Page 8 of 20
Water meter readout with raspberry and Inductive NPN sensor
Posted: Friday 13 October 2017 20:48
by Trigun
pvangorp wrote: Friday 13 October 2017 19:36
Should be sWaterUsage in keep Alice part!
alright, I tested it with using the line in a browser and that works! the virtual device did change, great!
but back in the script it does nog change, I've also tried the "Commandarray... etc" no luck either.
any ideas?
this is my setup:
-- Water usage
-- Retrieve value from water meter device:
sWaterUsage = otherdevices_svalues['Watermeter']
-- To have a better readable format, divide number by 1000:
sWaterUsagePrint = tonumber(sWaterUsage / 1000);
-- calculation is done with the unmodified water value
sWaterUsage = tonumber(sWaterUsage);
-- For Debuging
print("Water usage until now is " .. sWaterUsagePrint .. "m3 ")
function timedifference(s)
year = string.sub(s, 1, 4)
month = string.sub(s, 6, 7)
day = string.sub(s, 9, 10)
hour = string.sub(s, 12, 13)
t1 = os.time()
difference = os.difftime (t1, t2)
return difference
if (devicechanged['GPIO Watermeter'] == 'Off')
then
sWaterUsageTot = (sWaterUsage + 1)
print("Water usage is set to " .. sWaterUsageTot / 1000 .. "m3 ");
commandArray['UpdateDevice'] = '8|0|'..sWaterUsageTot..''
os.execute('wget http://IPADDRESS:PORT/json.htm?type=command¶m=udevice&idx=IDX&svalue='..sWaterUsageTot..' -O /dev/null')
-- Keep a live device
if (timedifference(otherdevices_lastupdate["Watermeter"]) > 300)
then
print("Water usage is still " .. sWaterUsage / 1000 .. "m3 ");
commandArray['UpdateDevice'] = '8|0|'..sWaterUsage..''
os.execute('wget http://IPADDRESS:PORT/json.htm?type=command¶m=udevice&idx=IDX&svalue='..sWaterUsage..' -O /dev/null')
Re: Watermeter lezen met raspberry en Inductieve NPN sensor
Posted: Friday 13 October 2017 20:58
by pvangorp
Do you get some sort of error in the log? Looks oke to me. Is the ip included in your system settings network e.g. 127.0.0.*;192.168.*.* of both devices? Executing in browser should be the same as in script. You can use a print for debuging instead of os.execute. Otherwise I need to create a simmilar environment to test it in real.
Posted: Friday 13 October 2017 21:11
by Trigun
pvangorp wrote: Friday 13 October 2017 20:58
I can see the lua script being triggerd but the master device is not being updated.
I don't see any errors at all. I'try the print option.
thank you!
Posted: Friday 13 October 2017 21:21
by Trigun
Trigun wrote: Friday 13 October 2017 21:11
thank you!
Strange, it seems nothing happens. is this what you meant with "print"?
-- Water usage
-- For Debuging
t1 = os.time()
return difference
then
print('wget http://192.168.1.94:8080/json.htm?type=command¶m=udevice&idx=157&svalue='..sWaterUsageTot..' -O /dev/null')
then
print('wget http://192.168.1.94:8080/json.htm?type=command¶m=udevice&idx=157&svalue='..sWaterUsage..' -O /dev/null')
it doen't show anything at all in the log file. it's just like the line is not being used.
Posted: Friday 13 October 2017 21:27
by pvangorp
What happens when you swap the commandarray and weet line order. The print above the commandarray is in the log?
Posted: Friday 13 October 2017 21:33
by Trigun
pvangorp wrote: Friday 13 October 2017 21:27
something happend.
2017-10-13 21:29:06.049 LUA: Water usage is still 173.005m3
2017-10-13 21:29:06.050 LUA: wget http://192.168.1.94:8080/json.htm?type=command¶m=udevice&idx=157&svalue=173005 -O /dev/null
2017-10-13 21:29:06.067 EventSystem: Script event triggered: /home/pi/domoticz/scripts/lua/script_device_Watermeter.lua
but unfortunately nothing happens on the other device.
i just found out that I never see the following print:
is this correct or should it only set once, in the beginning?
Posted: Monday 23 October 2017 10:19
by LouiS22
Trigun wrote: Friday 13 October 2017 21:33
something happend.
Have you found the bug yet?
