Watermeter with ESP8266
MaikelK
Re: Watermeter with ESP8266
Post by MaikelK »
So no %value%/2 settings for the TCRT?
How does your wiring look like, i got massive boot problems i think. Im in the test stage Every once in a few days and cant seems to start the esp-01 correctly.
I have another unit with a dht-22 and that starts up pretty good if i put it in a different room to log.
LouiS22
Post by LouiS22 »
MaikelK wrote:So no %value%/2 settings for the TCRT?
I noticed the same, had to disconnect the sensor to let nodemcu boot up. Could be a bug in ESPEasy firmware.
MaikelK
Post by MaikelK »
How did you guys wire it up to the ESP-01 and the NodeMcu V1(the black board ESP-12E)?
I got 10x DS18B20 sensors connected to D0 and D1 and when i connect the TCRT5000 break-out board to D2 for example it wont see the pulses?
I wired it straight in, so D0 of the TCRT5000 to the inputs of the NodeMcu board in this case as this is the board i would like to use as this one is already inside the utility cabinet.
andreo
Domoticz version: 2024.3
Post by andreo »
D2 is the same as GPIO2
>> GPIO state on startup <<
When choosing GPIO pins to use, it’s best to avoid GPIO 0, 2 and 15 unless absolutely necessary. If you do end up using them, you’ll need pullups / pulldowns to ensure the correct bootloader mode. You should also be aware of the fact that GPIO 0 is driven as an output during startup.
>> Bootloader modes <<
  • GPIO 0 GPIO 2 GPIO 15
    UART Download Mode (Programming) 0 1 0
    Flash Startup (Normal) 1 1 0
    SD-Card Boot 0 0 1
Latest version of Domoticz and more running on Docker|Raspberry Pi 4-B 8GB Bookworm|RF-Link|Klik Aan Klik Uit|Nefit easy|ESPeasy|P1 power meter|S0PCM-5 through Ser2Net|Alecto WS5500|FrtizBox|Satel Integra|Solis
Greetz Andre.
Geniux3000
Post by Geniux3000 »
My name is Carlos, and I'm writing because I'm trying to monitor my home water meter, but I'm having trouble making my own design.
So, I wanted to ask you if it would be possible for you to send me the schematic and firmware that the PCB of the following entry: https://www.domoticz.com/forum/viewtopic.php?t=14196
If you could help me, I'd really appreciate it. :D
Geniux3000
arvindaditya19
Post by arvindaditya19 »
hey I am trying to build al ora based water meter retrofit for existing water meters your helps will be appreciated.
[email protected]
ajayrajspark
Post by ajayrajspark »
Hello my friend
very interesting design
I am very much interested to do this project. can you provide me all the files
Piet47
Domoticz version: 2022.3
Post by Piet47 »
HI ,
I am also interested in the design, can you send me all the files please.
regards Piet
florin
Post by florin »
can you help me with details for building the assembly?
thanks
Rickishier
Post by Rickishier »
he hi, just new to this forum
i would like the schematics for the board :) and i know a lot of my friends would like to have it as well, is it maybe possible to make it public/open source?
thanks in advance
Rick
wasik10
Post by wasik10 »
Can you send me the files, please? This design is very interesting.
Best Regards
Lukas
