Zigate Hue gu10 white ambiance Topic is solved
keros
Re: Zigate Hue gu10 white ambiance
The Decode8000 error is something else for which we don't have a solution for the moment.
Moderator on Easydomoticz.com, the French DomoticZ forum.
French writer for ZigBeeForDomoticZ Plugin Wiki
Okay. It doesn't look like it gives problems.keros wrote: Sunday 13 June 2021 21:20 The Decode8000 error is something else for which we don't have a solution for the moment.
And the problems with the color? In my last post I attached my log.
Domoticz latest stable, Intel NUC, Proxmox, Zigate, RFLink, Kaku switches, Ikea lights, Xiaomi sensors, Honeywell smoke detectors, Yeelight, Shelly, Slave Domoticz PI 3B+, Node-Red, Espeasy.
keros
I don't have enough skills to answer your problem. Wait for the come back of Pipiche, he was out for the weekend.
Unfortunately it seems that there is not the all logs that I'm expecting. I just see the Status and Errors here, so may be you have disable Log in the Domoticz Hardware Plugin settings.
Hi,pipiche wrote: Monday 14 June 2021 10:31 Unfortunately it seems that there is not the all logs that I'm expecting. I just see the Status and Errors here, so may be you have disable Log in the Domoticz Hardware Plugin settings.
The log is as in the screenshot, what settings do you need there?
And should a pair it again when changed the log?
- firefox_2021-06-14_18-33-41.jpg (40.65 KiB) Viewed 1204 times
No , you need to go to the Plugin Web Ui, Tools -> Debug (Advanced)
debugInput
debugCluster
debugPairing
debugInput
debugCluster
debugPairing
That looks okay, the log settings.pipiche wrote: Monday 14 June 2021 19:17 No , you need to go to the Plugin Web Ui, Tools -> Debug (Advanced)
debugInput
debugCluster
debugPairing
attached a new logfile.
- export05.txt
- (297.05 KiB) Downloaded 64 times
- screenshot
- firefox_2021-06-14_19-20-32.jpg (65.48 KiB) Viewed 1201 times
what you attached, seems to be an export.json, not the log file when doing the pairing ?
So I need to do a new paring, and what logs do you need?pipiche wrote: Monday 14 June 2021 21:32 what you attached, seems to be an export.json, not the log file when doing the pairing ?
Basically with the debug that you have enabled now, just redo a full pairing , and then you give me the log.
if possible, please do update the beta branch
Update done, and the log attached.pipiche wrote: Monday 14 June 2021 22:03 Basically with the debug that you have enabled now, just redo a full pairing , and then you give me the log.
2021-06-15 13:42:43.488 Sunrise: 05:10:00 SunSet: 21:56:00
2021-06-15 13:42:43.488 Day length: 16:46:00 Sun at south: 13:33:00
2021-06-15 13:42:43.488 Civil twilight start: 04:21:00 Civil twilight end: 22:45:00
2021-06-15 13:42:43.488 Nautical twilight start: 03:00:00 Nautical twilight end: 00:06:00
2021-06-15 13:42:43.488 There is no astronomical twilight in the space of 24 hours
2021-06-15 13:42:54.396 Active notification Subsystems: email, fcm, telegram (3/13)
2021-06-15 13:42:54.527 Starting shared server on: :::7979
2021-06-15 13:42:56.568 Zigate hardware started.
2021-06-15 13:42:56.569 Shelly hardware started.
2021-06-15 13:42:56.569 Google devices hardware started.
2021-06-15 13:42:56.904 Shelly: (Shelly) New hardware creation enabled
2021-06-15 13:42:57.679 Status: Zigate: (Zigate) [ MainThread] Plugin Database: DeviceList-16.txt
2021-06-15 13:42:57.689 Status: Zigate: (Zigate) [ MainThread] DeviceConf loaded
2021-06-15 13:42:57.692 Status: RFLink: Controller Initialized!...
2021-06-15 13:42:57.768 Status: RFLink: RFLink Detected, Version: 1.1 Revision: 48 Build: 4
2021-06-15 13:42:57.770 Status: MQTT: MQTT: connected to: 192.168.1.5:1883
2021-06-15 13:42:57.943 Status: Zigate: (Zigate) [ MainThread] load ListOfDevice
2021-06-15 13:42:57.971 Status: MQTT: MQTT: Subscribed
2021-06-15 13:42:58.790 Status: Zigate: (Zigate) [ MainThread] 37 Entries loaded from /home/pi/domoticz/plugins/Domoticz-Zigate/Data/DeviceList-16.txt
2021-06-15 13:42:58.887 Status: Zigate: (Zigate) [ MainThread] Transport mode: USB
2021-06-15 13:42:58.888 Status: Zigate: (Zigate) Connection Name: Zigate, Transport: Serial, Address: /dev/serial/by-id/usb-Silicon_Labs_ZiGate_0001-if00-port0
2021-06-15 13:42:58.905 Status: Zigate: (Zigate) [ MainThread] ZigateTransport: Serial Connection open: Serial<id=0x664ee5f0, open=True>(port='/dev/serial/by-id/usb-Silicon_Labs_ZiGate_0001-if00-port0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=None, xonxoff=False, rtscts=False, dsrdtr=False)
2021-06-15 13:42:58.906 Status: Zigate: (Zigate) [ZiGateWriter_16] ZigateTransport: writer_thread Thread start.
2021-06-15 13:42:58.907 Status: Zigate: (Zigate) [ZiGateForwarder_16] ZigateTransport: thread_processing_and_sending Thread start.
2021-06-15 13:42:58.907 Status: Zigate: (Zigate) Connection open: Serial<id=0x664ee5f0, open=True>(port='/dev/serial/by-id/usb-Silicon_Labs_ZiGate_0001-if00-port0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=None, xonxoff=False, rtscts=False, dsrdtr=False)
2021-06-15 13:42:58.994 Status: Python EventSystem: Initalizing event module.
2021-06-15 13:42:58.999 Status: EventSystem: Started
2021-06-15 13:42:58.999 Status: EventSystem: Queue thread started...
2021-06-15 13:43:01.333 Shelly: (Shelly) Connected to MQTT Server: 192.168.1.5:1883
2021-06-15 13:43:01.344 Status: Zigate: (Zigate) [ZiGateSerial_16] ==> Transport Mode switch to: 31d
2021-06-15 13:43:01.349 Status: Zigate: (Zigate) [ZiGateForwarder_16] ZiGate Classic
2021-06-15 13:43:01.349 Status: Zigate: (Zigate) [ZiGateForwarder_16] Installer Version Number: 031d
2021-06-15 13:43:09.165 Status: Zigate: (Zigate) [ZiGateForwarder_16] Zigate addresses ieee: 00158d0001ee040a , short addr: 0000
2021-06-15 13:43:09.165 Status: Zigate: (Zigate) [ZiGateForwarder_16] Network state UP, PANID: 5889 extPANID: 0x2fe14f25179533d9 Channel: 11
2021-06-15 13:43:13.731 Dummy: Light/Switch (Bel voordeur PIR)
2021-06-15 13:43:14.060 Status: Zigate: (Zigate) [ MainThread] Request Disabling Accepting new Hardware
2021-06-15 13:43:14.121 Status: Incoming connection from: 192.168.1.81
2021-06-15 13:43:14.980 Status: Zigate: (Zigate) [ZiGateForwarder_16] Accepting new Hardware: Disable
2021-06-15 13:43:15.321 Status: Zigate: (Zigate) [ZiGateForwarder_16] Number of devices recently active in Zigate = 26
2021-06-15 13:43:15.322 Status: Zigate: (Zigate) [ZiGateForwarder_16] [00] DevID = 00 Network addr = bfdf IEEE = 00158d000636a25e LQI = 118 Power = 00 Model = lumi.sensor_motion ( PIR Woonkamer )
2021-06-15 13:43:15.322 Status: Zigate: (Zigate) [ZiGateForwarder_16] [01] DevID = 01 Network addr = 557a IEEE = 00158d0003fb0366 LQI = 125 Power = 00 Model = lumi.sensor_motion.aq2 ( Pir voordeur )
2021-06-15 13:43:15.322 Status: Zigate: (Zigate) [ZiGateForwarder_16] [02] DevID = 02 Network addr = 4e7b IEEE = 00158d0004096d67 LQI = 116 Power = 00 Model = lumi.sensor_magnet.aq2 ( Deursensor woonkamer )
2021-06-15 13:43:15.323 Status: Zigate: (Zigate) [ZiGateForwarder_16] [03] DevID = 03 Network addr = 3478 IEEE = 00158d0005225f00 LQI = 118 Power = 00 Model = lumi.sensor_magnet.aq2 ( Deursensor voordeur )
2021-06-15 13:43:15.323 Status: Zigate: (Zigate) [ZiGateForwarder_16] [04] DevID = 04 Network addr = 0721 IEEE = 00158d0006c243b7 LQI = 071 Power = 00 Model = lumi.sensor_wleak.aq1 ( Watersensor Vaatwasser )
2021-06-15 13:43:15.324 Status: Zigate: (Zigate) [ZiGateForwarder_16] [05] DevID = 05 Network addr = caca IEEE = 00158d00045cfdb5 LQI = 093 Power = 00 Model = lumi.sensor_magnet.aq2 ( Deursensor tuin )
2021-06-15 13:43:15.324 Status: Zigate: (Zigate) [ZiGateForwarder_16] [06] DevID = 28 Network addr = 6bc1 IEEE = ec1bbdfffe1b813b LQI = 110 Power = 01 Model = TRADFRI bulb E27 WW clear 250lm ( Woonkamer Eethoek-4 )
2021-06-15 13:43:15.324 Status: Zigate: (Zigate) [ZiGateForwarder_16] [07] DevID = 29 Network addr = dd5f IEEE = 0017880109714b42 LQI = 131 Power = 01 Model = LTG002 ( )
2021-06-15 13:43:15.325 Status: Zigate: (Zigate) [ZiGateForwarder_16] [08] DevID = 2a Network addr = 64c0 IEEE = ec1bbdfffea28399 LQI = 138 Power = 01 Model = TRADFRI bulb E27 WW clear 250lm ( Woonkamer Eethoek-1 )
2021-06-15 13:43:15.325 Status: Zigate: (Zigate) [ZiGateForwarder_16] [09] DevID = 2b Network addr = 6c7c IEEE = ccccccfffef43db1 LQI = 141 Power = 01 Model = TRADFRI bulb E27 WW clear 250lm ( Woonkamer Eethoek-3 )
