ACDB-6500BC doorbell
Mavy
Re: ACDB-6500BC doorbell
Post by Mavy »
I am using this same doorbell and for me it worked without any issues. The only difference i can see is that i have ATI,AD and Hideki enabled.
@mbliek, i am pretty sure the 6500BC is an ARC devices because it has the Letter code selector.
Heisenberg
Post by Heisenberg »
I tried again by pushing the doorbell and this is what I see in the ' Not Used' Devices section. But after I added the unit by giving it a name (Doorbell) and push the doorbell again, nothing happens.
Raspberry Pi Type B
Raspberry Pi Type B2
RFXCOMtrx433e
b_weijenberg
Post by b_weijenberg »
The doorbell button transmits only an ON command.
You have the reset the state to OFF before you will see the ON command change.
RFX-433, RFX-433EMC, RFX-868
Heisenberg
b_weijenberg wrote:The doorbell button transmits only an ON command.
Thnx for the quick reply. Could you tell me how to reset to OFF state? Do I need to reset the Doorbell receiver or something else?
Raspberry Pi Type B
RFXCOMtrx433e
mbliek
Post by mbliek »
No need for that, it doesn't show on/off in domoticz.
Did you add the doorbell as type doorbell?
Not just only the name.
Heisenberg
Yes, I did. But still no recognition in Domiticz when I push the button. The doorbell does ring when front door button is pushed.
Raspberry Pi Type B
RFXCOMtrx433e
Mavy
Post by Mavy »
What exactly are you trying to achieve? As said before the doorbell only send an on command, so you wont actually see anything change other then a new on record in the log.
Heisenberg
Mavy wrote:I am using this same doorbell and for me it worked without any issues. The only difference i can see is that i have ATI,AD and Hideki enabled.
Gents,
Today I sucessfully added this doorbell. It was indeed recognized by Domoticz as an ARC device. I suddenly was able to see the device after pushing doorbell button on front door. Thnx all!
Last edited by Heisenberg on Wednesday 19 February 2014 16:51, edited 1 time in total.
Raspberry Pi Type B
RFXCOMtrx433e
mbliek
Post by mbliek »
Glad it's working now
sincze
Domoticz version: 2024.4
Post by sincze »
Mavy wrote:What exactly are you trying to achieve? As said before the doorbell only send an on command, so you wont actually see anything change other then a new on record in the log.
In this case I would like to achieve
If (dark) & (doorbell is pressed (status = chime) then "switch on front door light"
after 1 minute switch off the light.
I thought if status of the doorbell would reset to "off" after 1 minute this could help me to switch the front light off.
The reset option is available with the motion sensor.
Doorbell vs Motion
Doorbell vs Motion
Pass2php
USB: RFXCom, ZWave, Sonoff 3
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Solar: Omnik, PVOutput
Sensors: You name it I got 1.
robingerritsen
Post by robingerritsen »
Gents,
I have exact the same problem! Can you tell me what you did?
i have enabled the ARC protocol, but it still wont work......
Ariz
Target OS: OS X
Post by Ariz »
thnx, looking forward to read your installation steps.
gclub
