Page 2 of 4
Re: Dashticz - Module - 112 Meldingen (Dutch)
Posted: Thursday 19 March 2020 19:58
by PietjePuck
Change
columns[1]['blocks'] = ['alarmmeldingen']
To
columns[1]['blocks'] = [alarmmeldingen]
Posted: Thursday 19 March 2020 19:59
by Lokonli
Define your block as follows:
blocks['alarmmeldingen'] = {
  rss: 'https://www.alarmeringen.nl/feeds/region/rotterdam-rijnmond.rss',
  filter: 'Poortugaal,Rhoon,Hoogvliet,Traumaheli,Pernis',
  show_lastupdate:true,
  width:12,
  interval: 180,
  results: 5}
(or as what PietjePuck is proposing)
city has been renamed to filter
Posted: Thursday 19 March 2020 20:28
by HansieNL
Don't know what changed, but in the latest beta it's working :D
Posted: Thursday 19 March 2020 20:29
by Lokonli
That's what I like to hear :)
Posted: Thursday 19 March 2020 21:32
by HansieNL
Lokonli wrote: Thursday 19 March 2020 19:49 If you want to remove the icon, add the following to your block definition:
	icon: '',  //This are two tick-marks
Just found out that you can change the icon to your own image :D :D :
    image: '../custom/img/siren.png',
Posted: Friday 20 March 2020 13:01
by Alfagek
Thanks PietjePuk and Lokonli. Running nice over here :D
Posted: Friday 20 March 2020 18:36
by HansieNL
Is it possible to remove the seconds from the time? Or can I do that with css?
Posted: Friday 20 March 2020 19:17
by PietjePuck
I need to change the code for this
Posted: Friday 20 March 2020 19:19
by PietjePuck
:lol: I am a very punctual guy
Posted: Friday 20 March 2020 19:55
by HansieNL
I’m punctual on the minute ;)
All other blocks are using hh:mm. Than they’ll be in line with the rest then.
Maybe show seconds optional?
Posted: Sunday 22 March 2020 9:57
by qwerk
Hi, I am running dashticz of a synology webserveer. php 7.3 and apache 2.4 ( tried all combinations (php 5.6, 7.2 and apache 2.2)
I copies the same block as you provide
rss: 'http://www.alarmeringen.nl/feeds/region ... jnmond.rss',
show_lastupdate: true,
width:12,
icon: 'fas fa-bullhorn',
interval: 180,
results: 5,
this is my line
columns[3]['blocks'] = [buttons.buienradar,maps.a50,'garbage',buttons.webcamoprit,buttons.webcamtuin,buttons.webcamterras,'alarmmeldingen'];
In a browser the rss url works on the webserver. so no resolving issues orso.
on my dashticz web I only get:
Aantekening 2020-03-22 095610.jpg (6.56 KiB) Viewed 3131 times
and the error:
Aantekening 2020-03-22 095528.jpg (4.42 KiB) Viewed 3131 times
please advice
Posted: Sunday 22 March 2020 10:02
by EdwinK
In your blocks, change
to
columns[3]['blocks'] = [buttons.buienradar,maps.a50,'garbage',buttons.webcamoprit,buttons.webcamtuin,buttons.webcamterras,alarmmeldingen];
Remove the '
Posted: Sunday 22 March 2020 10:11
by qwerk
When I remove both the '
The whole column disappears.
When using var instead of blocks you are correct.
I tried both the var and the blocks option.
it has to be something stupid.
I added the alarmmeldingen.js
I added the line in dashticz.js
Posted: Sunday 22 March 2020 10:48
by Lokonli
qwerk wrote: Sunday 22 March 2020 10:11 When I remove both the '
I would advice to update to the latest beta, and follow the instructions in the manual:
https://dashticz.readthedocs.io/en/beta ... ingen.html
Posted: Sunday 22 March 2020 11:31
by qwerk
@lokonli I used "git fetch" but that does not update to the latests.
I removed dashticz, did a "git clone" beta. And copied my CONFIG.js
same error.
I installed dashticz on my domoticz server. and alarmmeldingen works !!!! ( I now have other issues)
So the problem is with my synology webserver.
I will search there
Posted: Sunday 22 March 2020 11:53
by Lokonli
qwerk wrote: Sunday 22 March 2020 11:31 @lokonli I used "git fetch" but that does not update to the latests.
same error.
I will search there
git fetch doesn't update. Try git pull.
alarmeringen requires a working CORS proxy.
Did you configure PHP for Dashticz on your Synology correctly?
You can try using a public CORS server:
config['default_cors_url'] = 'https://cors-anywhere.herokuapp.com/';
However, this server is not always running, so it would be better to use the internal CORS server.
Posted: Sunday 22 March 2020 11:58
by qwerk
I found my issue. In the php settings openssl was not activated.
I have a working alarmmeldingen.
thanks for your help and the git explanation
Posted: Sunday 22 March 2020 12:37
by PietjePuck
HansieNL wrote: Friday 20 March 2020 18:36 Is it possible to remove the seconds from the time? Or can I do that with css?
I just changed the code to fulfill your request wait a bit until @lokonli will merge it in the beta.
Posted: Sunday 22 March 2020 17:34
by Lokonli
Done
Posted: Tuesday 31 March 2020 18:13
by toro
This is realy great, I like it a lot.
Thank you very much PietjePuck. And Lokonli for adding it to the beta.
Just a small request though. Is it possible to add the day in front of the time?
If you live in a town where not every day alerts are given, it is a little bit hard to track what happend when.
It is just a simple addition, I made it for myself. But would be nice to get this implemented in the release.
Alarmmeldingen with day.png (9.82 KiB) Viewed 3006 times
And realy great would be if it is possible to show it in the locale language.
As this only works in the Netherlands, that would be in Dutch ;-)
I did it like this (just a snippit):
pubDate = pubDate.toString();
	switch(pubDate.split(' ')[0]) {
		case 'Sun':
			newDay = 'Zo';
			break;
		case 'Mon':
			newDay = 'Ma';
			break;
		case 'Tue':
			newDay = 'Di';
			break;
		case 'Wed':
			newDay = 'Wo';
			break;
		case 'Thu':
			newDay = 'Do';
			break;
		case 'Fri':
			newDay = 'Vr';
			break;
		case 'Sat':
			newDay = 'Za';
			break
pubDate = pubDate.split(' ')[4];
pubDate = newDay + ' ' + pubDate.split(':')[0] + ':' + pubDate.split(':')[1];
