQI = 116 Power = 00 Model = lumi.sensor_magnet.aq2 ( Deursensor woonkamer )
2021-06-15 13:43:15.323 Status: Zigate: (Zigate) [ZiGateForwarder_16] [03] DevID = 03 Network addr = 3478 IEEE = 00158d0005225f00 LQI = 118 Power = 00 Model = lumi.sensor_magnet.aq2 ( Deursensor voordeur )
2021-06-15 13:43:15.323 Status: Zigate: (Zigate) [ZiGateForwarder_16] [04] DevID = 04 Network addr = 0721 IEEE = 00158d0006c243b7 LQI = 071 Power = 00 Model = lumi.sensor_wleak.aq1 ( Watersensor Vaatwasser )
2021-06-15 13:43:15.324 Status: Zigate: (Zigate) [ZiGateForwarder_16] [05] DevID = 05 Network addr = caca IEEE = 00158d00045cfdb5 LQI = 093 Power = 00 Model = lumi.sensor_magnet.aq2 ( Deursensor tuin )
2021-06-15 13:43:15.324 Status: Zigate: (Zigate) [ZiGateForwarder_16] [06] DevID = 28 Network addr = 6bc1 IEEE = ec1bbdfffe1b813b LQI = 110 Power = 01 Model = TRADFRI bulb E27 WW clear 250lm ( Woonkamer Eethoek-4 )
2021-06-15 13:43:15.324 Status: Zigate: (Zigate) [ZiGateForwarder_16] [07] DevID = 29 Network addr = dd5f IEEE = 0017880109714b42 LQI = 131 Power = 01 Model = LTG002 ( )
2021-06-15 13:43:15.325 Status: Zigate: (Zigate) [ZiGateForwarder_16] [08] DevID = 2a Network addr = 64c0 IEEE = ec1bbdfffea28399 LQI = 138 Power = 01 Model = TRADFRI bulb E27 WW clear 250lm ( Woonkamer Eethoek-1 )
2021-06-15 13:43:15.325 Status: Zigate: (Zigate) [ZiGateForwarder_16] [09] DevID = 2b Network addr = 6c7c IEEE = ccccccfffef43db1 LQI = 141 Power = 01 Model = TRADFRI bulb E27 WW clear 250lm ( Woonkamer Eethoek-3 )
2021-06-15 13:43:15.326 Status: Zigate: (Zigate) [ZiGateForwarder_16] [10] DevID = 2c Network addr = 6ab5 IEEE = 00158d000444e9e3 LQI = 082 Power = 01 Model = lumi.relay.c2acn01 ( Water schakelaar tuin achter )
2021-06-15 13:43:15.326 Status: Zigate: (Zigate) [ZiGateForwarder_16] [11] DevID = 2d Network addr = aa16 IEEE = 680ae2fffe4a16b8 LQI = 140 Power = 01 Model = TRADFRI bulb E27 WS opal 1000lm ( Woonkamer eethoek achter )
2021-06-15 13:43:15.326 Status: Zigate: (Zigate) [ZiGateForwarder_16] [12] DevID = 2e Network addr = 10e9 IEEE = 0017880109796dad LQI = 117 Power = 01 Model = LTG002 ( )
2021-06-15 13:43:15.327 Status: Zigate: (Zigate) [ZiGateForwarder_16] [13] DevID = 2f Network addr = 8445 IEEE = 00178801097966b1 LQI = 124 Power = 01 not found in ListOfDevices
2021-06-15 13:43:15.327 Status: Zigate: (Zigate) [ZiGateForwarder_16] [14] DevID = 30 Network addr = 9ab3 IEEE = ec1bbdfffe468a93 LQI = 141 Power = 01 Model = TRADFRI bulb GU10 WS 400lm ( Woonkamer salontafel_2 )
2021-06-15 13:43:15.328 Status: Zigate: (Zigate) [ZiGateForwarder_16] [15] DevID = 31 Network addr = f1f1 IEEE = 680ae2fffe413429 LQI = 093 Power = 01 Model = TRADFRI control outlet ( TV boven schakelaar )
2021-06-15 13:43:15.328 Status: Zigate: (Zigate) [ZiGateForwarder_16] [16] DevID = 32 Network addr = 7f15 IEEE = ec1bbdfffe986a27 LQI = 138 Power = 01 Model = TRADFRI bulb GU10 WS 400lm ( Woonkamer salontafel_1 )
2021-06-15 13:43:15.328 Status: Zigate: (Zigate) [ZiGateForwarder_16] [17] DevID = 33 Network addr = 2d3c IEEE = ec1bbdfffeabe177 LQI = 150 Power = 01 Model = TRADFRI bulb E27 WW clear 250lm ( Woonkamer Eethoek-2 )
2021-06-15 13:43:15.329 Status: Zigate: (Zigate) [ZiGateForwarder_16] [18] DevID = 34 Network addr = 5a7a IEEE = 680ae2fffe373006 LQI = 124 Power = 01 Model = TRADFRI bulb GU10 WS 400lm ( Woonkamer salontafel_3 )
2021-06-15 13:43:15.329 Status: Zigate: (Zigate) [ZiGateForwarder_16] [19] DevID = 35 Network addr = 8ca0 IEEE = 680ae2fffe4c5b85 LQI = 141 Power = 01 Model = TRADFRI bulb E27 WS opal 1000lm ( Woonkamer eethoek voor )
2021-06-15 13:43:15.330 Status: Zigate: (Zigate) [ZiGateForwarder_16] [20] DevID = 36 Network addr = 8b16 IEEE = 000d6ffffe485188 LQI = 133 Power = 01 Model = TRADFRI bulb E27 WS opal 980lm ( Woonkamer bankstel )
2021-06-15 13:43:15.330 Status: Zigate: (Zigate) [ZiGateForwarder_16] [21] DevID = 37 Network addr = f295 IEEE = ec1bbdfffeb8ab2a LQI = 099 Power = 01 Model = TRADFRI bulb E27 WW clear 250lm ( Woonkamer achterdeur )
2021-06-15 13:43:15.330 Status: Zigate: (Zigate) [ZiGateForwarder_16] [22] DevID = 38 Network addr = 14e4 IEEE = ec1bbdfffe9a6b26 LQI = 114 Power = 01 Model = TRADFRI bulb E27 WW clear 250lm ( Woonkamer Eethoek-5 )
2021-06-15 13:43:15.331 Status: Zigate: (Zigate) [ZiGateForwarder_16] [23] DevID = 39 Network addr = 8ef3 IEEE = 0017880109037d19 LQI = 113 Power = 01 Model = ( Woonkamer Vloerlamp )
2021-06-15 13:43:15.331 Status: Zigate: (Zigate) [ZiGateForwarder_16] [24] DevID = 3a Network addr = 73ea IEEE = 0017880108a2eb84 LQI = 076 Power = 01 Model = LWA004 ( Voordeur lamp )
2021-06-15 13:43:15.327 Error: Zigate: (Zigate) DeviceExist - Found some inconsistency Inputs: 8445 00178801097966b1 instead of None
2021-06-15 13:43:19.075 Status: Zigate: (Zigate) [ MainThread] Zigate set to Certification : CE
2021-06-15 13:43:19.075 Status: Zigate: (Zigate) [ MainThread] Start Group Management
2021-06-15 13:43:19.096 Status: Zigate: (Zigate) [ MainThread] Available Firmware - ManufCode: 117c ImageType: 0x11c2 FileVersion: 23028631 Size: 179390 Bytes Filename: 159701-2.1-TRADFRI-wireless-dimmer-2.3.028.ota.ota.signed
2021-06-15 13:43:19.110 Status: Zigate: (Zigate) [ MainThread] Available Firmware - ManufCode: 117c ImageType: 0x2203 FileVersion: 23007631 Size: 207870 Bytes Filename: 100355342-2.1-TRADFRI-bulb-ws-gu10-2.3.007.ota.ota.signed
2021-06-15 13:43:19.122 Status: Zigate: (Zigate) [ MainThread] Available Firmware - ManufCode: 117c ImageType: 0x2801 FileVersion: 13009572 Size: 178366 Bytes Filename: 10035515-TRADFRI-bulb-cws-1.3.009.ota.ota.signed
2021-06-15 13:43:19.134 Status: Zigate: (Zigate) [ MainThread] Available Firmware - ManufCode: 117c ImageType: 0x4201 FileVersion: 12217572 Size: 173246 Bytes Filename: 159698-TRADFRI-driver-lp-1.2.217.ota.ota.signed
2021-06-15 13:43:19.146 Status: Zigate: (Zigate) [ MainThread] Available Firmware - ManufCode: 117c ImageType: 0x4202 FileVersion: 12217572 Size: 173246 Bytes Filename: 159697-TRADFRI-driver-hp-1.2.217.ota.ota.signed
2021-06-15 13:43:19.160 Status: Zigate: (Zigate) [ MainThread] Available Firmware - ManufCode: 117c ImageType: 0x4203 FileVersion: 20022623 Size: 208830 Bytes Filename: 191100-4.1-TRADFRI-sy5882-driver-ws-2.0.022.ota.ota.signed
