Update Available !... Update Now? Version #4834
panser
Re: Update Available !... Update Now? Version #4834
Post by panser »
trying to update from 4836 -> 4858
From gui:
/home/pi/domoticz/scripts/update_domoticz: 27: /home/pi/domoticz/scripts/update_domoticz: systemctl: not found
From terminal:
pi@raspberrypi ~/domoticz $ ./updatebeta
Updating to latest beta version...
Please Standby...
--2016-03-05 10:34:01--  http://www.domoticz.com/download.php?channel=beta&type=release&system=linux&machine=armv6l
Resolving http://www.domoticz.com (http://www.domoticz.com)... 185.27.142.198
Connecting to http://www.domoticz.com (http://www.domoticz.com)|185.27.142.198|:80... connected.
HTTP request sent, awaiting response... 302 Found
Location: http://www.domoticz.com/releases/beta/domoticz_linux_armv6l.tgz [following]
--2016-03-05 10:34:01--  http://www.domoticz.com/releases/beta/domoticz_linux_armv6l.tgz
Reusing existing connection to http://www.domoticz.com:80.
HTTP request sent, awaiting response... 404 Not Found
2016-03-05 10:34:01 ERROR 404: Not Found.
gizmocuz
Post by gizmocuz »
@Siewert308SW
I see the problem, you are working with a raspberry pi 1 (armv6l) and this armv6l should have been renamed to armv7l
Did you had problems before with updating from the web interface? (Also before the latest stable ?)
gizmocuz
Post by gizmocuz »
If you change your updatebeta script to:
#!/bin/sh
# This script can be used to upgrade to the latest beta version
lowercase(){
    echo "$1" | sed "y/ABCDEFGHIJKLMNOPQRSTUVWXYZ/abcdefghijklmnopqrstuvwxyz/"
OS=`lowercase \`uname -s\``
MACH=`uname -m`
if [ ${MACH} = "armv6l" ]
then
 MACH="armv7l"
fi
echo "Updating to latest beta version..."
echo "Please Standby..."
wget -O domoticz_beta.tgz "http://www.domoticz.com/download.php?channel=beta&type=release&system=${OS}&machine=${MACH}"
tar xvfz domoticz_beta.tgz
rm domoticz_beta.tgz
echo "Restarting Domoticz... (please standby...)"
sudo service domoticz.sh restart
then i think you should be able the new beta (#4861), and from that moment on hopefully also from the web gui
jvbussel
Post by jvbussel »
Sorry, the problem still exists.
I am at version 4834 and got this morning a new update version 48.. (Sorry forgot the mumber).
The process of updating looks like it normally does but afterwards it is still at version 4834
But immediately a new version 4860 is reported.
Same proces, everything looks again as a normal update process. At the end however still version 4834.
And immediately the next version 4861 is reported.
Siewert308SW
Domoticz version: Stable
Post by Siewert308SW »
gizmocuz wrote:@Siewert308SW
Just checked, wasn't sure anymore.
My PI is a Raspberry Pi REV 2 Model B UK version (blue audio port)
Uname -m gives me a armv6l
As for you question, till 3843 i can't remember if i had update issues.
At least not this issue we are talking about.
Will change the updatebeta script to what you are suggesting to and see in the upcoming updates
Setup:
- DS923+ Docker
Domoticz Latest Stable
Mosquitto / ZwaveJSUI @ Aeotec Z-Stick Gen5+ / PiHole Unbound
P1 USB Gas/Power, HW watermeter
- A lot of Zwave switches, contacts, plugs, smoke/Co2 ect
- DiY 7.5kWh Solar Storage @ GitHuB
Siewert308SW
gizmocuz wrote:If you change your updatebeta script to:
#!/bin/sh
lowercase(){
MACH=`uname -m`
if [ ${ARCH} = "armv6l" ]
then
 ARCH="armv7l"
fi
Thx, did the trick and updating went fine...
Setup:
- DS923+ Docker
gerrit
Post by gerrit »
Same error after manual changing script.
