Dashticz - Module - Tv Guide (Dutch)
robgeerts
- Domoticz version: 3.7067
Re: Dashticz - Module - Tv Guide (Dutch)
Do yo get any errors?
In latest beta, everything is working fine here?
poudenes
- Domoticz version: 3.8993
I use for some months 1 version without update to latest beta. And from one to other day it stop working.robgeerts wrote: Monday 26 February 2018 21:23 Do yo get any errors?
So maybe its not a problem of the beta itself?
10us
Same for me. I used it for weeks, nothing changed in my setup. Didn't update anything and the Tv Guide keeps loading without display any data.I use for some months 1 version without update to latest beta. And from one to other day it stop working.
- HansieNL
@robgeerts: I get a bunch of error, but don't know to get rid with them. Everything works ok in Ubuntu Linux???
This is one for example: jquery.min.js:4 GET http://dashticz.nl/tv/channels.php 404 (Not Found)
Blah blah blah
Herre
Same issue here. No update doen lately, running on master for several weeks now TV Guide is only loading.
10us
Just fixed the problem after replace the tvguide.js file with the latest beta from github.10us wrote: Tuesday 27 February 2018 10:07Same for me. I used it for weeks, nothing changed in my setup. Didn't update anything and the Tv Guide keeps loading without display any data.I use for some months 1 version without update to latest beta. And from one to other day it stop working.
Herre
@10us: Indeed that solves the issue.
Herre
@10us: Please check at your end as well.
Apparently this is not a stable situation, back on the loading issue. Instead of 404 issue I now get the following issues:
[Error] Origin http://—.—.-.—:—- is not allowed by Access-Control-Allow-Origin.
[Error] Failed to load resource: Origin http://—.—.-.—:— is not allowed by Access-Control-Allow-Origin. (channels.php, line 0)
[Error] XMLHttpRequest cannot load http://dashticz.nl/tv/channels.php due to access control checks.
poudenes
This worked for me as well still using the old dashticz and now with new tvguide.js10us wrote: Monday 05 March 2018 23:17Just fixed the problem after replace the tvguide.js file with the latest beta from github.10us wrote: Tuesday 27 February 2018 10:07Same for me. I used it for weeks, nothing changed in my setup. Didn't update anything and the Tv Guide keeps loading without display any data.I use for some months 1 version without update to latest beta. And from one to other day it stop working.
Herre
I'm glad for you folks, but I'm still having the same problems. Apparently a CORS issue, does anybody have a solution for this? Kind regardspoudenes wrote: Thursday 08 March 2018 9:06This worked for me as well still using the old dashticz and now with new tvguide.js10us wrote: Monday 05 March 2018 23:17Just fixed the problem after replace the tvguide.js file with the latest beta from github.10us wrote: Tuesday 27 February 2018 10:07
broozr
Works for me, only after copying this file:
https://github.com/Dashticz/dashticz_v2 ... tvguide.js
to the js/tvguide.js file. "Problem" is, this refreshes at a given interval - 60000 * 5 (5 minutes), line 71. Probably should be configuring this in the object itself (and if not set, default to these 5 minutes)?
1981nick1981
Hi, is there a way to use this plugin in belgium?
hsvt
Is it possible to remove the channel name?
I mean the "NPO3".
I made for each channel a separate block with each a channel symbol.
So the name in each line is not necessary.
I mean the "NPO3".
- TV guide
- channelname.GIF (160.7 KiB) Viewed 1205 times
- HansieNL
@hsvt To hide the channel name you can add the following code to your custom.css:
Only you got now - - Don't have an answer right now how to hide one of them. Hopefully @Lokonli can give us the answer.
Edit: just see that the icon/image will be removed too. You have to add .dt_state to the code:
.tvguide em {
display: none !important;
.tvguide .dt_state em {
}Blah blah blah
Lokonli
It's a bit difficult to hide the second '-'
I could add a block parameter:
layout: 0 => Row including tv station name
layout: 1 => Row excluding tv station name.
or, bit more generic solution, add a template parameter, like:
This would be the default. The new one, without tv station:
or, I'll combine the two.
layout: 0, template parameter will be used
layout:1, predefined template without station name will be used.
I think I'll do this. If you've additional suggestions please let me know.
rowTemplate : '{{starttime}} - {{endtime}} - <em> {{station}} </em> - <b>{{program}}</b>'
rowTemplate : '{{starttime}} - {{endtime}} - <b>{{program}}</b>'
Lokonli
In latest beta I've added the tvguide block parameter 'layout'
Set it to 1 to remove the tv station.
CSS styling will be a bit different. I've changed it into a table. CSS classed are used for 'tvtime', 'tvchannel', 'tvtitle' and 'tvsep'
Can you test?
Documentation needs to be updated ...
Can you test?
- HansieNL
Thanks again. This is my TV Guide now...
These are the codes used... And used my own images ofcourse.
CONFIS.js:
CONFIS.js:
- Spoiler: show
- Spoiler: show
Blah blah blah
hsvt
Yes, it works.
Solution in excact 24 hour.
Only put "layout: 1" into each line.
The most time it was to find out how to get the beta version.
But this is how my TV-guide looks now.
Thanks for it.
- tv gids.JPG (94.03 KiB) Viewed 1157 times
hsvt
I can't see the image. (Also not in the PM you sent)
- HansieNL
Mmm... I just tried 3 browsers on iPad without a problem. Tried also a private browser. It has a http link and no https. I don’t know if something is blocking it from viewing at your side.
@hsvt Dan zou deze wel zichtbaar moeten zijn...
Blah blah blah
