Alexa, Google Home and Siri
Madgeni
Post by Madgeni »
I believe the default ssl port for synology is 8443, not 443?
Madgeni
Post by Madgeni »
Hi all, Controlicz is undergoing maintenance - apologies for the outage, should be back in an hour
*Edit* - maintenance complete
DomoPal
Post by DomoPal »
Madgeni wrote: Wednesday 13 February 2019 16:33 Hi all, Controlicz is undergoing maintenance - apologies for the outage, should be back in an hour
When I try to create an account it fails and there's an error: "Recaptcha 2 module not found"
Madgeni
Post by Madgeni »
DomoPal wrote: Thursday 14 February 2019 17:09
Apologies - this is now fixed.
WarLion
Post by WarLion »
its controlicz working?
on google assistance replyt with the device controlicz is not avalible in this moment (mexico)
i been trying to test connection on the profile page and dont show anything , also try to delete the account ask for confirmation but dont delete profile ,
Madgeni
Post by Madgeni »
WarLion wrote: Friday 22 February 2019 1:03 its controlicz working?
Hi -
Controlicz is fine. If you'd like to re-register, and mail me from your controlicz profile, i'll work out why your connection failed.
The test works fine, but is browser dependent, and requires pop-ups.
Madgeni
Post by Madgeni »
Quick update from Google:
Native blind controls (so recognised as blinds) is being soft-launched - finally. This will, inevitably, take time to be rolled out across regions, so won't be implementing it yet. It works in English, but not in Dutch. This will make Open/Close, as well as more natural percentage behaviour available - "Hey Google, open the kitchen blinds to 50%" etc.
EddyG
Post by EddyG »
Nice. :D Can't wait until it is rolled out in NL.
It currently sounds a bit stupid to say "Aan" and "Uit" in NL.
Is there any roll-out schema from Google for other missing functionalities?
Madgeni
Post by Madgeni »
am on the Early Access Programme, and i can say it's very slow. Really want Sensors asap, and am pressing them for timescales, but you can appreciate they dont tend to share that stuff (certainly not with me!)
dagasoft
Post by dagasoft »
Madgeni wrote:Quick update from Google:
Hi!
I see that blinds now appear as blinds in my Google home app. I can open close with natural command (open blind instead of power on/off) but I see that in Google home app they appear with a gear as if they weren't set up. Do you know if I have to do something?
Madgeni
Post by Madgeni »
Hi there -
this is normal. They will be including in-app controls for the blinds soon - including a slider for percentage open. Percentage open should also be working with voice now.
Varazir
Post by Varazir »
Wee my blinder shows up as a blinder in GH. But I can't get the % to work. Open and close works fine
I see this in the log when I say: lower blinder 50%
2019-03-16 08:48:25.817 Status: User: controlicz initiated a switch command (50/Bedroom Blinder/Set Level)
But nothing happens to the blinder.
Skickat från min Nokia 7 plus via Tapatalk
Raspberry PI 4 with RaZberry Controller 2016 ZWave+ and CC2531(zigbee)
Several IKEA devices/z-wave devices
Madgeni
Post by Madgeni »
Hi -
can you control your blinds by percentages? Can you try again and i'll see what it's doing, that log entry looks right to me
Varazir
Post by Varazir »
Madgeni wrote: Sunday 17 March 2019 16:32 Hi -
Okay checked a bit more now
When I use the slider on the webgui
2019-03-17 17:49:40.286 Python: Changed: ID: 50 Name: Bedroom Blinder, Type: 244, subType: 73, switchType: 16, s_value: 100, n_value: 1, n_value_string: Open, last_update_string: 2019-03-17 17:49:39
When I use voice: lower 10%
2019-03-17 17:50:47.199 Python: Changed: ID: 50 Name: Bedroom Blinder, Type: 244, subType: 73, switchType: 16, s_value: 50, n_value: 2, n_value_string: Set Level: 50 %, last_update_string: 2019-03-17 17:50:46
The blind get closed
When I use voice: raise 50%
2019-03-17 17:51:59.576 Python: Changed: ID: 51 Name: Bedroom_Blinder_Current_Consumption, Type: 248, subType: 1, switchType: 0, s_value: 0.0, n_value: 0, n_value_string: 0.0, last_update_string: 2019-03-17 17:51:58
GH responds with correct info but nothing happens
Madgeni
Post by Madgeni »
Thanks - can you try again? Turned on some logging
Varazir
Post by Varazir »
Madgeni wrote: Sunday 17 March 2019 20:29 Thanks - can you try again? Turned on some logging
Tested it again, still nothing and the second time it just said it couldn't connect to the website
2019-03-17 21:23:05.043 Python: Changed: ID: 50 Name: Bedroom Blinder, Type: 244, subType: 73, switchType: 16, s_value: 0, n_value: 0, n_value_string: Closed, last_update_string: 2019-03-17 21:23:03
Madgeni
Post by Madgeni »
Varazir wrote: Sunday 17 March 2019 21:25 Tested it again, still nothing and the second time it just said it couldn't connect to the website
Can you 'sync my devices' and try again please? Thanks
salvacalatayud
Post by salvacalatayud »
I've tested the same, GH tells me that this function is not avalable for now
Madgeni
Post by Madgeni »
Ok, that's a different issue. Will raise it with Google (they'd assured me that all languages were now supported)
Madgeni
Post by Madgeni »
salvacalatayud wrote: Monday 18 March 2019 10:53 I've tested the same, GH tells me that this function is not avalable for now
Can you give me an example phrase or two (in Spanish) which isn't working? Google have asked for some examples?
