Dashticz - Feature Requests
MarceldeJongNL
Domoticz version: 3.5108
Re: Dashticz - Feature Requests
Post by MarceldeJongNL »
Oh, and an other one that would be awesome:
I use the find my iPhone script to store some LAT & LON in a VAR in domoticz. If I change this to a Custom Text Device, could it also be possible to use these values in Google Maps instead of the static values? Multiple maps (or multiple pins on 1 map) would be fantastic
Hardware: Raspberry Pi 2B | RFXCOM RFXtrx433E v1 | Synology DS213+ | KaKu Clones | Conrad RSL switches | KAKu Doorbell Clone | USB Webcam | ICY Thermostat | Resol DL2 | Imatic Relay Board | Eminent 6230 | Eminent 6220 | iMatic 16 ports Relay Board
robgeerts
Domoticz version: 3.7067
Post by robgeerts »
MarceldeJongNL wrote:I would love to use one instance of Dashticz for multiple custom configurations (Desktop, Tablet, Phone, etc)
Could you make an option, to specify as specific Custom folder in the HTML file? Like a simple variable you put in the HTML file
Example:
index.html uses /custom (default)
mobile.html uses /custom_mobile
tablet_second_floor.html uses /custom_tablet_second_floor
That would make managing multiple instances a breeze
Thanks for all you effort!
This works in latest beta :)
http://www.domoticz.com/forum/viewtopic ... 67&t=17489
MarceldeJongNL
robgeerts wrote: This works in latest beta :)
You are amazing! Will test ASAP!
gielie
Domoticz version: latest β
Post by gielie »
Id like to switch the name and data for my Toon thermostat, this is not possible with the switch blocks code.
IS this something i can do or should Rob add this feature?
- Aeotec MultiSensor 6
- FIBARO FGS223
- FIBARO FGWPE Wall Plug
- Neo CoolCam Power plug
- Popp Smoke Detector
- Toon
- Kodi Media Server
robgeerts
Post by robgeerts »
I have to fix this I guess, will look into this
gielie
Post by gielie »
Id like to add show_lastupdate to single blocks instead of show to all blocks and then hide it by other blocks where i don't want it. I only want to show the last update at the presence block, is this possible?
- FIBARO FGS223
- Toon
- Kodi Media Server
robgeerts
Post by robgeerts »
Switch should now work in latest version.
blocks['144_2'] = {}
blocks['144_2']['switch'] = true;
mongoose
Post by mongoose »
Only just starting with Dashticz, very well done :) Loving it so far.
The feature I'd like to see is, something along the lines of a sensor percentage being converted to a picture. i.e A water tank level
Now that being said, I haven't build my tank meter yet. (could use the battery icon as well)
The other thing that would be cool, is to change a picture according to how warm/cold it is. i.e. 0 - 10 degrees c show a jacket, 10-20 shorts and tshirt :P Or icons that change colour.
percent half.png (46.14 KiB) Viewed 3835 times
percent almost full.png (46.14 KiB) Viewed 3835 times
clubeddie
Post by clubeddie »
robgeerts wrote:
clubeddie wrote:Is it possible to show the costs of consumed power and gas?
These data is available in the log section of domoticz, and a user can adjust the kwh and m3 price of his supplier.
I don't know if this data can be extracted somehow?
No is also an answer :-)
Do you get this data back from the json output?
http://URL_TO_DOMOTICZ/json.htm?type=devices
No, there is no data aboit it. Only the counters. Then is it maybe only possible if there is a script with an calculator, where you can set the cost price.
robgeerts
Post by robgeerts »
It could be that theres a separate url for returning the costs... I'll dive into this later
gielie
Post by gielie »
robgeerts wrote:Switch should now work in latest version.
The switch block of my Toon thermostaat is not working, i still have the temp above the text and i can not switch this.
- FIBARO FGS223
- Toon
- Kodi Media Server
robgeerts
Post by robgeerts »
Did you change 144 to the correct idx and is _2 right?
gielie
Post by gielie »
robgeerts wrote:Did you change 144 to the correct idx and is _2 right?
Yes my idx of the Toon Room Setpoint is 303, and not with an extra _# so i don't know why u use this, but still its not working, when i add a _# nothing is showing thus i need to use the idx 303
- FIBARO FGS223
- Toon
- Kodi Media Server
robgeerts
Post by robgeerts »
So it looks like this?
blocks[303] = {}
blocks[303]['switch'] = true;
Can anyone else test this works or not?
HansieNL
Post by HansieNL »
robgeerts wrote:So it looks like this?
blocks[303] = {}
Doesn't work. Even with ['switch'] = true; temperature stays on top.
Blah blah blah
SwordFish
Domoticz version: V4.11375
Post by SwordFish »
blocks[303] = {}
I have a Nest thermostaat and the ' blocks[xxx]['switch'] = true; ' isn't working either
qwerk
Post by qwerk »
I have a horstman and same here. not switching
funny, that temp related devices are the other way around from lamps /switches
HansieNL
Post by HansieNL »
qwerk wrote:I have a horstman and same here. not switching
I had the same thoughts and was thinking why it's done that way. As you can see is the temperature font much bigger, because that's the setting you wanna know. For me it's now even logical if the name is removed. I just have one thermostat, so the icon and temp says enough.
Hope you understand it a bit better. ;)
It would be nice if the flames icon would be red if the thermostat is heating.
Blah blah blah
godinperson
Post by godinperson »
A Kodi widget would be nice, something like this: http://3.bp.blogspot.com/-hn9QvlyWj-Q/W ... uttons.jpg
SuperMouse
Post by SuperMouse »
Is it also possible to lock items (switches) so the cannot be altered in the dashboard.
If someone accidently presses the presence "aanwezig/afwezi'g" switch you have the wrong data.
Locked
