I think this can be done in the config.js, see wiki for examples (http://www.domoticz.com/wiki/Dashticz_V2_-_Custom_JS)WaTTe wrote:Change the text of a temperature sensor depending on the measured temperature.
Eg a green color at 5 degrees an orange color at 15 a red at 25 etc.
Dashticz - Feature Requests
- htilburgs
Re: Dashticz - Feature Requests
Hardware:
- htilburgs
Sorry, I forgot to reply, but it works great!!robgeerts wrote:I've added this class in BETA: calendar_iconhtilburgs wrote:Rob, one question. Is it possible to change the class of the calendar image?
Now is has class ICON and is it not quite possible to change format of location of the image.
Thanx for the hard work.
CSS:
.icon.calendar_icon {
max-width: 45px !important;
margin-top: -6px !important;
margin-left: -6px !important;
}- Attachments
- Schermafbeelding 2017-06-23 om 13.12.39.png (77.69 KiB) Viewed 4081 times
Hardware:
MsbS
Currently the graphs for T+H+B are combined - each data item in the graph has 3 values. I would love 3 buttons in the graph to switch to showing T or H or B.
- mlamie
- Domoticz version: 3.5877
Great screenshot. I would like to have the F1 calander in Dashticz as well. Can you share your setup? Which sources you used? etc...htilburgs wrote: Sorry, I forgot to reply, but it works great!!
CSS:Code: Select all
.icon.calendar_icon { max-width: 45px !important; margin-top: -6px !important; margin-left: -6px !important; }
Raspberry Pi 3, RaZberry, RFXtrx433
Various Z-Wave devices, KlikAanKlikUit devices, ESP8266 NodeMCU, Sonoff POW and a Essent E-thermostaat
IP camera: Dahua 4MP IPC-HDBW4421R-AS, Vivotek FD8134V
- HansieNL
Blah blah blah
Derik
- Domoticz version: BETA
Dear...
Perhaps possible to make a other screen [ url ] for buienradar?
Now we are looking to a picture for the past hour...
Perhaps possible to implement future 3 hours:
https://www.buienradar.nl/nederland/nee ... adar/3uurs
Or someone help with a how to change the url in the beta version.
Like to hear...
Like to hear...
robgeerts
- Domoticz version: 3.7067
Unfortunately, there's no image you can use for the upcoming 3 hours.... havent found one yet..
jake
bumpjake wrote:Feature request:
- Ability to change amount of digits in a block value (for instance: don't show 7.123 kWh today, but 7.1 kWh today) this to save space in the block
- Ability to change a block's value unit (for instance not 1500 Watt, but 1500 W) this to save space in the block
Not needed for me, but possibly for some specific cases
- Ability to convert a block value (for instance, not 1500W, but 1.5kW)
blacksn0w
Will have a look on this, since the data is submitted completely from Domoticz, it would be neccesary to submit the -to replaced text- and the -replace with- text.jake wrote:jake wrote:Feature request:
For example
blocks[123]['unit'] = 'Watt,W'
//Just pushed this to Github, waiting for merge (https://github.com/robgeerts/dashticz_v2/pull/107)
Usage: blocks[123]['unit'] = 'Watt;W';
robgeerts
Available in latest beta!
jake
I just did a git pull, I updated the config.js file:robgeerts wrote:Available in latest beta!
blocks['39_2'] = {}
blocks['39_2']['width'] = 4;
blocks['39_2']['title'] = 'Opbrengst' //vermogen in Watt
blocks['39_2']['unit'] = 'Watt;W';
blocks['142_1'] = {}
blocks['142_1']['width'] = 4;
blocks['142_1']['title'] = 'Verbruik' //vermogen in Watt
blocks['142_1']['unit'] = 'Watt;W';-
robgeerts
Ah, you are using another block then the one blacksn0w created it for...
Are you already on it or shall I take a look?
@blacksn0w: he's using a block wich is defined in main.js... in the IF on row 944, 976 or 1019.blacksn0w wrote:Usage: blocks[123]['unit'] = 'Watt;W';
blacksn0w
I'm not really familiar with this devices, so i would be glad if you could have a look.robgeerts wrote:Ah, you are using another block then the one blacksn0w created it for...
I'm afraid i would destroy the whole function more than adding this feature
robgeerts
Will do
robgeerts
Could you test latest beta?jake wrote:I just did a git pull, I updated the config.js file:robgeerts wrote:Available in latest beta!
But no change, I still see 'Watt' instead of 'W'Code: Select all
blocks['39_2'] = {} blocks['39_2']['width'] = 4; blocks['39_2']['title'] = 'Opbrengst' //vermogen in Watt blocks['39_2']['unit'] = 'Watt;W'; blocks['142_1'] = {} blocks['142_1']['width'] = 4; blocks['142_1']['title'] = 'Verbruik' //vermogen in Watt blocks['142_1']['unit'] = 'Watt;W';
jake
I did, but no change, still displaying 'Watt' instead of the requested 'W'. I at the moment use the PVoutput.org wattage and the P1 smart meter wattage with the new 'units' style.robgeerts wrote:Could you test latest beta?jake wrote:I just did a git pull, I updated the config.js file:robgeerts wrote:Available in latest beta!
Derik
Dear Rob,
a option to place the day data in 1 line.: Save space and read simple?
Change the color of this weather icons....
Change the color of temp automatically when
hot = red
warm = orange
normal = white
cold = bleu
very cold.....
Edit:
Please also the ccs to change the text size and color [ please
hot = red
warm = orange
normal = white
cold = bleu
very cold.....
Edit:
sebasjuh
I saw the Formula1 schedule would it be something to add a football calendar to see what matches are coming up (dutch eredivisie league or maybe only for your favorite football club) ?
- HansieNL
The F1 calendar is just a personal Google calender, so nothing special. If you can find a ics file from your favorite football club you can add it to Dashticz the same way as the F1 calndar.sebasjuh wrote:I saw the Formula1 schedule would it be something to add a football calendar to see what matches are coming up (dutch eredivisie league or maybe only for your favorite football club) ?
Blah blah blah
garethhowell
- Domoticz version: 3.9317
Ability to vary the column layout depending on the display device.
My dashboard is a pretty standard 5,5,2 column layout with the main switches and scenes in the middle column. This makes sense on a tablet display, but not on a phone.
What I'd like to be able to do is present column 2 first if the display device is less that a certain width.