2021-06-15 13:43:19.173 Status: Zigate: (Zigate) [ MainThread] Available Firmware - ManufCode: 117c ImageType: 0x11ca FileVersion: 21024631 Size: 180926 Bytes Filename: 10043101-3.1-TRADFRI-dimmer-2.1.024.ota.ota.signed
2021-06-15 13:43:19.186 Status: Zigate: (Zigate) [ MainThread] Available Firmware - ManufCode: 117c ImageType: 0x11c8 FileVersion: 20022623 Size: 186814 Bytes Filename: 10039874-1.0-TRADFRI-motion-sensor-2-2.0.022.ota.ota.signed
2021-06-15 13:43:19.200 Status: Zigate: (Zigate) [ MainThread] Available Firmware - ManufCode: 117c ImageType: 0x4206 FileVersion: 21022631 Size: 208254 Bytes Filename: 10047227-1.2-TRADFRI-cv-cct-unified-2.1.022.ota.ota.signed
2021-06-15 13:43:19.214 Status: Zigate: (Zigate) [ MainThread] Available Firmware - ManufCode: 117c ImageType: 0x2201 FileVersion: 23007631 Size: 208126 Bytes Filename: 10035514-2.1-TRADFRI-bulb-ws-2.3.007.ota.ota.signed
2021-06-15 13:43:19.226 Status: Zigate: (Zigate) [ MainThread] Available Firmware - ManufCode: 117c ImageType: 0x4101 FileVersion: 12245572 Size: 181118 Bytes Filename: 159495-TRADFRI-transformer-1.2.245.ota.ota.signed
2021-06-15 13:43:19.239 Status: Zigate: (Zigate) [ MainThread] Available Firmware - ManufCode: 117c ImageType: 0x1187 FileVersion: 22009631 Size: 186942 Bytes Filename: 10037585-5.1-TRADFRI-connected-blind-2.2.009.ota.ota.signed
2021-06-15 13:43:19.252 Status: Zigate: (Zigate) [ MainThread] Available Firmware - ManufCode: 117c ImageType: 0x11c1 FileVersion: 23014631 Size: 182590 Bytes Filename: 159699-5.1-TRADFRI-remote-control-2.3.014.ota.ota.signed
2021-06-15 13:43:19.265 Status: Zigate: (Zigate) [ MainThread] Available Firmware - ManufCode: 117c ImageType: 0x1102 FileVersion: 22005631 Size: 189822 Bytes Filename: 10037603-3.1-TRADFRI-signal-repeater-2.2.005.ota.ota.signed
2021-06-15 13:43:19.276 Status: Zigate: (Zigate) [ MainThread] Available Firmware - ManufCode: 117c ImageType: 0x2101 FileVersion: 12214572 Size: 168318 Bytes Filename: 159696-TRADFRI-bulb-w-1000lm-1.2.214.ota.ota.signed
2021-06-15 13:43:19.287 Status: Zigate: (Zigate) [ MainThread] Available Firmware - ManufCode: 117c ImageType: 0x11c4 FileVersion: 12214572 Size: 157822 Bytes Filename: 159700-TRADFRI-motion-sensor-1.2.214.ota.ota.signed
2021-06-15 13:43:19.300 Status: Zigate: (Zigate) [ MainThread] Available Firmware - ManufCode: 117c ImageType: 0x11c5 FileVersion: 22010631 Size: 179838 Bytes Filename: 10005778-10.1-TRADFRI-onoff-shortcut-control-2.2.010.ota.ota.signed
2021-06-15 13:43:19.311 Status: Zigate: (Zigate) [ MainThread] Available Firmware - ManufCode: 117c ImageType: 0x0002 FileVersion: 165801bc Size: 166270 Bytes Filename: 190579-ncp572b444.ebl.ota.ota.signed
2021-06-15 13:43:19.325 Status: Zigate: (Zigate) [ MainThread] Available Firmware - ManufCode: 117c ImageType: 0x4204 FileVersion: 20023623 Size: 209086 Bytes Filename: 10038562-2.1-TRADFRI-sy5882-bulb-ws-2.0.023.ota.ota.signed
2021-06-15 13:43:19.339 Status: Zigate: (Zigate) [ MainThread] Available Firmware - ManufCode: 117c ImageType: 0x1101 FileVersion: 20024623 Size: 202110 Bytes Filename: 10005777-6.1-TRADFRI-control-outlet-2.0.024.ota.ota.signed
2021-06-15 13:43:19.353 Status: Zigate: (Zigate) [ MainThread] Available Firmware - ManufCode: 117c ImageType: 0x4103 FileVersion: 21022631 Size: 202878 Bytes Filename: 10046695-1.1-TRADFRI-light-unified-w-2.1.022.ota.ota.signed
2021-06-15 13:43:19.367 Status: Zigate: (Zigate) [ MainThread] Available Firmware - ManufCode: 117c ImageType: 0x2202 FileVersion: 23007631 Size: 208702 Bytes Filename: 159695-2.1-TRADFRI-bulb-ws-1000lm-2.3.007.ota.ota.signed
2021-06-15 13:43:19.389 Status: Zigate: (Zigate) [ZiGateForwarder_16] TxPower Attenuation : 0 dBm
2021-06-15 13:43:24.844 Status: Zigate: (Zigate) [ MainThread] Available Firmware - ManufCode: 117c ImageType: 0x4205 FileVersion: 21022631 Size: 208254 Bytes Filename: 10040611-3.2-TRADFRI-sy5882-unified-2.1.022.ota.ota.signed
2021-06-15 13:43:24.849 Status: Zigate: (Zigate) [ MainThread] Start Web Server connection
2021-06-15 13:43:24.868 Status: Zigate: (Zigate) [ MainThread] Web backend for Web User Interface started on port: 9440
2021-06-15 13:43:24.868 Status: Zigate: (Zigate) [ MainThread] Plugin with Zigate firmware 031d correctly initialized
2021-06-15 13:43:28.302 Status: Zigate: (Zigate) [ MainThread] There is a newer plugin version available on gitHub
2021-06-15 13:43:28.302 Status: Zigate: (Zigate) [ MainThread] There is a newer Zigate Firmware version available
2021-06-15 13:43:34.783 Status: Notification: Bewatering voor Uitgeschakeld
2021-06-15 13:43:35.954 Notification sent (email) => Success
2021-06-15 13:43:39.582 Dummy: Light/Switch (Bel voordeur PIR)
2021-06-15 13:43:43.985 EventSystem: Event triggered: Buitenzit weer_1
2021-06-15 13:43:43.985 Status: buitenzitweer ingeschakeld
2021-06-15 13:43:44.005 Dummy: Light/Switch (Buitenzit weer)
2021-06-15 13:43:59.715 Dummy: Light/Switch (Bel voordeur PIR)
2021-06-15 13:44:01.778 Status: Notification sent (Email)
2021-06-15 13:44:44.004 EventSystem: Event triggered: Buitenzit weer_1
2021-06-15 13:44:44.021 Dummy: Light/Switch (Buitenzit weer)
2021-06-15 13:44:44.004 Status: buitenzitweer ingeschakeld
2021-06-15 13:45:17.603 Dummy: Light/Switch (Bel voordeur PIR)
2021-06-15 13:45:37.701 Dummy: Light/Switch (Bel voordeur PIR)
2021-06-15 13:45:44.014 EventSystem: Event triggered: Buitenzit weer_1
2021-06-15 13:45:44.060 Dummy: Light/Switch (Buitenzit weer)
2021-06-15 13:45:44.528 Dummy: Light/Switch (Bel voordeur PIR)
2021-06-15 13:45:44.015 Status: buitenzitweer ingeschakeld
2021-06-15 13:45:58.900 Status: Notification: Bewatering voor Uitgeschakeld
2021-06-15 13:45:59.621 Notification sent (email) => Success
2021-06-15 13:45:59.886 Status: Zigate: (Zigate) [ZiGateForwarder_16] Device Annoucement: Voortuin relay NwkId: d4ad Ieee: 00158d000444ee2f MacCap: 8e
2021-06-15 13:46:05.601 Dummy: Light/Switch (Bel voordeur PIR)
2021-06-15 13:46:25.648 Dummy: Light/Switch (Bel voordeur PIR)
2021-06-15 13:46:34.451 Status: Zigate: (Zigate) [ MainThread] onDeviceRemoved - removing End Device
2021-06-15 13:46:34.505 Status: Zigate: (Zigate) Device Zigate - ColorControlRGBWW-0017880109714b42-0b with IEEE: 0017880109714b42 fully removed from the system.
