Page 9 of 24
Re: Aurora theme
Posted: Wednesday 10 January 2018 22:55
by rhendriks
blauwebuis wrote: Tuesday 09 January 2018 23:21 @rhendriks - try the fluid feature.
How must I do this , sorry i'm a noob
Re: Aurora theme
Posted: Thursday 11 January 2018 9:13
by blauwebuis
@rhendrink: go to settings and then the theme tab. Tick the box. Done.
I'll look into the settings bug.
Re: Aurora theme
Posted: Thursday 11 January 2018 21:12
by piokuc
Good will be change icon for Mobile Devices because now it is the same as Custom Icon.
Also good will be add icon for third submenu... like Fibaro and other
Re: Aurora theme
Posted: Thursday 11 January 2018 21:38
by remb0
When I use my internal adress it goes well on my pc and android chrome.
but when I use my domain: I see only a shite screen with a empty dropdownlist on the top.
on my work, and android telephone.
what's the issue?
Re: Aurora theme
Posted: Thursday 11 January 2018 21:43
by blauwebuis
A white screen is an indication of a javascript error. Do you have access to the console on any of those devices, so see what the error is?
Re: Aurora theme
Posted: Thursday 11 January 2018 22:50
by rhendriks
blauwebuis wrote: Thursday 11 January 2018 9:13 @rhendrink: go to settings and then the theme tab. Tick the box. Done.
Sorry , It didn't help.
Re: Aurora theme
Posted: Friday 12 January 2018 8:42
by jeanclic
@rhendrink: I think what he means is to tick the box "Use entire screen for item display", which I think is the "fluid" thing.
Re: Aurora theme
Posted: Friday 12 January 2018 9:33
by Jochem
Blauwebuis,
Is there a solution for the thing that everyday when I login the background colors and text colors are appear as default colors, when I click on refresh (F5) I get the colors I selected in setup.
Re: Aurora theme
Posted: Friday 12 January 2018 11:17
by blauwebuis
@jochem: ah, your post helps me better understand what is going on (since I can't reproduce the issue). Do other people have the same thing? Where a refresh does bring back your settings?
Re: Aurora theme
Posted: Friday 12 January 2018 12:37
by Eoreh
blauwebuis wrote: Friday 12 January 2018 11:17 @jochem: ah, your post helps me better understand what is going on (since I can't reproduce the issue). Do other people have the same thing? Where a refresh does bring back your settings?
I have seen many places in previous versions, but not now.
Its good idea to bring number version to theme Aurora for egz. in Theme settings "Aurora" near About.
So We could ask for the version number to which people report an error
Re: Aurora theme
Posted: Friday 12 January 2018 13:38
by bdormael
I have this on my iPhone X, on my iPad and Windows PC it's working fine.
Also on my iPhone X the dashboard is always showing the "default" template (not Aurora), I can't get to show Aurora. The other tabs are OK.
Re: Aurora theme
Posted: Saturday 13 January 2018 11:44
by blauwebuis
There's a new version online that should fix the login problem, and may fix some others too.
Re: Aurora theme
Posted: Saturday 13 January 2018 18:05
by jeanclic
Just tried the last release : it still works, but I have things like following in the dev console on Chrome. is that normal ?
domoticzdevices.js:28 [Violation] Added non-passive event listener to a scroll-blocking 'touchstart' event. Consider marking event handler as 'passive' to make the page more responsive. See https://www.chromestatus.com/feature/5745543795965952
makeSVGnode @ domoticzdevices.js:28
Device.drawIcon @ domoticzdevices.js:499
Device.htmlMinimum @ domoticzdevices.js:745
(anonymous) @ FloorplanController.js:292
each @ jquery-1.12.0.min.js:2
(anonymous) @ FloorplanController.js:278
(anonymous) @ FloorplanController.js:275
(anonymous) @ angular.min.js:96
(anonymous) @ angular.min.js:131
$eval @ angular.min.js:145
$digest @ angular.min.js:142
$apply @ angular.min.js:146
l @ angular.min.js:97
J @ angular.min.js:102
t.onload @ angular.min.js:103
angular.min.js:102 [Violation] 'load' handler took 157ms
[Violation] Forced reflow while executing JavaScript took 46ms
38domoticzdevices.js:28 [Violation] Added non-passive event listener to a scroll-blocking 'touchstart' event. Consider marking event handler as 'passive' to make the page more responsive. See https://www.chromestatus.com/feature/5745543795965952
[Violation] Forced reflow while executing JavaScript took 37ms
75domoticzdevices.js:28 [Violation] Added non-passive event listener to a scroll-blocking 'touchstart' event. Consider marking event handler as 'passive' to make the page more responsive. See https://www.chromestatus.com/feature/5745543795965952
[Violation] Forced reflow while executing JavaScript took 39ms
37domoticzdevices.js:28 [Violation] Added non-passive event listener to a scroll-blocking 'touchstart' event. Consider marking event handler as 'passive' to make the page more responsive. See https://www.chromestatus.com/feature/5745543795965952
[Violation] Forced reflow while executing JavaScript took 43ms
25domoticzdevices.js:28 [Violation] Added non-passive event listener to a scroll-blocking 'touchstart' event. Consider marking event handler as 'passive' to make the page more responsive. See https://www.chromestatus.com/feature/5745543795965952
13domoticzdevices.js:28 [Violation] Added non-passive event listener to a scroll-blocking 'touchstart' event. Consider marking event handler as 'passive' to make the page more responsive. See https://www.chromestatus.com/feature/5745543795965952
[Violation] Forced reflow while executing JavaScript took 34ms
dashboard_show_data_visualizations.js:18 THEME JS - dataviz is enabled
Re: Aurora theme
Posted: Saturday 13 January 2018 20:48
by Jochem
Hello Blauwebuis,
I just tried your new version and it seems much more stable.
