Is it gonna rain within the next X minutes?
poudenes
Domoticz version: 3.8993
Re: Is it gonna rain within the next X minutes?
Post by poudenes »
Thanks. If 60 and 120 min works.. then its better then nothing for now :)
Ill follow this topic and see if the script will be updated !!
Siewert308SW wrote:@poudenes
It's a Lua script.
But forget about the script i amended.
After a closer look it aint working as i intended.
The 60 and 120min forecast are printed but are presenting the 30min prediction.
Need a closer look.
krizzz
Post by krizzz »
After copying the script from the wikipedia https://www.domoticz.com/wiki/Is_it_gonna_rain the script gives an error
./script_time_rain.lua: line 1: ----------------------------------------------------------------------------------------------------------------: command not found
./script_time_rain.lua: line 2: syntax error near unexpected token `('
./script_time_rain.lua: line 2: `-- IsItGonnaRain( int minutesinfuture)'
Anyone having an idea?
jvdz
Domoticz version: 4.107
Post by jvdz »
How are you running this? ( What command did you run?)
Jos
Dropshot
Post by Dropshot »
Hi, I would like to make use of this script, only I dont know whether I'm doing it correct. I get this in my log:
2017-04-23 17:00:00.403 LUA: Regen verwacht: 0 mm binnen 15 minuten.
So the script seems to be working, yet my device (Rain expected) isn't updated. It still says 'Hello World'.. How can I get this working?
krizzz
Post by krizzz »
jvdz wrote:How are you running this? ( What command did you run?)
Jos
jvdz
Post by jvdz »
try this command:
lua script_time_rain.lua
Jos
EdwinK
Post by EdwinK »
Rain Expected:
Rain Expected:
Screen Shot 2017-04-25 at 21.23.34.png (24.08 KiB) Viewed 2614 times
Guess something is wrong :, because it's really raining outside.
BarryT
Domoticz version: 2024.3
Post by BarryT »
EdKo66 wrote:Screen Shot 2017-04-25 at 21.23.34.pngGuess something is wrong :, because it's really raining outside.
I think its because it is an "rain radar" so it doesnt show the rainfall at the moment, but only in future, like IS it gonna rain in 30 minutes, and if yes how much..
lat & lon correct?
What does the log says?
BarryT
Post by BarryT »
   minuten=30
btw, here can you change the "radar" time..
now it is giving a warning for the rain in 30 minutes, but you can change this to your needs.
BarryT
Post by BarryT »
Dropshot wrote:Hi, I would like to make use of this script, only I dont know whether I'm doing it correct. I get this in my log:
did you chmod the txt file? did you have the correct text idx?
Dropshot
Post by Dropshot »
Thanks, I hadn't chmod the file. Now it works!
EdwinK
Post by EdwinK »
lat & lon correct?
Lat&lon are correct. Have accidentely deleted the logs, so can't tell.
Siewert308SW
Domoticz version: Stable
Post by Siewert308SW »
Which script are you using, could pass it here?
In order to see how you set it up.
Because i have the feeling that you have setup the rainfall below 60 while the round number is setup to 1 decimal or less behind the comma.
Meaning the script says "0.003mm rain expected" but your widget gets updated to 0 decimal behind the comma.
Setup:
- DS923+ Docker
Domoticz Latest Stable
Mosquitto / ZwaveJSUI @ Aeotec Z-Stick Gen5+ / PiHole Unbound
P1 USB Gas/Power, HW watermeter
- A lot of Zwave switches, contacts, plugs, smoke/Co2 ect
- DiY 7.5kWh Solar Storage @ GitHuB
EdwinK
Post by EdwinK »
This is the script I'm using
local RainTextIDX = 113   -- your domoticz text device
debug = false -- enable or disable debug output
tempfilename = '../var/packages/domoticz/scripts/lua/tmp/Rain.tmp' -- be sure this is in the correct map, and give it chmod 0666
totalrain = 0
rainlines = 0
function IsItGonnaRain( minutesinfuture )
   url='http://gpsgadget.buienradar.nl/data/raintext/?lat=51.86&lon=4.41' -- this is important!! change the lat and lon to your needs!!