2021-06-15 13:46:34.512 Status: Zigate: (Zigate) [ MainThread] onDeviceRemoved - removing Device Zigate - ColorControlRGBWW-0017880109714b42-0b -> 0017880109714b42 in Zigate
2021-06-15 13:46:34.605 Status: Zigate: (Zigate) [ MainThread] onDeviceRemoved - removing End Device
2021-06-15 13:46:34.639 Status: Zigate: (Zigate) Device Zigate - ColorControlRGBWW-0017880109796dad-0b with IEEE: 0017880109796dad fully removed from the system.
2021-06-15 13:46:34.645 Status: Zigate: (Zigate) [ MainThread] onDeviceRemoved - removing Device Zigate - ColorControlRGBWW-0017880109796dad-0b -> 0017880109796dad in Zigate
2021-06-15 13:46:44.033 EventSystem: Event triggered: Buitenzit weer_1
2021-06-15 13:46:44.070 Dummy: Light/Switch (Buitenzit weer)
2021-06-15 13:46:44.033 Status: buitenzitweer ingeschakeld
2021-06-15 13:46:45.693 Status: Zigate: (Zigate) Plugin Restart command : http://admin:[email protected]:8080/json.htm?type=command¶m=updatehardware&htype=94&idx=16&name=Zigate&address=0.0.0.0&port=9999&serialport=/dev/serial/by-id/usb-Silicon_Labs_ZiGate_0001-if00-port0&Mode1=USB&Mode2=&Mode3=False&Mode4=9440&Mode5=&Mode6=14&extra=Zigate&enabled=true&datatimeout=0
2021-06-15 13:46:57.450 Status: Zigate: (Zigate) [ MainThread] Request Accepting new Hardware for ever
2021-06-15 13:46:57.774 Status: Zigate: (Zigate) [ZiGateForwarder_16] Accepting new Hardware: On
2021-06-15 13:47:02.378 Yeelight Controller: Color Switch (Tuin tafel)
2021-06-15 13:47:44.022 EventSystem: Event triggered: Buitenzit weer_1
2021-06-15 13:47:44.044 Dummy: Light/Switch (Buitenzit weer)
2021-06-15 13:47:44.022 Status: buitenzitweer ingeschakeld
2021-06-15 13:48:15.712 Error: Zigate: (Zigate) DeviceExist - Found some inconsistency Inputs: dd5f 0017880109714b42 instead of None
2021-06-15 13:48:18.473 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: dd5f Active Endpoint Response Ep: 0b LQI: 135
2021-06-15 13:48:18.473 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: dd5f Active Endpoint Response Ep: f2 LQI: 135
2021-06-15 13:48:18.474 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: dd5f Request Simple Descriptor for Ep: 0b
2021-06-15 13:48:18.475 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: dd5f Request Simple Descriptor for Ep: f2
2021-06-15 13:48:19.393 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: dd5f Simple Descriptor Response EP: 0x0b LQI: 138
2021-06-15 13:48:19.393 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: dd5f ProfileID 0104
2021-06-15 13:48:19.393 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: dd5f ZDeviceID 010c
2021-06-15 13:48:19.394 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: dd5f Application Version 0001
2021-06-15 13:48:19.394 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: dd5f Cluster IN Count: 09
2021-06-15 13:48:19.394 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: dd5f Cluster In 1: 0000 (Basic)
2021-06-15 13:48:19.394 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: dd5f Cluster In 2: 0003 (Identify)
2021-06-15 13:48:19.394 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: dd5f Cluster In 3: 0004 (Groups)
2021-06-15 13:48:19.395 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: dd5f Cluster In 4: 0005 (Scenes)
2021-06-15 13:48:19.395 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: dd5f Cluster In 5: 0006 (On/Off)
2021-06-15 13:48:19.395 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: dd5f Cluster In 6: 0008 (Level Control)
2021-06-15 13:48:19.395 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: dd5f Cluster In 7: 1000 (Touchlink)
2021-06-15 13:48:19.395 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: dd5f Cluster In 8: fc02
2021-06-15 13:48:19.395 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: dd5f Cluster In 9: 0300 (Colour Control)
2021-06-15 13:48:19.396 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: dd5f Cluster OUT Count: 01
2021-06-15 13:48:19.396 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: dd5f Cluster Out 1: 0019 (Over-the-Air Upgrade)
2021-06-15 13:48:19.683 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: dd5f Simple Descriptor Response EP: 0xf2 LQI: 135
2021-06-15 13:48:19.683 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: dd5f ProfileID a1e0
2021-06-15 13:48:19.683 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: dd5f ZDeviceID 0061
2021-06-15 13:48:19.683 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: dd5f Application Version 0000
2021-06-15 13:48:19.683 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: dd5f Cluster IN Count: 00
2021-06-15 13:48:19.683 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: dd5f Cluster OUT Count: 01
2021-06-15 13:48:19.684 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: dd5f Cluster Out 1: 0021
2021-06-15 13:48:23.102 Status: Zigate: (Zigate) [0] NEW OBJECT: dd5f Request Node Descriptor
2021-06-15 13:48:23.102 Status: Zigate: (Zigate) [0] NEW OBJECT: dd5f Request Attribute for Cluster 0x0300 to get ColorMode
2021-06-15 13:48:28.094 Status: Zigate: (Zigate) [1] NEW OBJECT: dd5f Request Attribute for Cluster 0x0300 to get ColorMode
2021-06-15 13:48:33.082 Status: Zigate: (Zigate) [2] NEW OBJECT: dd5f Request Attribute for Cluster 0x0300 to get ColorMode
2021-06-15 13:48:44.066 EventSystem: Event triggered: Buitenzit weer_1
2021-06-15 13:48:44.090 Dummy: Light/Switch (Buitenzit weer)
2021-06-15 13:48:44.067 Status: buitenzitweer ingeschakeld
2021-06-15 13:49:02.100 Status: Notification sent (Email)
2021-06-15 13:49:10.661 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 8445 Active Endpoint Response Ep: 0b LQI: 114
2021-06-15 13:49:10.661 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 8445 Active Endpoint Response Ep: f2 LQI: 114
2021-06-15 13:49:10.662 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 8445 Request Simple Descriptor for Ep: 0b
2021-06-15 13:49:10.662 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 8445 Request Simple Descriptor for Ep: f2
2021-06-15 13:49:10.522 Error: Zigate: (Zigate) DeviceExist - Found some inconsistency Inputs: 8445 00178801097966b1 instead of None
2021-06-15 13:49:11.551 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 8445 Simple Descriptor Response EP: 0x0b LQI: 141
2021-06-15 13:49:11.551 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 8445 ProfileID 0104
2021-06-15 13:49:11.551 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 8445 ZDeviceID 010c
2021-06-15 13:49:11.551 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 8445 Application Version 0001
2021-06-15 13:49:11.552 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 8445 Cluster IN Count: 09
2021-06-15 13:49:11.552 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 8445 Cluster In 1: 0000 (Basic)
2021-06-15 13:49:11.552 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 8445 Cluster In 2: 0003 (Identify)
2021-06-15 13:49:11.552 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 8445 Cluster In 3: 0004 (Groups)
2021-06-15 13:49:11.552 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 8445 Cluster In 4: 0005 (Scenes)
2021-06-15 13:49:11.552 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 8445 Cluster In 5: 0006 (On/Off)
