How to monitor your internet connection with virtual custom sensors
Trigun
- Domoticz version: 4.10717
Re: How to monitor your internet connection with virtual custom sensors
Hi Edko66,
Ok, I got the last part working. but still othing happens within domoticz.
I the domoticz logfile it doesn't seem check on the script for some reason.
is there anything else I need to setup within domoticz besides creating 3 virtual devices?
I installed it through the following.
wget -O speedtest-cli https://raw.githubusercontent.com/sivel ... est_cli.py
within the CLI it works fine but somehow domoticz is seeing the output
safi78
- Domoticz version: LastBeta
Hi Trigun,
What's the output of the script if you run it manually?
Looks like it looses the location to output.txt.
Specifying that output.txt should be at ~/ and later cat'ing it from there might do the trick
Also, your speedtest package seems to be in the admin folder. Did you schedule this in the crontab for admin as well? Or another user (that might not have permissions on that folder?)
Can you try this? I hope that with the '~' it will place the output.txt to the home-folder of the user you schedule it for, so it wouldn't matter which user you use. Next to that it's more specific to where the output.txt is, might work ...
#!/bin/bash
#setup
host=192.168.10.21
port=8084
pingidx=8
downloadidx=6
uploadidx=7
# no need to edit
/volume1/homes/admin/Speedtest/speedtest-cli --server 5302 > ~/output.txt
ping=$(cat ~/output.txt | sed -ne 's/^Ping: \([0-9]*\.[0-9]*\).*/\1/p')
download=$(cat ~/output.txt | sed -ne 's/^Download: \([0-9]*\.[0-9]*\).*/\1/p')
upload=$(cat ~/output.txt | sed -ne 's/^Upload: \([0-9]*\.[0-9]*\).*/\1/p')
#output if you run it manually
echo "ping = $ping ms"
echo "download = $download Mbps"
echo "upload = $upload Mbps"
curl -s -i -H "Accept: application/json" "http://$host:$port/json.htm?type=command¶m=udevice&idx=$pingidx&svalue=$ping"
curl -s -i -H "Accept: application/json" "http://$host:$port/json.htm?type=command¶m=udevice&idx=$downloadidx&svalue=$download"
curl -s -i -H "Accept: application/json" "http://$host:$port/json.htm?type=command¶m=udevice&idx=$uploadidx&svalue=$upload"
homebridge, rfxcom, zwave, nest, applamp, hue, debian, apple, mysensors, netatmo, fibaro, synology, foscam, otherz
- Siewert308SW
- Domoticz version: Stable
Just wanna say thx for your script.
Using it to monitor some issues with my connection -> isp regarding ping times.
Setup:
- DS923+ Docker
Domoticz Latest Stable
Mosquitto / ZwaveJSUI @ Aeotec Z-Stick Gen5+ / PiHole Unbound
P1 USB Gas/Power, HW watermeter
- A lot of Zwave switches, contacts, plugs, smoke/Co2 ect
- DiY 7.5kWh Solar Storage @ GitHuB
- DS923+ Docker
safi78
Nice to be appreciatedSiewert308SW wrote:Just wanna say thx for your script.
Trigun
Hi safi78,safi78 wrote:Hi Trigun,
#!/bin/bash #setup host=192.168.10.21 port=8084 pingidx=8 downloadidx=6 uploadidx=7 # no need to edit /volume1/homes/admin/Speedtest/speedtest-cli --server 5302 > ~/output.txt ping=$(cat ~/output.txt | sed -ne 's/^Ping: \([0-9]*\.[0-9]*\).*/\1/p') download=$(cat ~/output.txt | sed -ne 's/^Download: \([0-9]*\.[0-9]*\).*/\1/p') upload=$(cat ~/output.txt | sed -ne 's/^Upload: \([0-9]*\.[0-9]*\).*/\1/p') #output if you run it manually echo "ping = $ping ms" echo "download = $download Mbps" echo "upload = $upload Mbps" curl -s -i -H "Accept: application/json" "http://$host:$port/json.htm?type=command¶m=udevice&idx=$pingidx&svalue=$ping" curl -s -i -H "Accept: application/json" "http://$host:$port/json.htm?type=command¶m=udevice&idx=$downloadidx&svalue=$download" curl -s -i -H "Accept: application/json" "http://$host:$port/json.htm?type=command¶m=udevice&idx=$uploadidx&svalue=$upload"
thnx for you reply!
It perfectly generates an output.txt file in the folder, the data is correct when I compare it to the output in de CLI but for some reason Domoticz is not picking up the values. I have no idea why it isn't working.
Grtz.
safi78
Again,
Are you sure your host, port and idx settings are correct? And that you can connect without a password?
Trigun
ok, this is what I do.safi78 wrote:Again,
I connect to the CLI run the following command: /volume1/homes/admin/Speedtest/stdomo.sh (without a password)
I get the following result: It takes long though for the script to finish, even though the results are already in the script.
