Watermeter with ESP8266
MaikelK
Re: Watermeter with ESP8266
So no %value%/2 settings for the TCRT?
How does your wiring look like, i got massive boot problems i think. Im in the test stage Every once in a few days and cant seems to start the esp-01 correctly.
I have another unit with a dht-22 and that starts up pretty good if i put it in a different room to log.
- LouiS22
I noticed the same, had to disconnect the sensor to let nodemcu boot up. Could be a bug in ESPEasy firmware.MaikelK wrote:So no %value%/2 settings for the TCRT?
MaikelK
How did you guys wire it up to the ESP-01 and the NodeMcu V1(the black board ESP-12E)?
I got 10x DS18B20 sensors connected to D0 and D1 and when i connect the TCRT5000 break-out board to D2 for example it wont see the pulses?
I wired it straight in, so D0 of the TCRT5000 to the inputs of the NodeMcu board in this case as this is the board i would like to use as this one is already inside the utility cabinet.
- andreo
- Domoticz version: 2024.3
D2 is the same as GPIO2
>> GPIO state on startup <<
When choosing GPIO pins to use, it’s best to avoid GPIO 0, 2 and 15 unless absolutely necessary. If you do end up using them, you’ll need pullups / pulldowns to ensure the correct bootloader mode. You should also be aware of the fact that GPIO 0 is driven as an output during startup.
>> Bootloader modes <<
>> Bootloader modes <<
- GPIO 0 GPIO 2 GPIO 15
UART Download Mode (Programming) 0 1 0
Flash Startup (Normal) 1 1 0
SD-Card Boot 0 0 1
Latest version of Domoticz and more running on Docker|Raspberry Pi 4-B 8GB Bookworm|RF-Link|Klik Aan Klik Uit|Nefit easy|ESPeasy|P1 power meter|S0PCM-5 through Ser2Net|Alecto WS5500|FrtizBox|Satel Integra|Solis
Greetz Andre.
Greetz Andre.
Geniux3000
My name is Carlos, and I'm writing because I'm trying to monitor my home water meter, but I'm having trouble making my own design.
So, I wanted to ask you if it would be possible for you to send me the schematic and firmware that the PCB of the following entry: https://www.domoticz.com/forum/viewtopic.php?t=14196
If you could help me, I'd really appreciate it.
Geniux3000
arvindaditya19
hey I am trying to build al ora based water meter retrofit for existing water meters your helps will be appreciated.
[email protected]
[email protected]
ajayrajspark
Hello my friend
very interesting design
I am very much interested to do this project. can you provide me all the files
Piet47
- Domoticz version: 2022.3
HI ,
I am also interested in the design, can you send me all the files please.
regards Piet
regards Piet
florin
can you help me with details for building the assembly?
thanks
thanks
Rickishier
he hi, just new to this forum
i would like the schematics for the board
and i know a lot of my friends would like to have it as well, is it maybe possible to make it public/open source?
thanks in advance
Rick
thanks in advance
Rick
wasik10
Can you send me the files, please? This design is very interesting.
Best Regards
Lukas
Best Regards
Lukas
Users browsing this forum: Bing [Bot], HansSch and 1 guest