2021-06-15 13:49:11.553 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 8445 Cluster In 6: 0008 (Level Control)
2021-06-15 13:49:11.553 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 8445 Cluster In 7: 1000 (Touchlink)
2021-06-15 13:49:11.553 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 8445 Cluster In 8: fc02
2021-06-15 13:49:11.553 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 8445 Cluster In 9: 0300 (Colour Control)
2021-06-15 13:49:11.553 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 8445 Cluster OUT Count: 01
2021-06-15 13:49:11.553 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 8445 Cluster Out 1: 0019 (Over-the-Air Upgrade)
2021-06-15 13:49:11.784 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 8445 Simple Descriptor Response EP: 0xf2 LQI: 141
2021-06-15 13:49:11.785 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 8445 ProfileID a1e0
2021-06-15 13:49:11.785 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 8445 ZDeviceID 0061
2021-06-15 13:49:11.785 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 8445 Application Version 0000
2021-06-15 13:49:11.785 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 8445 Cluster IN Count: 00
2021-06-15 13:49:11.785 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 8445 Cluster OUT Count: 01
2021-06-15 13:49:11.785 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 8445 Cluster Out 1: 0021
2021-06-15 13:49:13.093 Status: Zigate: (Zigate) [0] NEW OBJECT: 8445 Request Node Descriptor
2021-06-15 13:49:13.093 Status: Zigate: (Zigate) [0] NEW OBJECT: 8445 Request Attribute for Cluster 0x0300 to get ColorMode
2021-06-15 13:49:18.058 Status: Zigate: (Zigate) [1] NEW OBJECT: 8445 Request Attribute for Cluster 0x0300 to get ColorMode
2021-06-15 13:49:23.080 Status: Zigate: (Zigate) [2] NEW OBJECT: 8445 Request Attribute for Cluster 0x0300 to get ColorMode
2021-06-15 13:49:44.095 EventSystem: Event triggered: Buitenzit weer_1
2021-06-15 13:49:44.116 Dummy: Light/Switch (Buitenzit weer)
2021-06-15 13:49:44.096 Status: buitenzitweer ingeschakeld
2021-06-15 13:49:44.161 Error: Zigate: (Zigate) DeviceExist - Found some inconsistency Inputs: 10e9 0017880109796dad instead of None
2021-06-15 13:49:46.881 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 10e9 Active Endpoint Response Ep: 0b LQI: 102
2021-06-15 13:49:46.881 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 10e9 Active Endpoint Response Ep: f2 LQI: 102
2021-06-15 13:49:46.884 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 10e9 Request Simple Descriptor for Ep: 0b
2021-06-15 13:49:46.885 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 10e9 Request Simple Descriptor for Ep: f2
2021-06-15 13:49:47.798 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 10e9 Simple Descriptor Response EP: 0x0b LQI: 105
2021-06-15 13:49:47.798 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 10e9 ProfileID 0104
2021-06-15 13:49:47.798 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 10e9 ZDeviceID 010c
2021-06-15 13:49:47.798 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 10e9 Application Version 0001
2021-06-15 13:49:47.798 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 10e9 Cluster IN Count: 09
2021-06-15 13:49:47.798 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 10e9 Cluster In 1: 0000 (Basic)
2021-06-15 13:49:47.799 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 10e9 Cluster In 2: 0003 (Identify)
2021-06-15 13:49:47.799 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 10e9 Cluster In 3: 0004 (Groups)
2021-06-15 13:49:47.799 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 10e9 Cluster In 4: 0005 (Scenes)
2021-06-15 13:49:47.799 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 10e9 Cluster In 5: 0006 (On/Off)
2021-06-15 13:49:47.799 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 10e9 Cluster In 6: 0008 (Level Control)
2021-06-15 13:49:47.800 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 10e9 Cluster In 7: 1000 (Touchlink)
2021-06-15 13:49:47.800 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 10e9 Cluster In 8: fc02
2021-06-15 13:49:47.800 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 10e9 Cluster In 9: 0300 (Colour Control)
2021-06-15 13:49:47.800 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 10e9 Cluster OUT Count: 01
2021-06-15 13:49:47.800 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 10e9 Cluster Out 1: 0019 (Over-the-Air Upgrade)
2021-06-15 13:49:48.083 Status: Zigate: (Zigate) [0] NEW OBJECT: 10e9 Request Node Descriptor
2021-06-15 13:49:48.083 Status: Zigate: (Zigate) [0] NEW OBJECT: 10e9 Request Attribute for Cluster 0x0300 to get ColorMode
2021-06-15 13:49:48.108 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 10e9 Simple Descriptor Response EP: 0xf2 LQI: 102
2021-06-15 13:49:48.108 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 10e9 ProfileID a1e0
2021-06-15 13:49:48.108 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 10e9 ZDeviceID 0061
2021-06-15 13:49:48.109 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 10e9 Application Version 0000
2021-06-15 13:49:48.109 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 10e9 Cluster IN Count: 00
2021-06-15 13:49:48.109 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 10e9 Cluster OUT Count: 01
2021-06-15 13:49:48.109 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 10e9 Cluster Out 1: 0021
2021-06-15 13:49:53.061 Status: Zigate: (Zigate) [1] NEW OBJECT: 10e9 Request Attribute for Cluster 0x0300 to get ColorMode
2021-06-15 13:49:58.105 Status: Zigate: (Zigate) [2] NEW OBJECT: 10e9 Request Attribute for Cluster 0x0300 to get ColorMode
2021-06-15 13:50:00.184 Status: dzVents: Info: EnergyCost: ------ Start internal script: Energieverbruik Jacuzzi:, trigger: "every 10 minutes"
2021-06-15 13:50:00.203 Status: dzVents: Debug: EnergyCost: Processing device-adapter for Jacuzzi verbruik: kWh device adapter
2021-06-15 13:50:00.205 Status: dzVents: Debug: EnergyCost: Processing device-adapter for Stroomkosten Jacuzzi: Custom sensor device adapter
2021-06-15 13:50:00.205 Status: dzVents: Debug: EnergyCost: Stroomkosten Jacuzzi ==>> previous value: 1.02 ; new value 1.03
2021-06-15 13:50:00.205 Status: dzVents: Info: EnergyCost: ------ Finished Energieverbruik Jacuzzi
2021-06-15 13:50:00.206 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2021-06-15 13:50:02.905 Status: Notification sent (Email) Code: Select all
2021-06-15 15:26:02.585 Status: Notification sent (Email)
2021-06-15 15:26:28.653 Error: Zigate: (Zigate) DeviceExist - Found some inconsistency Inputs: 8445 00178801097966b1 instead of None
2021-06-15 15:26:31.738 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 8445 Active Endpoint Response Ep: 0b LQI: 117
2021-06-15 15:26:31.738 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 8445 Active Endpoint Response Ep: f2 LQI: 117
2021-06-15 15:26:31.741 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 8445 Request Simple Descriptor for Ep: 0b
2021-06-15 15:26:31.742 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 8445 Request Simple Descriptor for Ep: f2
2021-06-15 15:26:32.647 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 8445 Simple Descriptor Response EP: 0x0b LQI: 114
