i am using a nodemcu unit buy a wemos-d1-mini will work as well
it is running ESPeasy software
as a sensor i am using a LJ12-A3 proximity sensor which picks up magnetic disturbance
this thread will help you
i did not use a voltage converter but i used an optocoupler
https://www.twoenter.nl/blog/smarthome/ ... -domoticz/
how to copy data from watermeter to waterflow [Solved]
Gravityz
- Domoticz version: 2026.3
Re: how to copy data from watermeter to waterflow
- nodemcu.jpg (185.93 KiB) Viewed 1043 times
Gravityz
i am using a nodemcu unit but a wemos d1 mini will work as well
input NodeMCU and Wemos D1 mini both have 3.3 inputs
sensoren work correctly on 5V
attach sensor to 5V but inputs through a pullup resistor to 3.3V
Number8
- Domoticz version: 2022.1
Thank you so much for the detailed information.
Debian buster on NUC and three RPi with buster.
Gravityz
your welcome.
to be more specific, i checked and i have the sensor hooked up to D5(not D13)
Number8
Just another question: does the time value sent by esp pulsecounter is specific to espeasy? I'm wondering whether I could use Tasmota instead.Gravityz wrote: Thursday 28 January 2021 18:20 the same goes for waterflow.
it turns out the esp pulsecounter sends out a time between pulse in ms. i use this number to calculate the exact flow and send this value over to domoticz.
