domoticz in synology as package! Available now.
jumbotroll
Re: domoticz in synology as package! Available now.
Post by jumbotroll »
startfish wrote: Tuesday 29 May 2018 22:16 Hello Jumbotroll ! I'm very interested in use Domoticz in my Synology. I'm using V 6.2 (last one) and I have a DS215j model (it's a MARVELL Armada 375 88F6720). Please could you compile for this version?
Thanks for your help
Sure ;)
Will be uploaded to my server.
https://paypal.me/Jumbotroll
Jumbotroll
http://www.jadahl.com
startfish
Post by startfish »
Thanks... I'll check it in few minutes :)
startfish
Post by startfish »
Installed and working.. I'll check it tomorrow and give you feedback .
PieterS
Domoticz version: 2024.7
Post by PieterS »
jumbotroll wrote: Sunday 27 May 2018 20:16
PieterS wrote: Sunday 27 May 2018 19:52 Thanks for fast reply.
Choosed to install the package with version 7.70 but that installed nmap. No errors during installation.
My scripts uses nc-command and that is not found when I run that in putty.
I am not very fimiliar with Linux so I give it a try later on this week.
Or try a workaround in the virtual Windows machine that I can run on the new DS718. :D :D
The nmap package does not support nc command.
The Netcat package does, so why don't you install both packages :D
Sorry, don''t understand your answer.
My question was to get a version of NetCat for DSM 6.1 so that I can use the NC command. You delivered me NMap. :roll:
You write that the Netcat package does support nc; I know.. that's why I asked for Netcatpackage...
How do I install both packages if I got one?
Synology with Domoticz build (V2024.7) in Docker
jumbotroll
PieterS wrote: Wednesday 30 May 2018 16:00
You will find both packages in that folder for apollolake.
netcat and NMap.
netcat_apollolake-6.1_0.7.1-3.spk
http://www.jadahl.com/synospks/netcat_a ... .7.1-3.spk
Jumbotroll
PieterS
Post by PieterS »
Sorry!!! Missed that specific file! :shock: :roll:
Installed and works as usual! Thnx
jumbotroll
PieterS wrote: Wednesday 30 May 2018 16:40 Sorry!!! Missed that specific file! :shock: :roll:
Great you got it to work!
Thanks for feedback.
Jumbotroll
Bryx
Post by Bryx »
neuros wrote: Sunday 06 May 2018 21:06
jumbotroll wrote: Sunday 06 May 2018 17:34
neuros wrote: Sunday 06 May 2018 14:13 @jumbotroll
I'm using DSM 6.2-23648 on my DS918+. The kernel is
Linux DS918 4.4.59+ #23648 SMP PREEMPT Sat Mar 17 02:57:07 CST 2018 x86_64 GNU/Linux synology_apollolake_918+
With the latest domoticz_apollolake-6.2_3.0.9317-7.spk the serial modules wont load:
cp210x: version magic '4.4.59 SMP preempt mod_unload ' should be '4.4.59+ SMP preempt mod_unload '
[ +0.014012] pl2303: version magic '4.4.59 SMP preempt mod_unload ' should be '4.4.59+ SMP preempt mod_unload '
[ +0.012783] ch341: version magic '4.4.59 SMP preempt mod_unload ' should be '4.4.59+ SMP preempt mod_unload '
[ +0.012727] ti_usb_3410_5052: version magic '4.4.59 SMP preempt mod_unload ' should be '4.4.59+ SMP preempt mod_unload '
Could you update the serialdrivers for this kernel?
Please test the latest beta build domoticz_apollolake-6.2_3.0.9390-7.spk
and give feedback.
With the domoticz_apollolake-6.2_3.0.9390-7.spk build the serial modules load normally except for the first line 'module verification failed..." I don't know what it means - however the cp210x module works.
[May 6 19:32] cp210x: module verification failed: signature and/or required key missing - tainting kernel
[ +0.010768] usbcore: registered new interface driver cp210x
[ +0.006291] usbserial: USB Serial support registered for cp210x
[ +0.006668] cp210x 1-3:1.0: cp210x converter detected
[ +0.005785] usb 1-3: cp210x converter now attached to ttyUSB0
[ +0.009077] usbcore: registered new interface driver pl2303
[ +0.006306] usbserial: USB Serial support registered for pl2303
[ +0.009563] usbcore: registered new interface driver ch341
[ +0.006187] usbserial: USB Serial support registered for ch341-uart
[ +0.010182] usbcore: registered new interface driver ti_usb_3410_5052
[ +0.007288] usbserial: USB Serial support registered for TI USB 3410 1 port adapter
[ +0.008621] usbserial: USB Serial support registered for TI USB 5052 2 port adapter
Thanks for the update!!
