Enviado desde mi Redmi 4X mediante TapatalkMadgeni wrote:thats not good - had a quick check, can you access your Domoticz host over the internet? it's timing out.
Controlicz - Domoticz to Google Home/Assistant integration Topic is solved
salvacalatayud
PM sent
salvacalatayud
I can access over Internet without problems, only get an invalid ssl certificate advice
Madgeni
Ok, that's weird, your host is now showing as available. Try again?
salvacalatayud
Still the sameMadgeni wrote: Wednesday 27 June 2018 14:49 Ok, that's weird, your host is now showing as available. Try again?
salvacalatayud
Now it say "sorry I couldn't reach controlicz"
Madgeni
I'm working on something, so there will be very small outages (it's down for 2-5 seconds per release).
salvacalatayud
Thanks Madgeni, now it is working!!
The user i had created for Controlicz didn't have permission, only could read. Changed to regular user (not admin) and works perfect.
jpvaneijk
- Domoticz version: latest
Hi Madgeni,jpvaneijk wrote: Thursday 21 June 2018 18:03 Thanks for the update Madgeni. I'm trying to understand what the implications could be for the situation I'm in.
My problem you solved in this post (june 13) seems te be back: http://www.domoticz.com/forum/viewtopic ... 24#p183424
All the hubs activitys's seem to by 'Light' again in Controlicz in column Google/Alexa.
I know you can fix this, you waved your magic wand before.
Is it something I did? How to permanently solve this?
I know you'll be bellyshaking when your in my home when I say: Hey Google, turn all the lights on![]()
Had lots of trouble updating to the latetst Domoticz. Had to reinstall serveral times.
Finaly it's all up-n-running again but now I've got the same problem again as before.
Yoy promissed me that couln't happen again, now didn't ya?
Thanx for your hard work man!
Madgeni
All fixed - it was an issue with one of your Selector switchesjpvaneijk wrote: Wednesday 27 June 2018 22:20Hi Madgeni,jpvaneijk wrote: Thursday 21 June 2018 18:03 Thanks for the update Madgeni. I'm trying to understand what the implications could be for the situation I'm in.
Yoy promissed me that couln't happen again, now didn't ya?![]()
jpvaneijk
Thanks verry much Madgeni. All fixed and I'm verry, verry happy again!
annegerben
Hi Madgeni/Nick,
I think since a week a get a message on my google home that "controlicz is not available right now."
Also when I logon to the website and click test connection I have to logon again.
I've been using controlicz since december '17 and worked fine until now, can you help me to get this fixed?
thanks in advance.
thanks in advance.
Madgeni
Hi there - can you mail me from your Controlicz profile and i'll take a look for you. Can you also try unlinking/relinking in Google Home?
Madgeni
Quick update:
Blinds and sensors are coming soon! Blind coding done - sensors when i get some documentation that makes sense :S
annegerben
mail sent.Madgeni wrote: Friday 29 June 2018 9:17 Hi there - can you mail me from your Controlicz profile and i'll take a look for you. Can you also try unlinking/relinking in Google Home?
unlinking/relinking in Google Home I will try when I'm home again.
- EdwinK
- Domoticz version: BETA
Trying to set this up. Already had contact with you. Now keep getting the 'check your connection setup' message. Tried another ddns site (no-ip), but still no luck.
Madgeni
Assume this is fixed now?EdwinK wrote: Friday 29 June 2018 10:47 Trying to set this up. Already had contact with you. Now keep getting the 'check your connection setup' message. Tried another ddns site (no-ip), but still no luck.
Madgeni
if you're on Android, you can do it from Google Assistantannegerben wrote: Friday 29 June 2018 10:36mail sent.Madgeni wrote: Friday 29 June 2018 9:17 Hi there - can you mail me from your Controlicz profile and i'll take a look for you. Can you also try unlinking/relinking in Google Home?
- EdwinK
Nope, not yet. Still trying though.
Madgeni
mail me if you need support, i can check the logs, see what's happening
edit: try login page, rather than basic authentication - does that make any difference?
- EdwinK
Going to try that
Edit: Nope, didn't work. One time I got 'check username and password' (or something close), but other then that nothing. Might be a problem with the DDNS-servers, but I can't imagine both NO-IP and Duckdns having problems. Port 443 is open.