2021-06-15 15:26:32.647 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 8445 ProfileID 0104
2021-06-15 15:26:32.647 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 8445 ZDeviceID 010c
2021-06-15 15:26:32.648 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 8445 Application Version 0001
2021-06-15 15:26:32.648 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 8445 Cluster IN Count: 09
2021-06-15 15:26:32.648 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 8445 Cluster In 1: 0000 (Basic)
2021-06-15 15:26:32.648 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 8445 Cluster In 2: 0003 (Identify)
2021-06-15 15:26:32.648 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 8445 Cluster In 3: 0004 (Groups)
2021-06-15 15:26:32.648 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 8445 Cluster In 4: 0005 (Scenes)
2021-06-15 15:26:32.648 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 8445 Cluster In 5: 0006 (On/Off)
2021-06-15 15:26:32.648 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 8445 Cluster In 6: 0008 (Level Control)
2021-06-15 15:26:32.648 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 8445 Cluster In 7: 1000 (Touchlink)
2021-06-15 15:26:32.648 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 8445 Cluster In 8: fc02
2021-06-15 15:26:32.648 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 8445 Cluster In 9: 0300 (Colour Control)
2021-06-15 15:26:32.649 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 8445 Cluster OUT Count: 01
2021-06-15 15:26:32.649 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 8445 Cluster Out 1: 0019 (Over-the-Air Upgrade)
2021-06-15 15:26:32.949 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 8445 Simple Descriptor Response EP: 0xf2 LQI: 117
2021-06-15 15:26:32.949 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 8445 ProfileID a1e0
2021-06-15 15:26:32.950 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 8445 ZDeviceID 0061
2021-06-15 15:26:32.950 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 8445 Application Version 0000
2021-06-15 15:26:32.950 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 8445 Cluster IN Count: 00
2021-06-15 15:26:32.950 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 8445 Cluster OUT Count: 01
2021-06-15 15:26:32.950 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 8445 Cluster Out 1: 0021
2021-06-15 15:26:37.083 Status: Zigate: (Zigate) [0] NEW OBJECT: 8445 Request Node Descriptor
2021-06-15 15:26:37.084 Status: Zigate: (Zigate) [0] NEW OBJECT: 8445 Request Attribute for Cluster 0x0300 to get ColorMode
2021-06-15 15:26:42.094 Status: Zigate: (Zigate) [1] NEW OBJECT: 8445 Request Attribute for Cluster 0x0300 to get ColorMode
2021-06-15 15:26:44.661 Status: buitenzitweer ingeschakeld
2021-06-15 15:26:47.079 Status: Zigate: (Zigate) [2] NEW OBJECT: 8445 Request Attribute for Cluster 0x0300 to get ColorMode
2021-06-15 15:26:51.739 Error: Zigate: (Zigate) DeviceExist - Found some inconsistency Inputs: dd5f 0017880109714b42 instead of None
2021-06-15 15:27:02.057 Status: Zigate: (Zigate) [0] NEW OBJECT: dd5f TimeOut in 0045 restarting at 0x004d
2021-06-15 15:27:02.482 Status: Notification sent (Email)
2021-06-15 15:27:08.716 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: dd5f Active Endpoint Response Ep: 0b LQI: 111
2021-06-15 15:27:08.716 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: dd5f Active Endpoint Response Ep: f2 LQI: 111
2021-06-15 15:27:08.719 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: dd5f Request Simple Descriptor for Ep: 0b
2021-06-15 15:27:08.720 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: dd5f Request Simple Descriptor for Ep: f2
2021-06-15 15:27:09.899 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: dd5f Simple Descriptor Response EP: 0x0b LQI: 111
2021-06-15 15:27:09.899 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: dd5f ProfileID 0104
2021-06-15 15:27:09.899 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: dd5f ZDeviceID 010c
2021-06-15 15:27:09.899 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: dd5f Application Version 0001
2021-06-15 15:27:09.900 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: dd5f Cluster IN Count: 09
2021-06-15 15:27:09.900 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: dd5f Cluster In 1: 0000 (Basic)
2021-06-15 15:27:09.900 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: dd5f Cluster In 2: 0003 (Identify)
2021-06-15 15:27:09.900 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: dd5f Cluster In 3: 0004 (Groups)
2021-06-15 15:27:09.900 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: dd5f Cluster In 4: 0005 (Scenes)
2021-06-15 15:27:09.900 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: dd5f Cluster In 5: 0006 (On/Off)
2021-06-15 15:27:09.901 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: dd5f Cluster In 6: 0008 (Level Control)
2021-06-15 15:27:09.901 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: dd5f Cluster In 7: 1000 (Touchlink)
2021-06-15 15:27:09.901 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: dd5f Cluster In 8: fc02
2021-06-15 15:27:09.901 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: dd5f Cluster In 9: 0300 (Colour Control)
2021-06-15 15:27:09.901 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: dd5f Cluster OUT Count: 01
2021-06-15 15:27:09.901 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: dd5f Cluster Out 1: 0019 (Over-the-Air Upgrade)
2021-06-15 15:27:10.198 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: dd5f Simple Descriptor Response EP: 0xf2 LQI: 114
2021-06-15 15:27:10.198 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: dd5f ProfileID a1e0
2021-06-15 15:27:10.198 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: dd5f ZDeviceID 0061
2021-06-15 15:27:10.198 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: dd5f Application Version 0000
2021-06-15 15:27:10.198 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: dd5f Cluster IN Count: 00
2021-06-15 15:27:10.198 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: dd5f Cluster OUT Count: 01
2021-06-15 15:27:10.199 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: dd5f Cluster Out 1: 0021
2021-06-15 15:27:12.074 Status: Zigate: (Zigate) [1] NEW OBJECT: dd5f Request Node Descriptor
2021-06-15 15:27:12.074 Status: Zigate: (Zigate) [1] NEW OBJECT: dd5f Request Attribute for Cluster 0x0300 to get ColorMode
2021-06-15 15:27:17.074 Status: Zigate: (Zigate) [2] NEW OBJECT: dd5f Request Attribute for Cluster 0x0300 to get ColorMode
2021-06-15 15:27:20.338 Error: Zigate: (Zigate) DeviceExist - Found some inconsistency Inputs: 10e9 0017880109796dad instead of None
2021-06-15 15:27:32.103 Status: Zigate: (Zigate) [0] NEW OBJECT: 10e9 TimeOut in 0045 restarting at 0x004d
2021-06-15 15:27:37.878 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 10e9 Active Endpoint Response Ep: 0b LQI: 123
2021-06-15 15:27:37.878 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 10e9 Active Endpoint Response Ep: f2 LQI: 123
2021-06-15 15:27:37.879 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 10e9 Request Simple Descriptor for Ep: 0b
2021-06-15 15:27:37.880 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 10e9 Request Simple Descriptor for Ep: f2