Only one thing I found, if I click on Set clock as an item, it start with one clock on the dashboard, after a few seconds I have another clock, and after a few minutes I have a lot of clocks on the dashboard...
I call it a little clock bug.. :D
do you already know about this thing???
- thuis morning i started domoticz om my iPad, it started with the default white colors of the Aurora theme, but normaly with a refresh it turned to the blue colors i conigured but now i cant het the blue colors back, even if i click save settings... everything stays white..
Re: Aurora theme
Posted: Sunday 14 January 2018 13:35
by rhendriks
rhendriks wrote: Tuesday 09 January 2018 18:57 Before the last update I had three columns , now is this two .
The "overige sensoren "stood right along the other column,
How can I change the width of the columns?
I can't solved the problem , where can I find the code who is responsible for the width?
Re: Aurora theme
Posted: Sunday 14 January 2018 13:41
by remb0
blauwebuis wrote: Thursday 11 January 2018 21:43 A white screen is an indication of a javascript error. Do you have access to the console on any of those devices, so see what the error is?
Failed to load resource: net::ERR_CONNECTION_TIMED_OUT
send @ jquery-1.12.0.min.js:4
4custom.js:393 THEME JS - Javascript loaded by RequireJS
3jquery-1.12.0.min.js Failed to load resource: net::ERR_CONNECTION_TIMED_OUT
/#/Offline:1 Application Cache Error event: Manifest fetch failed (6) https://mydomain.nl/html5.appcache
custom.js:686 THEMEJS - URL change detected
custom.js:456 inside page change detected
custom.js:461 https://mydomain.nl/#/Offline
custom.js:468 THEME JS - new page: offline
custom.js:82 THEME JS - checking if mobile display should be used
custom.js:91 THEHE JS - is mobile view also on the desktop? false
custom.js:489 THEME JS - NEW BACK END
custom.js:539 observer: observing mainview container
custom.js:499 load observer fired
custom.js:509 observer: A new mainview was loaded. Disconnecting observer and starting improvement.
custom.js:568 THEME JS - now in backend improvements
when using internet adres I don't get this errors
Re: Aurora theme
Posted: Sunday 14 January 2018 15:21
by Mace
Really like this theme, great work!
What I can't figure out is when a graph is shown in a temperature block and when it's not:
Re: Aurora theme
Posted: Monday 15 January 2018 9:57
by blauwebuis
@mace: have a look in the file "dashboard_show_data_visualizations.js"
At the top you will find all the visualisations that are currently started. If you can help your item become part of the list, that would be great.
@rembo: looks like an issue with a file outside of the theme. Hmm. Try the latest version, see if that helps. The timeout warnings should hopefully be gone. And does the new version fix your other issue too? I've simplified how it grabs the base url.
@rhendriks: I think I know what the problem is. Do you have an item with a very long name? Currently that makes items a little bit wider it seems. That might push the entire column down. I'm looking into it.
@jochem: clock bug has been fixed. Thanks for pointing it out.
@piokuc: I've created a mobile icon, and have suggested it for domoticz to use in a pull request. https://github.com/domoticz/domoticz/pull/2056
@eoreh: For now I won't do version numbers. If people have issues, the first thing they should do is upgrade to the latest version. Since a theme is just CSS and Javascript there is no risk to your system in upgrading.
@bdormael: the dashboard is something that Domoticz changes to the oldschool iPhone look. I would like it to not do that. But currently there is no option in domoticz to turn it off. Perhaps you can make a feature request?