2021-06-15 13:43:15.326 Status: Zigate: (Zigate) [ZiGateForwarder_16] [10] DevID = 2c Network addr = 6ab5 IEEE = 00158d000444e9e3 LQI = 082 Power = 01 Model = lumi.relay.c2acn01 ( Water schakelaar tuin achter )
2021-06-15 13:43:15.326 Status: Zigate: (Zigate) [ZiGateForwarder_16] [11] DevID = 2d Network addr = aa16 IEEE = 680ae2fffe4a16b8 LQI = 140 Power = 01 Model = TRADFRI bulb E27 WS opal 1000lm ( Woonkamer eethoek achter )
2021-06-15 13:43:15.326 Status: Zigate: (Zigate) [ZiGateForwarder_16] [12] DevID = 2e Network addr = 10e9 IEEE = 0017880109796dad LQI = 117 Power = 01 Model = LTG002 ( )
2021-06-15 13:43:15.327 Status: Zigate: (Zigate) [ZiGateForwarder_16] [13] DevID = 2f Network addr = 8445 IEEE = 00178801097966b1 LQI = 124 Power = 01 not found in ListOfDevices
2021-06-15 13:43:15.327 Status: Zigate: (Zigate) [ZiGateForwarder_16] [14] DevID = 30 Network addr = 9ab3 IEEE = ec1bbdfffe468a93 LQI = 141 Power = 01 Model = TRADFRI bulb GU10 WS 400lm ( Woonkamer salontafel_2 )
2021-06-15 13:43:15.328 Status: Zigate: (Zigate) [ZiGateForwarder_16] [15] DevID = 31 Network addr = f1f1 IEEE = 680ae2fffe413429 LQI = 093 Power = 01 Model = TRADFRI control outlet ( TV boven schakelaar )
2021-06-15 13:43:15.328 Status: Zigate: (Zigate) [ZiGateForwarder_16] [16] DevID = 32 Network addr = 7f15 IEEE = ec1bbdfffe986a27 LQI = 138 Power = 01 Model = TRADFRI bulb GU10 WS 400lm ( Woonkamer salontafel_1 )
2021-06-15 13:43:15.328 Status: Zigate: (Zigate) [ZiGateForwarder_16] [17] DevID = 33 Network addr = 2d3c IEEE = ec1bbdfffeabe177 LQI = 150 Power = 01 Model = TRADFRI bulb E27 WW clear 250lm ( Woonkamer Eethoek-2 )
2021-06-15 13:43:15.329 Status: Zigate: (Zigate) [ZiGateForwarder_16] [18] DevID = 34 Network addr = 5a7a IEEE = 680ae2fffe373006 LQI = 124 Power = 01 Model = TRADFRI bulb GU10 WS 400lm ( Woonkamer salontafel_3 )
2021-06-15 13:43:15.329 Status: Zigate: (Zigate) [ZiGateForwarder_16] [19] DevID = 35 Network addr = 8ca0 IEEE = 680ae2fffe4c5b85 LQI = 141 Power = 01 Model = TRADFRI bulb E27 WS opal 1000lm ( Woonkamer eethoek voor )
2021-06-15 13:43:15.330 Status: Zigate: (Zigate) [ZiGateForwarder_16] [20] DevID = 36 Network addr = 8b16 IEEE = 000d6ffffe485188 LQI = 133 Power = 01 Model = TRADFRI bulb E27 WS opal 980lm ( Woonkamer bankstel )
2021-06-15 13:43:15.330 Status: Zigate: (Zigate) [ZiGateForwarder_16] [21] DevID = 37 Network addr = f295 IEEE = ec1bbdfffeb8ab2a LQI = 099 Power = 01 Model = TRADFRI bulb E27 WW clear 250lm ( Woonkamer achterdeur )
2021-06-15 13:43:15.330 Status: Zigate: (Zigate) [ZiGateForwarder_16] [22] DevID = 38 Network addr = 14e4 IEEE = ec1bbdfffe9a6b26 LQI = 114 Power = 01 Model = TRADFRI bulb E27 WW clear 250lm ( Woonkamer Eethoek-5 )
2021-06-15 13:43:15.331 Status: Zigate: (Zigate) [ZiGateForwarder_16] [23] DevID = 39 Network addr = 8ef3 IEEE = 0017880109037d19 LQI = 113 Power = 01 Model = ( Woonkamer Vloerlamp )
2021-06-15 13:43:15.331 Status: Zigate: (Zigate) [ZiGateForwarder_16] [24] DevID = 3a Network addr = 73ea IEEE = 0017880108a2eb84 LQI = 076 Power = 01 Model = LWA004 ( Voordeur lamp )
2021-06-15 13:43:15.327 Error: Zigate: (Zigate) DeviceExist - Found some inconsistency Inputs: 8445 00178801097966b1 instead of None
2021-06-15 13:43:19.075 Status: Zigate: (Zigate) [ MainThread] Zigate set to Certification : CE
2021-06-15 13:43:19.075 Status: Zigate: (Zigate) [ MainThread] Start Group Management
2021-06-15 13:43:19.096 Status: Zigate: (Zigate) [ MainThread] Available Firmware - ManufCode: 117c ImageType: 0x11c2 FileVersion: 23028631 Size: 179390 Bytes Filename: 159701-2.1-TRADFRI-wireless-dimmer-2.3.028.ota.ota.signed
2021-06-15 13:43:19.110 Status: Zigate: (Zigate) [ MainThread] Available Firmware - ManufCode: 117c ImageType: 0x2203 FileVersion: 23007631 Size: 207870 Bytes Filename: 100355342-2.1-TRADFRI-bulb-ws-gu10-2.3.007.ota.ota.signed
2021-06-15 13:43:19.122 Status: Zigate: (Zigate) [ MainThread] Available Firmware - ManufCode: 117c ImageType: 0x2801 FileVersion: 13009572 Size: 178366 Bytes Filename: 10035515-TRADFRI-bulb-cws-1.3.009.ota.ota.signed
2021-06-15 13:43:19.134 Status: Zigate: (Zigate) [ MainThread] Available Firmware - ManufCode: 117c ImageType: 0x4201 FileVersion: 12217572 Size: 173246 Bytes Filename: 159698-TRADFRI-driver-lp-1.2.217.ota.ota.signed
2021-06-15 13:43:19.146 Status: Zigate: (Zigate) [ MainThread] Available Firmware - ManufCode: 117c ImageType: 0x4202 FileVersion: 12217572 Size: 173246 Bytes Filename: 159697-TRADFRI-driver-hp-1.2.217.ota.ota.signed
2021-06-15 13:43:19.160 Status: Zigate: (Zigate) [ MainThread] Available Firmware - ManufCode: 117c ImageType: 0x4203 FileVersion: 20022623 Size: 208830 Bytes Filename: 191100-4.1-TRADFRI-sy5882-driver-ws-2.0.022.ota.ota.signed
2021-06-15 13:43:19.173 Status: Zigate: (Zigate) [ MainThread] Available Firmware - ManufCode: 117c ImageType: 0x11ca FileVersion: 21024631 Size: 180926 Bytes Filename: 10043101-3.1-TRADFRI-dimmer-2.1.024.ota.ota.signed
2021-06-15 13:43:19.186 Status: Zigate: (Zigate) [ MainThread] Available Firmware - ManufCode: 117c ImageType: 0x11c8 FileVersion: 20022623 Size: 186814 Bytes Filename: 10039874-1.0-TRADFRI-motion-sensor-2-2.0.022.ota.ota.signed
2021-06-15 13:43:19.200 Status: Zigate: (Zigate) [ MainThread] Available Firmware - ManufCode: 117c ImageType: 0x4206 FileVersion: 21022631 Size: 208254 Bytes Filename: 10047227-1.2-TRADFRI-cv-cct-unified-2.1.022.ota.ota.signed
2021-06-15 13:43:19.214 Status: Zigate: (Zigate) [ MainThread] Available Firmware - ManufCode: 117c ImageType: 0x2201 FileVersion: 23007631 Size: 208126 Bytes Filename: 10035514-2.1-TRADFRI-bulb-ws-2.3.007.ota.ota.signed
2021-06-15 13:43:19.226 Status: Zigate: (Zigate) [ MainThread] Available Firmware - ManufCode: 117c ImageType: 0x4101 FileVersion: 12245572 Size: 181118 Bytes Filename: 159495-TRADFRI-transformer-1.2.245.ota.ota.signed
2021-06-15 13:43:19.239 Status: Zigate: (Zigate) [ MainThread] Available Firmware - ManufCode: 117c ImageType: 0x1187 FileVersion: 22009631 Size: 186942 Bytes Filename: 10037585-5.1-TRADFRI-connected-blind-2.2.009.ota.ota.signed
2021-06-15 13:43:19.252 Status: Zigate: (Zigate) [ MainThread] Available Firmware - ManufCode: 117c ImageType: 0x11c1 FileVersion: 23014631 Size: 182590 Bytes Filename: 159699-5.1-TRADFRI-remote-control-2.3.014.ota.ota.signed
2021-06-15 13:43:19.265 Status: Zigate: (Zigate) [ MainThread] Available Firmware - ManufCode: 117c ImageType: 0x1102 FileVersion: 22005631 Size: 189822 Bytes Filename: 10037603-3.1-TRADFRI-signal-repeater-2.2.005.ota.ota.signed
2021-06-15 13:43:19.276 Status: Zigate: (Zigate) [ MainThread] Available Firmware - ManufCode: 117c ImageType: 0x2101 FileVersion: 12214572 Size: 168318 Bytes Filename: 159696-TRADFRI-bulb-w-1000lm-1.2.214.ota.ota.signed
2021-06-15 13:43:19.287 Status: Zigate: (Zigate) [ MainThread] Available Firmware - ManufCode: 117c ImageType: 0x11c4 FileVersion: 12214572 Size: 157822 Bytes Filename: 159700-TRADFRI-motion-sensor-1.2.214.ota.ota.signed
2021-06-15 13:43:19.300 Status: Zigate: (Zigate) [ MainThread] Available Firmware - ManufCode: 117c ImageType: 0x11c5 FileVersion: 22010631 Size: 179838 Bytes Filename: 10005778-10.1-TRADFRI-onoff-shortcut-control-2.2.010.ota.ota.signed
2021-06-15 13:43:19.311 Status: Zigate: (Zigate) [ MainThread] Available Firmware - ManufCode: 117c ImageType: 0x0002 FileVersion: 165801bc Size: 166270 Bytes Filename: 190579-ncp572b444.ebl.ota.ota.signed
2021-06-15 13:43:19.325 Status: Zigate: (Zigate) [ MainThread] Available Firmware - ManufCode: 117c ImageType: 0x4204 FileVersion: 20023623 Size: 209086 Bytes Filename: 10038562-2.1-TRADFRI-sy5882-bulb-ws-2.0.023.ota.ota.signed
2021-06-15 13:43:19.339 Status: Zigate: (Zigate) [ MainThread] Available Firmware - ManufCode: 117c ImageType: 0x1101 FileVersion: 20024623 Size: 202110 Bytes Filename: 10005777-6.1-TRADFRI-control-outlet-2.0.024.ota.ota.signed
2021-06-15 13:43:19.353 Status: Zigate: (Zigate) [ MainThread] Available Firmware - ManufCode: 117c ImageType: 0x4103 FileVersion: 21022631 Size: 202878 Bytes Filename: 10046695-1.1-TRADFRI-light-unified-w-2.1.022.ota.ota.signed
2021-06-15 13:43:19.367 Status: Zigate: (Zigate) [ MainThread] Available Firmware - ManufCode: 117c ImageType: 0x2202 FileVersion: 23007631 Size: 208702 Bytes Filename: 159695-2.1-TRADFRI-bulb-ws-1000lm-2.3.007.ota.ota.signed
