Dashticz - Module - Tv Guide (Dutch)
robgeerts
Domoticz version: 3.7067
Re: Dashticz - Module - Tv Guide (Dutch)
Post by robgeerts »
Do yo get any errors?
In latest beta, everything is working fine here?
poudenes
Domoticz version: 3.8993
Post by poudenes »
robgeerts wrote: Monday 26 February 2018 21:23 Do yo get any errors?
I use for some months 1 version without update to latest beta. And from one to other day it stop working.
So maybe its not a problem of the beta itself?
10us
Post by 10us »
Same for me. I used it for weeks, nothing changed in my setup. Didn't update anything and the Tv Guide keeps loading without display any data.
HansieNL
Post by HansieNL »
@robgeerts: I get a bunch of error, but don't know to get rid with them. Everything works ok in Ubuntu Linux???
This is one for example: jquery.min.js:4 GET http://dashticz.nl/tv/channels.php 404 (Not Found)
Blah blah blah
Herre
Post by Herre »
Same issue here. No update doen lately, running on master for several weeks now TV Guide is only loading.
10us
Post by 10us »
10us wrote: Tuesday 27 February 2018 10:07
Just fixed the problem after replace the tvguide.js file with the latest beta from github.
Herre
Post by Herre »
@10us: Indeed that solves the issue.
Herre
Post by Herre »
@10us: Please check at your end as well.
Apparently this is not a stable situation, back on the loading issue. Instead of 404 issue I now get the following issues:
[Error] Origin http://—.—.-.—:—- is not allowed by Access-Control-Allow-Origin.
[Error] Failed to load resource: Origin http://—.—.-.—:— is not allowed by Access-Control-Allow-Origin. (channels.php, line 0)
[Error] XMLHttpRequest cannot load http://dashticz.nl/tv/channels.php due to access control checks.
poudenes
Post by poudenes »
10us wrote: Monday 05 March 2018 23:17
This worked for me as well still using the old dashticz and now with new tvguide.js
Herre
Post by Herre »
poudenes wrote: Thursday 08 March 2018 9:06
I'm glad for you folks, but I'm still having the same problems. Apparently a CORS issue, does anybody have a solution for this? Kind regards
broozr
Post by broozr »
Works for me, only after copying this file:
https://github.com/Dashticz/dashticz_v2 ... tvguide.js
to the js/tvguide.js file. "Problem" is, this refreshes at a given interval - 60000 * 5 (5 minutes), line 71. Probably should be configuring this in the object itself (and if not set, default to these 5 minutes)?
1981nick1981
Post by 1981nick1981 »
Hi, is there a way to use this plugin in belgium?
hsvt
Post by hsvt »
Is it possible to remove the channel name?
I mean the "NPO3".
I made for each channel a separate block with each a channel symbol.
So the name in each line is not necessary.
TV guide
TV guide
HansieNL
Post by HansieNL »
@hsvt To hide the channel name you can add the following code to your custom.css:
.tvguide em {
	display: none !important;
Only you got now - - Don't have an answer right now how to hide one of them. Hopefully @Lokonli can give us the answer.
Edit: just see that the icon/image will be removed too. You have to add .dt_state to the code:
.tvguide .dt_state em {
Blah blah blah
Lokonli
Post by Lokonli »
It's a bit difficult to hide the second '-'
I could add a block parameter:
layout: 0 => Row including tv station name
layout: 1 => Row excluding tv station name.
or, bit more generic solution, add a template parameter, like:
rowTemplate : '{{starttime}} - {{endtime}} - <em> {{station}} </em> - <b>{{program}}</b>'
This would be the default. The new one, without tv station:
rowTemplate : '{{starttime}} - {{endtime}} - <b>{{program}}</b>'
or, I'll combine the two.
layout: 0, template parameter will be used
layout:1, predefined template without station name will be used.
I think I'll do this. If you've additional suggestions please let me know.
Lokonli
Post by Lokonli »
In latest beta I've added the tvguide block parameter 'layout'
Set it to 1 to remove the tv station.
CSS styling will be a bit different. I've changed it into a table. CSS classed are used for 'tvtime', 'tvchannel', 'tvtitle' and 'tvsep'
Can you test?
Documentation needs to be updated ...
HansieNL
Post by HansieNL »
Thanks again. This is my TV Guide now...
These are the codes used... And used my own images ofcourse.
