homebridge-edomoticz Plugin
Marci
Domoticz version: 3.8153
Re: eDomoticz Homebridge-Plugin
Post by Marci »
Ta - amended...!
asmithdub
Post by asmithdub »
Thanks so much for this! Just got up and running tonight.
Quick questions, have scenes been implemented yet?
And blind/ shutters. Can these be controlled?
Marci
Post by Marci »
Scenes: not directly. Create a dummy/virtual/manual switch in Domoticz. Head to switches tab & hit edit button for that switch, and set the On action to trigger the scene (see https://www.domoticz.com/wiki/Domoticz_ ... _on_or_off), and an Off delay to reset the switch.
eDomoticz / Homebridge will see the virtual switch.
Blinds: depends on switch type they're detected as. Try it & see... If not, raise an issue on GitHub repo with json output as per opening post & I'll add to the to-do list.
deejc
Domoticz version: 3.5641
Post by deejc »
@marci I wish you were writing the plugin for Vera !!!! I cannot get it to work, I rarely had problems with your plugin but this one is murders. It's so slow and crashes often , Arghhhh.
Domoticz 3.5641 on RPI (Raspbian GNU/Linux 8)
Marci
Post by Marci »
Add the Vera devices to Domoticz, then go back to using eDomoticz...? https://www.domoticz.com/wiki/VERA
asmithdub
Post by asmithdub »
Marci wrote:Scenes: not directly. Create a dummy/virtual/manual switch in Domoticz. Head to switches tab & hit edit button for that switch, and set the On action to trigger the scene (see https://www.domoticz.com/wiki/Domoticz_ ... _on_or_off), and an Off delay to reset the switch.
Thank you!
Marci
Post by Marci »
If you've just updated to iOS9.3 and suddenly devices have all vanished, nudge your homebridge install up to latest, then restart homebridge...
sudo npm update -g homebridge
forever restart /usr/local/lib/node_modules/homebridge/bin/homebridge
deejc
Post by deejc »
Marci wrote:Add the Vera devices to Domoticz, then go back to using eDomoticz...? https://www.domoticz.com/wiki/VERA
That looks like massive aggro
SwordFish
Domoticz version: V4.11375
Post by SwordFish »
Great plugin, but i don't get it to work. I have tried everything. Its seems that i haven't got a /usr/local/lib/node_modules/homebridge/bin/homebridge, I only got /usr/local/lib/node_modules/homebridge/. I did follow the installation guide on the first post?
Can someone point me into the right directions :)
Marci
Post by Marci »
Sounds like homebridge failed whilst compiling... run:
sudo npm install -g homebridge
...again, and copy / paste any output into your reply.
SwordFish
Post by SwordFish »
this is when I do "sudo npm install -g homebridge'
Marci
Post by Marci »
K - looks to have installed ok... Use
sudo find / -name homebridge
...to find out where it's put the binary.
simon_rb
Post by simon_rb »
I'm currently using the legacy domoticz shim and it's working rather well. If I switch too this plugin, am I right in thinking you get feedback of the device if you ask for it (assuming it's supported). Secondly, all my devices show up as lights, including switches for stuff like TVs etc.. Does this plugin recognise the difference or is it a domoticz thing? They all show up as Lighting 2 in Domoticz. I'd like to add all the lights and sockets/switches for living room, kitchen, bedroom etc together and if I say turn on living room lights, only the lights turn on and not the TV, Blu Ray Player, PS4 etc..
Thanks guys and girls.
SwordFish
Post by SwordFish »
Marci wrote:K - looks to have installed ok... Use
This is the outcome;
Marci
Post by Marci »
simon_rb wrote:Hi,
Yes
Down to your choice of HomeKit app. Eve for instance allows you to categorise switches via changing their icon and assigning Siri Names
If only your lights are defined as lights in your HomeKit app, and the rest are defined as switches, then yes, this will work.
Again, all down to your choice of HomeKit app, room definitions etc.
Marci
Post by Marci »
It must be failing to compile silently... will get back to you with further steps (assuming you've tried the "if homebridge fails to install" steps in the original post)
simon_rb
Post by simon_rb »
Thanks Marci, I use Eve and they show up as switches and lights correctly however if I add all devices in my living room to a living room room (that's a mouthful). When I say turn all living room lights off even the switches turn off. I will check this to confirm.
What would be the best way to migrate from the legacy shim to your addon?
Thanks again!! :-)
Update:- checked Eve and for my surround sound I only have lightbulb and all the others are the same.
Marci
Post by Marci »
That's with the old shim. Things should look different once you're using latest homebridge and plugin...
Marci
Post by Marci »
To switch, delete current homebridge folder then follow installation instructions in the first post.
simon_rb
Post by simon_rb »
Marci wrote:To switch, delete current homebridge folder then follow installation instructions in the first post.
Good morning, do I need to do this as homebridge is the latest version and working well. Or do you mean the persist folder?
How do I change them from lights to switches in domoticz? If you mean the icons then yes they have been changed. They actually show up in eve as switched but when I tell Siri to turn the lights off she turns off everything including the switches, not just the lights.
