Page 2 of 12
Re: Python Plugin: Python Plugin Manager
Posted: Saturday 03 March 2018 16:31
by remb0
some ideas:
add a short info message on
https://www.domoticz.com/wiki/Plugins
and maybe a column if plugin is installable from PP-manager?
pp manager default in domoticz? (would help lots of users searching for plugins etc.)
categories for plugins? hardware / web services because the list will grow fast and with categories (maybe an extra metadata of the plugins) the dropdown will be shorter.
maybe a screenshot for the plugins? if the plugin has a folder: screenshots ?
what if a plugin is installed already? can it be updated from the manager?
is there an install log of the prerequisites of a plugin?
one problem:
When I enable pp manager my domoticz goes down. and when restarting I can't disable the plugin: problem adding hardware.
Posted: Saturday 03 March 2018 16:39
by remb0
IDANIT wrote: Wednesday 28 February 2018 15:23
I've change from 3.5.3 to different Python version (3.4.4) and now everything works fine.
Can you reply the commands for other users? (like me
Posted: Saturday 03 March 2018 16:56
by ycahome
remb0 wrote: Saturday 03 March 2018 16:31
add a short info message on https://www.domoticz.com/wiki/Plugins
I would try to contact dnpwwo. A "repository" like approach would be more preferable.
Note that this plugin currently works only on Debian based systems (Linux, raspberry)
Currently, plugin framework does not allow plugin configuration from within the plugin code.
If plugin was installed from GitHub with git command (not just a zip download) can be managed.
this is an information that can be provided from plugin creators just like the installation scripts for those prerequisites.
Posted: Saturday 03 March 2018 20:08
by IDANIT
remb0 wrote: Saturday 03 March 2018 16:39
Well, there are two ways, sophisticated by "update-alternatives" or easy by "remove"
. First one didn't work for me, so I give You second one
1. first, check what's on Your system
2. if You have 3.4 already move to 4.
if dont...
3.
4.
sudo apt-get remove python3.5
sudo apt-get autoremove
sudo reboot
Thats it
Posted: Saturday 03 March 2018 21:49
by pvklink
@remb0
I had the same problems that python did not start (sometimes)
I followed your procedure
i@raspberrypi:~ $ compgen -c python
python3.5
python2
python3.4
python3.4m
python-config
python3
python
python2.7-config
python2.7
python3.5m
python2-config
python3m
pi@raspberrypi:~ $ sudo apt-get remove python3.5
Pakketlijsten worden ingelezen... Klaar
Boom van vereisten wordt opgebouwd
De statusinformatie wordt gelezen... Klaar
Pakket 'python3.5' is niet geïnstalleerd, en wordt dus niet verwijderd
U kunt 'apt --fix-broken install' uitvoeren om dit op te lossen.
De volgende pakketten hebben niet-voldane vereisten:
alacarte : Vereisten: gnome-menus (>= 3.5.3) maar het zal niet geïnstalleerd worden
python-minecraftpi : Vereisten: minecraft-pi maar het zal niet geïnstalleerd worden
E: Er zijn niet-voldane vereisten. U kunt best 'apt --fix-broken install' uitvoeren zonder pakketten op te geven, (of u kunt zelf een oplossing specificeren).
also did a
python 3.5 still remains!
sudo update-alternatives --config python
Keuze Pad Prioriteit Status
0 /usr/bin/python3.5 3 automatische modus
1 /usr/bin/python2.7 2 handmatige modus
* 2 /usr/bin/python3 1 handmatige modus
3 /usr/bin/python3.5 3 handmatige modus
python --version
Python 3.5.3
Posted: Saturday 03 March 2018 21:57
by pvklink
Solved my problem, i can select 3.4 and python works now
Anyone an idea why
-EnableEventScriptSystem value has become 0 (off). It was 1 (ON) and after playing with weatherunderground and detect hardware devices python stopped and this value became 0
- i cant remove python 3.5 (see previous post)
solution:
sudo update-alternatives --install /usr/bin/python python /usr/bin/python3.4 4 (4 is variable)
and then
and choose option 4(variable)
Also python is working again after updating EnableEventScriptSystem to 1
rowid Key nValue sValue
139 EnableEventScriptSystem 1
Posted: Sunday 04 March 2018 9:26
by ycahome
Hello again.
