Page 73 of 94
Posted: Friday 24 August 2018 7:46
by sakbal
I just tried to do a manual install of 'domoticz_armada38x-6.2_4.0.9700-7.spk.tar' to my Synology DS216j but i get "invalid file format"
How do I resolve this?
I currently have 3.0.8153-7 installed
Sakbal
Posted: Friday 24 August 2018 8:32
by jumbotroll
sakbal wrote: Friday 24 August 2018 7:46
Sakbal
Remove .tar the file name should be only .spk domoticz_armada38x-6.2_4.0.9700-7.spk
Posted: Sunday 09 September 2018 20:41
by Venemans
@Jumbotroll
Is is possible to make a new version of Domoticz for Synology Dsm version 5.2?
In the latest version there is a problem with sunset and sunrise time. It is now stuck on a fixed time and doesn't follow sunset and sunrise.
Because of that my Milight lamps switch on to late.
I hope you can make a new version of Domoticz for my old Synology DS410.
I am now running version 3.8837.
Thanks in advance.
Posted: Sunday 09 September 2018 21:14
by jumbotroll
Venemans wrote: Sunday 09 September 2018 20:41
@Jumbotroll
Thanks in advance.
Sorry DS410 use arch-ppc853x and have to old gcc from synology to compile newer versions of domoticz.
Posted: Sunday 09 September 2018 22:56
by Venemans
@Jumbotroll
But can you compile a newer version then I have of Domoticz
version V3. 0 for DS410?
I think the problem will be solved then.
I understand that compiling a version 4 for DS410 is impossible for you.
Thank you.
Posted: Thursday 20 September 2018 7:58
by michass
Please help!
I have DS119J, unit is not available yet.
I can't install domoticz
Please prepare proper version for this model
- 2018-09-20 07_54_29-Domowy - Synology DiskStation.png (61.46 KiB) Viewed 3278 times
Posted: Thursday 20 September 2018 10:28
by jimicek
Hi Jumbotroll,
please what is the last available Domoticz version for Synology DSM-5.2? At
www.jadahl.com I found for my DS213 the last stable version Domoticz v3.0.5877-7 and the last beta domoticz_88f6282-5.2_3.0.8922-7.spk.
Is possible to compile some new version for this NAS (either by you, or by me - can you share the experience?) - or are some problems (uncompatible system) ?
Anyway thank you so much for all your work for Syno Domoticz community.
Cheers, Jimicek
Posted: Thursday 20 September 2018 10:37
by jumbotroll
jimicek wrote: Thursday 20 September 2018 10:28
Hi Jumbotroll,
Cheers, Jimicek
I have posted this answer in a lot of post here on the forum..
The toolchain and gcc from synology for arch-88f62xx is to old and is not compatible to build newer version of domoticz.
Posted: Thursday 20 September 2018 10:40
by jumbotroll
michass wrote: Thursday 20 September 2018 7:58
Please help!
DS119j use arch-armada37xx and I will build a beta version for you to test.
You can download from my server
Here:
http://www.jadahl.com/domoticz_beta_6.2/
Posted: Friday 21 September 2018 10:04
by michass
jumbotroll wrote: Thursday 20 September 2018 10:40
Please help!
Here:
Working:D
Can you prepare stable?
Posted: Friday 21 September 2018 10:37
by jumbotroll
michass wrote: Friday 21 September 2018 10:04
Working:D
I will build stable version for armada37xx when next stable version is ready.
Posted: Monday 24 September 2018 11:48
by michass
Hi Jumbotroll,
I have 4.0.10007-7 package without Python and i have feeling, that i have conflict with surveillance, Drive, git and download station.
Maybe this is problem with compatibility syno packages with new hardware. I don't know, but i know, when syno packages are disabled Unit works fine and when syno packages run without domoticz also.
Best Regards
Michał
Posted: Monday 24 September 2018 16:33
by jumbotroll
michass wrote: Monday 24 September 2018 11:48
Hi Jumbotroll,
Best Regards
Michał
I use 4.0.10007-7 on DS-712+ with latest DSM version and have none of this problem..
Maybe you have some conflict with webserver port?
Did you change default ports? http-8084 and https-8443.
Posted: Monday 24 September 2018 23:31
by michass
I have use default 8084 and 8443 ports without webserver
Posted: Monday 24 September 2018 23:44
by jumbotroll
michass wrote: Monday 24 September 2018 23:31
Take backup of domoticz.db and try to reinstall domoticz package, maybe something went wrong under update DSM or latest domoticz..
Posted: Wednesday 26 September 2018 19:06
by nono212
Hello JumboTroll
I have a small problem with the last image .
I am trying to work with EQ-3 max ( I follow this wiki
https://www.domoticz.com/wiki/EQ3_MAX! )
So I was using it on my RPi It works fine but I prefer to work on Synology ( more reliable )
these are the requirements :
sudo apt-get install lua5.2
sudo apt-get install lua-socket
sudo apt-get install luarocks
sudo luarocks install luasec
sudo luarocks install luasocket
sudo luarocks install basexx
when I type lua with the name of the script in the wiki there is no lua program ...
Maybe I am doing it wrong ?
Can you please Help
Posted: Wednesday 26 September 2018 21:58
by jumbotroll
nono212 wrote: Wednesday 26 September 2018 19:06
Hello JumboTroll
Can you please Help
Sorry there is no lua spk (package) for synology yet...
You can't use apt-get install commands on synology.
Posted: Thursday 27 September 2018 13:35
by michass
jumbotroll wrote: Monday 24 September 2018 23:44
Still the same.
I think DS119J have better CPU, same RAM, but have limitations.
On DS115J everything works. maybe not fast but works. They want, to buy more expensive models.
Posted: Saturday 29 September 2018 14:42
by nono212
thanks to mzvut for MAX there is a new plugin (
viewtopic.php?p=192832#p192832)
so I do not need anymore LUA
I still have a question :In domoticz there is log ... that is logrotated ...
I would like to send the log of domoticz to the syslog of the Synology So It will be kept more long ...
Can you help ?
Posted: Tuesday 02 October 2018 17:24
by Ashram56
Good Morning,
Completely new to Domoticz (currently using Jeedom), I wanted to install it on my Synology NAS (a DS1618+), however it looks like your server (and as a result your repository) are down ?
Best regards
