Controlicz - Domoticz to Google Home/Assistant integration Topic is solved
Alexa, Google Home and Siri
salvacalatayud
Re: Controlicz - Domoticz to Google Home/Assistant integration
Post by salvacalatayud »
PM sent
Madgeni wrote:thats not good - had a quick check, can you access your Domoticz host over the internet? it's timing out.
Enviado desde mi Redmi 4X mediante Tapatalk
salvacalatayud
I can access over Internet without problems, only get an invalid ssl certificate advice
Madgeni
Post by Madgeni »
Ok, that's weird, your host is now showing as available. Try again?
salvacalatayud
Madgeni wrote: Wednesday 27 June 2018 14:49 Ok, that's weird, your host is now showing as available. Try again?
Still the same
salvacalatayud
Now it say "sorry I couldn't reach controlicz"
Madgeni
Post by Madgeni »
I'm working on something, so there will be very small outages (it's down for 2-5 seconds per release).
salvacalatayud
Thanks Madgeni, now it is working!!
The user i had created for Controlicz didn't have permission, only could read. Changed to regular user (not admin) and works perfect.
jpvaneijk
Domoticz version: latest
Post by jpvaneijk »
jpvaneijk wrote: Thursday 21 June 2018 18:03 Thanks for the update Madgeni. I'm trying to understand what the implications could be for the situation I'm in.
My problem you solved in this post (june 13) seems te be back: http://www.domoticz.com/forum/viewtopic ... 24#p183424
All the hubs activitys's seem to by 'Light' again in Controlicz in column Google/Alexa.
I know you can fix this, you waved your magic wand before.
Is it something I did? How to permanently solve this?
I know you'll be bellyshaking when your in my home when I say: Hey Google, turn all the lights on :mrgreen: :lol: :D
Hi Madgeni,
Had lots of trouble updating to the latetst Domoticz. Had to reinstall serveral times.
Finaly it's all up-n-running again but now I've got the same problem again as before.
Yoy promissed me that couln't happen again, now didn't ya? :lol:
Thanx for your hard work man!
Madgeni
Post by Madgeni »
jpvaneijk wrote: Wednesday 27 June 2018 22:20
Hi Madgeni,
All fixed - it was an issue with one of your Selector switches :)
jpvaneijk
Post by jpvaneijk »
Thanks verry much Madgeni. All fixed and I'm verry, verry happy again!
annegerben
Post by annegerben »
Hi Madgeni/Nick,
I think since a week a get a message on my google home that "controlicz is not available right now."
Also when I logon to the website and click test connection I have to logon again.
I've been using controlicz since december '17 and worked fine until now, can you help me to get this fixed?
thanks in advance.
Madgeni
Post by Madgeni »
Hi there - can you mail me from your Controlicz profile and i'll take a look for you. Can you also try unlinking/relinking in Google Home?
Madgeni
Post by Madgeni »
Quick update:
Blinds and sensors are coming soon! Blind coding done - sensors when i get some documentation that makes sense :S
annegerben
Madgeni wrote: Friday 29 June 2018 9:17 Hi there - can you mail me from your Controlicz profile and i'll take a look for you. Can you also try unlinking/relinking in Google Home?
mail sent.
unlinking/relinking in Google Home I will try when I'm home again.
EdwinK
Post by EdwinK »
Trying to set this up. Already had contact with you. Now keep getting the 'check your connection setup' message. Tried another ddns site (no-ip), but still no luck.
Madgeni
Post by Madgeni »
EdwinK wrote: Friday 29 June 2018 10:47 Trying to set this up. Already had contact with you. Now keep getting the 'check your connection setup' message. Tried another ddns site (no-ip), but still no luck.
Assume this is fixed now?
Madgeni
Post by Madgeni »
annegerben wrote: Friday 29 June 2018 10:36
mail sent.
if you're on Android, you can do it from Google Assistant
EdwinK
Post by EdwinK »
Madgeni wrote: Friday 29 June 2018 12:26
Nope, not yet. Still trying though.
Madgeni
Post by Madgeni »
mail me if you need support, i can check the logs, see what's happening
edit: try login page, rather than basic authentication - does that make any difference?
EdwinK
Post by EdwinK »
Going to try that :)
Edit: Nope, didn't work. One time I got 'check username and password' (or something close), but other then that nothing. Might be a problem with the DDNS-servers, but I can't imagine both NO-IP and Duckdns having problems. Port 443 is open.
Screen Shot 2018-06-29 at 10.39.22.png (21.24 KiB) Viewed 2027 times
Screen Shot 2018-06-29 at 12.54.42.png (72.38 KiB) Viewed 2027 times
