murtadin
Post by murtadin »
bing69 wrote:
murtadin wrote:I think, that separate battery devices is very bad idea.
Sent from my MI MAX using Tapatalk
Why?
I have about 30+ sensors and there will be a mess of devices in my device section.
bing69
Post by bing69 »
Why?
I understand 8-) but for me no problem. I have in the Device list 80 devices too, but no problem for me.
mvveelen
Post by mvveelen »
Why?
Then you just don't add these :)
bertbigb
Post by bertbigb »
I suggest to keep it the way it is. That is how all battery sensors are displayed in Domoticz.
Best regards Bert
Synology DS1517+ - DSM 6.2
mvveelen
Post by mvveelen »
Yes-No-Yes-No-Yes-No..... :D :D
Why not just let people decide and put it back in. And if you don't want separate battery status: don't add the devices. If you do want them: add them.
Everybody happy :)
bing69
Post by bing69 »
mvveelen wrote:Yes-No-Yes-No-Yes-No..... :D :D
Everybody happy :)
+1
bertbigb
Post by bertbigb »
In my opinion this is off topic. If they're in the device list you can get very long lists. Domoticz decided about a standard and keep it that way is my opinion.
Best regards Bert
bing69
Post by bing69 »
bertbigb wrote:In my opinion this is off topic. If they're in the device list you can get very long lists. Domoticz decided about a standard and keep it that way is my opinion.
they come in the utility list, so you do not bother if you do not come :|
murtadin
Post by murtadin »
only two persons want it - rest agree with Corbin.
mvveelen
Post by mvveelen »
corbin wrote:I'll add it back in on my fork, so will have the integrated battery level with the device, and also a separate voltage device.
OK, thanks corbin, now let's stop the off-topic discussion and get back to the great work corbin has done / is doing.
bing69
Post by bing69 »
Corbin is wise enough to make the right decision. But that the rest don't want it i do not agree. For me it is just a request! No more and no less.
deennoo
Post by deennoo »
OK i belive that can be usefull until we don't know Real bat low level reported, wait for it on Xiaomi app then Read it on domoticz and please share.
When done, this can be add to domoticz and then disaper from utility.
What do you think about it ?
http://domo-attitude.fr
bing69
Post by bing69 »
deennoo wrote:OK i belive that can be usefull until we don't know Real bat low level reported, wait for it on Xiaomi app then Read it on domoticz and please share.
it's ok for me!
Neutrino
Domoticz version: 2021.1
Post by Neutrino »
Totally agree !
StefanoA
Post by StefanoA »
Hi everyone
I finally figured out why my connection to Xiaomi Smart Plugs wasn't working despite several updates and trials
I had initially my raspberry 3pi B connected through wired LAN to the router (I thought that was the best and safest way)
Then I read in the troubleshooting guide that WiFi connection is better, so I disabled the wired LAN eth0 using this command:
sudo ifconfig eth0 down
and connected using WiFi, thereafter everything seems to work properly.
I just recommend to update the Troubleshooting guide as in my case detection of all devices was correct, the problem was in writing/sending On/Off commands to the plugs
jelleeelco
Post by jelleeelco »
I have seen the question has been asked several times: does the Xiaomi plug work as a repeater? I think I tested it thorougly and can say NO.
I tested it with playing a sound on open/close of one of the door sensors. If I don't have a Xiaomi plug plugged in, the point it still works / doesn't work anymore is in the addict, just after a door (door open). When I put a Xiaomi plug only 3 meters away (direct line of sight...not sure if that matters but just to say there is no concrete or something in between), and the plug has connection to the Gateway, the range if the window sensor is exactly the same.
Did anyone else came to the same conclusion?
pikapt
Post by pikapt »
StefanoA I had exactly the same issue. I was using an RPI one with wired Ethernet and I was having weird behaviors from Xiaomi devices. I've tried a Rpi three and had the same thing. Once I've switched the wired connection off and used the wireless connection, everything start working as it should. It's really weird! I was wondering how I could debug it a little further because a Rpi one is more than enough to use with domoticz.
jelleeelco my tests on using the plug as a repeater were actually really bad. I think it does something but what it does doesn't work really well :) My tests (and what I've read in other forums) are that we shouldn't rely on the plugs as repeaters. Be happy to know about more user experiences..
murtadin
Post by murtadin »
StefanoA wrote:Hi everyone
Both lan and wi-fi are in bridge in the same subnet or they are not and have different subnets?
pikapt
Post by pikapt »
murtadin in my case they were exactly on the same network (subnet). I was also having issues when I had the Xiaomi connected to one AP and the RPI to another, and both are on the same network.
So, I had to physically change the Xiaomi gateway to be close to RPI and ensure they were both using the same wireless network.
quack3d
Post by quack3d »
Any ideas why humidity is not the same in the standalone device as in the temp + humidity device?