2021-06-15 13:43:19.389 Status: Zigate: (Zigate) [ZiGateForwarder_16] TxPower Attenuation : 0 dBm
2021-06-15 13:43:24.844 Status: Zigate: (Zigate) [ MainThread] Available Firmware - ManufCode: 117c ImageType: 0x4205 FileVersion: 21022631 Size: 208254 Bytes Filename: 10040611-3.2-TRADFRI-sy5882-unified-2.1.022.ota.ota.signed
2021-06-15 13:43:24.849 Status: Zigate: (Zigate) [ MainThread] Start Web Server connection
2021-06-15 13:43:24.868 Status: Zigate: (Zigate) [ MainThread] Web backend for Web User Interface started on port: 9440
2021-06-15 13:43:24.868 Status: Zigate: (Zigate) [ MainThread] Plugin with Zigate firmware 031d correctly initialized
2021-06-15 13:43:28.302 Status: Zigate: (Zigate) [ MainThread] There is a newer plugin version available on gitHub
2021-06-15 13:43:28.302 Status: Zigate: (Zigate) [ MainThread] There is a newer Zigate Firmware version available
2021-06-15 13:43:34.783 Status: Notification: Bewatering voor Uitgeschakeld
2021-06-15 13:43:35.954 Notification sent (email) => Success
2021-06-15 13:43:39.582 Dummy: Light/Switch (Bel voordeur PIR)
2021-06-15 13:43:43.985 EventSystem: Event triggered: Buitenzit weer_1
2021-06-15 13:43:43.985 Status: buitenzitweer ingeschakeld
2021-06-15 13:43:44.005 Dummy: Light/Switch (Buitenzit weer)
2021-06-15 13:43:59.715 Dummy: Light/Switch (Bel voordeur PIR)
2021-06-15 13:44:01.778 Status: Notification sent (Email)
2021-06-15 13:44:44.004 EventSystem: Event triggered: Buitenzit weer_1
2021-06-15 13:44:44.021 Dummy: Light/Switch (Buitenzit weer)
2021-06-15 13:44:44.004 Status: buitenzitweer ingeschakeld
2021-06-15 13:45:17.603 Dummy: Light/Switch (Bel voordeur PIR)
2021-06-15 13:45:37.701 Dummy: Light/Switch (Bel voordeur PIR)
2021-06-15 13:45:44.014 EventSystem: Event triggered: Buitenzit weer_1
2021-06-15 13:45:44.060 Dummy: Light/Switch (Buitenzit weer)
2021-06-15 13:45:44.528 Dummy: Light/Switch (Bel voordeur PIR)
2021-06-15 13:45:44.015 Status: buitenzitweer ingeschakeld
2021-06-15 13:45:58.900 Status: Notification: Bewatering voor Uitgeschakeld
2021-06-15 13:45:59.621 Notification sent (email) => Success
2021-06-15 13:45:59.886 Status: Zigate: (Zigate) [ZiGateForwarder_16] Device Annoucement: Voortuin relay NwkId: d4ad Ieee: 00158d000444ee2f MacCap: 8e
2021-06-15 13:46:05.601 Dummy: Light/Switch (Bel voordeur PIR)
2021-06-15 13:46:25.648 Dummy: Light/Switch (Bel voordeur PIR)
2021-06-15 13:46:34.451 Status: Zigate: (Zigate) [ MainThread] onDeviceRemoved - removing End Device
2021-06-15 13:46:34.505 Status: Zigate: (Zigate) Device Zigate - ColorControlRGBWW-0017880109714b42-0b with IEEE: 0017880109714b42 fully removed from the system.
2021-06-15 13:46:34.512 Status: Zigate: (Zigate) [ MainThread] onDeviceRemoved - removing Device Zigate - ColorControlRGBWW-0017880109714b42-0b -> 0017880109714b42 in Zigate
2021-06-15 13:46:34.605 Status: Zigate: (Zigate) [ MainThread] onDeviceRemoved - removing End Device
2021-06-15 13:46:34.639 Status: Zigate: (Zigate) Device Zigate - ColorControlRGBWW-0017880109796dad-0b with IEEE: 0017880109796dad fully removed from the system.
2021-06-15 13:46:34.645 Status: Zigate: (Zigate) [ MainThread] onDeviceRemoved - removing Device Zigate - ColorControlRGBWW-0017880109796dad-0b -> 0017880109796dad in Zigate
2021-06-15 13:46:44.033 EventSystem: Event triggered: Buitenzit weer_1
2021-06-15 13:46:44.070 Dummy: Light/Switch (Buitenzit weer)
2021-06-15 13:46:44.033 Status: buitenzitweer ingeschakeld
2021-06-15 13:46:45.693 Status: Zigate: (Zigate) Plugin Restart command : http://admin:[email protected]:8080/json.htm?type=command¶m=updatehardware&htype=94&idx=16&name=Zigate&address=0.0.0.0&port=9999&serialport=/dev/serial/by-id/usb-Silicon_Labs_ZiGate_0001-if00-port0&Mode1=USB&Mode2=&Mode3=False&Mode4=9440&Mode5=&Mode6=14&extra=Zigate&enabled=true&datatimeout=0
2021-06-15 13:46:57.450 Status: Zigate: (Zigate) [ MainThread] Request Accepting new Hardware for ever
2021-06-15 13:46:57.774 Status: Zigate: (Zigate) [ZiGateForwarder_16] Accepting new Hardware: On
2021-06-15 13:47:02.378 Yeelight Controller: Color Switch (Tuin tafel)
2021-06-15 13:47:44.022 EventSystem: Event triggered: Buitenzit weer_1
2021-06-15 13:47:44.044 Dummy: Light/Switch (Buitenzit weer)
2021-06-15 13:47:44.022 Status: buitenzitweer ingeschakeld
2021-06-15 13:48:15.712 Error: Zigate: (Zigate) DeviceExist - Found some inconsistency Inputs: dd5f 0017880109714b42 instead of None
2021-06-15 13:48:18.473 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: dd5f Active Endpoint Response Ep: 0b LQI: 135
2021-06-15 13:48:18.473 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: dd5f Active Endpoint Response Ep: f2 LQI: 135
2021-06-15 13:48:18.474 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: dd5f Request Simple Descriptor for Ep: 0b
2021-06-15 13:48:18.475 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: dd5f Request Simple Descriptor for Ep: f2
2021-06-15 13:48:19.393 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: dd5f Simple Descriptor Response EP: 0x0b LQI: 138
2021-06-15 13:48:19.393 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: dd5f ProfileID 0104
2021-06-15 13:48:19.393 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: dd5f ZDeviceID 010c
2021-06-15 13:48:19.394 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: dd5f Application Version 0001
2021-06-15 13:48:19.394 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: dd5f Cluster IN Count: 09
2021-06-15 13:48:19.394 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: dd5f Cluster In 1: 0000 (Basic)
2021-06-15 13:48:19.394 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: dd5f Cluster In 2: 0003 (Identify)
2021-06-15 13:48:19.394 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: dd5f Cluster In 3: 0004 (Groups)
2021-06-15 13:48:19.395 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: dd5f Cluster In 4: 0005 (Scenes)
2021-06-15 13:48:19.395 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: dd5f Cluster In 5: 0006 (On/Off)
2021-06-15 13:48:19.395 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: dd5f Cluster In 6: 0008 (Level Control)
2021-06-15 13:48:19.395 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: dd5f Cluster In 7: 1000 (Touchlink)
2021-06-15 13:48:19.395 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: dd5f Cluster In 8: fc02
2021-06-15 13:48:19.395 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: dd5f Cluster In 9: 0300 (Colour Control)
2021-06-15 13:48:19.396 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: dd5f Cluster OUT Count: 01
2021-06-15 13:48:19.396 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: dd5f Cluster Out 1: 0019 (Over-the-Air Upgrade)
2021-06-15 13:48:19.683 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: dd5f Simple Descriptor Response EP: 0xf2 LQI: 135
2021-06-15 13:48:19.683 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: dd5f ProfileID a1e0
2021-06-15 13:48:19.683 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: dd5f ZDeviceID 0061
2021-06-15 13:48:19.683 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: dd5f Application Version 0000
2021-06-15 13:48:19.683 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: dd5f Cluster IN Count: 00
2021-06-15 13:48:19.683 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: dd5f Cluster OUT Count: 01
2021-06-15 13:48:19.684 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: dd5f Cluster Out 1: 0021
2021-06-15 13:48:23.102 Status: Zigate: (Zigate) [0] NEW OBJECT: dd5f Request Node Descriptor
2021-06-15 13:48:23.102 Status: Zigate: (Zigate) [0] NEW OBJECT: dd5f Request Attribute for Cluster 0x0300 to get ColorMode
2021-06-15 13:48:28.094 Status: Zigate: (Zigate) [1] NEW OBJECT: dd5f Request Attribute for Cluster 0x0300 to get ColorMode
2021-06-15 13:48:33.082 Status: Zigate: (Zigate) [2] NEW OBJECT: dd5f Request Attribute for Cluster 0x0300 to get ColorMode
2021-06-15 13:48:44.066 EventSystem: Event triggered: Buitenzit weer_1
2021-06-15 13:48:44.090 Dummy: Light/Switch (Buitenzit weer)
2021-06-15 13:48:44.067 Status: buitenzitweer ingeschakeld
2021-06-15 13:49:02.100 Status: Notification sent (Email)
2021-06-15 13:49:10.661 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 8445 Active Endpoint Response Ep: 0b LQI: 114
