How to get that update button? I've asked for that several times to safi78 but haven't seen it beforeandi216 wrote:Hi,
In Settings you can add a Iframe empty url for various?
framb0ise v2 - awesome new dashboard!
Maikie
Re: framb0ise v2 - awesome new dashboard!
andi216
- Domoticz version: 3.7243
@Maikie
I've added dumm Push On Button.
Off Delay:60.
On Action: script:///home/pi/domoticz/scripts/framb0ise_update.sh
#!/bin/sh
SnapFile="/home/pi/domoticz/www/framb0ise"
# Remove Image
/bin/rm -rf $SnapFile
cd /home/pi/domoticz/www
git clone https://github.com/safi78/framb0ise
Off Delay:60.
#!/bin/sh
# Remove Image
- jvdz
- Domoticz version: 4.107
safi78 asked me to announce en release the recent developments, so I just updated the master branch with all changes made in the past couple of days.
The main change made in this release is that framb0ise now makes a hidden room for each fixed widget in domoticz prefixed by "$fr-????", which allows you to sort/sequence the widgets in the framb0ise webpage by simply changing the sequence of the rooms under the Domoticz Roomplans option. You can also add devices to these fixed widgets by simply adding them to the specific hidden room. For example you can add a Rain level device to the :"$fr-buienradarWidget"room which will then appear in the Buienradar widget.
The extra created roomnames will be:
$fr-anwbWidget
$fr-darkskyWidget
$fr-icsWidget
$fr-cameraWidget
$fr-infoWidget
$fr-rssWidget
$fr-cssWidget
$fr-cameraWidget-cam-? (one for each camera)
Please ensure you open the Setup page one time after upgrade, check the radio "Domoticz (for all devices)" and select the save button at the bottom to ensure things will initialize properly
Enjoy,
Jos
Change list:
Added: Framb0ise will now create a hidden room named $fra-????? for each fixed widget to allow you to sequence them in framb0ise and add additional devices to those fixed widgets.
Added: Selector switch support.
Fixed: ical parser bugfixes (thanks to adrianmihalko)
Fixed: Rain title in buienradar as the "to time" was missing.
Fixed: added multiple (4) framb0ise uservariables as the single one was unable to save all information due to length limitation in Domoticz.
$fr-anwbWidget
$fr-darkskyWidget
$fr-icsWidget
$fr-cameraWidget
$fr-infoWidget
$fr-rssWidget
$fr-cssWidget
Enjoy,
Jos
Change list:
- jvdz
Just updated the master branch with a number of fixes.
enjoy
Jos
enjoy
Jos
Maikie
Looks good!
Some changes safi made are reversed now tho. He changed some power meters to show current and day total instead of only grand total
The second one is good, current and day summary
- jvdz
Added Type "General"/sub.type "kWh" to display as the middle one in the latest commit. Hope that works.
Jos
Jos
safi78
- Domoticz version: LastBeta
Pushed a new version with support for the security panel (and some other enhancements).
homebridge, rfxcom, zwave, nest, applamp, hue, debian, apple, mysensors, netatmo, fibaro, synology, foscam, otherz
safi78
New version:
As requested, a custom Widget (to work with services as https://www.yourweather.co.uk/widget/ for our abroad friends
Just tick the box and add the url. This will be used as input for an <img source="your URL"> tag. Move it around with the 'rooms-plan'.
safi78
try the new update so you don't have to fiddle with codebimse wrote:andi216 wrote:Hi,
How did you get this great weather system
tontze
- Domoticz version: Beta Ch
Did git pull. enabled darsky widget --> blank screen
Settings button not working after enabling darksky.
Chrome console output:
Also, is this normal :
Uncaught ReferenceError: editSettings is not defined
at HTMLAnchorElement.onclick (192.168.xxx.xxx/:28)Also, is this normal :
Smartthings
zigbee2mqtt
RFLink 433mhz / Nrf 2.4Ghz
Mi Light
esp8266MiLight Hub
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
- jvdz
I've fixed a merge issue so try the latest version to see if that works correct again, else @safi78 needs to have a look.tontze wrote:Did git pull. enabled darsky widget --> blank screen![]()
Jos
tontze
Thnx, working nowjvdz wrote:I've fixed a merge issue so try the latest version to see if that works correct again, else @safi78 needs to have a look.tontze wrote:Did git pull. enabled darsky widget --> blank screen![]()
Jos
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
andi216
Thanks for updating, it works correctly.
And thanks for Custom Url. It seems I'm the only one who wanted this facility.
kniazio
Everything is very cool.kniazio wrote:My cams not visible
my cams is:
http://192.168.1.161:8085/snapshot
http://192.168.1.162:8086/snapshot
Why can not I see my cameras?
http://192.168.1.100:8078/json.htm?type=cameras
result
0
Address "192.168.1.161"
Enabled "true"
ImageURL "snapshot"
Name "Brama"
Password ""
Port 8085
Username ""
idx "1"
1
Address "192.168.1.162"
Enabled "true"
ImageURL "snapshot"
Name "Schody"
Password ""
Port 8086
Username ""
idx "2"
status "OK"
title "Cameras"-
godinperson
Nice project! Where can I change the radar location and traffic jam location?
safi78
Hi godinperson,godinperson wrote:Hi,
These widget use a fixed data-source, hardcoded for the larger Dutch user-base. However, if you have a good website for your needs which proved a good source (JSON preferably) I'd be happy to include that for you. Let me know.
safi78
That means you got it working?kniazio wrote:kniazio wrote: I've already dealt with myself.
kniazio
Yessafi78 wrote:That means you got it working?kniazio wrote:kniazio wrote: I've already dealt with myself.
jkimmel
- Domoticz version: 2021.1
Settings don't open here with xxx.xxx.xxx.xxx/framb0ise
Howto check whether installation is ok?
Rfxcom
Raspi 4
Raspi 4
safi78
In settings, you only have to specify your domoticz server url, not the /framb0ise in the url.