+ even though there is no ping time, it does show a ping value in the output.txt file, I guess this is due to the fixed server I selected (5302)
I tried using the script you send in the previous reply, but so far no luck.
Grtz.
safi78
Can you try again without the '-s' after the 'curl' command?
As far as i can tell, you don't get a ping value (could be another version of speedtest-cli than I use).
And, curl returns it's result after trying to update domoticz, I don't see that here. (could be another version of curl).
Run it again, without the -s and send the results?
Trigun
did it.
the result in the output.txt file is as follows: the output from the cli is as follows: it cold very well be I got the wrong version.
perhaps you can tell me which one I need for a synology NAS.
do I perhaps need to install a specific version of curl?
Cheers
Cheers
safi78
change
to
/volume1/homes/admin/Speedtest/speedtest-cli --server 5302 > ~/output.txtCode: Select all
/volume1/homes/admin/Speedtest/speedtest-cli --simple --server 5302 > ~/output.txthomebridge, rfxcom, zwave, nest, applamp, hue, debian, apple, mysensors, netatmo, fibaro, synology, foscam, otherz
Trigun
I got a ping value now
see: but stil no result in Domoticz.
Grtz
Grtz
safi78
change
to
and show what happens.
curl -i -H "Accept: application/json" "http://$host:$port/json.htm?type=command¶m=udevice&idx=$pingidx&svalue=$ping"
curl -i -H "Accept: application/json" "http://$host:$port/json.htm?type=command¶m=udevice&idx=$downloadidx&svalue=$download"
curl -i -H "Accept: application/json" "http://$host:$port/json.htm?type=command¶m=udevice&idx=$uploadidx&svalue=$upload"
Trigun
I don't know what happend, but i re-installed speedtest-cli and re-did the script using your update ~/ and it works!
thanks a lot safi78. much appreciated!!
safi78
I doubt if that was your problem, after adding the '--simple' the part to 'get' the data out of the txt was fixed already.Trigun wrote:I don't know what happend, but i re-installed speedtest-cli and re-did the script using your update ~/ and it works!
The problem was in your host/user/pass/idx and curl part, you probably changed something there.
Anyway, always glad to help!
ilpier
Here's the problem!
On windows 10,with CMD!
Someone help me?
Someone help me?
bertbigb
If you provide your script also we could hopefully see where the mistake (typo) is. Now we only know it is in line 14ilpier wrote:Here's the problem!
Someone help me?
Best regards Bert
Synology DS1517+ - DSM 6.2
ilpier
yes Sorry!
here's the code!
here's the code!
#!/bin/bash
#setup
port=8080
username=Admin
password=***
host=localhost
pingidx=239
downloadidx=241
uploadidx=240
# no need to edit
speedtest-cli --simple > output.txt
ping=$(cat output.txt | sed -ne 's/^Ping: \([0-9]*\.[0-9]*\).*/\1/p')
download=$(cat output.txt | sed -ne 's/^Download: \([0-9]*\.[0-9]*\).*/\1/p')
upload=$(cat output.txt | sed -ne 's/^Upload: \([0-9]*\.[0-9]*\).*/\1/p')
curl -s -i -H "Accept: application/json" "http://$username:$password@$host:$port/json.htm?type=command¶m=udevice&idx=$pingidx&svalue=$ping"
curl -s -i -H "Accept: application/json" "http://$username:$password@$host:$port/json.htm?type=command¶m=udevice&idx=$downloadidx&svalue=$download"
curl -s -i -H "Accept: application/json" "http://$username:$password@$host:$port/json.htm?type=command¶m=udevice&idx=$uploadidx&svalue=$upload"-
ben53252642
We need a combined sensor for Internet Upload and Download, like we have combined sensor for Temperature and Humidity, I have about 300 devices in my Domoticz, keeping them as organised as possible is essential!
bertbigb
Hi ilpier,
I think your problem is related to the fact that your windows system doesn't know where to find the several files.
Your speedtest.sh is at C:\Users\andre\Desktop and you run the script from folder C:\Users\andre
But where will the system find speedtest-cli and where should it write output.txt?
That is why in Linux you use something like:
Here it is obvious. The speedtest-cli is at location: /volume1/homes/admin/Speedtest/
The output.txt file is written in ~/ which means in Linux the user directory of the user who is running this script.
I suggest that you put the script speedtest.sh in the same folder as where you put the speedtest-cli and run the script from that location.
Lets see what happens but most likely you will have results.
Good luck.
Good luck.
Best regards Bert
ilpier
Thx @bertbidb,yes,i put .sh in the same folder of speedtest-cli and now,in the same folder i have output.txt with Ping,Download and Upload!
but in Domoticz nothing happen!