2021-06-15 13:49:10.661 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 8445 Active Endpoint Response Ep: f2 LQI: 114
2021-06-15 13:49:10.662 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 8445 Request Simple Descriptor for Ep: 0b
2021-06-15 13:49:10.662 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 8445 Request Simple Descriptor for Ep: f2
2021-06-15 13:49:10.522 Error: Zigate: (Zigate) DeviceExist - Found some inconsistency Inputs: 8445 00178801097966b1 instead of None
2021-06-15 13:49:11.551 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 8445 Simple Descriptor Response EP: 0x0b LQI: 141
2021-06-15 13:49:11.551 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 8445 ProfileID 0104
2021-06-15 13:49:11.551 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 8445 ZDeviceID 010c
2021-06-15 13:49:11.551 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 8445 Application Version 0001
2021-06-15 13:49:11.552 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 8445 Cluster IN Count: 09
2021-06-15 13:49:11.552 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 8445 Cluster In 1: 0000 (Basic)
2021-06-15 13:49:11.552 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 8445 Cluster In 2: 0003 (Identify)
2021-06-15 13:49:11.552 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 8445 Cluster In 3: 0004 (Groups)
2021-06-15 13:49:11.552 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 8445 Cluster In 4: 0005 (Scenes)
2021-06-15 13:49:11.552 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 8445 Cluster In 5: 0006 (On/Off)
2021-06-15 13:49:11.553 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 8445 Cluster In 6: 0008 (Level Control)
2021-06-15 13:49:11.553 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 8445 Cluster In 7: 1000 (Touchlink)
2021-06-15 13:49:11.553 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 8445 Cluster In 8: fc02
2021-06-15 13:49:11.553 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 8445 Cluster In 9: 0300 (Colour Control)
2021-06-15 13:49:11.553 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 8445 Cluster OUT Count: 01
2021-06-15 13:49:11.553 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 8445 Cluster Out 1: 0019 (Over-the-Air Upgrade)
2021-06-15 13:49:11.784 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 8445 Simple Descriptor Response EP: 0xf2 LQI: 141
2021-06-15 13:49:11.785 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 8445 ProfileID a1e0
2021-06-15 13:49:11.785 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 8445 ZDeviceID 0061
2021-06-15 13:49:11.785 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 8445 Application Version 0000
2021-06-15 13:49:11.785 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 8445 Cluster IN Count: 00
2021-06-15 13:49:11.785 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 8445 Cluster OUT Count: 01
2021-06-15 13:49:11.785 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 8445 Cluster Out 1: 0021
2021-06-15 13:49:13.093 Status: Zigate: (Zigate) [0] NEW OBJECT: 8445 Request Node Descriptor
2021-06-15 13:49:13.093 Status: Zigate: (Zigate) [0] NEW OBJECT: 8445 Request Attribute for Cluster 0x0300 to get ColorMode
2021-06-15 13:49:18.058 Status: Zigate: (Zigate) [1] NEW OBJECT: 8445 Request Attribute for Cluster 0x0300 to get ColorMode
2021-06-15 13:49:23.080 Status: Zigate: (Zigate) [2] NEW OBJECT: 8445 Request Attribute for Cluster 0x0300 to get ColorMode
2021-06-15 13:49:44.095 EventSystem: Event triggered: Buitenzit weer_1
2021-06-15 13:49:44.116 Dummy: Light/Switch (Buitenzit weer)
2021-06-15 13:49:44.096 Status: buitenzitweer ingeschakeld
2021-06-15 13:49:44.161 Error: Zigate: (Zigate) DeviceExist - Found some inconsistency Inputs: 10e9 0017880109796dad instead of None
2021-06-15 13:49:46.881 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 10e9 Active Endpoint Response Ep: 0b LQI: 102
2021-06-15 13:49:46.881 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 10e9 Active Endpoint Response Ep: f2 LQI: 102
2021-06-15 13:49:46.884 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 10e9 Request Simple Descriptor for Ep: 0b
2021-06-15 13:49:46.885 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 10e9 Request Simple Descriptor for Ep: f2
2021-06-15 13:49:47.798 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 10e9 Simple Descriptor Response EP: 0x0b LQI: 105
2021-06-15 13:49:47.798 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 10e9 ProfileID 0104
2021-06-15 13:49:47.798 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 10e9 ZDeviceID 010c
2021-06-15 13:49:47.798 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 10e9 Application Version 0001
2021-06-15 13:49:47.798 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 10e9 Cluster IN Count: 09
2021-06-15 13:49:47.798 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 10e9 Cluster In 1: 0000 (Basic)
2021-06-15 13:49:47.799 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 10e9 Cluster In 2: 0003 (Identify)
2021-06-15 13:49:47.799 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 10e9 Cluster In 3: 0004 (Groups)
2021-06-15 13:49:47.799 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 10e9 Cluster In 4: 0005 (Scenes)
2021-06-15 13:49:47.799 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 10e9 Cluster In 5: 0006 (On/Off)
2021-06-15 13:49:47.799 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 10e9 Cluster In 6: 0008 (Level Control)
2021-06-15 13:49:47.800 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 10e9 Cluster In 7: 1000 (Touchlink)
2021-06-15 13:49:47.800 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 10e9 Cluster In 8: fc02
2021-06-15 13:49:47.800 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 10e9 Cluster In 9: 0300 (Colour Control)
2021-06-15 13:49:47.800 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 10e9 Cluster OUT Count: 01
2021-06-15 13:49:47.800 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 10e9 Cluster Out 1: 0019 (Over-the-Air Upgrade)
2021-06-15 13:49:48.083 Status: Zigate: (Zigate) [0] NEW OBJECT: 10e9 Request Node Descriptor
2021-06-15 13:49:48.083 Status: Zigate: (Zigate) [0] NEW OBJECT: 10e9 Request Attribute for Cluster 0x0300 to get ColorMode
2021-06-15 13:49:48.108 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 10e9 Simple Descriptor Response EP: 0xf2 LQI: 102
2021-06-15 13:49:48.108 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 10e9 ProfileID a1e0
2021-06-15 13:49:48.108 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 10e9 ZDeviceID 0061
2021-06-15 13:49:48.109 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 10e9 Application Version 0000
2021-06-15 13:49:48.109 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 10e9 Cluster IN Count: 00
2021-06-15 13:49:48.109 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 10e9 Cluster OUT Count: 01
2021-06-15 13:49:48.109 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 10e9 Cluster Out 1: 0021
2021-06-15 13:49:53.061 Status: Zigate: (Zigate) [1] NEW OBJECT: 10e9 Request Attribute for Cluster 0x0300 to get ColorMode
2021-06-15 13:49:58.105 Status: Zigate: (Zigate) [2] NEW OBJECT: 10e9 Request Attribute for Cluster 0x0300 to get ColorMode
2021-06-15 13:50:00.184 Status: dzVents: Info: EnergyCost: ------ Start internal script: Energieverbruik Jacuzzi:, trigger: "every 10 minutes"
2021-06-15 13:50:00.203 Status: dzVents: Debug: EnergyCost: Processing device-adapter for Jacuzzi verbruik: kWh device adapter
2021-06-15 13:50:00.205 Status: dzVents: Debug: EnergyCost: Processing device-adapter for Stroomkosten Jacuzzi: Custom sensor device adapter
2021-06-15 13:50:00.205 Status: dzVents: Debug: EnergyCost: Stroomkosten Jacuzzi ==>> previous value: 1.02 ; new value 1.03
2021-06-15 13:50:00.205 Status: dzVents: Info: EnergyCost: ------ Finished Energieverbruik Jacuzzi
2021-06-15 13:50:00.206 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2021-06-15 13:50:02.905 Status: Notification sent (Email) Domoticz latest stable, Intel NUC, Proxmox, Zigate, RFLink, Kaku switches, Ikea lights, Xiaomi sensors, Honeywell smoke detectors, Yeelight, Shelly, Slave Domoticz PI 3B+, Node-Red, Espeasy.