Re: Aurora theme
Posted: Monday 15 January 2018 13:04
by remb0
require.js:8 Uncaught Error: Load timeout for modules: main,../acttheme/dashboard_show_data_visualizations,../acttheme/dashboard_merge_items_with_same_name,../acttheme/dashboard_camera_previews,../acttheme/blockly_import_export
http://requirejs.org/docs/errors.html#timeout
    at C (require.js:8)
    at D (require.js:13)
    at require.js:14
C @ require.js:8
D @ require.js:13
(anonymous) @ require.js:14
setTimeout (async)
D @ require.js:14
setTimeout (async)
D @ require.js:14
setTimeout (async)
D @ require.js:14
setTimeout (async)
D @ require.js:14
setTimeout (async)
D @ require.js:14
setTimeout (async)
D @ require.js:14
setTimeout (async)
D @ require.js:14
setTimeout (async)
D @ require.js:14
setTimeout (async)
D @ require.js:14
setTimeout (async)
D @ require.js:14
setTimeout (async)
D @ require.js:14
setTimeout (async)
D @ require.js:14
setTimeout (async)
D @ require.js:14
setTimeout (async)
D @ require.js:14
setTimeout (async)
D @ require.js:14
setTimeout (async)
D @ require.js:14
setTimeout (async)
D @ require.js:14
setTimeout (async)
D @ require.js:14
setTimeout (async)
D @ require.js:14
setTimeout (async)
D @ require.js:14
setTimeout (async)
D @ require.js:14
setTimeout (async)
D @ require.js:14
setTimeout (async)
D @ require.js:14
setTimeout (async)
D @ require.js:14
setTimeout (async)
D @ require.js:14
setTimeout (async)
D @ require.js:14
setTimeout (async)
D @ require.js:14
setTimeout (async)
D @ require.js:14
setTimeout (async)
D @ require.js:14
setTimeout (async)
D @ require.js:14
setTimeout (async)
D @ require.js:14
setTimeout (async)
D @ require.js:14
(index):1 Application Cache Error event: Manifest fetch failed (6) https://domain.nl/html5.appcache
jquery-1.12.0.min.js:4 GET https://domain.nl/json.htm?type=command&param=getconfig net::ERR_CONNECTION_TIMED_OUT
ajax @ jquery-1.12.0.min.js:4
$rootScope.GetGlobalConfig @ app.js:649
(anonymous) @ app.js:746
invoke @ angular.min.js:41
(anonymous) @ angular.min.js:43
q @ angular.min.js:7
cb @ angular.min.js:43
c @ angular.min.js:20
Bc @ angular.min.js:21
(anonymous) @ angularAMD.min.js:7
i @ jquery-1.12.0.min.js:2
add @ jquery-1.12.0.min.js:2
n.fn.ready @ jquery-1.12.0.min.js:2
c.bootstrap @ angularAMD.min.js:7
(anonymous) @ app.js:928
execCb @ require.js:29
check @ require.js:18
(anonymous) @ require.js:23
(anonymous) @ require.js:8
v @ require.js:7
emit @ require.js:23
check @ require.js:19
enable @ require.js:23
init @ require.js:17
E @ require.js:14
completeLoad @ require.js:28
onScriptLoad @ require.js:29
jquery-1.12.0.min.js:4 XHR failed loading: GET "https://domain.nl/json.htm?type=command&param=getconfig".
v @ require.js:7
E @ require.js:14
jquery-1.12.0.min.js:4 GET https://domain.nl/json.htm?type=command&param=getversion net::ERR_CONNECTION_TIMED_OUT
(anonymous) @ app.js:748
v @ require.js:7
E @ require.js:14
jquery-1.12.0.min.js:4 XHR failed loading: GET "https://domain.nl/json.htm?type=command&param=getversion".
v @ require.js:7
E @ require.js:14
jquery-1.12.0.min.js:4 XHR failed loading: GET "https://domain.nl/json.htm?type=command&param=getauth".
(anonymous) @ app.js:775
v @ require.js:7
E @ require.js:14
jquery-1.12.0.min.js:4 GET https://domain.nl/json.htm?type=command&param=getauth net::ERR_CONNECTION_TIMED_OUT
v @ require.js:7
E @ require.js:14
require.js:29 [Violation] 'load' handler took 21231ms
I see a big domoticz icon and the message: domoticz offline
maybe something to do with authentication (because inside my netwerk 192.168.x.x i have no authentication) ?
Re: Aurora theme
Posted: Monday 15 January 2018 17:32
by Jochem
@ blauwebuis
Maybe it's a good idea to put a version number in the clock box which can be placed on the dashboard page..
It will be very handy to see what version everybody is talking about, and that we can follow your progression. ;-)
just found some little bugs in your new version;
-the camera is not showing it's stream...
- on the attached picture you see in the right lower corner "© 2012-2018 Domoticz | WWW: Domoticz.com". if I scrol the screen it stays in that box..
Good luck... do your best ;-)
