Growatt shows minus value since update of domoticz
mvanrijnbach
Re: Growatt shows minus value since update of domoticz
Post by mvanrijnbach »
Hi everybody,
since last Tuesday my growatt inverter only displays zero values in Domoticz. Nothing has changed, so this puzzled me. I found this thread and I updated the script according to sincze's suggestions. However, now my growatt device is colored 'red' in Domoticz, so it is not updating values at all anymore. Anybody experienced this before or do you have suggestions how to fix it?
Best regards, Michiel.
sincze
Domoticz version: 2024.4
Post by sincze »
That is weird indeed script and plugin are working here.
Is the URL https instead of http ??.
Pass2php
USB: RFXCom, ZWave, Sonoff 3
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Solar: Omnik, PVOutput
Sensors: You name it I got 1.
mvanrijnbach
Hi sincze,
the URL is: http://server-api.growatt.com/newLoginAPI.do
I didn't change the script until the zero values started to show up. I made the changes you suggested.
sincze
Post by sincze »
Ok, if the pass2php is now modified it should work without the negative values.
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
mvanrijnbach
I didn't have negative values, but zero values from one day to another. Now I updated the script according to your suggestions in this thread, but now the inverter does not update in Domoticz at all. I'll attach the updated script in this post, maybe you'll the problem right away. BTW, what is the purpose of the growatt cookie?
growatt-invertertest.txt
(7.92 KiB) Downloaded 80 times
sincze
Post by sincze »
Cookies are used to prove a successful login.
You present the cookie... if valid we can request the data.
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
mvanrijnbach
With the old script the login was successful (I could also see this in the log). With the adjusted script I do not receive any values.
growatt.txt
(332 Bytes) Downloaded 47 times
mvanrijnbach
If I return to the old script (the one from github) the growatt domoticz device is updated again, but with zero values again.
mvanrijnbach
Has anyone experienced this recently as well?
petervandersman
Post by petervandersman »
Yeap, same here... zeros since mid June. $Result seems to be empty...
PieterS
Domoticz version: 2024.7
Post by PieterS »
Just a tip for an alternative and no dependency from external servers:
I use Grot to read the data from the inverter and emulates the servers of Growatt in China. It runs (if you like) in Docker and sends for example to PVoutput.org and/or via MQTT and Node-RED to Domoticz or Influxdb and so on. This is the result in Domoticz:
Have a look at https://github.com/johanmeijer/grott. Just very satisfied!
Synology with Domoticz build (V2024.7) in Docker
mvanrijnbach
@petervandersman, did you ever find out why this happened? The script hasn't changed. I'm not a php expert, but there must be a way to debug the script.
@PieterS, I'll take a look at this. I have no idea what you meant by all of that, I guess I can find some info about it on the internet.
mvanrijnbach
Problem solved.
I took the latest script from incze's github and now it works again. Apparently, there have been some changes in the script with respect to the version I had. As far I can see the login form has changed on the 16th of June, so that's probably why I started seeing zeros since mid June:
define('LOGIN_FORM_URL', 'http://server-api.growatt.com/newLoginAPI.do'); // URL of the login form.
define('LOGIN_ACTION_URL', 'http://server-api.growatt.com/newLoginAPI.do'); // Login action URL. Sometimes, this is the same URL as the login form.
became
define('LOGIN_FORM_URL', 'https://server-api.growatt.com/newTwoLoginAPI.do'); // 16-06-2022: URL of the login form.
define('LOGIN_ACTION_URL', 'https://server-api.growatt.com/newTwoLoginAPI.do'); // 16-06-2022: Login action URL. Sometimes, this is the same URL as the login form.
There are some other changes in the script, but this must have been the culprit.
rick8245
Post by rick8245 »
Hi Michiel,
I just modified the script and indeed you found the solution. It now works great again.
Thanks for sharing your solution.
Regards, Rick