Posted: Wednesday 25 October 2017 18:07
by pvangorp
New feature tip. You can hide the dummy “GPIO Watermeter” by putting a $ in front of the name (don’t forget to change the script aswell) or put the device in the “hidden devices” Floor plan.
Posted: Sunday 29 October 2017 20:26
by Draakje
Hobbybob wrote: Sunday 13 August 2017 20:36
Okay, I've tried to read up on the information about this, and I came up with the following wiring-scheme. As said, I am not very good at reading diagrams with symbols, so I made something a litte more visual for myself.
Can anybody with a little more knowledge than me check if this would be a good way? I calculated the 1kOhm and 2kOhm on the site oohlaf mentioned, and fiddled with the Ohms to get two values that I can actually buy, and produces as close to 3.3V as possible.
Ok I would like to have some more information about this setup..
I am about to connect the same sensor on my Raspberry pi3.
I have read about the voltage being 3,3V but My raspberry has (2) 5 volt connections on the GPIO.
So my real question is.. do I need the resistors shown in the diagram? as I am putting 5 volt in.....
Many thanks for any info.
Posted: Sunday 29 October 2017 20:58
by Trigun
LouiS22 wrote: Monday 23 October 2017 10:19
something happend.
Hi louiS22,
Haven't found it yet as the code seems correct.
I was hoping pvangorp could help us out.
Posted: Monday 30 October 2017 4:24
by pvangorp
Draakje wrote: Sunday 29 October 2017 20:26
Use a zener diode, as I mentioned before. The zener diode is for protection. It prevents that the GPIO pin get more then 3.3v.
https://www.kiwi-electronics.nl/zenerdiode-3v3-500ma
You can also use a logic level converter from 5v to 3.3v, more accurate, but zener is cheaper.
Posted: Monday 30 October 2017 4:32
by pvangorp
I created a test environment for your situation.
As you can see in your dump something goes wrong!!!
I looked into it and ¶m is translated wrong by Domoticz.
(type=command¶m=udevice)
Change the order of the url parameters and use:
json.htm?param=udevice&type=command&idx=......
and it will work.
Posted: Monday 30 October 2017 6:53
by philchillbill
LouiS22 wrote: Wednesday 11 October 2017 10:35
Is there any way to transfer these values from a slave PI to a Master PI? (Virtual counters don't get updated this way
I'm just curious why everybody seems to think that the slave-pi in this situation needs to run Domoticz? I have a slave-pi in my house to read out a quad current meter that I have installed in my meter closet (better English than meter cast
) to give more granularity per breaker-group than my p1 smart-meter does. I just update the counters/meters/switches in my main (and only) Domoticz instance (running on a NUC incidentally, not a pi) using JSON.
if (pwr[i] != oldpwr[i] ):
idx=str(meters[i])
url = 'http://192.168.1.12:8080/json.htm?type=command¶m=udevice&nvalue=0&idx='+idx+'&svalue='+pwr[i]
print "Meter | "+time.ctime()+"\n "+url
try:
request = urllib2.Request(url)
response = urllib2.urlopen(request)
except urllib2.HTTPError, e:
print e.code; time.sleep(60)
except urllib2.URLError, e:
print e.args; time.sleep(60)
is an example of how I update 'remotely' without having to have Domoticz locally on the remote machine. What's the benefit of having Domoticz on the slave-pi - might be easier than DDNS if the master and slave pi's are not on the same WiFi?
Posted: Monday 30 October 2017 7:41
by Draakje
pvangorp wrote: Monday 30 October 2017 4:24
And the zener diode goes on the input (GPIO pin 40) ?
Posted: Monday 30 October 2017 11:28
by pvangorp
To your input GPIO of your Pi. Check your zener diode with a voltage meter. It does mater how you connect it. If wrong it stil gives 5v to your pi!
Posted: Monday 30 October 2017 11:33
by Draakje
pvangorp wrote: Monday 30 October 2017 11:28
Ok I am not an expert in zenerdiodes. So what is the correct way? how do I check it with a voltage meter?
what to look for?
Posted: Monday 30 October 2017 11:35
by pvangorp
The output is about 3volt or about 5volt when wrong way connected.
Posted: Monday 30 October 2017 11:36
by Draakje
pvangorp wrote: Monday 30 October 2017 11:35
Ok so test when the sensor is connected (but not to the GPIO)
Posted: Monday 30 October 2017 11:38
by pvangorp
Yep
Posted: Monday 30 October 2017 11:41
by Draakje
pvangorp wrote: Monday 30 October 2017 11:38Yep
Many thanks! will follow up
