Page 2 of 5
Re: v3.2.0 beta
Posted: Saturday 09 November 2019 19:47
by Lokonli
pvklink wrote: Saturday 09 November 2019 18:28 Ok, i solved almost everything!
i did a git pull and after that my screen was a chaos.
so i did a new install etc. etc... and copied the old custom files back, and again a chaos screen!
i enabled column by columns (4 pages) and...
i had one line with 'chromecast' in it...I did not use this anymore and removed the plugin longtime ago in domoticz because it was unstable
it was still in the column line and with 3.1 this is no problem, but with 3.2 all kind of switches are missing ...
columns[7]['blocks'] = [publictransport.ovinfotrain,publictransport.ovinfotram,tvguide.dutch,'chromecast','streamplayer',1749,1750,1473]
Indeed I see the chromecast block generates an error. My mistake. I'll fix it.
Edit:
I've disabled the Chromecast module (temporarily)
Re: v3.2.0 beta
Posted: Saturday 09 November 2019 20:22
by pvklink
yep , for buttons and ov ....
Re: v3.2.0 beta
Posted: Saturday 09 November 2019 20:25
by pvklink
ok, thanks!
EVerything works OK now!
Re: v3.2.0 beta html and special blocks
Posted: Sunday 10 November 2019 9:58
by pvklink
Hi, i am busy changing my styling with the new formats for special blocks...
Cam, garbage, clock & sunrise are working.
But
1.i cant style news ...
this is the js part
// NEWS FEED
blocks['news_nualg'] = {}
blocks['news_nualg']['feed'] = 'http://www.nu.nl/rss/algemeen';
and these are some samples of my css, i cant define the height of a news block like news_nualg
2. Other question: Why can i use an item like divcam1 without buttons. and for cams i have to add calenders. in front, why is this different?
* news */
div[data-id='news_nualg'] {height: 136;} /* does not work */
[data-id='news_nualg'].blocktitle {height: 136;} /* does not work */
/* cam */
div[data-id='divcam1'] {height: 172px;width: 240px;}
div[data-id='divcam2'] {height: 172px;width: 240px;}
div[data-id='divcam3'] {height: 550px;}
div[data-id='divcam4'] {height: 550px;}
/* calenders */
div[data-id='calendars.dvpeter'] {height: 133px;}
div[data-id='calendars.dvado'] {height: 133px;}
div[data-id='calendars.dvf1'] {height: 352px;}
div[data-id='calendars.dvfam'] {height: 135px;}
div[data-id='calendars.dvfam'] .items {height: 100%;overflow-y: auto;}
/* clock & sunrise */
div[data-id='clock'] {height: 118px;}
div[data-id='sunrise'] {height: 90px;}
/*  garbage */
div[data-id='garbage'] {height: 85px;width: 480px;}
div[data-id='garbage'] .items {height: 100%;overflow-y: auto;}
Posted: Sunday 10 November 2019 11:06
by Lokonli
pvklink wrote: Sunday 10 November 2019 9:58 Hi, i am busy changing my styling with the new formats for special blocks...
But
this is the js part
// NEWS FEED
* news */
/* cam */
/* calenders */
/*  garbage */
You can set the height of a news block in CONFIG.js as follows:
    feed: 'http://www.nu.nl/rss/algemeen',
    maxheight: 400,
    title: 'Nu.nl' //optional
I see this is not documented yet...
If you have added a title to the news block, then you can change the styling of the title part in custom.css:
[data-id='news_nualg'].news .dt_title {
    height:50px
Back to your two lines that didn't work:
The first one doesn't work because normally the height is calculated dynamically by the news content, and that overrules the css styling. You can have a forced height by using the the maxheight parameter in the block definition in CONFIG.js, as described above.
The second one doesn't work, because the data-id is not added to the title, but only to the container.
2)
The calendar block still uses the 'old' format. In the old html template 'calendar' was added in front of the key (=date-id). In one of the future updates I'll change it to the new template.
