No data from sbfspot to Domoticz
Mithrandir
Re: No data from sbfspot to Domoticz
Post by Mithrandir »
A great!
Was already screenshotting my code
bontwoody
Domoticz version: 4.10717
Post by bontwoody »
#!/usr/bin/python
from sqlite3 import connect
from datetime import datetime
conn = connect('/home/pi/smadata/SBFspot.db')
curs = conn.cursor()
#Get last rows of day file for latest reading of solar output
curs.execute("select Timestamp, Power, TotalYield from vwDayData ORDER BY Timestamp DESC LIMIT 20")
rows1=curs.fetchall()
print(rows1)
curs.close
conn.close
conn = connect('/home/pi/domoticz/domoticz.db')
#get last reading added to domoticz
curs.execute("select Date from Meter ORDER BY Date DESC LIMIT 1")
rows2=curs.fetchall()
#get last timestamp added to domoticz
if len(rows2)==0: #check there is some data in Meter table
now=datetime.now()
DT=now.strftime("%d/%m/%Y %H:%M:%S")
else:
#print(rows2)
DT=rows2[0][0]
a=0 # variable for flag to append date - 0=append, 1=dont append
for n in range(19):
if DT!=rows1[n][0] and a==0:#append data
#print("append", DT, rows1[n][0],a, rows1[n][1], rows1[n][2])
val=rows1[n][1]
tot=rows1[n][2]
params = (11,val*10,tot,rows1[n][0])
curs.execute("INSERT INTO Meter(DeviceRowID,Usage,Value,Date) VALUES (?,?,?,?)", params)
conn.commit()
elif DT==rows1[n][0] and a==0: #set 'dont append'flag
#print("set flag", DT, rows1[n][0],a)
a=1
else:
print("do nothing", DT, rows1[n][0],a)
curs.close()
conn.close()
I'm a great believer in luck and the more I practice the luckier I get.
Mithrandir
Great! It’s working now... thanks for all the support
bontwoody
Post by bontwoody »
Glad to have been of help :-)
Mithrandir
Very interesting! It works for the day overview but Friday shows total of the eTotal and not the day total.
And very surprisingly; SBFspot is now also working a bit.. not the daily but weekly and monthly is showing the right information. Don’t understand that the python script is doing the exact opposite.
Mithrandir
Really not sure what’s happening.. the python script is now updating based on the current new numbers. It now also shows Saturday so I guess it was just the startup in that part of the script.
The ‘original’ is not showing current and still doesnt have the numbers from Friday. Tried to disable/enable but not updating anymore.
bontwoody
Post by bontwoody »
Very Odd! The Python data should settle down as you get more data points I think. One way of seeing what going on might be to look directly into the Domoticz database. Could you download a copy from your zero and view it on a another computer?
HvdW
Domoticz version: 2023.2
Post by HvdW »
The solution is simple.
- Do the automated setup once more.
- Preserve your settings
- Choose advanced options
- Choose advances CSV settings
- Set export to CSV to ON
That's all
Bugs bug me.
Mithrandir
I tried your solution with reinstalling SBFspot config but that's not working. It imports old data but not the new data. Or do you mean a different way with "automated setup"?
I used: curl -s https://raw.githubusercontent.com/sbfsp ... pot-config | sudo bash
thanks!!
Doudy
Post by Doudy »
bontwoody wrote: Friday 22 November 2019 18:04 Virtualdevice.png
OK, so I havent been able to get the inbuilt import function to work properly but I have managed to use a virtual sensor and a python script to do what is required. There are a couple of glitches with the data in the image but Im very close. Im still fiddling with it to get the best results but Im happy to share how I did it with you if you want. Basically I an querying the SBFspot database directly and then inserting the values into the Domoticz database through the python code which is run every 5 minutes via crontab.
I just tested your script and it works :)
I used a copy of the Domoticz DB to do these tests !
I created one Device - Virtual Sensor(497) - Electric (Instant +counter ) => 243 General / 29 kWh Electric (Instant+Counter) voir ici : https://www.domoticz.com/wiki/Developin ... hon_plugin
The script used:
