homebridge-edomoticz Plugin
- Marci
- Domoticz version: 3.8153
Re: eDomoticz Homebridge-Plugin
Ta - amended...!
Extended Domoticz homebridge-plugin for latest Homebridge - adds temp/humidity/pressure sensors, power consumption sensors, DarkSkies virtual weather station support, YouLess Meter support, general % usage support & switch/lamp status checking!
asmithdub
Thanks so much for this! Just got up and running tonight.
Quick questions, have scenes been implemented yet?
And blind/ shutters. Can these be controlled?
- Marci
Scenes: not directly. Create a dummy/virtual/manual switch in Domoticz. Head to switches tab & hit edit button for that switch, and set the On action to trigger the scene (see https://www.domoticz.com/wiki/Domoticz_ ... _on_or_off), and an Off delay to reset the switch.
eDomoticz / Homebridge will see the virtual switch.
Blinds: depends on switch type they're detected as. Try it & see... If not, raise an issue on GitHub repo with json output as per opening post & I'll add to the to-do list.
- deejc
- Domoticz version: 3.5641
@marci I wish you were writing the plugin for Vera !!!! I cannot get it to work, I rarely had problems with your plugin but this one is murders. It's so slow and crashes often , Arghhhh.
Domoticz 3.5641 on RPI (Raspbian GNU/Linux 8)
- Marci
Add the Vera devices to Domoticz, then go back to using eDomoticz...? https://www.domoticz.com/wiki/VERA
asmithdub
Thank you!Marci wrote:Scenes: not directly. Create a dummy/virtual/manual switch in Domoticz. Head to switches tab & hit edit button for that switch, and set the On action to trigger the scene (see https://www.domoticz.com/wiki/Domoticz_ ... _on_or_off), and an Off delay to reset the switch.
- Marci
If you've just updated to iOS9.3 and suddenly devices have all vanished, nudge your homebridge install up to latest, then restart homebridge...
sudo npm update -g homebridge
forever restart /usr/local/lib/node_modules/homebridge/bin/homebridgeExtended Domoticz homebridge-plugin for latest Homebridge - adds temp/humidity/pressure sensors, power consumption sensors, DarkSkies virtual weather station support, YouLess Meter support, general % usage support & switch/lamp status checking!
- deejc
That looks like massive aggroMarci wrote:Add the Vera devices to Domoticz, then go back to using eDomoticz...? https://www.domoticz.com/wiki/VERA
SwordFish
- Domoticz version: V4.11375
Great plugin, but i don't get it to work. I have tried everything. Its seems that i haven't got a /usr/local/lib/node_modules/homebridge/bin/homebridge, I only got /usr/local/lib/node_modules/homebridge/. I did follow the installation guide on the first post?
Can someone point me into the right directions
- Marci
Sounds like homebridge failed whilst compiling... run:
...again, and copy / paste any output into your reply.
sudo npm install -g homebridgeExtended Domoticz homebridge-plugin for latest Homebridge - adds temp/humidity/pressure sensors, power consumption sensors, DarkSkies virtual weather station support, YouLess Meter support, general % usage support & switch/lamp status checking!
SwordFish
this is when I do "sudo npm install -g homebridge'
- Marci
K - looks to have installed ok... Use
...to find out where it's put the binary.
sudo find / -name homebridge...to find out where it's put the binary.
simon_rb
- Target OS: -
I'm currently using the legacy domoticz shim and it's working rather well. If I switch too this plugin, am I right in thinking you get feedback of the device if you ask for it (assuming it's supported). Secondly, all my devices show up as lights, including switches for stuff like TVs etc.. Does this plugin recognise the difference or is it a domoticz thing? They all show up as Lighting 2 in Domoticz. I'd like to add all the lights and sockets/switches for living room, kitchen, bedroom etc together and if I say turn on living room lights, only the lights turn on and not the TV, Blu Ray Player, PS4 etc..
Thanks guys and girls.
SwordFish
This is the outcome;Marci wrote:K - looks to have installed ok... Use
- Marci
Yessimon_rb wrote:Hi,
Down to your choice of HomeKit app. Eve for instance allows you to categorise switches via changing their icon and assigning Siri NamesSecondly, all my devices show up as lights, including switches for stuff like TVs etc.. Does this plugin recognise the difference or is it a domoticz thing? They all show up as Lighting 2 in Domoticz.
If only your lights are defined as lights in your HomeKit app, and the rest are defined as switches, then yes, this will work.I'd like to add all the lights and sockets/switches for living room, kitchen, bedroom etc together and if I say turn on living room lights, only the lights turn on and not the TV, Blu Ray Player, PS4 etc..
Again, all down to your choice of HomeKit app, room definitions etc.
- Marci
It must be failing to compile silently... will get back to you with further steps (assuming you've tried the "if homebridge fails to install" steps in the original post)SwordFish wrote:This is the outcome;Marci wrote:K - looks to have installed ok... Use
simon_rb
- Target OS: -
Thanks Marci, I use Eve and they show up as switches and lights correctly however if I add all devices in my living room to a living room room (that's a mouthful). When I say turn all living room lights off even the switches turn off. I will check this to confirm.
What would be the best way to migrate from the legacy shim to your addon?
Thanks again!!
Update:- checked Eve and for my surround sound I only have lightbulb and all the others are the same.
Thanks again!!
- Marci
That's with the old shim. Things should look different once you're using latest homebridge and plugin...
- Marci
To switch, delete current homebridge folder then follow installation instructions in the first post.
simon_rb
- Target OS: -
Good morning, do I need to do this as homebridge is the latest version and working well. Or do you mean the persist folder?Marci wrote:To switch, delete current homebridge folder then follow installation instructions in the first post.
How do I change them from lights to switches in domoticz? If you mean the icons then yes they have been changed. They actually show up in eve as switched but when I tell Siri to turn the lights off she turns off everything including the switches, not just the lights.