Re: v3.2.0 beta
Posted: Sunday 10 November 2019 11:18
by pvklink
OK, thanks Lokonli!
Does it bother you that I keep asking for special blocks, I want to check them all with the new styling rules and thougt this could be a nice place to check if everything works and to check everything is documented...
When i am ready i will put my css in here...for the part of the special blocks
Re: v3.2.0 beta
Posted: Sunday 10 November 2019 12:11
by pvklink
This works indeed!
[data-id='news_nusp'].news .dt_title {height:25px} /* this only works if the block has a title in custom.js */
/* but this not .............still testing */
[data-id='news_nusp'].news .col-data {height: 100%;overflow-y: auto;}
blocks['news_nusp'] = {}
blocks['news_nusp']['feed'] = 'http://www.nu.nl/rss/sport';
blocks['news_nusp']['maxheight'] = 100;
blocks['news_nusp']['title'] = 'Nu.nl (sport)';
Re: v3.2.0 beta
Posted: Sunday 10 November 2019 16:00
by Dave47
After update I have no switches
I have change for buttons 'image' to 'btnimage'
blocks like:
   blocks['s1'] = {}
blocks['s1']['width'] = 4;
blocks['s1']['title'] = 'Alles uit/aan';
	blocks['s1']['playsound'] = 'sounds/ping.mp3';
	blocks['s1']['playsoundOn'] = 'sounds/ping.mp3';
	blocks['s1']['playsoundOff'] = 'sounds/ping.mp3';
blocks['116'] = {}
blocks['116']['width'] = 4;
blocks['116']['title'] = 'Dashticz';
blocks['s9'] = {}
blocks['s9']['width'] = 6;
blocks['s9']['title'] = 'Relax';
blocks['s9']['gotoslide'] = 2;
	blocks['s9']['playsound'] = 'sounds/ping.mp3';
	blocks['s9']['playsoundOn'] = 'sounds/ping.mp3';
	blocks['s9']['playsoundOff'] = 'sounds/ping.mp3';
blocks['s11'] = {}
blocks['s11']['width'] = 6;
blocks['s11']['title'] = 'Reset spots';
blocks['s11']['gotoslide'] = 2;
blocks['125'] = {}
blocks['125']['width'] = 4;
blocks['125']['title'] = 'Geofencing';
Blocks like 's1' and 's9' shows me a switch, other blocks no switches.
I don`t understand wat to do
F12 gives: 4 errors. I dont know how to upload a file
    if (isRGBDeviceAndEnabled(device)) {  //we have to manually destroy the previous spectrum color picker
        $('.rgbw' + idx).spectrum("destroy");
    $('div.block_' + idx).html(html);
    if(!isProtected(idx)) {
        $('div.block_' + idx).addClass('hover');
I dont know what to do
Re: v3.2.0 beta
Posted: Sunday 10 November 2019 18:10
by Lokonli
pvklink wrote: Sunday 10 November 2019 11:18 OK, thanks Lokonli!
No problem, that's fine. Thanks for testing :)
Re: v3.2.0 beta
Posted: Sunday 10 November 2019 18:13
by Lokonli
Dave47 wrote: Sunday 10 November 2019 16:00 After update I have no switches
blocks like:
   blocks['s1'] = {}
blocks['116'] = {}
blocks['s9'] = {}
blocks['s11'] = {}
blocks['125'] = {}
Ai, sorry, you found another bug. As a temporary workaround add the following to CONFIG.js to disable RGB color picker:
config['no_rgb'] = 1;
I'll try to fix it tonight.
Re: v3.2.0 beta
Posted: Sunday 10 November 2019 18:22
by Dave47
Must i also rewrite these blocks?
blocks['116'] = {} blocks['116']['width'] = 4; blocks['116']['title'] = 'Dashticz';
I have ' 116' must i write 116?
In readthedocks the settings is a little bit difference for v3
Re: v3.2.0 beta
Posted: Sunday 10 November 2019 18:52
by HansieNL
Dave47 wrote: Sunday 10 November 2019 18:22 Must i also rewrite these blocks?