This is a shame, I'm not getting the logs here, I don't know what is wrong on your setup , but I cannot really understand what is happening There is only the Status here , not the log.
As I mentioned earlier I beleive you have only enabled Status and I guess Errors in the Domotciz LogLevel .
Check the Log Level
2021-06-15 15:26:02.585 Status: Notification sent (Email)
2021-06-15 15:26:28.653 Error: Zigate: (Zigate) DeviceExist - Found some inconsistency Inputs: 8445 00178801097966b1 instead of None
2021-06-15 15:26:31.738 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 8445 Active Endpoint Response Ep: 0b LQI: 117
2021-06-15 15:26:31.738 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 8445 Active Endpoint Response Ep: f2 LQI: 117
2021-06-15 15:26:31.741 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 8445 Request Simple Descriptor for Ep: 0b
2021-06-15 15:26:31.742 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 8445 Request Simple Descriptor for Ep: f2
2021-06-15 15:26:32.647 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 8445 Simple Descriptor Response EP: 0x0b LQI: 114
2021-06-15 15:26:32.647 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 8445 ProfileID 0104
2021-06-15 15:26:32.647 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 8445 ZDeviceID 010c
2021-06-15 15:26:32.648 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 8445 Application Version 0001
2021-06-15 15:26:32.648 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 8445 Cluster IN Count: 09
2021-06-15 15:26:32.648 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 8445 Cluster In 1: 0000 (Basic)
2021-06-15 15:26:32.648 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 8445 Cluster In 2: 0003 (Identify)
2021-06-15 15:26:32.648 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 8445 Cluster In 3: 0004 (Groups)
2021-06-15 15:26:32.648 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 8445 Cluster In 4: 0005 (Scenes)
2021-06-15 15:26:32.648 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 8445 Cluster In 5: 0006 (On/Off)
2021-06-15 15:26:32.648 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 8445 Cluster In 6: 0008 (Level Control)
2021-06-15 15:26:32.648 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 8445 Cluster In 7: 1000 (Touchlink)
2021-06-15 15:26:32.648 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 8445 Cluster In 8: fc02
2021-06-15 15:26:32.648 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 8445 Cluster In 9: 0300 (Colour Control)
2021-06-15 15:26:32.649 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 8445 Cluster OUT Count: 01
2021-06-15 15:26:32.649 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 8445 Cluster Out 1: 0019 (Over-the-Air Upgrade)
2021-06-15 15:26:32.949 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 8445 Simple Descriptor Response EP: 0xf2 LQI: 117
2021-06-15 15:26:32.949 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 8445 ProfileID a1e0
2021-06-15 15:26:32.950 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 8445 ZDeviceID 0061
2021-06-15 15:26:32.950 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 8445 Application Version 0000
2021-06-15 15:26:32.950 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 8445 Cluster IN Count: 00
2021-06-15 15:26:32.950 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 8445 Cluster OUT Count: 01
2021-06-15 15:26:32.950 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 8445 Cluster Out 1: 0021
2021-06-15 15:26:37.083 Status: Zigate: (Zigate) [0] NEW OBJECT: 8445 Request Node Descriptor
2021-06-15 15:26:37.084 Status: Zigate: (Zigate) [0] NEW OBJECT: 8445 Request Attribute for Cluster 0x0300 to get ColorMode
2021-06-15 15:26:42.094 Status: Zigate: (Zigate) [1] NEW OBJECT: 8445 Request Attribute for Cluster 0x0300 to get ColorMode
2021-06-15 15:26:44.661 Status: buitenzitweer ingeschakeld
2021-06-15 15:26:47.079 Status: Zigate: (Zigate) [2] NEW OBJECT: 8445 Request Attribute for Cluster 0x0300 to get ColorMode
2021-06-15 15:26:51.739 Error: Zigate: (Zigate) DeviceExist - Found some inconsistency Inputs: dd5f 0017880109714b42 instead of None
2021-06-15 15:27:02.057 Status: Zigate: (Zigate) [0] NEW OBJECT: dd5f TimeOut in 0045 restarting at 0x004d
2021-06-15 15:27:02.482 Status: Notification sent (Email)
2021-06-15 15:27:08.716 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: dd5f Active Endpoint Response Ep: 0b LQI: 111
2021-06-15 15:27:08.716 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: dd5f Active Endpoint Response Ep: f2 LQI: 111
2021-06-15 15:27:08.719 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: dd5f Request Simple Descriptor for Ep: 0b
2021-06-15 15:27:08.720 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: dd5f Request Simple Descriptor for Ep: f2
2021-06-15 15:27:09.899 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: dd5f Simple Descriptor Response EP: 0x0b LQI: 111
2021-06-15 15:27:09.899 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: dd5f ProfileID 0104
2021-06-15 15:27:09.899 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: dd5f ZDeviceID 010c
2021-06-15 15:27:09.899 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: dd5f Application Version 0001
2021-06-15 15:27:09.900 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: dd5f Cluster IN Count: 09
2021-06-15 15:27:09.900 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: dd5f Cluster In 1: 0000 (Basic)
2021-06-15 15:27:09.900 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: dd5f Cluster In 2: 0003 (Identify)
2021-06-15 15:27:09.900 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: dd5f Cluster In 3: 0004 (Groups)
2021-06-15 15:27:09.900 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: dd5f Cluster In 4: 0005 (Scenes)
2021-06-15 15:27:09.900 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: dd5f Cluster In 5: 0006 (On/Off)
2021-06-15 15:27:09.901 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: dd5f Cluster In 6: 0008 (Level Control)
2021-06-15 15:27:09.901 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: dd5f Cluster In 7: 1000 (Touchlink)
2021-06-15 15:27:09.901 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: dd5f Cluster In 8: fc02
2021-06-15 15:27:09.901 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: dd5f Cluster In 9: 0300 (Colour Control)
2021-06-15 15:27:09.901 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: dd5f Cluster OUT Count: 01
2021-06-15 15:27:09.901 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: dd5f Cluster Out 1: 0019 (Over-the-Air Upgrade)
2021-06-15 15:27:10.198 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: dd5f Simple Descriptor Response EP: 0xf2 LQI: 114
2021-06-15 15:27:10.198 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: dd5f ProfileID a1e0
2021-06-15 15:27:10.198 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: dd5f ZDeviceID 0061
2021-06-15 15:27:10.198 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: dd5f Application Version 0000
2021-06-15 15:27:10.198 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: dd5f Cluster IN Count: 00
2021-06-15 15:27:10.198 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: dd5f Cluster OUT Count: 01
2021-06-15 15:27:10.199 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: dd5f Cluster Out 1: 0021
2021-06-15 15:27:12.074 Status: Zigate: (Zigate) [1] NEW OBJECT: dd5f Request Node Descriptor
2021-06-15 15:27:12.074 Status: Zigate: (Zigate) [1] NEW OBJECT: dd5f Request Attribute for Cluster 0x0300 to get ColorMode
2021-06-15 15:27:17.074 Status: Zigate: (Zigate) [2] NEW OBJECT: dd5f Request Attribute for Cluster 0x0300 to get ColorMode