#!/usr/bin/python
# -*- coding: utf-8 -*-
## Obtenir les 20 dernières lignes du fichier du jour pour les dernières lecture de la production solaire.
## Obtenir plus de 1 en cas de mauvaise connexion Bluetooth
print(rows1)
curs.close
conn.close
## Obtenir la dernière lecture ajoutée à domoticz
	now=datetime.now()
else:
## Obtenir le dernier horodatage ajouté à domoticz
	print(rows2)
	DT =rows2[0][0]
	a=0 ## variable pour l'indicateur d'ajout de la date - 0=ajouter, 1=ne pas ajouter
for n in range (19) :
	if DT !=rows1[n][0] and a== 0: ## append data
		val=rows1[n][1]
		tot =rows1[n][2]
		params = (497,val*10,tot,rows1[n][0])
		curs.execute("INSERT INTO Meter(DeviceRowID,Usage,Value,Date) VALUES (?,?, ?,?)", params)
		conn.commit()
	elif DT==row1[n][0] and a==0 : ## set 'dont append'flag
		a=1
	else :
		print ("Ne rien faire", DT, row1[n][0],a)
curs.close()
conn.close()
The command:
pi@raspberrypi-185:~/domoticz/scripts/python $ python SBFSpot_db_2.py
Here is the result :
[(u'2022-08-12 17:00:00', 1464, 21718773), (u'2022-08-12 16:55:00', 1464, 21718651), (u'2022-08-12 16:50:00', 1500, 21718529), (u'2022-08-12 16:45:00', 1512, 21718404), (u'2022-08-12 16:40:00', 1524, 21718278), (u'2022-08-12 16:35:00', 1524, 21718151), (u'2022-08-12 16:30:00', 1548, 21718024), (u'2022-08-12 16:25:00', 1560, 21717895), (u'2022-08-12 16:20:00', 1572, 21717765), (u'2022-08-12 16:15:00', 1584, 21717634), (u'2022-08-12 16:10:00', 1596, 21717502), (u'2022-08-12 16:05:00', 1608, 21717369), (u'2022-08-12 16:00:00', 1596, 21717235), (u'2022-08-12 15:55:00', 1620, 21717102), (u'2022-08-12 15:50:00', 1596, 21716967), (u'2022-08-12 15:45:00', 1608, 21716834), (u'2022-08-12 15:40:00', 1488, 21716700), (u'2022-08-12 15:35:00', 1620, 21716576), (u'2022-08-12 15:30:00', 1632, 21716441), (u'2022-08-12 15:25:00', 1644, 21716305)]
[(u'2022-08-13 08:15:03',)]
('append', u'2022-08-13 08:15:03', u'2022-08-12 17:00:00', 0, 1464, 21718773)
('append', u'2022-08-13 08:15:03', u'2022-08-12 16:55:00', 0, 1464, 21718651)
('append', u'2022-08-13 08:15:03', u'2022-08-12 16:50:00', 0, 1500, 21718529)
('append', u'2022-08-13 08:15:03', u'2022-08-12 16:45:00', 0, 1512, 21718404)
('append', u'2022-08-13 08:15:03', u'2022-08-12 16:40:00', 0, 1524, 21718278)
('append', u'2022-08-13 08:15:03', u'2022-08-12 16:35:00', 0, 1524, 21718151)
('append', u'2022-08-13 08:15:03', u'2022-08-12 16:30:00', 0, 1548, 21718024)
('append', u'2022-08-13 08:15:03', u'2022-08-12 16:25:00', 0, 1560, 21717895)
('append', u'2022-08-13 08:15:03', u'2022-08-12 16:20:00', 0, 1572, 21717765)
('append', u'2022-08-13 08:15:03', u'2022-08-12 16:15:00', 0, 1584, 21717634)
('append', u'2022-08-13 08:15:03', u'2022-08-12 16:10:00', 0, 1596, 21717502)
('append', u'2022-08-13 08:15:03', u'2022-08-12 16:05:00', 0, 1608, 21717369)
('append', u'2022-08-13 08:15:03', u'2022-08-12 16:00:00', 0, 1596, 21717235)
('append', u'2022-08-13 08:15:03', u'2022-08-12 15:55:00', 0, 1620, 21717102)
('append', u'2022-08-13 08:15:03', u'2022-08-12 15:50:00', 0, 1596, 21716967)
('append', u'2022-08-13 08:15:03', u'2022-08-12 15:45:00', 0, 1608, 21716834)
('append', u'2022-08-13 08:15:03', u'2022-08-12 15:40:00', 0, 1488, 21716700)
('append', u'2022-08-13 08:15:03', u'2022-08-12 15:35:00', 0, 1620, 21716576)
('append', u'2022-08-13 08:15:03', u'2022-08-12 15:30:00', 0, 1632, 21716441)
But the result is not what I expected:
I have negative data!! :(
An idea ?
One question:
Could you describe the line for me? '2022-08-13 08:15:03', u'2022-08-12 15:30:00', 0, 1632, 21716441 mostly 1632, 21716441
Doudy
Post by Doudy »
I found a solution :)
I delete the data in tables Meter and Meter_Calendar
sudo /etc/init.d/domoticz.sh stop
cd domoticz
sqlite3 domoticz.db
DELETE from Meter where DeviceRowId = 497;
DELETE from Meter_Calendar where DeviceRowId = 497;
.quit
sudo /etc/init.d/domoticz.sh start
Result:
Two more questions :
I have data since 2009 how to integrate them?
