Page 2 of 4
Re: Lidl now also sells Zigbee smarthome devices
Posted: Wednesday 02 December 2020 16:26
by EddyG
Some time ago a nice GUI was introduced in the Zigbee2MQTT environment.
It is configured in the configuration.yaml like
experimental:
output: json
new_api: true
frontend:
port: 8081
In this case port 8081 is used, but you can use any free port, see zigbee2MQTT doc.
Under Settings -> About you can find the info from my screenshot.
In your case zigbee2MQTT is not started see error, so you might do some debug logging to find out why.
In the configuration.yaml you have to use the right USB port.
Posted: Wednesday 02 December 2020 16:50
by BertB
EddyG wrote: Wednesday 02 December 2020 16:26
experimental:
output: json
new_api: true
frontend:
port: 8081
Thank you, but I am a bit confused here, as I connected the LIDL gateway via IP. Is that wrong?
Posted: Wednesday 02 December 2020 18:23
by EddyG
How do you connect Lidl gateway via IP, what hardware type?
Posted: Wednesday 02 December 2020 19:16
by Melissen
In the log (sudo journalctl -u zigbee2mqtt.service -f) the motion sensor TY0202 shows up like this:
dec 02 18:51:12 raspberrypi npm[13388]: Zigbee2MQTT:info 2020-12-02 18:51:12: MQTT publish: topic 'zigbee2mqtt/MotionSensor_Z001', payload '{"battery_low":false,"linkquality":0,"occupancy":true,"tamper":false}'
dec 02 18:51:13 raspberrypi npm[13388]: Zigbee2MQTT:info 2020-12-02 18:51:13: MQTT publish: topic 'zigbee2mqtt/MotionSensor_Z001', payload '{"battery_low":false,"linkquality":0,"occupancy":true,"tamper":true}'
But it doesn't show up in Domoticz. How can I add this device to Domoticz?
Which steps do I have to make, to get it work?
Or is it already added in the last update?
I'm currently using this version of Domoticz:
Version: 2020.2
Build Hash: b63341bc0
Compile Date: 2020-04-26 13:47:55
dzVents Version: 3.0.2
Python Version: 3.7.3 (default, Dec 20 2019, 18:57:59) [GCC 8.3.0]
Posted: Wednesday 02 December 2020 19:30
Posted: Wednesday 02 December 2020 19:31
by EddyG
I suppose that it might be a different brand, because in the plugin under adaptors/cr the TY0202 motionsensor is present.
A lot if not all of the Lidl devices are not (yet) implemented in the plugin see:
https://github.com/stas-demydiuk/domoti ... gin/issues
If it is not implemented in the plugin then you could go the node-red way.
Posted: Wednesday 02 December 2020 19:44
by BertB
EddyG wrote: Wednesday 02 December 2020 18:23
Like this
pi@DOMOX:~/domoticz $ sudo nano /opt/zigbee2mqtt/data/configuration.yaml
GNU nano 3.2 /opt/zigbee2mqtt/data/configuration.yaml
# Home Assistant integration (MQTT discovery)
homeassistant: false
# allow new devices to join
permit_join: true
# MQTT settings
mqtt:
# MQTT base topic for zigbee2mqtt MQTT messages
base_topic: zigbee2mqtt
# MQTT server URL
server: 'mqtt://localhost'
# MQTT server authentication, uncomment if required:
# user: my_user
# password: my_password
# Serial settings
serial:
# Location of CC2531 USB sniffer
port: 'tcp://ip adress of the gateway:6668'
experimental:
output: json
new_api: true
frontend:
port: 8081
Posted: Wednesday 02 December 2020 19:54
by EddyG
It asks for the USB port and not an IP-address
# Serial settings
serial:
With these items does zigbee2MQTT work:
https://www.zigbee2mqtt.io/getting_star ... _need.html
and
https://www.zigbee2mqtt.io/information/ ... pters.html
Posted: Wednesday 02 December 2020 20:05
by BertB
Right. So the story so far is, that the lidl gateway does not work with domoticz.