2021-06-15 15:27:20.338 Error: Zigate: (Zigate) DeviceExist - Found some inconsistency Inputs: 10e9 0017880109796dad instead of None
2021-06-15 15:27:32.103 Status: Zigate: (Zigate) [0] NEW OBJECT: 10e9 TimeOut in 0045 restarting at 0x004d
2021-06-15 15:27:37.878 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 10e9 Active Endpoint Response Ep: 0b LQI: 123
2021-06-15 15:27:37.878 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 10e9 Active Endpoint Response Ep: f2 LQI: 123
2021-06-15 15:27:37.879 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 10e9 Request Simple Descriptor for Ep: 0b
2021-06-15 15:27:37.880 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 10e9 Request Simple Descriptor for Ep: f2
2021-06-15 15:27:39.092 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 10e9 Simple Descriptor Response EP: 0x0b LQI: 123
2021-06-15 15:27:39.092 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 10e9 ProfileID 0104
2021-06-15 15:27:39.092 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 10e9 ZDeviceID 010c
2021-06-15 15:27:39.092 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 10e9 Application Version 0001
2021-06-15 15:27:39.093 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 10e9 Cluster IN Count: 09
2021-06-15 15:27:39.093 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 10e9 Cluster In 1: 0000 (Basic)
2021-06-15 15:27:39.093 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 10e9 Cluster In 2: 0003 (Identify)
2021-06-15 15:27:39.093 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 10e9 Cluster In 3: 0004 (Groups)
2021-06-15 15:27:39.093 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 10e9 Cluster In 4: 0005 (Scenes)
2021-06-15 15:27:39.093 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 10e9 Cluster In 5: 0006 (On/Off)
2021-06-15 15:27:39.093 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 10e9 Cluster In 6: 0008 (Level Control)
2021-06-15 15:27:39.093 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 10e9 Cluster In 7: 1000 (Touchlink)
2021-06-15 15:27:39.093 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 10e9 Cluster In 8: fc02
2021-06-15 15:27:39.093 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 10e9 Cluster In 9: 0300 (Colour Control)
2021-06-15 15:27:39.093 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 10e9 Cluster OUT Count: 01
2021-06-15 15:27:39.093 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 10e9 Cluster Out 1: 0019 (Over-the-Air Upgrade)
2021-06-15 15:27:39.390 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 10e9 Simple Descriptor Response EP: 0xf2 LQI: 123
2021-06-15 15:27:39.391 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 10e9 ProfileID a1e0
2021-06-15 15:27:39.391 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 10e9 ZDeviceID 0061
2021-06-15 15:27:39.391 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 10e9 Application Version 0000
2021-06-15 15:27:39.391 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 10e9 Cluster IN Count: 00
2021-06-15 15:27:39.391 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 10e9 Cluster OUT Count: 01
2021-06-15 15:27:39.391 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 10e9 Cluster Out 1: 0021
2021-06-15 15:27:42.100 Status: Zigate: (Zigate) [1] NEW OBJECT: 10e9 Request Node Descriptor
2021-06-15 15:27:42.101 Status: Zigate: (Zigate) [1] NEW OBJECT: 10e9 Request Attribute for Cluster 0x0300 to get ColorMode
2021-06-15 15:27:47.080 Status: Zigate: (Zigate) [2] NEW OBJECT: 10e9 Request Attribute for Cluster 0x0300 to get ColorMode
2021-06-15 15:27:47.791 Status: buitenzitweer ingeschakeld
2021-06-15 15:27:48.339 Zigate: (Zigate) [ZiGateForwarder_16] Decode8030 - Bind response, Device: 10e9 Status: 00 MsgSequenceNumber: 0x66/102 i_sqn: 153
2021-06-15 15:27:48.339 Zigate: (Zigate) [ZiGateForwarder_16] Decode8030 - Set bind request to binded : nwkid 10e9 ep: 0b cluster: 0300
2021-06-15 15:27:48.342 Zigate: (Zigate) [ZiGateForwarder_16] ZigateRead - MsgType: 8011, MsgLength: 0008, MsgCRC: b9, Data: 0010e9000021f8, LQI: 0
2021-06-15 15:27:48.620 Zigate: (Zigate) [ZiGateForwarder_16] ZigateRead - MsgType: 8000, MsgLength: 0007, MsgCRC: 2b, Data: 0067003002f9, LQI: 0
2021-06-15 15:27:48.642 Zigate: (Zigate) [ZiGateForwarder_16] ZigateRead - MsgType: 8030, MsgLength: 0006, MsgCRC: 54, Data: 67000210e9, LQI: 126
2021-06-15 15:27:48.642 Zigate: (Zigate) [ZiGateForwarder_16] Decode8030 - Msgdata: 67000210e9, MsgLen: 10
2021-06-15 15:27:48.642 Zigate: (Zigate) [ZiGateForwarder_16] Decode8030 - Bind reponse for 10e9
2021-06-15 15:27:48.642 Zigate: (Zigate) [ZiGateForwarder_16] Decode8030 - Bind response, Device: 10e9 Status: 00 MsgSequenceNumber: 0x67/103 i_sqn: 154
2021-06-15 15:27:48.642 Zigate: (Zigate) [ZiGateForwarder_16] Decode8030 - Set bind request to binded : nwkid 10e9 ep: 0b cluster: 0000
2021-06-15 15:27:48.647 Zigate: (Zigate) [ZiGateForwarder_16] ZigateRead - MsgType: 8011, MsgLength: 0008, MsgCRC: b8, Data: 0010e9000021f9, LQI: 0
2021-06-15 15:27:48.924 Zigate: (Zigate) [ZiGateForwarder_16] ZigateRead - MsgType: 8000, MsgLength: 0007, MsgCRC: 3a, Data: 0067012001fa, LQI: 0
2021-06-15 15:27:48.941 Zigate: (Zigate) [ZiGateForwarder_16] ZigateRead - MsgType: 8120, MsgLength: 0008, MsgCRC: 44, Data: 6710e90b000600, LQI: 126
2021-06-15 15:27:48.942 Zigate: (Zigate) [ZiGateForwarder_16] Decode8120 - Configure reporting response : 6710e90b000600
2021-06-15 15:27:48.943 Zigate: (Zigate) [ZiGateForwarder_16] --> SQN: [67], SrcAddr: 10e9, SrcEP: 0b, ClusterID: 0006, Attribute: None Status: 00
2021-06-15 15:27:48.944 Zigate: (Zigate) [ZiGateForwarder_16] ------- - i_sqn: 155 e_sqn: 67
2021-06-15 15:27:48.944 Zigate: (Zigate) [ZiGateForwarder_16] ------- - Sqn matches for Attribute: 0000
2021-06-15 15:27:48.948 Zigate: (Zigate) [ZiGateForwarder_16] ZigateRead - MsgType: 8011, MsgLength: 0008, MsgCRC: 9d, Data: 0010e9010006fa, LQI: 0
2021-06-15 15:27:49.226 Zigate: (Zigate) [ZiGateForwarder_16] ZigateRead - MsgType: 8000, MsgLength: 0007, MsgCRC: 34, Data: 0068012001fb, LQI: 0
2021-06-15 15:27:49.240 Zigate: (Zigate) [ZiGateForwarder_16] ZigateRead - MsgType: 8120, MsgLength: 0008, MsgCRC: 45, Data: 6810e90b000800, LQI: 126
2021-06-15 15:27:49.240 Zigate: (Zigate) [ZiGateForwarder_16] Decode8120 - Configure reporting response : 6810e90b000800
2021-06-15 15:27:49.242 Zigate: (Zigate) [ZiGateForwarder_16] --> SQN: [68], SrcAddr: 10e9, SrcEP: 0b, ClusterID: 0008, Attribute: None Status: 00
2021-06-15 15:27:49.242 Zigate: (Zigate) [ZiGateForwarder_16] ------- - i_sqn: 156 e_sqn: 68
2021-06-15 15:27:49.243 Zigate: (Zigate) [ZiGateForwarder_16] ------- - Sqn matches for Attribute: 0000
2021-06-15 15:27:49.248 Zigate: (Zigate) [ZiGateForwarder_16] ZigateRead - MsgType: 8011, MsgLength: 0008, MsgCRC: 92, Data: 0010e9010008fb, LQI: 0
2021-06-15 15:27:49.528 Zigate: (Zigate) [ZiGateForwarder_16] ZigateRead - MsgType: 8000, MsgLength: 0007, MsgCRC: 32, Data: 0069012001fc, LQI: 0
2021-06-15 15:27:49.546 Zigate: (Zigate) [ZiGateForwarder_16] ZigateRead - MsgType: 8120, MsgLength: 000a, MsgCRC: cc, Data: 6910e90b030000088c, LQI: 123
2021-06-15 15:27:49.546 Zigate: (Zigate) [ZiGateForwarder_16] Decode8120 - Configure reporting response : 6910e90b030000088c
2021-06-15 15:27:49.548 Zigate: (Zigate) [ZiGateForwarder_16] --> SQN: [69], SrcAddr: 10e9, SrcEP: 0b, ClusterID: 0300, Attribute: 0008 Status: 8c
2021-06-15 15:27:49.549 Zigate: (Zigate) [ZiGateForwarder_16] Decode8120 - Configure Reporting response - ClusterID: 0300/0008, MsgSrcAddr: 10e9, MsgSrcEp:0b , Status: 8c