Your code should normally work. If you like you can also use the following code:
blocks['116'] = {
	width: 4,
	title: Dashticz
Re: v3.2.0 beta
Posted: Sunday 10 November 2019 19:52
by Dave47
Ok, i can see the switches.
Another problem:
Script5 : toegang geweigerd.
Bestand: about:blank, regel: 1, kolom: 1
I don`t know which script. How can i find it?
And
function playAudio(file) {
//    var key = $.md5(file);
    file = file.split('/');
    var filename = file[(file.length - 1)].split('.');
    filename = filename[0];
    delete file[(file.length - 1)];
    if (!gettingDevices) {
        ion.sound({
            sounds: [
                { name: filename }
            path: file.join('/') + "/",
            preload: true,
            multiplay: false
        ion.sound.play(filename);
ion is niet gedefinieerd
Maybe something is wrong in this, i remove sounds. Is it possible to set a sound for block 78?
blocks['78'] = {}
blocks['78']['width'] = 12;
blocks['78']['title'] = 'Huego2';
blocks['78']['flash'] = 1000;
	blocks['78']['playsound'] = 'sounds/ping.mp3';
Re: v3.2.0 beta
Posted: Sunday 10 November 2019 20:06
by Lokonli
Dave47 wrote: Sunday 10 November 2019 19:52
Another problem:
And
        ion.sound({
            sounds: [
                { name: filename }
            preload: true,
            multiplay: false
blocks['78'] = {}
RGB colorpicker is fixed in latest beta. You can update via
git pull
Don't forget to refresh the cache.
I'll look into ion sound.
It seems I''ve overlooked some modules in one of the files that I removed...
Re: v3.2.0 beta
Posted: Sunday 10 November 2019 20:12
by Ierlandfan
Probably an example error or maybe it's a bug, not sure. Tried it with:
"version": "3.2.0",
"branch": "beta",
I use the following code, taken from the example doc.
calendars.f1 = {
    maxitems: 6,
    url: 'https://www.f1calendar.com/#!/timezone/Europe-Amsterdam',
    icalurl: 'http://www.f1calendar.com/download/f1-calendar_p1_p2_p3_q_gp_alarm-20.ics',
    calFormat: 1,
    dateFormat: "dd M",
    timeFormat: "HH",
    icon: 'fas fa-car'
With this code the config gives an error. If I comment the block the config loads ok.
Re: v3.2.0 beta
Posted: Sunday 10 November 2019 20:22
by Dave47
Thank you!
Re: v3.2.0 beta
Posted: Sunday 10 November 2019 20:26
by Lokonli
ion sound is fixed as well.
Re: v3.2.0 beta
Posted: Sunday 10 November 2019 20:30
by Lokonli
Ierlandfan wrote: Sunday 10 November 2019 20:12 Probably an example error or maybe it's a bug, not sure. Tried it with:
"version": "3.2.0",
"branch": "beta",
calendars.f1 = {
    maxitems: 6,
    calFormat: 1,
    dateFormat: "dd M",
    timeFormat: "HH",
    icon: 'fas fa-car'
First, before you add the f1 calendar, you have to declare the calendars object once with:
var calendars = {};
Like:
var calendars = {};
calendars.f1 = {
    maxitems: 6,
    calFormat: 1,
    dateFormat: "dd M",
    timeFormat: "HH",
    icon: 'fas fa-car'
Not really a bug, but the documentation could be more clear on this.
Re: v3.2.0 beta
Posted: Sunday 10 November 2019 23:14
by janumix
On mobile browser there is no longer possible to swipe down.
Previously, columns were positioned one below the other. Now, only the first is displayed.
How can I back to previous behaviour ?
Re: v3.2.0 beta
Posted: Monday 11 November 2019 8:00
by Lokonli
Swiper indeed has been enabled on mobile devices. You can swipe horizontally.
I'll make enableSwiper a config setting, so that you can disable it.