New version is here. You have nothing to do. You will get new version on next domoticz restart or plugin "Update".
v.1.4.10
Added: Xiaomi PM2.5 Sensor
Added: Sony Bravia TV (with Kodi remote)
Changed: Selected (NotifyOnly) is now the default option for auto update
@remb0: Adopted your idea. Thanks
As for making this plugin default on domoticz, am trying first to make it play under Windows or only if Detect Linux .
Thank you for your help
Posted: Sunday 04 March 2018 9:36
by IDANIT
ycahome wrote: Sunday 04 March 2018 9:26
Hello again.
v.1.4.10
Great Job! TYVM!
https://github.com/kofec/domoticz-AirPurifier maybe next?
Posted: Sunday 04 March 2018 9:47
by DeBaat
Wow!
Wonderful idea.
Was looking in how to add Sonos plugin but was holding back because I wasn't that confident accessing the bare system.
I do have some good experience with managing plugins for WordPress. Might find some ideas there?
Keep up the good work!
Posted: Sunday 04 March 2018 15:32
by michellejohnso1
Python Plugin Management, simplified
[spam ? ?
Posted: Sunday 04 March 2018 15:39
by ycahome
michellejohnso1 wrote: Sunday 04 March 2018 15:32
.. pluginmanager documentation master file, created by
What was that?
Your first post to this forum and looks like spam advertising!!
Maybe you should use some code tags in order to make your post readable!!
Posted: Tuesday 06 March 2018 10:51
by ycahome
New version is here. You have nothing to do. You will get new version on next Domoticz restart or plugin "Update".
v.1.4.17
Added: Denon/Marantz Amplifier
Added: Disc usage
Added: Dutch earthquakes
Added: Hive Active Heating
Wiki Plugin catalogue updated. A suffix "$" added to mark the plugins that have some dependencies (from what is mentioned to instructions)
Posted: Saturday 10 March 2018 17:12
by deennoo
Thx Ycahome for your works
I try to run your plugin manager on my test domoticz (rpi 3 + stretch) domo beta 3.9014 python 3.5.3
Each time i try to add a plugin (Miflora mate xiaomi robot, pm2.5) this create a segmentation fault, any idea ?
Posted: Saturday 10 March 2018 19:18
by ycahome
deennoo wrote: Saturday 10 March 2018 17:12
Seems that the are problems with some plugins, raspberry and python 3.5.
Two questions:
- you are pressing "Update" after selecting "Miflora mate xiaomi robot or pm2.5", correct?
- can you post me the results of the following commands?
python --version
and
python3 --version
Posted: Sunday 11 March 2018 8:48
by ycahome
v.1.4.18 is here:
Added: Meteo Alarm EU RSS Reader
Added: Mikrotik RouterOS
Added: Moon Phases
Help me include your plugins (on GitHub) by requesting changes on GitHub.
Regards,
Posted: Sunday 11 March 2018 8:51
by florisi
just downloaded pp-manager in the plugins directory.
rebooted my raspberry but nothing appears.
running Domoticz v3.9014 (latest beta) on pi3
Posted: Sunday 11 March 2018 8:54
by ycahome
make sure that you have python installed
Posted: Sunday 11 March 2018 9:02
by florisi
here is my output about python:
sudo apt-get install python3
Reading package lists... Done
Building dependency tree
Reading state information... Done
python3 is already the newest version (3.5.3-1).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
pi@domotica:~ $ python --version
Python 2.7.13
Any hints?
Posted: Sunday 11 March 2018 9:07
by ycahome
are you sure that you don't see "Python plugin manager" on plugin list?
Any log entries?
Posted: Sunday 11 March 2018 9:10
by florisi
Absolutely sure, no python plugin manager in the list.
Which logfile would u like to see?