   if debug then print(url) end
read = os.execute('curl --connect-timeout 5 -s -o '..tempfilename..' "'..url..'"')   file = io.open(tempfilename, "r")
   while true do
      line = file:read("*line")
      if not line then break end
      if debug then print('Line:'..line) end
      linetime=string.sub(tostring(line), 5, 9)
      if debug then print('Linetime: '..linetime) end
      linetime2 = os.time{year=os.date('%Y'), month=os.date('%m'), day=os.date('%d'), hour=string.sub(linetime,1,2), min=string.sub(linetime,4,5), sec=os.date('%S')}
      difference = os.difftime (linetime2,os.time())
      if ((difference > 0) and (difference<=minutesinfuture*60)) then
         if debug then print('Line in time range found') end
         rain=tonumber(string.sub(tostring(line), 0, 3))
         totalrain = totalrain+rain
         rainlines=rainlines+1
         if debug then print('Rain in timerange: '..rain) end
         if debug then print('Total rain now: '..totalrain) end
   file:close()
   averagerain=totalrain/rainlines
   return(averagerain)
function round(num, idp)
   local mult = 10^(idp or 0)
   return math.floor(num * mult + 0.5) / mult
   minuten=15
   RainPrediction = IsItGonnaRain(minuten)
   RainmmHour=10^((RainPrediction-109)/32)
   if (RainPrediction > 20  ) then
      verw = 3
      RainPredictionText=('('..round(RainmmHour, 1)..' mm) regen verwacht!')
      verw = 2
      RainPredictionText=('Voorlopig blijft het droog!')
   commandArray[2] = {['UpdateDevice'] = RainTextIDX .. '|0|' .. tostring(RainPredictionText)}
At the moment the script is spewing out errors '2017-04-29 19:20:01.901 Error: EventSystem: in Regen Verwacht: [string "local RainTextIDX = 113 -- your domoticz te..."]:13: attempt to index global 'file' (a nil value)', so I stopped it for now.
poudenes
Post by poudenes »
Used your script and work great here. Now figure out to change the interval. Want change it so every 10min it will check at buienrader for rain. Now i see lot of loggings:
2017-04-29 20:22:00.297 EventSystem: Script event triggered: REGEN 17.04.29
2017-04-29 20:22:00.410 EventSystem: Script event triggered: REGEN 17.04.29
2017-04-29 20:22:00.520 EventSystem: Script event triggered: REGEN 17.04.29
2017-04-29 20:22:00.674 EventSystem: Script event triggered: REGEN 17.04.29
2017-04-29 20:22:00.793 EventSystem: Script event triggered: REGEN 17.04.29
2017-04-29 20:22:00.906 EventSystem: Script event triggered: REGEN 17.04.29
2017-04-29 20:22:01.017 EventSystem: Script event triggered: REGEN 17.04.29
2017-04-29 20:22:12.113 EventSystem: Script event triggered: REGEN 17.04.29
totalrain = 0
rainlines = 0
   while true do
   file:close()
   return(averagerain)
   minuten=15
      verw = 3
      verw = 2
jvdz
Post by jvdz »
Looks line you have line 11 at the end of line 10... change that to:
totalrain = 0
rainlines = 0
   while true do
Jos
EdwinK
Post by EdwinK »
Thanks. :) Guess I did make some error :)
But still there is this error:
2017-04-29 21:28:00.219 Error: EventSystem: in Regen Verwacht: [string "local RainTextIDX = '113' -- your domoticz ..."]:17: 'end' expected (to close 'while' at line 13) near
Screen Shot 2017-04-30 at 17.54.09.png (17.69 KiB) Viewed 2481 times
poudenes
Post by poudenes »
Can someone help me with this... the script repeats many times... lots of lines like this for triggering Buitenrader to check if its gonna rain.
jvdz
Post by jvdz »
Is this triggered by the Event system? Internal or External files?
Internal -> Check the setting that it is Time in stead of All or Device.
External -> WHat is the script name ? something like script_time_xxx.lua?
jos
poudenes
Post by poudenes »
I have it into Domoticz itself. with a name : regen30 17.04.29 as name (Scene year/month/day of creation or modification)