2021-06-15 15:27:39.092 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 10e9 Simple Descriptor Response EP: 0x0b LQI: 123
2021-06-15 15:27:39.092 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 10e9 ProfileID 0104
2021-06-15 15:27:39.092 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 10e9 ZDeviceID 010c
2021-06-15 15:27:39.092 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 10e9 Application Version 0001
2021-06-15 15:27:39.093 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 10e9 Cluster IN Count: 09
2021-06-15 15:27:39.093 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 10e9 Cluster In 1: 0000 (Basic)
2021-06-15 15:27:39.093 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 10e9 Cluster In 2: 0003 (Identify)
2021-06-15 15:27:39.093 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 10e9 Cluster In 3: 0004 (Groups)
2021-06-15 15:27:39.093 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 10e9 Cluster In 4: 0005 (Scenes)
2021-06-15 15:27:39.093 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 10e9 Cluster In 5: 0006 (On/Off)
2021-06-15 15:27:39.093 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 10e9 Cluster In 6: 0008 (Level Control)
2021-06-15 15:27:39.093 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 10e9 Cluster In 7: 1000 (Touchlink)
2021-06-15 15:27:39.093 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 10e9 Cluster In 8: fc02
2021-06-15 15:27:39.093 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 10e9 Cluster In 9: 0300 (Colour Control)
2021-06-15 15:27:39.093 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 10e9 Cluster OUT Count: 01
2021-06-15 15:27:39.093 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 10e9 Cluster Out 1: 0019 (Over-the-Air Upgrade)
2021-06-15 15:27:39.390 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 10e9 Simple Descriptor Response EP: 0xf2 LQI: 123
2021-06-15 15:27:39.391 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 10e9 ProfileID a1e0
2021-06-15 15:27:39.391 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 10e9 ZDeviceID 0061
2021-06-15 15:27:39.391 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 10e9 Application Version 0000
2021-06-15 15:27:39.391 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 10e9 Cluster IN Count: 00
2021-06-15 15:27:39.391 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 10e9 Cluster OUT Count: 01
2021-06-15 15:27:39.391 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 10e9 Cluster Out 1: 0021
2021-06-15 15:27:42.100 Status: Zigate: (Zigate) [1] NEW OBJECT: 10e9 Request Node Descriptor
2021-06-15 15:27:42.101 Status: Zigate: (Zigate) [1] NEW OBJECT: 10e9 Request Attribute for Cluster 0x0300 to get ColorMode
2021-06-15 15:27:47.080 Status: Zigate: (Zigate) [2] NEW OBJECT: 10e9 Request Attribute for Cluster 0x0300 to get ColorMode
2021-06-15 15:27:47.791 Status: buitenzitweer ingeschakeld
2021-06-15 15:27:48.339 Zigate: (Zigate) [ZiGateForwarder_16] Decode8030 - Bind response, Device: 10e9 Status: 00 MsgSequenceNumber: 0x66/102 i_sqn: 153
2021-06-15 15:27:48.339 Zigate: (Zigate) [ZiGateForwarder_16] Decode8030 - Set bind request to binded : nwkid 10e9 ep: 0b cluster: 0300
2021-06-15 15:27:48.342 Zigate: (Zigate) [ZiGateForwarder_16] ZigateRead - MsgType: 8011, MsgLength: 0008, MsgCRC: b9, Data: 0010e9000021f8, LQI: 0
2021-06-15 15:27:48.620 Zigate: (Zigate) [ZiGateForwarder_16] ZigateRead - MsgType: 8000, MsgLength: 0007, MsgCRC: 2b, Data: 0067003002f9, LQI: 0
2021-06-15 15:27:48.642 Zigate: (Zigate) [ZiGateForwarder_16] ZigateRead - MsgType: 8030, MsgLength: 0006, MsgCRC: 54, Data: 67000210e9, LQI: 126
2021-06-15 15:27:48.642 Zigate: (Zigate) [ZiGateForwarder_16] Decode8030 - Msgdata: 67000210e9, MsgLen: 10
2021-06-15 15:27:48.642 Zigate: (Zigate) [ZiGateForwarder_16] Decode8030 - Bind reponse for 10e9
2021-06-15 15:27:48.642 Zigate: (Zigate) [ZiGateForwarder_16] Decode8030 - Bind response, Device: 10e9 Status: 00 MsgSequenceNumber: 0x67/103 i_sqn: 154
2021-06-15 15:27:48.642 Zigate: (Zigate) [ZiGateForwarder_16] Decode8030 - Set bind request to binded : nwkid 10e9 ep: 0b cluster: 0000
2021-06-15 15:27:48.647 Zigate: (Zigate) [ZiGateForwarder_16] ZigateRead - MsgType: 8011, MsgLength: 0008, MsgCRC: b8, Data: 0010e9000021f9, LQI: 0
2021-06-15 15:27:48.924 Zigate: (Zigate) [ZiGateForwarder_16] ZigateRead - MsgType: 8000, MsgLength: 0007, MsgCRC: 3a, Data: 0067012001fa, LQI: 0
2021-06-15 15:27:48.941 Zigate: (Zigate) [ZiGateForwarder_16] ZigateRead - MsgType: 8120, MsgLength: 0008, MsgCRC: 44, Data: 6710e90b000600, LQI: 126
2021-06-15 15:27:48.942 Zigate: (Zigate) [ZiGateForwarder_16] Decode8120 - Configure reporting response : 6710e90b000600
2021-06-15 15:27:48.943 Zigate: (Zigate) [ZiGateForwarder_16] --> SQN: [67], SrcAddr: 10e9, SrcEP: 0b, ClusterID: 0006, Attribute: None Status: 00
2021-06-15 15:27:48.944 Zigate: (Zigate) [ZiGateForwarder_16] ------- - i_sqn: 155 e_sqn: 67
2021-06-15 15:27:48.944 Zigate: (Zigate) [ZiGateForwarder_16] ------- - Sqn matches for Attribute: 0000
2021-06-15 15:27:48.948 Zigate: (Zigate) [ZiGateForwarder_16] ZigateRead - MsgType: 8011, MsgLength: 0008, MsgCRC: 9d, Data: 0010e9010006fa, LQI: 0
2021-06-15 15:27:49.226 Zigate: (Zigate) [ZiGateForwarder_16] ZigateRead - MsgType: 8000, MsgLength: 0007, MsgCRC: 34, Data: 0068012001fb, LQI: 0
2021-06-15 15:27:49.240 Zigate: (Zigate) [ZiGateForwarder_16] ZigateRead - MsgType: 8120, MsgLength: 0008, MsgCRC: 45, Data: 6810e90b000800, LQI: 126
2021-06-15 15:27:49.240 Zigate: (Zigate) [ZiGateForwarder_16] Decode8120 - Configure reporting response : 6810e90b000800
2021-06-15 15:27:49.242 Zigate: (Zigate) [ZiGateForwarder_16] --> SQN: [68], SrcAddr: 10e9, SrcEP: 0b, ClusterID: 0008, Attribute: None Status: 00
2021-06-15 15:27:49.242 Zigate: (Zigate) [ZiGateForwarder_16] ------- - i_sqn: 156 e_sqn: 68
2021-06-15 15:27:49.243 Zigate: (Zigate) [ZiGateForwarder_16] ------- - Sqn matches for Attribute: 0000
2021-06-15 15:27:49.248 Zigate: (Zigate) [ZiGateForwarder_16] ZigateRead - MsgType: 8011, MsgLength: 0008, MsgCRC: 92, Data: 0010e9010008fb, LQI: 0
2021-06-15 15:27:49.528 Zigate: (Zigate) [ZiGateForwarder_16] ZigateRead - MsgType: 8000, MsgLength: 0007, MsgCRC: 32, Data: 0069012001fc, LQI: 0
2021-06-15 15:27:49.546 Zigate: (Zigate) [ZiGateForwarder_16] ZigateRead - MsgType: 8120, MsgLength: 000a, MsgCRC: cc, Data: 6910e90b030000088c, LQI: 123
2021-06-15 15:27:49.546 Zigate: (Zigate) [ZiGateForwarder_16] Decode8120 - Configure reporting response : 6910e90b030000088c
2021-06-15 15:27:49.548 Zigate: (Zigate) [ZiGateForwarder_16] --> SQN: [69], SrcAddr: 10e9, SrcEP: 0b, ClusterID: 0300, Attribute: 0008 Status: 8c
2021-06-15 15:27:49.549 Zigate: (Zigate) [ZiGateForwarder_16] Decode8120 - Configure Reporting response - ClusterID: 0300/0008, MsgSrcAddr: 10e9, MsgSrcEp:0b , Status: 8c
2021-06-15 15:27:49.552 Zigate: (Zigate) [ZiGateForwarder_16] ZigateRead - MsgType: 8011, MsgLength: 0008, MsgCRC: 9e, Data: 0010e9010300fc, LQI: 0
2021-06-15 15:27:49.828 Zigate: (Zigate) [ZiGateForwarder_16] ZigateRead - MsgType: 8000, MsgLength: 0007, MsgCRC: 10, Data: 006a010001fd, LQI: 0
2021-06-15 15:27:49.841 Zigate: (Zigate) [ZiGateForwarder_16] ZigateRead - MsgType: 8100, MsgLength: 000e, MsgCRC: 7f, Data: 6a10e90b000600000010000101, LQI: 126
