Page 10 of 26
Re: Python Plugin: TUYA
Posted: Friday 02 April 2021 10:16
by manjh
OK, after a little patience, the lamp came in as WW! Success!
Now all I have to do is re-install the other lamps. Which is more work than you'd expect, since they disappear from all scenes when deleted....
Is there a way to reset without deleting them?
Posted: Friday 02 April 2021 10:26
by EdwinK
I just noticed this appearing again, about every second.
2021-04-02 10:24:56.251 Error: Tuya: (Tuya) handleThread: Expecting value: line 1 column 1 (char 0) line 198
Posted: Friday 02 April 2021 12:10
by Vomera
Xenomes wrote: Thursday 01 April 2021 21:02
Vomera wrote: Wednesday 31 March 2021 22:42
Where else should it be ?
The second tuyaha is not needed with my version of the plug-in. I was mislead with the naming of the directory. You are using the version of guino in that version is has limited control of RGB. Can you try my version of the plug[in.
https://github.com/Xenomes/Domoticz-TUYA-Plugin.
Okay tried again with your script
Version 1.0.6 is installed.
He sees the rgb strip as a switch and there is no RGB control
Posted: Friday 02 April 2021 12:28
by Xenomes
Vomera wrote: Friday 02 April 2021 12:10
I pushed a new update, remove faulty device => update plug-in => update button in Hardware at Tuya plug-in.
Posted: Friday 02 April 2021 12:30
by Xenomes
EdwinK wrote: Friday 02 April 2021 10:26
I don't ever seen it, try stop the plug-in, wait for minimal 61 seconds and start plug-in.
Posted: Friday 02 April 2021 12:31
by Xenomes
manjh wrote: Friday 02 April 2021 10:16
You can change the type/sub type directly in the database
1000% you own risk.
Posted: Friday 02 April 2021 12:33
by Xenomes
manjh wrote: Friday 02 April 2021 10:10
Xenomes wrote: Thursday 01 April 2021 22:06
manjh wrote: Thursday 01 April 2021 21:37
V.1.0.4
That is not the latest version ... Delete devices and update the plug-in, restart Domoticz and see the new detection.
Edit: Just push a new version
(âš RGBW(W) lights must be on a colour for correct detection âš )
OK, now getting version 6.
Deleted one lamp, disabled/enabled Tuya, now get this error in the log:
Error: (Tuya devices) handleThread: Expecting value: line 1 column 1 (char 0) line 198
Also:
Error: (Tuya devices) handleThread: login rate limited line 195
Try stop the plug-in, wait for minimal 61 seconds and start plug-in again.
Posted: Friday 02 April 2021 13:22
by Vomera
Xenomes wrote: Friday 02 April 2021 12:28
Getting also the same error after updating your script, now in domoticz he sees the ledstrip as RGB
021-04-02 13:20:46.573 Error: (Tuya) handleThread: Expecting value: line 1 column 1 (char 0) line 198
Posted: Friday 02 April 2021 15:02
by Xenomes
Vomera wrote: Friday 02 April 2021 13:22
Execute this and return the cli results
Posted: Friday 02 April 2021 21:20
by Vomera
Xenomes wrote: Friday 02 April 2021 15:02
With
Sudo command he said its already installed. So i tried to use the command
pip3 install tuyaha. Tuya installed, maybe in the user account instead with admin account. In hardware tab update and after that
it worked!!!!!. Finally!! Thank you so much!
Posted: Friday 02 April 2021 21:24
by Vomera
You can see if the answer above this post will help
Posted: Friday 02 April 2021 21:26
by Xenomes
Vomera wrote: Friday 02 April 2021 21:20
Met sudo commando gaf hij al aan geinstalleerd te zijn. Daarna commando
pip3 install tuyaha uitgevoerd en werd de tuya geinstalleerd waarschijnlijk user account. In hardware tab update uitgevoerd en daarna
DEED HIJ HET!!!!. Eindelijk opgelost!! Dank je wel! Samen komen we er wel haha.
OK greet news! every system has his quirks.
Posted: Saturday 03 April 2021 10:02
by manjh
Xenomes wrote: Friday 02 April 2021 12:31
1000% you own risk.
Ah. Risky, but exciting... is there a recommended tool to do this?
Posted: Saturday 03 April 2021 10:13
by Xenomes
manjh wrote: Saturday 03 April 2021 10:02
Best is by hand, this is a bit off-topic, you have to install sqllite3.
Posted: Saturday 03 April 2021 10:58
by manjh
Xenomes wrote: Saturday 03 April 2021 10:13
OK, understand. I guess simply deleting and adding the lamps may be easier....
Posted: Saturday 03 April 2021 11:02
by Xenomes
manjh wrote: Saturday 03 April 2021 10:58
U need to know how sql query works. select and update commands
Posted: Saturday 03 April 2021 11:17
by manjh
Xenomes wrote: Saturday 03 April 2021 11:02
I do, but the mere job of having to install SQL just for this small thing seems a bit over the top.
I've now deleted and re-installed the lamps, this was very simple.
Reviewing all scene settings was a bit more work, but also got it done.
All lamps are now recognized as WW. Thanks for the support!
Posted: Saturday 03 April 2021 11:20
by manjh
One additional thought, perhaps a suggestion for the user interface.
Setting the right color from the color wheel is nice, but it is difficult to get multiple lamps on the same color level.
For the dimmer it can be done by simply moving the slider until the percentage is close enough.
But for color there is no numerical reference>
Would it be possible to add an input field, so that the user can choose to either select from the color wheel, or enter a value in the input field?
Posted: Saturday 03 April 2021 14:12
by manjh
Now that the lamps are working, I am thinking about the next step: getting rid of the Tuya cloud dependency.
I ran into Tasmota, that seems promising.
Also found a procedure for flashing:
https://www.heise.de/ct/artikel/Tuya-Co ... 84830.html
Before I start playing around, possibly losing a perfectly good lamp, has anyone done this before? Any experience? Recommendations?
Posted: Saturday 03 April 2021 17:13
by Xenomes
manjh wrote: Saturday 03 April 2021 11:20
The colour wheel is default function of Domotixz, request for a input field you need be at the developer of Domoticz.
manjh wrote: Saturday 03 April 2021 14:12
Tuya-Convert only works with bulbs with a esp chip and older firmware version. Lots of new devices firmware upload hack don't work any more. You can't convert back to the original firmware without open and destroy the bulb. If the bulb accepts the Tasmota firmware then a new world of opportunities opens.
