Dashticz - Feature Requests
Locked
htilburgs
Re: Dashticz - Feature Requests
Post by htilburgs »
WaTTe wrote:Change the text of a temperature sensor depending on the measured temperature.
Eg a green color at 5 degrees an orange color at 15 a red at 25 etc.
I think this can be done in the config.js, see wiki for examples (http://www.domoticz.com/wiki/Dashticz_V2_-_Custom_JS)
Hardware:
htilburgs
Post by htilburgs »
robgeerts wrote:
htilburgs wrote:Rob, one question. Is it possible to change the class of the calendar image?
Now is has class ICON and is it not quite possible to change format of location of the image.
I've added this class in BETA: calendar_icon
Sorry, I forgot to reply, but it works great!!
Thanx for the hard work.
CSS:
.icon.calendar_icon {
	max-width: 45px !important;
	margin-top: -6px !important;
	margin-left: -6px !important;
Schermafbeelding 2017-06-23 om 13.12.39.png (77.69 KiB) Viewed 3430 times
Hardware:
MsbS
Post by MsbS »
Currently the graphs for T+H+B are combined - each data item in the graph has 3 values. I would love 3 buttons in the graph to switch to showing T or H or B.
mlamie
Domoticz version: 3.5877
Post by mlamie »
htilburgs wrote: Sorry, I forgot to reply, but it works great!!
CSS:
Great screenshot. I would like to have the F1 calander in Dashticz as well. Can you share your setup? Which sources you used? etc...
Raspberry Pi 3, RaZberry, RFXtrx433
Various Z-Wave devices, KlikAanKlikUit devices, ESP8266 NodeMCU, Sonoff POW and a Essent E-thermostaat
IP camera: Dahua 4MP IPC-HDBW4421R-AS, Vivotek FD8134V
HansieNL
Post by HansieNL »
CSS:
https://www.domoticz.com/forum/viewtopi ... 20#p134446
Blah blah blah
Derik
Post by Derik »
Dear...
Perhaps possible to make a other screen [ url ] for buienradar?
Now we are looking to a picture for the past hour...
Perhaps possible to implement future 3 hours:
https://www.buienradar.nl/nederland/nee ... adar/3uurs
Or someone help with a how to change the url in the beta version.
Like to hear...
robgeerts
Domoticz version: 3.7067
Post by robgeerts »
Unfortunately, there's no image you can use for the upcoming 3 hours.... havent found one yet..
jake
Post by jake »
jake wrote:Feature request:
- Ability to change amount of digits in a block value (for instance: don't show 7.123 kWh today, but 7.1 kWh today) this to save space in the block
- Ability to change a block's value unit (for instance not 1500 Watt, but 1500 W) this to save space in the block
Not needed for me, but possibly for some specific cases
- Ability to convert a block value (for instance, not 1500W, but 1.5kW)
bump :oops:
blacksn0w
Post by blacksn0w »
Will have a look on this, since the data is submitted completely from Domoticz, it would be neccesary to submit the -to replaced text- and the -replace with- text.
For example
blocks[123]['unit'] = 'Watt,W'
//Just pushed this to Github, waiting for merge (https://github.com/robgeerts/dashticz_v2/pull/107)
Usage: blocks[123]['unit'] = 'Watt;W';
robgeerts
Post by robgeerts »
Available in latest beta!
jake
Post by jake »
robgeerts wrote:Available in latest beta!
I just did a git pull, I updated the config.js file:
blocks['39_2'] = {}
blocks['39_2']['width'] = 4;
blocks['39_2']['title'] = 'Opbrengst' //vermogen in Watt
blocks['39_2']['unit'] = 'Watt;W';
blocks['142_1'] = {}
blocks['142_1']['width'] = 4;
blocks['142_1']['title'] = 'Verbruik' //vermogen in Watt
blocks['142_1']['unit'] = 'Watt;W';
But no change, I still see 'Watt' instead of 'W'
robgeerts
Post by robgeerts »
Ah, you are using another block then the one blacksn0w created it for...
blacksn0w wrote:Usage: blocks[123]['unit'] = 'Watt;W';
@blacksn0w: he's using a block wich is defined in main.js... in the IF on row 944, 976 or 1019.
Are you already on it or shall I take a look?
blacksn0w
Post by blacksn0w »
robgeerts wrote:Ah, you are using another block then the one blacksn0w created it for...
I'm not really familiar with this devices, so i would be glad if you could have a look.
I'm afraid i would destroy the whole function more than adding this feature :lol:
robgeerts
Post by robgeerts »
Will do :)
robgeerts
Post by robgeerts »
blocks['39_2'] = {}
Could you test latest beta?
jake
Post by jake »
blocks['39_2'] = {}
I did, but no change, still displaying 'Watt' instead of the requested 'W'. I at the moment use the PVoutput.org wattage and the P1 smart meter wattage with the new 'units' style.
Derik
Post by Derik »
Dear Rob,
a option to place the day data in 1 line.:
Save space and read simple?
Change the color of this weather icons....
Change the color of temp automatically when
hot = red
warm = orange
normal = white
cold = bleu
very cold.....:-)
Edit:
Please also the ccs to change the text size and color [ please :-) ]
sebasjuh
Post by sebasjuh »
I saw the Formula1 schedule would it be something to add a football calendar to see what matches are coming up (dutch eredivisie league or maybe only for your favorite football club) ?
HansieNL
Post by HansieNL »
sebasjuh wrote:I saw the Formula1 schedule would it be something to add a football calendar to see what matches are coming up (dutch eredivisie league or maybe only for your favorite football club) ?
The F1 calendar is just a personal Google calender, so nothing special. If you can find a ics file from your favorite football club you can add it to Dashticz the same way as the F1 calndar.
Blah blah blah
garethhowell
Domoticz version: 3.9317
Post by garethhowell »
Ability to vary the column layout depending on the display device.
My dashboard is a pretty standard 5,5,2 column layout with the main switches and scenes in the middle column. This makes sense on a tablet display, but not on a phone.
What I'd like to be able to do is present column 2 first if the display device is less that a certain width.
Locked
