Page 86 of 94
Posted: Saturday 31 August 2019 7:57
by michaelb
Hi Jumbotroll,
I recently updated the package to version V4.11213 (cedarview) and it seems it deletes the custom pages in the www/templates directory. Can you fix somthing so that in future builds this dir is retained?
Michael
Posted: Saturday 31 August 2019 15:40
by jumbotroll
michaelb wrote: Saturday 31 August 2019 7:57
Hi Jumbotroll,
Michael
Modified install script, please test latest build..
Posted: Sunday 01 September 2019 14:54
by Gravityz
Hi Jumbotroll, can you create a new appollolake without python build tonight (no hurry since i still see a couple of fixes coming in, gizmocuz is on a roll
There are a couple of new bugfixes and functionality regarding the buienradar implementation.(build 248 or newer)
Posted: Sunday 01 September 2019 16:36
by jumbotroll
Gravityz wrote: Sunday 01 September 2019 14:54
Apollolake is updated..
Posted: Sunday 01 September 2019 17:25
by Gravityz
thanks
Posted: Friday 06 September 2019 15:11
by Gravityz
Hi Jumbotroll, can you create build 290 or higher
they fixed some buienradar stuff ik like to test out
thanks
for other people reading this. i recently made another donation(yes the last one was 2 years ago
) to Jumbotroll because he is doing excellent work
If you value these synology builds please think about donating because this saves us a lot of time
Posted: Friday 06 September 2019 17:06
by jumbotroll
Gravityz wrote: Friday 06 September 2019 15:11
thanks
Updated
Posted: Sunday 08 September 2019 22:20
by Jumper3126
Just updated from 4.9700 to 4.10717 on my synology 218 play by deleting the old version and then installing the new one. I
'm not able to load the Device nor the Hardware tabs. All other tabs and settings are loaded directly. I've tried to reinstall both the python and non-python version but the same result. When I reinstall the 4.9700 version, the hardware and device functions work like normal again.
Any advice/idea how to solve this??
Solved it
Needed to empty cache
Posted: Thursday 19 September 2019 13:46
by Gravityz
Hi Jumbotroll.
can you create a new build(11324 or later)
want to check if the negative rain value is fixed
Posted: Sunday 06 October 2019 11:38
by Gravityz
hi Jumbotroll, is it possible to create build 352 or later.
the buienradar problem seems hard to fix.(rain counter does not get reset correctly)
Posted: Sunday 06 October 2019 16:07
by jumbotroll
Gravityz wrote: Sunday 06 October 2019 11:38
V4.11354 is uploaded
Posted: Tuesday 15 October 2019 17:53
by arkoko
Hi!
I have installed Jadahl package (Beta for DSM 6.2) on my two Synology devices (DS214 Play and DS218+) and downloading configuration file from Z-Wave Node Managemenrt does not working on both of them.
URL opened (e.g.
https://mysyno.address.me/zwavegetconfig.php?idx=2), but nothing happened, only empty page.
I just wonder is it global or related to Synology or to my environment? I can't check anymore, but before one instance ran on Raspberry Pi and if I remember correctly, downloading then worked.
"AEON Labs ZW090 Z-Stick Gen5 EU" and "AEON Labs DSA02203 Z-Stick S2" USB sticks are in use.
I like this package - donated!
Posted: Wednesday 16 October 2019 17:50
by Gravityz
not working on my synology as well but i do not use this functionality
mine is giving the same response page but with idx=3
what configuration file should get downloaded?
@Jumbotroll, build 367 or later should have some buienrader fixes and new functionality(could this really be the last fix
Posted: Monday 21 October 2019 10:36
by arkoko
For instance, I just installed for testing fresh last stable Domoticz on raspberry, then connected Z-Wave USB stick and downloading works. It gave me xml file (it's quite empty, because no added nodes to the controller).
zwcfg_0xcd99e118.xml:
- Spoiler: show
<?xml version="1.0" encoding="utf-8" ?>
<Driver xmlns="http://code.google.com/p/open-zwave/" version="3" home_id="0xcd99e118" node_id="1" api_capabilities="0" controller_capabilities="40" poll_interval="60000" poll_interval_between="false">
<Node id="1" name="Controller" location="" basic="2" generic="2" specific="1" type="Static PC Controller" listening="true" frequentListening="false" beaming="true" routing="true" max_baud_rate="40000" version="4" query_stage="Complete">
<Manufacturer id="115" name="Z-Wave.Me">
<Product type="400" id="1" name="ZME_UZB1 USB Stick" />
</Manufacturer>
<CommandClasses>
<CommandClass id="32" name="COMMAND_CLASS_BASIC" version="1" after_mark="true">
<Instance index="1" />
<Value type="byte" genre="basic" instance="1" index="0" label="Basic" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="0" />
</CommandClass>
</CommandClasses>
</Node>
</Driver>
Posted: Monday 21 October 2019 10:45
by Aad3229
I am running the latest stable on my Synology DS218+ and I don't have problems with Zwave.
Posted: Monday 21 October 2019 12:17
by arkoko
Configuration download work? Which type of Z-Wave stick you are using?
Posted: Thursday 24 October 2019 8:39
by matsumoto
No longer support for MARVELL Kirkwood 88F6282 (ds413j) ?
I've got a problem with Chrome displaying an empty screen with only a "replace" field.
If no more support, any detailed tutorial how to compile domoticz for my NAS ?
Thanks !
Posted: Thursday 24 October 2019 10:51
by Aad3229
I use the AON Aeotec ZW090 Z-Stick Gen5 EU. And, sorry, the configuration download page is empty by me as well.
Posted: Sunday 17 November 2019 16:13
by bertbigb
I encounter a very new problem for me.
I just downloaded
http://www.jadahl.com/domoticz_stable_6 ... rch=avoton for my Synology 1517+
It is installing but I can't get it to run from the package centre.
Someone else recognizing this problem? Who can help me or guide me a bit to get it to work?
Posted: Sunday 17 November 2019 17:55
by jumbotroll
bertbigb wrote: Sunday 17 November 2019 16:13
I just downloaded
You have installed the Python version and you have to install Python3 package for domoticz to run.
Download and install this:
https://global.download.synology.com/do ... mber=24922
