framb0ise v2 - awesome new dashboard!
jkimmel
Domoticz version: 2021.1
Re: framb0ise v2 - awesome new dashboard!
Post by jkimmel »
safi78 wrote:In settings, you only have to specify your domoticz server url, not the /framb0ise in the url.
Problem is settings don't open.
Having installed jessie and domoticz from scratch only cloned framb0ise into /domoticz/www
Domoticz is running fine.
Rfxcom
Raspi 4
ehallq
Post by ehallq »
Had trouble when installing this first, I had to visit ****/frambi0se/ . ****/frambi0se did not work
jkimmel
Post by jkimmel »
I needed
xxx.xxx.xxx.xxx:8080/framb0ise/index.html
Rfxcom
Raspi 4
markjgabb
Domoticz version: 3.8153
Post by markjgabb »
awesome add on, very nice and simple to use, easy layout and great working setup
was wondering for traffic what sort of information you would need to setup for australia/victoria....
for instance our local road authority has this system
http://api.vicroads.vic.gov.au/
is that the kind of thing you need?
V 2020.2 RPI 3
RFlink 334 mhz
mysensors
broadlink
Mirabella Genio Globes
markjgabb
Post by markjgabb »
is there any reason the calendar part cant be achieved using the private url for ggogle?
V 2020.2 RPI 3
RFlink 334 mhz
mysensors
broadlink
tlpeter
Post by tlpeter »
Now this is great and indeed only Domoticz config and that is what i need.
I do not want to setup a second tool only to see what i already have.
This is a great easy tool.
Maikie
Post by Maikie »
Would it be possible to show a negative value for power?
jvdz
Domoticz version: 4.107
Post by jvdz »
Maikie wrote: Friday 25 August 2017 11:47 Would it be possible to show a negative value for power?
Could you make an issue in github please so we dont forget to follow up?
Jos
jvdz
Post by jvdz »
sander815 wrote: Friday 25 August 2017 12:07 why doný i see the settings page when i open http://192.168.1.227:8080/framb0ise/
Did you actually copy the files there?
Have you tried adding index.html to that line?
Jos
thruhge
Post by thruhge »
Thanks for the great work.
I have a question about Blinds (433mhz), is this function available? Because I just see a powerbutton only.
safi78
Domoticz version: LastBeta
Post by safi78 »
thruhge wrote: Sunday 27 August 2017 9:44 Thanks for the great work.
You're welcome.
Is it possible to send us the json for this device?
Then we can have a look how this should be presented in the webinterface.
homebridge, rfxcom, zwave, nest, applamp, hue, debian, apple, mysensors, netatmo, fibaro, synology, foscam, otherz
safi78
Post by safi78 »
markjgabb wrote: Tuesday 01 August 2017 2:04 awesome add on, very nice and simple to use, easy layout and great working setup
That could work. Can you send me an example URL for your situation? Then we'll have a look at this :)
safi78
Post by safi78 »
jvdz wrote: Saturday 26 August 2017 10:32
Jos
Very interesting, I don't remember we 'don't do' negatives? Must be a javascript thingie.
tlpeter
Post by tlpeter »
Hi Safi78, i have a sunscreen which is controller by a fibaro roller shutter but all i see is a on/off switch.
This is the json for this deice:
   "ActTime" : 1503938059,
   "ServerTime" : "2017-08-28 18:34:19",
   "Sunrise" : "06:49",
   "Sunset" : "20:36",
   "result" : [
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "BatteryLevel" : 255,
         "CustomImage" : 0,
         "Data" : "Closed",
         "Description" : "",
         "Favorite" : 1,
         "HardwareID" : 16,
         "HardwareName" : "Zwave USB",
         "HardwareTypeVal" : 21,
         "HaveDimmer" : true,
         "HaveGroupCmd" : true,
         "HaveTimeout" : false,
         "ID" : "00000201",
         "Image" : "Light",
         "IsSubDevice" : false,
         "LastUpdate" : "2017-08-28 11:26:24",
         "Level" : 255,
         "LevelInt" : 255,
         "MaxDimLevel" : 100,
         "Name" : "Zonnescherm",
         "Notifications" : "false",
         "PlanID" : "12",
         "PlanIDs" : [ 12 ],
         "Protected" : false,
         "ShowNotifications" : true,
         "SignalLevel" : "-",
         "Status" : "Closed",
         "StrParam1" : "",
         "StrParam2" : "",
         "SubType" : "Switch",
         "SwitchType" : "Blinds",
         "SwitchTypeVal" : 3,
         "Timers" : "false",
         "Type" : "Light/Switch",
         "TypeImg" : "blinds",
         "Unit" : 1,
         "Used" : 1,
         "UsedByCamera" : false,
         "XOffset" : "0",
         "YOffset" : "0",
         "idx" : "2209"
   "status" : "OK",
   "title" : "Devices"
Can you fix this?
jvdz
Post by jvdz »
tlpeter wrote: Monday 28 August 2017 18:37 I have a sunscreen which is controller by a fibaro roller shutter but all i see is a on/off switch.
That is how it is implemented at this moment. It shows a Blue button for when it is (partially) closed and a green button for when it is Open.
It sends a Toggle Switch when pressed.
Jos
safi78
Post by safi78 »
Fixed by jvdz, try latest update.
Robbonnechere
Post by Robbonnechere »
Hi, I am a complete newbie so please be gentle ! If this post is in the wrong area please accept my apologies.
I have just setup my first Domoticz install. I set it up following a step by step giude, creating a new user called domoticz. Everything appears to run OK. I have working devices switches and a room and floor plan. When I tried to install your dashborad I got a permisions error, so I installed using sudo.
I now get a blank framb0ise page and can click on the settings icon and fill in the page, but nothing happens and it never updates the settings info. If I refresh or reboot there is still a blank page with no settings saved. I think possibly this is a permisions problem but have no idea where to look.
Any help or advice would be welcomed.
Rob
jvdz
Post by jvdz »
Hi Rob, do you have any ROOMPLANs defined in Domoticz with devices in it as those are used by franb0ise?
Jos
OttoBismark
Post by OttoBismark »
thanks to Safi78 for the good work. Since i'm a real newbie i was able to use framb0ise even if i'm not able to correctly show the weather forecast. Is it possible to integrate a widget like this one https://forecast.io/embed/#lat=41.91697 ... &name=Rome?
The darksky widget doesn't work for me. it shows an empty widget.
Last question: it would be possible to change the background image?
Thank you
Cheers
silver323
Post by silver323 »
I want to try this new dashboard. I installed it and when i open the browser with the address i get the start page.
Not with the setting right away but i click on the settings. Put my domoticz server and set storage location. Click on save.
After refreshing nothing happens. Settings is empty.
Cleared browser cache. Installed again from scratch. Still no luck.
