Page 2 of 2
Re: Definition stationclock in css
Posted: Friday 11 December 2020 14:13
by madpatrick
The time with Flipclock stands still in the Standby screen.
In the normal screens it flips
Posted: Friday 11 December 2020 14:25
by Lokonli
The tragedy of standby ...
I'll check :)
Posted: Friday 11 December 2020 14:28
by madpatrick
hahaha...
The standard 'clock' is working in the standby screen.
By the way. Now the time stottering. hangs for a few seconds and then go's for and then hangs....
Is it possible to center the station clock by default in the middle of the block?
Posted: Friday 11 December 2020 14:39
by Enz0jacco
Lokonli wrote: Friday 11 December 2020 14:25 The tragedy of standby ...
I'll check :)
now that we're talking about standby, is it possible to adjust the background in a color instead of an image?
tried a lot in css but none are working:(
Posted: Friday 11 December 2020 23:04
by Lokonli
Enz0jacco wrote: Friday 11 December 2020 14:39
I'll check :)
For the complete standby screen?
Add the following to custom.css:
.screenstandby {
    background-color: red !important
Posted: Saturday 12 December 2020 18:23
by madpatrick
Is it possible to create white dials ?
My background is dark so the dial are now visible
Posted: Saturday 12 December 2020 21:24
by Lokonli
madpatrick wrote: Saturday 12 December 2020 18:23 Is it possible to create white dials ?
Currently it's not supported, but it's not too difficult to add.
Currently, stationclock is constructed with the following color settings:
	// clock colors
	this.hourHandColor     = 'rgb(0,0,0)';
	this.minuteHandColor   = 'rgb(0,0,0)';
	this.secondHandColor   = 'rgb(200,0,0)';
I'll add it to the list.
Posted: Sunday 13 December 2020 18:43
by Lokonli
madpatrick wrote: Friday 11 December 2020 14:13 The time with Flipclock stands still in the Standby screen.
I don't see issues on my system.
What kind of system do you use for Dashticz?
Do you have more content on the standby screen?
Could you test with flipclock only?
Posted: Monday 14 December 2020 19:31
by madpatrick
Not sure what happened, but now it working normally.
I'm using a Sumsung tablet with Full Remote Browser
The content i'm using are : Clock, Rain forecast and garbage
Posted: Thursday 17 December 2020 22:36
by Lokonli
Lokonli wrote: Thursday 10 December 2020 19:42
Next addition will be - CSS Variable-Powered Clock by Emily Hayman (2 votes)
As promised, the hayman clock:
Add 'haymanclock' to a column, or define a custom block as follows:
blocks['myclock'] = {
   type: 'haymanclock'
I can still adapt the styling a bit. If needed I can add some additional configuration parameters.
Next clock requires at least 3 votes :)
Posted: Thursday 17 December 2020 23:01
by Enz0jacco
That’s a pity not many people are interested I guess:p
Thnx for the effort!
Sent from my iPad using Tapatalk
Posted: Friday 18 December 2020 7:29
by Chris12
Lokonli wrote: Thursday 17 December 2020 22:36
The "SVG Clock UI" had already 2 votes... is that one added as well?
Posted: Friday 18 December 2020 10:41
by Chris12
madpatrick wrote: Friday 11 December 2020 14:28 Is it possible to center the station clock by default in the middle of the block?
Did you found a sollution for this?
My standby-screen is a single column (width 12), in which I define the weather_own and a clock.
the weather_owm, is full size on the top part of the screen, but I can get the (flip)clock to be as big as the complete screen as well.
Posted: Friday 18 December 2020 15:25
by Enz0jacco
Chris12 wrote: Friday 18 December 2020 10:41
this is what I did with my stationclock
.standby .stationclock {
	display: flex !important;
	justify-content: center !important;
	align-items: center !important;
	background-color: rgb(0,0,0); !important;
	height: 800px !important; }
Posted: Friday 18 December 2020 17:36
by madpatrick
is did the same as Enz0jacco.
Put weather_own and the clock in 2 different blocks.
Posted: Friday 18 December 2020 18:48
by Chris12
Enz0jacco wrote: Friday 18 December 2020 15:25
Ok I give this a try as well for the normal clock.
Posted: Saturday 19 December 2020 11:03
by madpatrick
   type: 'haymanclock'
Is it possible to change the font color ?
Posted: Saturday 19 December 2020 13:25
by madpatrick
I've found out that this is working
.haymanclock .clock-day:before 		{font-weight: bold !important; color: rgba(168, 168, 168, .6) !important}
.haymanclock .clock-hours:before	{font-weight: bold !important; color: rgba(168, 168, 168, 1) !important}
.haymanclock .clock-minutes:before	{font-weight: bold !important; color: rgba(168, 168, 168, 1) !important}
.haymanclock .clock-seconds:before 	{font-weight: bold !important; color: rgba(168, 168, 168, 1) !important}
.haymanclock .clock-label		{color: rgba(255,255,0,.30) !important;font-weight: bold}