2021-06-15 15:27:49.552 Zigate: (Zigate) [ZiGateForwarder_16] ZigateRead - MsgType: 8011, MsgLength: 0008, MsgCRC: 9e, Data: 0010e9010300fc, LQI: 0
2021-06-15 15:27:49.828 Zigate: (Zigate) [ZiGateForwarder_16] ZigateRead - MsgType: 8000, MsgLength: 0007, MsgCRC: 10, Data: 006a010001fd, LQI: 0
2021-06-15 15:27:49.841 Zigate: (Zigate) [ZiGateForwarder_16] ZigateRead - MsgType: 8100, MsgLength: 000e, MsgCRC: 7f, Data: 6a10e90b000600000010000101, LQI: 126
2021-06-15 15:27:49.842 Zigate: (Zigate) [ZiGateForwarder_16] Decode8100 - idx: 26 Read Attribute Response: [10e9:0b] ClusterID: 0006 MsgSQN: 6a, i_sqn: 158, AttributeID: 0000 Status: 00 Type: 10 Size: 0001 ClusterData: >01<
2021-06-15 15:27:49.844 Zigate: (Zigate) [ZiGateForwarder_16] ReadCluster - 0006 - 10e9/0b AttrId: 0000 AttrType: 10 Attsize: 0001 Status: 00 AttrValue: 01
2021-06-15 15:27:49.845 Zigate: (Zigate) [ZiGateForwarder_16] ReadCluster - ClusterId=0006 - reception General: On/Off: 01
2021-06-15 15:27:49.848 Zigate: (Zigate) [ZiGateForwarder_16] ZigateRead - MsgType: 8011, MsgLength: 0008, MsgCRC: 9a, Data: 0010e9010006fd, LQI: 0
2021-06-15 15:27:50.129 Zigate: (Zigate) [ZiGateForwarder_16] ZigateRead - MsgType: 8000, MsgLength: 0007, MsgCRC: 12, Data: 006b010001fe, LQI: 0
2021-06-15 15:27:50.149 Zigate: (Zigate) [ZiGateForwarder_16] ZigateRead - MsgType: 8100, MsgLength: 000f, MsgCRC: 08, Data: 6b10e90b00064001002100020000, LQI: 123
2021-06-15 15:27:50.149 Zigate: (Zigate) [ZiGateForwarder_16] Decode8100 - idx: 28 Read Attribute Response: [10e9:0b] ClusterID: 0006 MsgSQN: 6b, i_sqn: 159, AttributeID: 4001 Status: 00 Type: 21 Size: 0002 ClusterData: >0000<
2021-06-15 15:27:50.151 Zigate: (Zigate) [ZiGateForwarder_16] ReadCluster - 0006 - 10e9/0b AttrId: 4001 AttrType: 21 Attsize: 0002 Status: 00 AttrValue: 0000
2021-06-15 15:27:50.152 Zigate: (Zigate) [ZiGateForwarder_16] ReadCluster - ClusterId=0006 - On Time Attr: 4001 Value: 0000
2021-06-15 15:27:50.155 Zigate: (Zigate) [ZiGateForwarder_16] ZigateRead - MsgType: 8011, MsgLength: 0008, MsgCRC: 99, Data: 0010e9010006fe, LQI: 0
2021-06-15 15:27:50.432 Zigate: (Zigate) [ZiGateForwarder_16] ZigateRead - MsgType: 8000, MsgLength: 0007, MsgCRC: 14, Data: 006c010001ff, LQI: 0
2021-06-15 15:27:50.444 Zigate: (Zigate) [ZiGateForwarder_16] ZigateRead - MsgType: 8100, MsgLength: 000f, MsgCRC: 0c, Data: 6c10e90b00064002002100020000, LQI: 123
2021-06-15 15:27:50.444 Zigate: (Zigate) [ZiGateForwarder_16] Decode8100 - idx: 28 Read Attribute Response: [10e9:0b] ClusterID: 0006 MsgSQN: 6c, i_sqn: 160, AttributeID: 4002 Status: 00 Type: 21 Size: 0002 ClusterData: >0000<
2021-06-15 15:27:50.446 Zigate: (Zigate) [ZiGateForwarder_16] ReadCluster - 0006 - 10e9/0b AttrId: 4002 AttrType: 21 Attsize: 0002 Status: 00 AttrValue: 0000
2021-06-15 15:27:50.447 Zigate: (Zigate) [ZiGateForwarder_16] ReadCluster - ClusterId=0006 - Off Wait Time Attr: 4002 Value: 0000
2021-06-15 15:27:50.450 Zigate: (Zigate) [ZiGateForwarder_16] ZigateRead - MsgType: 8011, MsgLength: 0008, MsgCRC: 98, Data: 0010e9010006ff, LQI: 0
2021-06-15 15:27:50.734 Zigate: (Zigate) [ZiGateForwarder_16] ZigateRead - MsgType: 8000, MsgLength: 0007, MsgCRC: ea, Data: 006d01000100, LQI: 0
2021-06-15 15:27:50.751 Zigate: (Zigate) [ZiGateForwarder_16] ZigateRead - MsgType: 8100, MsgLength: 000e, MsgCRC: bc, Data: 6d10e90b0008000000200001fe, LQI: 123
2021-06-15 15:27:50.752 Zigate: (Zigate) [ZiGateForwarder_16] Decode8100 - idx: 26 Read Attribute Response: [10e9:0b] ClusterID: 0008 MsgSQN: 6d, i_sqn: 161, AttributeID: 0000 Status: 00 Type: 20 Size: 0001 ClusterData: >fe<
2021-06-15 15:27:50.754 Zigate: (Zigate) [ZiGateForwarder_16] ReadCluster - 0008 - 10e9/0b AttrId: 0000 AttrType: 20 Attsize: 0001 Status: 00 AttrValue: fe
2021-06-15 15:27:50.754 Zigate: (Zigate) [ZiGateForwarder_16] ReadCluster - ClusterID: 0008 Addr: 10e9 MsgAttrID: 0000 MsgAttType: 20 MsgAttSize: 0001 MsgClusterData: fe
2021-06-15 15:27:50.754 Zigate: (Zigate) [ZiGateForwarder_16] ReadCluster - ClusterId=0008 - 10e9/0b Level Control: fe
2021-06-15 15:27:50.755 Zigate: (Zigate) UpdateDevice - (Zigate - ColorControlRGBWW-0017880109796dad-0b) 1:100
2021-06-15 15:27:50.777 Zigate: (Zigate) [ZiGateForwarder_16] ZigateRead - MsgType: 8011, MsgLength: 0008, MsgCRC: 69, Data: 0010e901000800, LQI: 0
2021-06-15 15:27:51.037 Zigate: (Zigate) [ZiGateForwarder_16] ZigateRead - MsgType: 8000, MsgLength: 0007, MsgCRC: e8, Data: 006e01000101, LQI: 0
2021-06-15 15:27:51.048 Zigate: (Zigate) [ZiGateForwarder_16] ZigateRead - MsgType: 8100, MsgLength: 000d, MsgCRC: 11, Data: 6e10e90b0300000086ff0000, LQI: 123
2021-06-15 15:27:51.049 Zigate: (Zigate) [ZiGateForwarder_16] Decode8100 - idx: 18 Read Attribute Response: [10e9:0b] status: 86 -> ff0000
2021-06-15 15:27:51.049 Zigate: (Zigate) [ZiGateForwarder_16] Decode8100 - idx: 24 Read Attribute Response: [10e9:0b] ClusterID: 0300 MsgSQN: 6e, i_sqn: 162, AttributeID: 0000 Status: 86 Type: Size: ClusterData: ><
2021-06-15 15:27:51.051 Zigate: (Zigate) [ZiGateForwarder_16] ReadCluster - 0300 - 10e9/0b AttrId: 0000 AttrType: Attsize: Status: 86 AttrValue:
2021-06-15 15:27:51.051 Zigate: (Zigate) [ZiGateForwarder_16] ReadCluster - Status 86 for addr: 10e9/0b on cluster/attribute 0300/0000
2021-06-15 15:27:51.056 Zigate: (Zigate) [ZiGateForwarder_16] ZigateRead - MsgType: 8011, MsgLength: 0008, MsgCRC: 63, Data: 0010e901030001, LQI: 0
2021-06-15 15:27:51.339 Zigate: (Zigate) [ZiGateForwarder_16] ZigateRead - MsgType: 8000, MsgLength: 0007, MsgCRC: ea, Data: 006f01000102, LQI: 0
2021-06-15 15:27:51.351 Zigate: (Zigate) [ZiGateForwarder_16] ZigateRead - MsgType: 8100, MsgLength: 000d, MsgCRC: 11, Data: 6f10e90b0300000186ff0000, LQI: 123
2021-06-15 15:27:51.352 Zigate: (Zigate) [ZiGateForwarder_16] Decode8100 - idx: 18 Read Attribute Response: [10e9:0b] status: 86 -> ff0000
2021-06-15 15:27:51.352 Zigate: (Zigate) [ZiGateForwarder_16] Decode8100 - idx: 24 Read Attribute Response: [10e9:0b] ClusterID: 0300 MsgSQN: 6f, i_sqn: 163, AttributeID: 0001 Status: 86 Type: Size: ClusterData: ><
2021-06-15 15:27:51.354 Zigate: (Zigate) [ZiGateForwarder_16] ReadCluster - 0300 - 10e9/0b AttrId: 0001 AttrType: Attsize: Status: 86 AttrValue:
2021-06-15 15:27:51.354 Zigate: (Zigate) [ZiGateForwarder_16] ReadCluster - Status 86 for addr: 10e9/0b on cluster/attribute 0300/0001
2021-06-15 15:27:51.357 Zigate: (Zigate) [ZiGateForwarder_16] ZigateRead - MsgType: 8011, MsgLength: 0008, MsgCRC: 60, Data: 0010e901030002, LQI: 0
2021-06-15 15:27:51.639 Zigate: (Zigate) [ZiGateForwarder_16] ZigateRead - MsgType: 8000, MsgLength: 0007, MsgCRC: f4, Data: 007001000103, LQI: 0
2021-06-15 15:27:51.656 Zigate: (Zigate) [ZiGateForwarder_16] ZigateRead - MsgType: 8100, MsgLength: 000f, MsgCRC: 35, Data: 7010e90b03000003002100027514, LQI: 123
2021-06-15 15:27:51.657 Zigate: (Zigate) [ZiGateForwarder_16] Decode8100 - idx: 28 Read Attribute Response: [10e9:0b] ClusterID: 0300 MsgSQN: 70, i_sqn: 164, AttributeID: 0003 Status: 00 Type: 21 Size: 0002 ClusterData: >7514<
2021-06-15 15:27:51.659 Zigate: (Zigate) [ZiGateForwarder_16] ReadCluster - 0300 - 10e9/0b AttrId: 0003 AttrType: 21 Attsize: 0002 Status: 00 AttrValue: 7514
2021-06-15 15:27:51.659 Zigate: (Zigate) [ZiGateForwarder_16] ReadCluster0300 - CurrentX: 29972
2021-06-15 15:27:51.662 Zigate: (Zigate) [ZiGateForwarder_16] ZigateRead - MsgType: 8011, MsgLength: 0008, MsgCRC: 61, Data: 0010e901030003, LQI: 0
2021-06-15 15:27:51.942 Zigate: (Zigate) [ZiGateForwarder_16] ZigateRead - MsgType: 8000, MsgLength: 0007, MsgCRC: f2, Data: 007101000104, LQI: 0
2021-06-15 15:27:51.971 Zigate: (Zigate) [ZiGateForwarder_16] ZigateRead - MsgType: 8100, MsgLength: 000f, MsgCRC: cd, Data: 7110e90b030000040021000268f7, LQI: 123