Posted: Wednesday 02 December 2020 21:22
From
https://community.home-assistant.io/t/s ... /243561/86
MattWestb from the Tasmota community pointed out that definitely is just a rebranded version of the standard Tuya TYGWZ-01 Zigbee Smart Life Gateway (TYGWZ01) hardware in a other enclosure so that means that the FCC has more pictures of the board here including those without that metal casing:
https://fccid.io/2ANDL-TYGWZ01
https://fccid.io/2ANDL-TYZS4
https://zigbeealliance.org/zigbee_produ ... t-gateway/
As can see it has unfortunately not an ESP8266 or ESP32 WiFi SoC but instead that RTL8196E is the WiFi/MCU SoC from Realtek running Linux as its operating system, and underneath that metal housing is only the Zigbee chip from Silicon Labs which is an EFR32 Series 1 (previous generation) thus similar to that what is on the Sonoff ZBBridge by ITead though it features an EFR32 Series 2 (newest generation) of Zigbee SoC.
Regardless it using RTL8196E WiFi/MCU chipset instead of ESP8266/ESP32 means no support for Tasmota.
Posted: Thursday 03 December 2020 9:20
by EddyG
BertB wrote: Wednesday 02 December 2020 20:05
But the good story is that eventually the devices of Lidl will work with zigbee2MQTT.
And most of them already do. Now it is waiting for the support in the zigbee plugin.
Posted: Thursday 03 December 2020 9:29
by EdwinK
So it should also work with Conbee?
Posted: Thursday 03 December 2020 9:47
EdwinK wrote: Thursday 03 December 2020 9:29
Check with the conbee/deconz plugin
https://github.com/Smanar/Domoticz-deCONZ
Posted: Thursday 03 December 2020 11:48
by qba1990
felix63 wrote: Saturday 28 November 2020 23:21
Bigted wrote: Saturday 28 November 2020 19:47
felix63 wrote: Saturday 28 November 2020 19:38
So I am left with two issues:
- why are no devices created in domoticz for the devices that zigbee2mqtt recognizes?
The Domoticz plugin for Zigbee2MQTT has to support the device, in addition to being supported by Zigbee2MQTT
I added the following line to /domoticz/plugins/zigbee2mqtt/adapters/tuya/__init__.py
'TS011F': OnOffSwitchAdapter, # TuYa Smart Plug
add that worked for the Smart Plug.
Update:
zigbee2mqtt 1.16.1-dev supports Lidl devices as Silvercrest. And with some tinkering to the zigbee2mqtt plugin I can now switch all the outlets on both devices
Thank You that was simple and genius
. I wouldn't dig there without Your help. Thank You!
Posted: Thursday 03 December 2020 13:09
by tonbor
tonbor wrote: Saturday 28 November 2020 14:45
Anybody succeded in connecting this lidl silvercrest hub with Domoticz?
Did I buy it in vain, anybody succeded in connecting the wired hub to domoticz?
Posted: Thursday 03 December 2020 14:42
by kiddigital
tonbor wrote:tonbor wrote: Saturday 28 November 2020 14:45
Haven’t tried the hub, but the smart plug works fine in combination with a Hue bridge. And thus also with Domoticz.
Domoticz is capable of talking/understanding the Hue bridge but I doubt that the Lidl hub talks exactly the same. So a separate ‘hardware’ module has to be developed for Domoticz to understand/interact with the Lidl hub.
The same applies btw to for example the Ikea (zigbee) hub. Although all these hubs talks Zigbee (3.0) at one-end, the other end (ethernet wire side) seem to have different interfaces.
Posted: Thursday 03 December 2020 16:13
by BertB
EddyG wrote: Thursday 03 December 2020 9:20
True, but now I have to decide to buy an USB Zigbee device.
Can you recommend one?
Posted: Thursday 03 December 2020 16:35
by Thorgal789
Yep some lidl device are working on conbee.
ATM I m making the integration for the xmas LED string support in domoticz >
https://github.com/Smanar/Domoticz-deCONZ/issues/78 (need special widget to manage effect)
Posted: Thursday 03 December 2020 17:20
by EddyG
If you are a hobbyist by a Texas Instruments CC2538 with CC2592 RF Amplifier or Texas Instruments LAUNCHXL-CC1352P-2
I use the latter.
If not a hobbyist then buy a commercial one. Look here
https://www.zigbee2mqtt.io/information/ ... pters.html and look at the specs.
My first adaptor was a Texas Instruments CC2531 but that one was not powerful enough for me.
Posted: Thursday 03 December 2020 19:17
by Pacman42
Has anyone managed to get the colors working on the RGB E27 LED?
I get them to work in Phosconn App (Conbee), but the RGB controls are not working from Domoticz. Any ideas?
Perhaps a problem with the Python plugin?