2021-06-15 15:27:49.842 Zigate: (Zigate) [ZiGateForwarder_16] Decode8100 - idx: 26 Read Attribute Response: [10e9:0b] ClusterID: 0006 MsgSQN: 6a, i_sqn: 158, AttributeID: 0000 Status: 00 Type: 10 Size: 0001 ClusterData: >01<
2021-06-15 15:27:49.844 Zigate: (Zigate) [ZiGateForwarder_16] ReadCluster - 0006 - 10e9/0b AttrId: 0000 AttrType: 10 Attsize: 0001 Status: 00 AttrValue: 01
2021-06-15 15:27:49.845 Zigate: (Zigate) [ZiGateForwarder_16] ReadCluster - ClusterId=0006 - reception General: On/Off: 01
2021-06-15 15:27:49.848 Zigate: (Zigate) [ZiGateForwarder_16] ZigateRead - MsgType: 8011, MsgLength: 0008, MsgCRC: 9a, Data: 0010e9010006fd, LQI: 0
2021-06-15 15:27:50.129 Zigate: (Zigate) [ZiGateForwarder_16] ZigateRead - MsgType: 8000, MsgLength: 0007, MsgCRC: 12, Data: 006b010001fe, LQI: 0
2021-06-15 15:27:50.149 Zigate: (Zigate) [ZiGateForwarder_16] ZigateRead - MsgType: 8100, MsgLength: 000f, MsgCRC: 08, Data: 6b10e90b00064001002100020000, LQI: 123
2021-06-15 15:27:50.149 Zigate: (Zigate) [ZiGateForwarder_16] Decode8100 - idx: 28 Read Attribute Response: [10e9:0b] ClusterID: 0006 MsgSQN: 6b, i_sqn: 159, AttributeID: 4001 Status: 00 Type: 21 Size: 0002 ClusterData: >0000<
2021-06-15 15:27:50.151 Zigate: (Zigate) [ZiGateForwarder_16] ReadCluster - 0006 - 10e9/0b AttrId: 4001 AttrType: 21 Attsize: 0002 Status: 00 AttrValue: 0000
2021-06-15 15:27:50.152 Zigate: (Zigate) [ZiGateForwarder_16] ReadCluster - ClusterId=0006 - On Time Attr: 4001 Value: 0000
2021-06-15 15:27:50.155 Zigate: (Zigate) [ZiGateForwarder_16] ZigateRead - MsgType: 8011, MsgLength: 0008, MsgCRC: 99, Data: 0010e9010006fe, LQI: 0
2021-06-15 15:27:50.432 Zigate: (Zigate) [ZiGateForwarder_16] ZigateRead - MsgType: 8000, MsgLength: 0007, MsgCRC: 14, Data: 006c010001ff, LQI: 0
2021-06-15 15:27:50.444 Zigate: (Zigate) [ZiGateForwarder_16] ZigateRead - MsgType: 8100, MsgLength: 000f, MsgCRC: 0c, Data: 6c10e90b00064002002100020000, LQI: 123
2021-06-15 15:27:50.444 Zigate: (Zigate) [ZiGateForwarder_16] Decode8100 - idx: 28 Read Attribute Response: [10e9:0b] ClusterID: 0006 MsgSQN: 6c, i_sqn: 160, AttributeID: 4002 Status: 00 Type: 21 Size: 0002 ClusterData: >0000<
2021-06-15 15:27:50.446 Zigate: (Zigate) [ZiGateForwarder_16] ReadCluster - 0006 - 10e9/0b AttrId: 4002 AttrType: 21 Attsize: 0002 Status: 00 AttrValue: 0000
2021-06-15 15:27:50.447 Zigate: (Zigate) [ZiGateForwarder_16] ReadCluster - ClusterId=0006 - Off Wait Time Attr: 4002 Value: 0000
2021-06-15 15:27:50.450 Zigate: (Zigate) [ZiGateForwarder_16] ZigateRead - MsgType: 8011, MsgLength: 0008, MsgCRC: 98, Data: 0010e9010006ff, LQI: 0
2021-06-15 15:27:50.734 Zigate: (Zigate) [ZiGateForwarder_16] ZigateRead - MsgType: 8000, MsgLength: 0007, MsgCRC: ea, Data: 006d01000100, LQI: 0
2021-06-15 15:27:50.751 Zigate: (Zigate) [ZiGateForwarder_16] ZigateRead - MsgType: 8100, MsgLength: 000e, MsgCRC: bc, Data: 6d10e90b0008000000200001fe, LQI: 123
2021-06-15 15:27:50.752 Zigate: (Zigate) [ZiGateForwarder_16] Decode8100 - idx: 26 Read Attribute Response: [10e9:0b] ClusterID: 0008 MsgSQN: 6d, i_sqn: 161, AttributeID: 0000 Status: 00 Type: 20 Size: 0001 ClusterData: >fe<
2021-06-15 15:27:50.754 Zigate: (Zigate) [ZiGateForwarder_16] ReadCluster - 0008 - 10e9/0b AttrId: 0000 AttrType: 20 Attsize: 0001 Status: 00 AttrValue: fe
2021-06-15 15:27:50.754 Zigate: (Zigate) [ZiGateForwarder_16] ReadCluster - ClusterID: 0008 Addr: 10e9 MsgAttrID: 0000 MsgAttType: 20 MsgAttSize: 0001 MsgClusterData: fe
2021-06-15 15:27:50.754 Zigate: (Zigate) [ZiGateForwarder_16] ReadCluster - ClusterId=0008 - 10e9/0b Level Control: fe
2021-06-15 15:27:50.755 Zigate: (Zigate) UpdateDevice - (Zigate - ColorControlRGBWW-0017880109796dad-0b) 1:100
2021-06-15 15:27:50.777 Zigate: (Zigate) [ZiGateForwarder_16] ZigateRead - MsgType: 8011, MsgLength: 0008, MsgCRC: 69, Data: 0010e901000800, LQI: 0
2021-06-15 15:27:51.037 Zigate: (Zigate) [ZiGateForwarder_16] ZigateRead - MsgType: 8000, MsgLength: 0007, MsgCRC: e8, Data: 006e01000101, LQI: 0
2021-06-15 15:27:51.048 Zigate: (Zigate) [ZiGateForwarder_16] ZigateRead - MsgType: 8100, MsgLength: 000d, MsgCRC: 11, Data: 6e10e90b0300000086ff0000, LQI: 123
2021-06-15 15:27:51.049 Zigate: (Zigate) [ZiGateForwarder_16] Decode8100 - idx: 18 Read Attribute Response: [10e9:0b] status: 86 -> ff0000
2021-06-15 15:27:51.049 Zigate: (Zigate) [ZiGateForwarder_16] Decode8100 - idx: 24 Read Attribute Response: [10e9:0b] ClusterID: 0300 MsgSQN: 6e, i_sqn: 162, AttributeID: 0000 Status: 86 Type: Size: ClusterData: ><
2021-06-15 15:27:51.051 Zigate: (Zigate) [ZiGateForwarder_16] ReadCluster - 0300 - 10e9/0b AttrId: 0000 AttrType: Attsize: Status: 86 AttrValue:
2021-06-15 15:27:51.051 Zigate: (Zigate) [ZiGateForwarder_16] ReadCluster - Status 86 for addr: 10e9/0b on cluster/attribute 0300/0000
2021-06-15 15:27:51.056 Zigate: (Zigate) [ZiGateForwarder_16] ZigateRead - MsgType: 8011, MsgLength: 0008, MsgCRC: 63, Data: 0010e901030001, LQI: 0
2021-06-15 15:27:51.339 Zigate: (Zigate) [ZiGateForwarder_16] ZigateRead - MsgType: 8000, MsgLength: 0007, MsgCRC: ea, Data: 006f01000102, LQI: 0
2021-06-15 15:27:51.351 Zigate: (Zigate) [ZiGateForwarder_16] ZigateRead - MsgType: 8100, MsgLength: 000d, MsgCRC: 11, Data: 6f10e90b0300000186ff0000, LQI: 123
2021-06-15 15:27:51.352 Zigate: (Zigate) [ZiGateForwarder_16] Decode8100 - idx: 18 Read Attribute Response: [10e9:0b] status: 86 -> ff0000
2021-06-15 15:27:51.352 Zigate: (Zigate) [ZiGateForwarder_16] Decode8100 - idx: 24 Read Attribute Response: [10e9:0b] ClusterID: 0300 MsgSQN: 6f, i_sqn: 163, AttributeID: 0001 Status: 86 Type: Size: ClusterData: ><
2021-06-15 15:27:51.354 Zigate: (Zigate) [ZiGateForwarder_16] ReadCluster - 0300 - 10e9/0b AttrId: 0001 AttrType: Attsize: Status: 86 AttrValue:
2021-06-15 15:27:51.354 Zigate: (Zigate) [ZiGateForwarder_16] ReadCluster - Status 86 for addr: 10e9/0b on cluster/attribute 0300/0001
2021-06-15 15:27:51.357 Zigate: (Zigate) [ZiGateForwarder_16] ZigateRead - MsgType: 8011, MsgLength: 0008, MsgCRC: 60, Data: 0010e901030002, LQI: 0
2021-06-15 15:27:51.639 Zigate: (Zigate) [ZiGateForwarder_16] ZigateRead - MsgType: 8000, MsgLength: 0007, MsgCRC: f4, Data: 007001000103, LQI: 0
2021-06-15 15:27:51.656 Zigate: (Zigate) [ZiGateForwarder_16] ZigateRead - MsgType: 8100, MsgLength: 000f, MsgCRC: 35, Data: 7010e90b03000003002100027514, LQI: 123
2021-06-15 15:27:51.657 Zigate: (Zigate) [ZiGateForwarder_16] Decode8100 - idx: 28 Read Attribute Response: [10e9:0b] ClusterID: 0300 MsgSQN: 70, i_sqn: 164, AttributeID: 0003 Status: 00 Type: 21 Size: 0002 ClusterData: >7514<
2021-06-15 15:27:51.659 Zigate: (Zigate) [ZiGateForwarder_16] ReadCluster - 0300 - 10e9/0b AttrId: 0003 AttrType: 21 Attsize: 0002 Status: 00 AttrValue: 7514
2021-06-15 15:27:51.659 Zigate: (Zigate) [ZiGateForwarder_16] ReadCluster0300 - CurrentX: 29972
2021-06-15 15:27:51.662 Zigate: (Zigate) [ZiGateForwarder_16] ZigateRead - MsgType: 8011, MsgLength: 0008, MsgCRC: 61, Data: 0010e901030003, LQI: 0
2021-06-15 15:27:51.942 Zigate: (Zigate) [ZiGateForwarder_16] ZigateRead - MsgType: 8000, MsgLength: 0007, MsgCRC: f2, Data: 007101000104, LQI: 0
2021-06-15 15:27:51.971 Zigate: (Zigate) [ZiGateForwarder_16] ZigateRead - MsgType: 8100, MsgLength: 000f, MsgCRC: cd, Data: 7110e90b030000040021000268f7, LQI: 123