Hello !
Above all, thank you for this titanic work!
With my Syno DS418J, recently updated with DSM 6.2-23739, I have exactly the same "magic version 4.4.59 SMP ..." problem when I plug in my RFLink and CH340 using this version of Domoticz: domoticz_rtd1296 -6.2_3.0.9521-7.spk
Yet everything else works perfectly on Domoticz except the serial drivers.
The CPU architecture of the DS418J is actually the Realtek RTD1293 and not the RTD1296. Could this be a problem?
I only recently received my RFLink and therefore not tested with DSM 6.1
I thank you in advance for your response :)
jumbotroll
Bryx wrote: Thursday 31 May 2018 13:54 Hello !
I have compiled a new beta version with driver fix..
This should work, please test and give feedback.
domoticz_rtd1296-6.2_3.0.9541-7.spk
Jumbotroll
Bryx
Post by Bryx »
Oh yes it works perfectly! Sooooo fast! I thank you so much !!
jumbotroll
Bryx wrote: Thursday 31 May 2018 15:58
Great! 8-)
Jumbotroll
michaelb
Post by michaelb »
Hello JumboTroll,
I'm a very happy user of your package (broadwell 6.1 with python) on my Synology. I hope you can help me with this one: since recent update it seems that the slider is missing on all my dimmer-switches. I can put the switch on and off but I can't change the intensity anymore. Tried on several devices, several browsers and apps but nothing works. Any tips?
See attached image:
Faulty dimmer
Faulty dimmer
Thanks in advance and I hope you will keep up the good work for a long time to come.
Michael
PieterS
Post by PieterS »
Maybe a small bug in your version. It is available in my version V3.9483. I use OpenZWave USB. Wondering what type of device you use.
michaelb
Post by michaelb »
I'm using a RFLink USB device. And I have to correct myself: I'm not on broadwell als stated earlier but on Cedarview (sorry :oops: )
michaelb
Post by michaelb »
UPDATE: The problem with missing sliders in dimmer switches is solved by upgrading to 3.9558, wich was posted yesterday. Thanks everyone.
nixalsschrott
Post by nixalsschrott »
For ds214play do I need to upgrade to version 6.2?
If so, is it possible do update manually from 6.1 version to 6.2 or is complete reinstall necessary?
Kind regards Matty
Domoticz Beta | Aeon Labs Z-Wave USB Stick Gen5 | Cyrus SmartHome 4-in-1 Multisensor | Qubino ZMNHCD1 - Roller Shutter | NEO COOLCAM NAS-WR01ZE Power Plug | Fibaro FGRGB-101 | WEMOS D1 MINI (ESP8266) Sensors CO2/TEMP/BARO |
jumbotroll
nixalsschrott wrote: Thursday 07 June 2018 10:18 For ds214play do I need to upgrade to version 6.2?
Kind regards Matty
You can update from from domoticz package 6.1 to 6.2.
I did test that on DS712+ without any problem, so I think it will work for DS214play to :-)
But you always have to take backup of domoticz.db and script, just in case.... 8-)
Jumbotroll
schumi2004
Domoticz version: 4.10603
Post by schumi2004 »
@jumbotroll
Could you compile the latest beta for my system (DS715 / Alpine / DSM6.2 with Python)?
Currently i have version v3.9613 running and i'm curious if a issue i have with a Dummy RGBWW switch and a few sub/slave Yeelight bulbs added wil be resolved.
Currently they are doing nothing.
I also read a few pages back you suggest to remove stable version when installing 6.2 beta? I didn't because i wasn't aware of it but everything runs smooth (except for the dummy switch yeelight slave thing) should i still start from scratch and import DB again, will that resolve my issue or is it a bug?
jumbotroll
schumi2004 wrote: Thursday 14 June 2018 12:52 @jumbotroll
I don't know if this is a bug, not using this this my self. Try search the forum under bugs..
I have updated latest DSM6.2 beta with python for you to test...
Jumbotroll
schumi2004
@jumbotroll
Could you (again) compile latest version for me (DS715 / Alpine / DSM6.2 with Python)?
I'm having issues removing times from your latest beta version and before reporting issues i would like to try the lates beta first (maybe it got resolved already)
And since i' don't have the source to compile it myself i need your help ;)