CONFIS.js:
var config = {}
config['domoticz_ip'] = 'http://192.168.2.14:8081';
config['app_title'] = 'TV Gids';
config['language'] = 'nl_NL';
config['hide_seconds'] = 1;
var tvguide = {}
tvguide.nederland_1 = { key:'nederland_1', image: '../custom/tvgids/img/001_nederland_1.svg', width:12, layout:1, channels: [1], url:'https://www.tvgids24.nl/gadget/npo_1', maxitems: 7 }
tvguide.nederland_2 = { key:'nederland_2', image: '../custom/tvgids/img/002_nederland_2.svg', width:12, layout:1, channels: [2], url:'https://www.tvgids24.nl/gadget/npo_2', maxitems: 7 }
tvguide.nederland_3 = { key:'nederland_3', image: '../custom/tvgids/img/003_nederland_3.svg', width:12, layout:1, channels: [3], url:'https://www.tvgids24.nl/gadget/npo_3', maxitems: 7 }
tvguide.rtl_4 = { key:'rtl_4', image: '../custom/tvgids/img/004_rtl_4.svg', width:12, layout:1, channels: [4], url:'https://www.tvgids24.nl/gadget/rtl_4', maxitems: 7 }
tvguide.rtl_5 = { key:'rtl_5', image: '../custom/tvgids/img/005_rtl_5.svg', width:12, layout:1, channels: [31], url:'https://www.tvgids24.nl/gadget/rtl_5', maxitems: 7 }
tvguide.sbs_6 = { key:'sbs_6', image: '../custom/tvgids/img/006_sbs_6.svg', width:12, layout:1, channels: [36], url:'https://www.tvgids24.nl/gadget/sbs6', maxitems: 7 }
tvguide.rtl_7 = { key:'rtl_7', image: '../custom/tvgids/img/007_rtl_7.svg', width:12, layout:1, channels: [46], url:'https://www.tvgids24.nl/gadget/rtl_7', maxitems: 7 }
tvguide.veronica = { key:'veronica', image: '../custom/tvgids/img/008_veronica.svg', width:12, layout:1, channels: [34], url:'https://www.tvgids24.nl/gadget/veronica', maxitems: 7 }
tvguide.fox = { key:'fox', image: '../custom/tvgids/img/011_fox.svg', width:12, layout:1, channels: [440], url:'https://www.tvgids24.nl/gadget/fox', maxitems: 7 }
tvguide.discovery = { key:'discovery', image: '../custom/tvgids/img/017_discovery.svg', width:12, layout:1, channels: [29], url:'https://www.tvgids24.nl/gadget/discovery_channel', maxitems: 7 }
tvguide.ngc = { key:'ngc', image: '../custom/tvgids/img/018_ngc.svg', width:12, layout:1, channels: [18], url:'https://www.tvgids24.nl/gadget/national_geographic', maxitems: 7 }
tvguide.ziggo_sport = { key:'ziggo_sport', image: '../custom/tvgids/img/014_ziggo_sport.svg', width:12, layout:1, channels: [466], url:'https://www.tvgids24.nl/gadget/ziggo_sport', maxitems: 7 }
var blocks = {}
var columns = {}
columns['bar'] = {}
columns[1] = {}
columns[1]['blocks'] = [tvguide.nederland_1,tvguide.rtl_4,tvguide.rtl_7,tvguide.discovery]
columns[1]['width'] = 4;
columns[2] = {}
columns[2]['blocks'] = [tvguide.nederland_2,tvguide.rtl_5,tvguide.veronica,tvguide.ngc]
columns[2]['width'] = 4;
columns[3] = {}
columns[3]['blocks'] = [tvguide.nederland_3,tvguide.sbs_6,tvguide.fox,tvguide.ziggo_sport]
columns[3]['width'] = 4;
var screens = {}
screens[1] = {}
screens[1]['background'] = 'bg14.jpg';
custom.css:
CUSTOM CSS FILE
.settingsicon,
.fullscreenicon {
	display: none;
.transbg[class*="col-xs"] {
    border-width: 3px !important;
    border-radius: 10px;
    background-color: rgba(0,0,0,0.7);
.transbg[class*="col-xs"].hover:hover {
.dt_block .col-icon {
    width: 56px !important;
.col-icon {
    max-width: 48px !important;
img.icon {
    max-width: 36px !important;
Blah blah blah
hsvt
Post by hsvt »
Yes, it works.
Solution in excact 24 hour. :o
hsvt wrote: Saturday 02 January 2021 0:02
Lokonli wrote: Sunday 03 January 2021 0:02
Thanks for it.
Only put "layout: 1" into each line.
The most time it was to find out how to get the beta version. :lol:
But this is how my TV-guide looks now.
tv gids.JPG (94.03 KiB) Viewed 1120 times
hsvt
Post by hsvt »
HansieNL wrote: Sunday 03 January 2021 1:07 Thanks again. This is my TV Guide now...
I can't see the image. (Also not in the PM you sent)
HansieNL
Post by HansieNL »
hsvt wrote: Sunday 03 January 2021 23:34
Mmm... I just tried 3 browsers on iPad without a problem. Tried also a private browser. It has a http link and no https. I don’t know if something is blocking it from viewing at your side.
@hsvt Dan zou deze wel zichtbaar moeten zijn...
Blah blah blah