2021-06-15 15:27:51.972 Zigate: (Zigate) [ZiGateForwarder_16] Decode8100 - idx: 28 Read Attribute Response: [10e9:0b] ClusterID: 0300 MsgSQN: 71, i_sqn: 165, AttributeID: 0004 Status: 00 Type: 21 Size: 0002 ClusterData: >68f7<
2021-06-15 15:27:51.974 Zigate: (Zigate) [ZiGateForwarder_16] ReadCluster - 0300 - 10e9/0b AttrId: 0004 AttrType: 21 Attsize: 0002 Status: 00 AttrValue: 68f7
2021-06-15 15:27:51.975 Zigate: (Zigate) [ZiGateForwarder_16] ReadCluster0300 - CurrentY: 26871
2021-06-15 15:27:51.977 Zigate: (Zigate) [ZiGateForwarder_16] ZigateRead - MsgType: 8011, MsgLength: 0008, MsgCRC: 66, Data: 0010e901030004, LQI: 0
2021-06-15 15:27:52.244 Zigate: (Zigate) [ZiGateForwarder_16] ZigateRead - MsgType: 8000, MsgLength: 0007, MsgCRC: f0, Data: 007201000105, LQI: 0
2021-06-15 15:27:52.256 Zigate: (Zigate) [ZiGateForwarder_16] ZigateRead - MsgType: 8100, MsgLength: 000f, MsgCRC: 3d, Data: 7210e90b0300000700210002016e, LQI: 123
2021-06-15 15:27:52.257 Zigate: (Zigate) [ZiGateForwarder_16] Decode8100 - idx: 28 Read Attribute Response: [10e9:0b] ClusterID: 0300 MsgSQN: 72, i_sqn: 166, AttributeID: 0007 Status: 00 Type: 21 Size: 0002 ClusterData: >016e<
2021-06-15 15:27:52.259 Zigate: (Zigate) [ZiGateForwarder_16] ReadCluster - 0300 - 10e9/0b AttrId: 0007 AttrType: 21 Attsize: 0002 Status: 00 AttrValue: 016e
2021-06-15 15:27:52.259 Zigate: (Zigate) [ZiGateForwarder_16] ReadCluster0300 - ColorTemperatureMireds: 366
2021-06-15 15:27:52.262 Zigate: (Zigate) [ZiGateForwarder_16] ZigateRead - MsgType: 8011, MsgLength: 0008, MsgCRC: 67, Data: 0010e901030005, LQI: 0
2021-06-15 15:27:52.545 Zigate: (Zigate) [ZiGateForwarder_16] ZigateRead - MsgType: 8000, MsgLength: 0007, MsgCRC: f2, Data: 007301000106, LQI: 0
2021-06-15 15:27:52.581 Zigate: (Zigate) [ZiGateForwarder_16] ZigateRead - MsgType: 8100, MsgLength: 000e, MsgCRC: 4d, Data: 7310e90b030000080030000102, LQI: 123
2021-06-15 15:27:52.582 Zigate: (Zigate) [ZiGateForwarder_16] Decode8100 - idx: 26 Read Attribute Response: [10e9:0b] ClusterID: 0300 MsgSQN: 73, i_sqn: 167, AttributeID: 0008 Status: 00 Type: 30 Size: 0001 ClusterData: >02<
2021-06-15 15:27:52.585 Zigate: (Zigate) [ZiGateForwarder_16] ReadCluster - 0300 - 10e9/0b AttrId: 0008 AttrType: 30 Attsize: 0001 Status: 00 AttrValue: 02
2021-06-15 15:27:52.586 Zigate: (Zigate) [ZiGateForwarder_16] readCluster - 0300 - 10e9/0b Color Mode: 0008 30 0001 02
2021-06-15 15:27:52.587 Zigate: (Zigate) [ZiGateForwarder_16] ZigateRead - MsgType: 8011, MsgLength: 0008, MsgCRC: 50, Data: 0010e901030006, LQI: 52
2021-06-15 15:27:52.848 Zigate: (Zigate) [ZiGateForwarder_16] ZigateRead - MsgType: 8000, MsgLength: 0007, MsgCRC: f4, Data: 007401000107, LQI: 0
2021-06-15 15:27:52.866 Zigate: (Zigate) [ZiGateForwarder_16] ZigateRead - MsgType: 8100, MsgLength: 000f, MsgCRC: 6c, Data: 7410e90b0300401000210002016e, LQI: 123
2021-06-15 15:27:52.867 Zigate: (Zigate) [ZiGateForwarder_16] Decode8100 - idx: 28 Read Attribute Response: [10e9:0b] ClusterID: 0300 MsgSQN: 74, i_sqn: 168, AttributeID: 4010 Status: 00 Type: 21 Size: 0002 ClusterData: >016e<
2021-06-15 15:27:52.868 Zigate: (Zigate) [ZiGateForwarder_16] ReadCluster - 0300 - 10e9/0b AttrId: 4010 AttrType: 21 Attsize: 0002 Status: 00 AttrValue: 016e
2021-06-15 15:27:52.869 Zigate: (Zigate) [ZiGateForwarder_16] readCluster - 0300 - 10e9/0b Attribute: 4010 21 0002 016e
2021-06-15 15:27:52.872 Zigate: (Zigate) [ZiGateForwarder_16] ZigateRead - MsgType: 8011, MsgLength: 0008, MsgCRC: 65, Data: 0010e901030007, LQI: 0
2021-06-15 15:27:54.079 Zigate: (Zigate) [ZiGateForwarder_16] ReadCluster - 0000 - 10e9/0b AttrId: 0001 AttrType: 20 Attsize: 0001 Status: 00 AttrValue: 02
2021-06-15 15:27:54.080 Zigate: (Zigate) [ZiGateForwarder_16] ReadCluster - Application version: 2
2021-06-15 15:27:54.086 Zigate: (Zigate) [ZiGateForwarder_16] ZigateRead - MsgType: 8011, MsgLength: 0008, MsgCRC: 6a, Data: 0010e90100000b, LQI: 0
2021-06-15 15:27:54.358 Zigate: (Zigate) [ZiGateForwarder_16] ZigateRead - MsgType: 8000, MsgLength: 0007, MsgCRC: f2, Data: 00790100010c, LQI: 0
2021-06-15 15:27:54.368 Zigate: (Zigate) [ZiGateForwarder_16] ZigateRead - MsgType: 8100, MsgLength: 000e, MsgCRC: 5d, Data: 7910e90b000000020020000101, LQI: 123
2021-06-15 15:27:54.369 Zigate: (Zigate) [ZiGateForwarder_16] Decode8100 - idx: 26 Read Attribute Response: [10e9:0b] ClusterID: 0000 MsgSQN: 79, i_sqn: 173, AttributeID: 0002 Status: 00 Type: 20 Size: 0001 ClusterData: >01<
2021-06-15 15:27:54.370 Zigate: (Zigate) [ZiGateForwarder_16] ReadCluster - 0000 - 10e9/0b AttrId: 0002 AttrType: 20 Attsize: 0001 Status: 00 AttrValue: 01
2021-06-15 15:27:54.371 Zigate: (Zigate) [ZiGateForwarder_16] ReadCluster - Stack version: 1
2021-06-15 15:27:54.374 Zigate: (Zigate) [ZiGateForwarder_16] ZigateRead - MsgType: 8011, MsgLength: 0008, MsgCRC: 6d, Data: 0010e90100000c, LQI: 0
2021-06-15 15:27:54.659 Zigate: (Zigate) [ZiGateForwarder_16] ZigateRead - MsgType: 8000, MsgLength: 0007, MsgCRC: f0, Data: 007a0100010d, LQI: 0
2021-06-15 15:27:54.672 Zigate: (Zigate) [ZiGateForwarder_16] ZigateRead - MsgType: 8100, MsgLength: 000e, MsgCRC: 5d, Data: 7a10e90b000000030020000103, LQI: 123
2021-06-15 15:27:54.672 Zigate: (Zigate) [ZiGateForwarder_16] Decode8100 - idx: 26 Read Attribute Response: [10e9:0b] ClusterID: 0000 MsgSQN: 7a, i_sqn: 174, AttributeID: 0003 Status: 00 Type: 20 Size: 0001 ClusterData: >03<
2021-06-15 15:27:54.674 Zigate: (Zigate) [ZiGateForwarder_16] ReadCluster - 0000 - 10e9/0b AttrId: 0003 AttrType: 20 Attsize: 0001 Status: 00 AttrValue: 03
2021-06-15 15:27:54.675 Zigate: (Zigate) [ZiGateForwarder_16] ReadCluster - 0x0000 - Hardware version: 3
2021-06-15 15:27:54.677 Zigate: (Zigate) [ZiGateForwarder_16] ZigateRead - MsgType: 8011, MsgLength: 0008, MsgCRC: 6c, Data: 0010e90100000d, LQI: 0
2021-06-15 15:27:54.961 Zigate: (Zigate) [ZiGateForwarder_16] ZigateRead - MsgType: 8000, MsgLength: 0007, MsgCRC: f2, Data: 007b0100010e, LQI: 0
2021-06-15 15:27:54.976 Zigate: (Zigate) [ZiGateForwarder_16] ZigateRead - MsgType: 8100, MsgLength: 0015, MsgCRC: 29, Data: 7b10e90b00000006004200083230323030333237, LQI: 126
2021-06-15 15:27:54.976 Zigate: (Zigate) [ZiGateForwarder_16] Decode8100 - idx: 40 Read Attribute Response: [10e9:0b] ClusterID: 0000 MsgSQN: 7b, i_sqn: 175, AttributeID: 0006 Status: 00 Type: 42 Size: 0008 ClusterData: >3230323030333237<
2021-06-15 15:27:54.982 Zigate: (Zigate) [ZiGateForwarder_16] ReadCluster - 0000 - 10e9/0b AttrId: 0006 AttrType: 42 Attsize: 0008 Status: 00 AttrValue: 3230323030333237
2021-06-15 15:27:54.984 Zigate: (Zigate) [ZiGateForwarder_16] ZigateRead - MsgType: 8011, MsgLength: 0008, MsgCRC: 6f, Data: 0010e90100000e, LQI: 0
2021-06-15 15:27:55.264 Zigate: (Zigate) [ZiGateForwarder_16] ZigateRead - MsgType: 8000, MsgLength: 0007, MsgCRC: f4, Data: 007c0100010f, LQI: 0
2021-06-15 15:27:55.277 Zigate: (Zigate) [ZiGateForwarder_16] ZigateRead - MsgType: 8100, MsgLength: 000e, MsgCRC: 4d, Data: 7c10e90b000000070030000101, LQI: 123
I know that the Hue GU10 doesn't work on your end, but from what I see this should work, and for now I only see a way to purchase one to make the test on my end.
Is that one you are refereing : https://www.amazon.co.uk/Philips-Ambian ... rzigbee-21 ?
