Controlicz - Domoticz to Google Home/Assistant integration Topic is solved
Madgeni
Re: Controlicz - Domoticz to Google Home/Assistant integration
I believe the default ssl port for synology is 8443, not 443?
Madgeni
Hi all, Controlicz is undergoing maintenance - apologies for the outage, should be back in an hour
*Edit* - maintenance complete
DomoPal
When I try to create an account it fails and there's an error: "Recaptcha 2 module not found"Madgeni wrote: Wednesday 13 February 2019 16:33 Hi all, Controlicz is undergoing maintenance - apologies for the outage, should be back in an hour
Madgeni
Apologies - this is now fixed.DomoPal wrote: Thursday 14 February 2019 17:09When I try to create an account it fails and there's an error: "Recaptcha 2 module not found"Madgeni wrote: Wednesday 13 February 2019 16:33 Hi all, Controlicz is undergoing maintenance - apologies for the outage, should be back in an hour
WarLion
its controlicz working?
on google assistance replyt with the device controlicz is not avalible in this moment (mexico)
i been trying to test connection on the profile page and dont show anything , also try to delete the account ask for confirmation but dont delete profile ,
Madgeni
Hi -WarLion wrote: Friday 22 February 2019 1:03 its controlicz working?
Controlicz is fine. If you'd like to re-register, and mail me from your controlicz profile, i'll work out why your connection failed.
The test works fine, but is browser dependent, and requires pop-ups.
Madgeni
Quick update from Google:
Native blind controls (so recognised as blinds) is being soft-launched - finally. This will, inevitably, take time to be rolled out across regions, so won't be implementing it yet. It works in English, but not in Dutch. This will make Open/Close, as well as more natural percentage behaviour available - "Hey Google, open the kitchen blinds to 50%" etc.
Nice.
Can't wait until it is rolled out in NL.
It currently sounds a bit stupid to say "Aan" and "Uit" in NL.
Is there any roll-out schema from Google for other missing functionalities?
Madgeni
am on the Early Access Programme, and i can say it's very slow. Really want Sensors asap, and am pressing them for timescales, but you can appreciate they dont tend to share that stuff (certainly not with me!)
dagasoft
Hi!Madgeni wrote:Quick update from Google:
I see that blinds now appear as blinds in my Google home app. I can open close with natural command (open blind instead of power on/off) but I see that in Google home app they appear with a gear as if they weren't set up. Do you know if I have to do something?
Madgeni
Hi there -
this is normal. They will be including in-app controls for the blinds soon - including a slider for percentage open. Percentage open should also be working with voice now.
- Varazir
Wee my blinder shows up as a blinder in GH. But I can't get the % to work. Open and close works fine
I see this in the log when I say: lower blinder 50%
2019-03-16 08:48:25.817 Status: User: controlicz initiated a switch command (50/Bedroom Blinder/Set Level)
But nothing happens to the blinder.
Skickat från min Nokia 7 plus via Tapatalk
Madgeni
Hi -
can you control your blinds by percentages? Can you try again and i'll see what it's doing, that log entry looks right to me
- Varazir
Okay checked a bit more nowMadgeni wrote: Sunday 17 March 2019 16:32 Hi -
When I use the slider on the webgui
2019-03-17 17:49:40.286 Python: Changed: ID: 50 Name: Bedroom Blinder, Type: 244, subType: 73, switchType: 16, s_value: 100, n_value: 1, n_value_string: Open, last_update_string: 2019-03-17 17:49:39
2019-03-17 17:50:47.199 Python: Changed: ID: 50 Name: Bedroom Blinder, Type: 244, subType: 73, switchType: 16, s_value: 50, n_value: 2, n_value_string: Set Level: 50 %, last_update_string: 2019-03-17 17:50:46When I use voice: raise 50%
2019-03-17 17:51:59.576 Python: Changed: ID: 51 Name: Bedroom_Blinder_Current_Consumption, Type: 248, subType: 1, switchType: 0, s_value: 0.0, n_value: 0, n_value_string: 0.0, last_update_string: 2019-03-17 17:51:58Raspberry PI 4 with RaZberry Controller 2016 ZWave+ and CC2531(zigbee)
Madgeni
Thanks - can you try again? Turned on some logging
- Varazir
Tested it again, still nothing and the second time it just said it couldn't connect to the website
2019-03-17 21:23:05.043 Python: Changed: ID: 50 Name: Bedroom Blinder, Type: 244, subType: 73, switchType: 16, s_value: 0, n_value: 0, n_value_string: Closed, last_update_string: 2019-03-17 21:23:03
Madgeni
Can you 'sync my devices' and try again please? ThanksVarazir wrote: Sunday 17 March 2019 21:25 Tested it again, still nothing and the second time it just said it couldn't connect to the website2019-03-17 21:23:05.043 Python: Changed: ID: 50 Name: Bedroom Blinder, Type: 244, subType: 73, switchType: 16, s_value: 0, n_value: 0, n_value_string: Closed, last_update_string: 2019-03-17 21:23:03
salvacalatayud
I've tested the same, GH tells me that this function is not avalable for now
Madgeni
Ok, that's a different issue. Will raise it with Google (they'd assured me that all languages were now supported)
Madgeni
Can you give me an example phrase or two (in Spanish) which isn't working? Google have asked for some examples?salvacalatayud wrote: Monday 18 March 2019 10:53 I've tested the same, GH tells me that this function is not avalable for now