The update still calles armv6l,
I am not good in scripting : I expect a script error VARS: ARCH and MACH mixed up.
After hardcoding &machine=${MACH} to &machine=armv7l it worked.
and able to update to 4861
4861 updates the script again and fails!
running the script
Please Standby...
--2016-03-05 11:50:05-- http://www.domoticz.com/download.php?ch ... ine=armv6l
Resolving www.domoticz.com (www.domoticz.com)... 185.27.142.198
Connecting to www.domoticz.com (www.domoticz.com)|185.27.142.198|:80... connected.
Location: http://www.domoticz.com/releases/beta/d ... armv6l.tgz [following]
--2016-03-05 11:50:05-- http://www.domoticz.com/releases/beta/d ... armv6l.tgz
Reusing existing connection to www.domoticz.com:80.
2016-03-05 11:50:05 ERROR 404: Not Found.
gzip: stdin: unexpected end of file
tar: Child returned status 1
tar: Error is not recoverable: exiting now
Restarting Domoticz Home Automation System:Starting Domoticz Home Automation System:.
pi@domoticzpi:~/domoticz$
Gerrit
dannybloe
Post by dannybloe »
MACH=`uname -m`
then
 ARCH="armv7l"
fi
Shouldn't this be:
MACH=`uname -m`
then
 MACH="armv7l"
fi
ARCH isn't used anywhere in the script. And that change indeed doesn't make it work. With MACH it works.
gizmocuz
Post by gizmocuz »
Yes, sorry, it was already committed hours ago, but did not update this forum post, will update the above post now
G3rard
Domoticz version: No
Post by G3rard »
gizmocuz wrote: How did you install Domoticz ?
I assume it is not from the binary install as said on the wiki ?
Because then you should have experienced this problem at the start.
It means you need to have boost 1.55, but actually the build system should link these libraries statically,
the user who created the build script for linux did not specify this.
This is one of the reasons why i link as much as possible statically for the raspberry pi, dont want to have this problem.
If you build from source code, i suggest to update the code, and build
(or install boost 1.55 for now)
I have indeed built from the source code following http://www.domoticz.com/wiki/Linux.
I just updated from source and built again. Now it is working fine.
Not using Domoticz anymore
HansLe
Domoticz version: V2.3530
Post by HansLe »
After changing the download script the update worked perfect. Thanks for the update guys!!!! :D
Raspberry Pi B+ | Domoticz v3.4834 | RFXtrx433E | Action sockets and remote control (a cheap solution to start with)
Sonos device: control via Action remote control and EasySonos (via Domoticz scripts)
2 x Chresta TX320, Kaku sensoren, D-link camera
gizmocuz
Post by gizmocuz »
New update for the raspberry available #4865, hope the web gui update now works fine...
panser
Post by panser »
Im not able to update to any above 4836. Tried web gui, ./updatebeta and your update script. (that works, but leaves me with 4836)
pi@raspberrypi ~/domoticz/scripts $ sudo uname -a
Linux raspberrypi 4.1.6+ #810 PREEMPT Tue Aug 18 15:19:58 BST 2015 armv6l GNU/Linux
Please Standby...
--2016-03-06 07:27:56--  http://www.domoticz.com/releases/beta/domoticz_linux_armv7l.tgz
HTTP request sent, awaiting response... 200 OK
Length: 12956294 (12M) [application/x-gtar-compressed]
Saving to: `domoticz_beta.tgz'
100%[=================================================================================================================================================================================================>] 12,956,294  5.34M/s   in 2.3s
2016-03-06 07:27:59 (5.34 MB/s) - `domoticz_beta.tgz' saved [12956294/12956294]
[....] Restarting Domoticz Home Automation System: domoticz2016-03-06 07:28:11.196  Domoticz V3.4836 (c)2012-2016 GizMoCuz
2016-03-06 07:28:11.198  Build Hash: 214e060, Date: 2016-03-03 09:16:19
What do I have to do, to get the latest beta?