2021-06-15 15:27:51.972 Zigate: (Zigate) [ZiGateForwarder_16] Decode8100 - idx: 28 Read Attribute Response: [10e9:0b] ClusterID: 0300 MsgSQN: 71, i_sqn: 165, AttributeID: 0004 Status: 00 Type: 21 Size: 0002 ClusterData: >68f7<
2021-06-15 15:27:51.974 Zigate: (Zigate) [ZiGateForwarder_16] ReadCluster - 0300 - 10e9/0b AttrId: 0004 AttrType: 21 Attsize: 0002 Status: 00 AttrValue: 68f7
2021-06-15 15:27:51.975 Zigate: (Zigate) [ZiGateForwarder_16] ReadCluster0300 - CurrentY: 26871
2021-06-15 15:27:51.977 Zigate: (Zigate) [ZiGateForwarder_16] ZigateRead - MsgType: 8011, MsgLength: 0008, MsgCRC: 66, Data: 0010e901030004, LQI: 0
2021-06-15 15:27:52.244 Zigate: (Zigate) [ZiGateForwarder_16] ZigateRead - MsgType: 8000, MsgLength: 0007, MsgCRC: f0, Data: 007201000105, LQI: 0
2021-06-15 15:27:52.256 Zigate: (Zigate) [ZiGateForwarder_16] ZigateRead - MsgType: 8100, MsgLength: 000f, MsgCRC: 3d, Data: 7210e90b0300000700210002016e, LQI: 123
2021-06-15 15:27:52.257 Zigate: (Zigate) [ZiGateForwarder_16] Decode8100 - idx: 28 Read Attribute Response: [10e9:0b] ClusterID: 0300 MsgSQN: 72, i_sqn: 166, AttributeID: 0007 Status: 00 Type: 21 Size: 0002 ClusterData: >016e<
2021-06-15 15:27:52.259 Zigate: (Zigate) [ZiGateForwarder_16] ReadCluster - 0300 - 10e9/0b AttrId: 0007 AttrType: 21 Attsize: 0002 Status: 00 AttrValue: 016e
2021-06-15 15:27:52.259 Zigate: (Zigate) [ZiGateForwarder_16] ReadCluster0300 - ColorTemperatureMireds: 366
2021-06-15 15:27:52.262 Zigate: (Zigate) [ZiGateForwarder_16] ZigateRead - MsgType: 8011, MsgLength: 0008, MsgCRC: 67, Data: 0010e901030005, LQI: 0
2021-06-15 15:27:52.545 Zigate: (Zigate) [ZiGateForwarder_16] ZigateRead - MsgType: 8000, MsgLength: 0007, MsgCRC: f2, Data: 007301000106, LQI: 0
2021-06-15 15:27:52.581 Zigate: (Zigate) [ZiGateForwarder_16] ZigateRead - MsgType: 8100, MsgLength: 000e, MsgCRC: 4d, Data: 7310e90b030000080030000102, LQI: 123
2021-06-15 15:27:52.582 Zigate: (Zigate) [ZiGateForwarder_16] Decode8100 - idx: 26 Read Attribute Response: [10e9:0b] ClusterID: 0300 MsgSQN: 73, i_sqn: 167, AttributeID: 0008 Status: 00 Type: 30 Size: 0001 ClusterData: >02<
2021-06-15 15:27:52.585 Zigate: (Zigate) [ZiGateForwarder_16] ReadCluster - 0300 - 10e9/0b AttrId: 0008 AttrType: 30 Attsize: 0001 Status: 00 AttrValue: 02
2021-06-15 15:27:52.586 Zigate: (Zigate) [ZiGateForwarder_16] readCluster - 0300 - 10e9/0b Color Mode: 0008 30 0001 02
2021-06-15 15:27:52.587 Zigate: (Zigate) [ZiGateForwarder_16] ZigateRead - MsgType: 8011, MsgLength: 0008, MsgCRC: 50, Data: 0010e901030006, LQI: 52
2021-06-15 15:27:52.848 Zigate: (Zigate) [ZiGateForwarder_16] ZigateRead - MsgType: 8000, MsgLength: 0007, MsgCRC: f4, Data: 007401000107, LQI: 0
2021-06-15 15:27:52.866 Zigate: (Zigate) [ZiGateForwarder_16] ZigateRead - MsgType: 8100, MsgLength: 000f, MsgCRC: 6c, Data: 7410e90b0300401000210002016e, LQI: 123
2021-06-15 15:27:52.867 Zigate: (Zigate) [ZiGateForwarder_16] Decode8100 - idx: 28 Read Attribute Response: [10e9:0b] ClusterID: 0300 MsgSQN: 74, i_sqn: 168, AttributeID: 4010 Status: 00 Type: 21 Size: 0002 ClusterData: >016e<
2021-06-15 15:27:52.868 Zigate: (Zigate) [ZiGateForwarder_16] ReadCluster - 0300 - 10e9/0b AttrId: 4010 AttrType: 21 Attsize: 0002 Status: 00 AttrValue: 016e
2021-06-15 15:27:52.869 Zigate: (Zigate) [ZiGateForwarder_16] readCluster - 0300 - 10e9/0b Attribute: 4010 21 0002 016e
2021-06-15 15:27:52.872 Zigate: (Zigate) [ZiGateForwarder_16] ZigateRead - MsgType: 8011, MsgLength: 0008, MsgCRC: 65, Data: 0010e901030007, LQI: 0
2021-06-15 15:27:54.079 Zigate: (Zigate) [ZiGateForwarder_16] ReadCluster - 0000 - 10e9/0b AttrId: 0001 AttrType: 20 Attsize: 0001 Status: 00 AttrValue: 02
2021-06-15 15:27:54.080 Zigate: (Zigate) [ZiGateForwarder_16] ReadCluster - Application version: 2
2021-06-15 15:27:54.086 Zigate: (Zigate) [ZiGateForwarder_16] ZigateRead - MsgType: 8011, MsgLength: 0008, MsgCRC: 6a, Data: 0010e90100000b, LQI: 0
2021-06-15 15:27:54.358 Zigate: (Zigate) [ZiGateForwarder_16] ZigateRead - MsgType: 8000, MsgLength: 0007, MsgCRC: f2, Data: 00790100010c, LQI: 0
2021-06-15 15:27:54.368 Zigate: (Zigate) [ZiGateForwarder_16] ZigateRead - MsgType: 8100, MsgLength: 000e, MsgCRC: 5d, Data: 7910e90b000000020020000101, LQI: 123
2021-06-15 15:27:54.369 Zigate: (Zigate) [ZiGateForwarder_16] Decode8100 - idx: 26 Read Attribute Response: [10e9:0b] ClusterID: 0000 MsgSQN: 79, i_sqn: 173, AttributeID: 0002 Status: 00 Type: 20 Size: 0001 ClusterData: >01<
2021-06-15 15:27:54.370 Zigate: (Zigate) [ZiGateForwarder_16] ReadCluster - 0000 - 10e9/0b AttrId: 0002 AttrType: 20 Attsize: 0001 Status: 00 AttrValue: 01
2021-06-15 15:27:54.371 Zigate: (Zigate) [ZiGateForwarder_16] ReadCluster - Stack version: 1
2021-06-15 15:27:54.374 Zigate: (Zigate) [ZiGateForwarder_16] ZigateRead - MsgType: 8011, MsgLength: 0008, MsgCRC: 6d, Data: 0010e90100000c, LQI: 0
2021-06-15 15:27:54.659 Zigate: (Zigate) [ZiGateForwarder_16] ZigateRead - MsgType: 8000, MsgLength: 0007, MsgCRC: f0, Data: 007a0100010d, LQI: 0
2021-06-15 15:27:54.672 Zigate: (Zigate) [ZiGateForwarder_16] ZigateRead - MsgType: 8100, MsgLength: 000e, MsgCRC: 5d, Data: 7a10e90b000000030020000103, LQI: 123
2021-06-15 15:27:54.672 Zigate: (Zigate) [ZiGateForwarder_16] Decode8100 - idx: 26 Read Attribute Response: [10e9:0b] ClusterID: 0000 MsgSQN: 7a, i_sqn: 174, AttributeID: 0003 Status: 00 Type: 20 Size: 0001 ClusterData: >03<
2021-06-15 15:27:54.674 Zigate: (Zigate) [ZiGateForwarder_16] ReadCluster - 0000 - 10e9/0b AttrId: 0003 AttrType: 20 Attsize: 0001 Status: 00 AttrValue: 03
2021-06-15 15:27:54.675 Zigate: (Zigate) [ZiGateForwarder_16] ReadCluster - 0x0000 - Hardware version: 3
2021-06-15 15:27:54.677 Zigate: (Zigate) [ZiGateForwarder_16] ZigateRead - MsgType: 8011, MsgLength: 0008, MsgCRC: 6c, Data: 0010e90100000d, LQI: 0
2021-06-15 15:27:54.961 Zigate: (Zigate) [ZiGateForwarder_16] ZigateRead - MsgType: 8000, MsgLength: 0007, MsgCRC: f2, Data: 007b0100010e, LQI: 0
2021-06-15 15:27:54.976 Zigate: (Zigate) [ZiGateForwarder_16] ZigateRead - MsgType: 8100, MsgLength: 0015, MsgCRC: 29, Data: 7b10e90b00000006004200083230323030333237, LQI: 126
2021-06-15 15:27:54.976 Zigate: (Zigate) [ZiGateForwarder_16] Decode8100 - idx: 40 Read Attribute Response: [10e9:0b] ClusterID: 0000 MsgSQN: 7b, i_sqn: 175, AttributeID: 0006 Status: 00 Type: 42 Size: 0008 ClusterData: >3230323030333237<
2021-06-15 15:27:54.982 Zigate: (Zigate) [ZiGateForwarder_16] ReadCluster - 0000 - 10e9/0b AttrId: 0006 AttrType: 42 Attsize: 0008 Status: 00 AttrValue: 3230323030333237
2021-06-15 15:27:54.984 Zigate: (Zigate) [ZiGateForwarder_16] ZigateRead - MsgType: 8011, MsgLength: 0008, MsgCRC: 6f, Data: 0010e90100000e, LQI: 0
2021-06-15 15:27:55.264 Zigate: (Zigate) [ZiGateForwarder_16] ZigateRead - MsgType: 8000, MsgLength: 0007, MsgCRC: f4, Data: 007c0100010f, LQI: 0
2021-06-15 15:27:55.277 Zigate: (Zigate) [ZiGateForwarder_16] ZigateRead - MsgType: 8100, MsgLength: 000e, MsgCRC: 4d, Data: 7c10e90b000000070030000101, LQI: 123
Re: Zigate Hue gu10 white ambiance
I was thinking, make a group for this moment. They work, but only the false color.
That was a mistake.... in my other groups some lights where removed.
Making a group in domoticz is not working, there i have 3 chooses of light.
- firefox_2021-06-19_22-53-59.jpg (78.72 KiB) Viewed 1145 times
I know that the Hue GU10 doesn't work on your end, but from what I see this should work, and for now I only see a way to purchase one to make the test on my end.
Is that one you are refereing : https://www.amazon.co.uk/Philips-Ambian ... rzigbee-21 ?Domoticz latest stable, Intel NUC, Proxmox, Zigate, RFLink, Kaku switches, Ikea lights, Xiaomi sensors, Honeywell smoke detectors, Yeelight, Shelly, Slave Domoticz PI 3B+, Node-Red, Espeasy.
