framb0ise v2 - awesome new dashboard!
Maikie
Re: framb0ise v2 - awesome new dashboard!
Post by Maikie »
andi216 wrote:Hi,
In Settings you can add a Iframe empty url for various?
How to get that update button? I've asked for that several times to safi78 but haven't seen it before
andi216
Domoticz version: 3.7243
Post by andi216 »
@Maikie
I've added dumm Push On Button.
Off Delay:60.
On Action: script:///home/pi/domoticz/scripts/framb0ise_update.sh
#!/bin/sh
SnapFile="/home/pi/domoticz/www/framb0ise"
# Remove Image
/bin/rm -rf $SnapFile
cd /home/pi/domoticz/www
git clone https://github.com/safi78/framb0ise
jvdz
Domoticz version: 4.107
Post by jvdz »
safi78 asked me to announce en release the recent developments, so I just updated the master branch with all changes made in the past couple of days.
The main change made in this release is that framb0ise now makes a hidden room for each fixed widget in domoticz prefixed by "$fr-????", which allows you to sort/sequence the widgets in the framb0ise webpage by simply changing the sequence of the rooms under the Domoticz Roomplans option. You can also add devices to these fixed widgets by simply adding them to the specific hidden room. For example you can add a Rain level device to the :"$fr-buienradarWidget"room which will then appear in the Buienradar widget.
The extra created roomnames will be:
$fr-anwbWidget
$fr-darkskyWidget
$fr-icsWidget
$fr-cameraWidget
$fr-infoWidget
$fr-rssWidget
$fr-cssWidget
$fr-cameraWidget-cam-? (one for each camera)
Please ensure you open the Setup page one time after upgrade, check the radio "Domoticz (for all devices)" and select the save button at the bottom to ensure things will initialize properly
Enjoy,
Jos
Change list:
Added: Framb0ise will now create a hidden room named $fra-????? for each fixed widget to allow you to sequence them in framb0ise and add additional devices to those fixed widgets.
Added: Selector switch support.
Fixed: ical parser bugfixes (thanks to adrianmihalko)
Fixed: Rain title in buienradar as the "to time" was missing.
Fixed: added multiple (4) framb0ise uservariables as the single one was unable to save all information due to length limitation in Domoticz.
jvdz
Post by jvdz »
Just updated the master branch with a number of fixes.
enjoy :)
Jos
Maikie
Post by Maikie »
Looks good!
Some changes safi made are reversed now tho. He changed some power meters to show current and day total instead of only grand total
The second one is good, current and day summary
jvdz
Post by jvdz »
Added Type "General"/sub.type "kWh" to display as the middle one in the latest commit. Hope that works.
Jos
safi78
Domoticz version: LastBeta
Post by safi78 »
Pushed a new version with support for the security panel (and some other enhancements).
homebridge, rfxcom, zwave, nest, applamp, hue, debian, apple, mysensors, netatmo, fibaro, synology, foscam, otherz
safi78
Post by safi78 »
New version:
As requested, a custom Widget (to work with services as https://www.yourweather.co.uk/widget/ for our abroad friends :) )
Just tick the box and add the url. This will be used as input for an <img source="your URL"> tag. Move it around with the 'rooms-plan'.
Screen Shot 2017-05-06 at 01.43.37.png (332.1 KiB) Viewed 7865 times
safi78
Post by safi78 »
bimse wrote:
andi216 wrote:Hi,
How did you get this great weather system
try the new update so you don't have to fiddle with code ;)
tontze
Domoticz version: Beta Ch
Post by tontze »
Did git pull. enabled darsky widget --> blank screen :(
Settings button not working after enabling darksky.
Chrome console output:
Uncaught ReferenceError: editSettings is not defined
    at HTMLAnchorElement.onclick (192.168.xxx.xxx/:28)
Also, is this normal :
Smartthings
zigbee2mqtt
RFLink 433mhz / Nrf 2.4Ghz
Mi Light
esp8266MiLight Hub
jvdz
Post by jvdz »
tontze wrote:Did git pull. enabled darsky widget --> blank screen :(
I've fixed a merge issue so try the latest version to see if that works correct again, else @safi78 needs to have a look.
Jos
tontze
Post by tontze »
Jos
Thnx, working now :)
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
andi216
Post by andi216 »
Thanks for updating, it works correctly.
And thanks for Custom Url. It seems I'm the only one who wanted this facility.
kniazio
Post by kniazio »
kniazio wrote:My cams not visible
my cams is:
http://192.168.1.161:8085/snapshot
http://192.168.1.162:8086/snapshot
Everything is very cool.
Why can not I see my cameras?
http://192.168.1.100:8078/json.htm?type=cameras
result
0
Address	"192.168.1.161"
Enabled	"true"
ImageURL	"snapshot"
Name	"Brama"
Password	""
Port	8085
Username	""
idx	"1"
1
Address	"192.168.1.162"
Enabled	"true"
ImageURL	"snapshot"
Name	"Schody"
Password	""
Port	8086
Username	""
idx	"2"
status	"OK"
title	"Cameras"
I've already dealt with myself.
godinperson
Post by godinperson »
Nice project! Where can I change the radar location and traffic jam location?
safi78
Post by safi78 »
godinperson wrote:Hi,
Hi godinperson,
These widget use a fixed data-source, hardcoded for the larger Dutch user-base. However, if you have a good website for your needs which proved a good source (JSON preferably) I'd be happy to include that for you. Let me know.
safi78
Post by safi78 »
kniazio wrote:
kniazio wrote: I've already dealt with myself.
That means you got it working? :)
kniazio
Post by kniazio »
Yes
jkimmel
Domoticz version: 2021.1
Post by jkimmel »
Settings don't open here with xxx.xxx.xxx.xxx/framb0ise
Howto check whether installation is ok?
Rfxcom
Raspi 4
safi78
Post by safi78 »
In settings, you only have to specify your domoticz server url, not the /framb0ise in the url.
