Went out to buy a LIDL Smart Plug and a Smart USB Extension Lead (power strip with 3 outlets). Want to include them in my setup with Domoticz Version: 2020.2 when using zigbee2mqtt 1.16.1. Both devices show up as a single TuYa TS011F in Zigbee2MQTT.
- Schermafbeelding 2020-11-28 om 19.31.39.png (79.26 KiB) Viewed 26085 times
I can also see them using zigbee2mqtt in domoticz.
- Schermafbeelding 2020-11-28 om 19.29.10.png (59.58 KiB) Viewed 26085 times
However no devices are created in Domoticz. Creating a group and adding the Smart Plug to this group I do get a switch in Domoticz. But this should not be necessary. For the Smart USB Extension Lead this has the effect that I can only switch the first of the three outlets through domoticz. If I push the button on the power plug itself it switches on all three of the outlets.
So I am left with two issues:
- why are no devices created in domoticz for the devices that zigbee2mqtt recognizes?
- how can I get the power block configured that it shows up as 3 separate switches?
