DIY cheap USB-cable to read P1 port of Dutch smart meter
martijndutch
Re: DIY cheap USB-cable to read P1 port of Dutch smart meter
Hoi,
Ik heb een 340 chip gebruikt met een runner up weerstand. Ik krijg nu consistente rommel binnen. Elk telegram ziet er zo uit
&L&&fLM=gifLfsF:^>>>>*&F:"VR"^ZJVgifLfsF6^>>>>*>F&::VR"^ZJVgifLfsF:^>>>>>>F>>>VR"^ZJVgifLfsF6^>>>>>>F>>>VR"^ZJV&sfLLfSffsfMfff&M=gifLffsfMffS*.VR"ZJVgifLffsfMffsfffMI%M=&sfLLff3&fMff&f&M=&sfLLffS^>>>>:ZJVgifLLLy=gifLffffsfMfff&&M=gifLffffsfMffff&M=&sfLLfS&fsfMM=gifLfffsfM&ffSfM%M=gifL&FfsfMfffMiSVgifL&ffsfMffS*.VR"ZJVgifLfffsfMffsfffMI%M=&SfLffSfsfMf&&M=&SfLLfSfsfM&f&f&&&&Lf&f&&&fLf&&&f&f&f&&&&&fLM=&SfLff3fSfM&L&&&&&f&ffL%MMfffff3&&fM&M=o_2.L=hJJy>>>..2:6JVJVgif1f3fs^*>ZJV&sfLfsfsfM&L&&&&&ff&f&%M=&sfLLfSfSfMf&f&&&&&f&f&f&&&fL&&f&fL&
Er zijn wel kleine verschillen wat logisch is. Waar zit mn fout..
bortek
It's been almost 2 years since the last post here. I just want to quick ask a question.
I am going to receive Landis E360 meter in a few days and want to verify that it can actually receive the data from P1 port. I want to do it before I connect my other doungles based ESP8266 or ESP32 boards. So I want sort of verify that the port is enabled and can received the data.
Therefore I want to connect to Raspberry Pi because I think it is the simplest way to test via a wired connection.
Can you someone please share the wiring diagram using RJ12 (6pin) P1 port to the Pi and what commands shall I use to check the incoming data on the serial interface?
hokanp
I have this https://www.sossolutions.nl/slimme-mete ... spberry-pi I have installed the software and that is up and running.
I do not get any data from my Landis Gyr E360.
Logfile:
2021-11-20 16:57:19,257,"ERROR","parseSerBuffer: p1 bericht verworpen wegens fout."
2021-11-20 16:57:19,256,"WARNING","recordSanityOk: Gefaald op actueel geleverd vermogen format (2.7.0) (lengte), waarde was 0000.000"
2021-11-20 16:57:19,254,"WARNING","recordSanityOk: Gefaald op actueel verbruikt vermogen format (1.7.0) (lengte), waarde was 0001.438"
2021-11-20 16:57:19,253,"WARNING","recordSanityOk: Gefaald op piek/dag format (2.8.2) (lengte), waarde was 999999999999"
2021-11-20 16:57:19,251,"WARNING","recordSanityOk: Gefaald op dal/nacht format (2.8.1) (lengte), waarde was 999999999999"
2021-11-20 16:57:19,250,"WARNING","recordSanityOk: Gefaald op piek/dag format (1.8.2) (lengte), waarde was 999999999999"
2021-11-20 16:57:19,248,"WARNING","recordSanityOk: Gefaald op dal/nacht format (1.8.1) (lengte), waarde was 999999999999"
2021-11-20 16:57:19,246,"WARNING","recordSanityOk: Gefaald op tariefcode, verwachte P of D, waarde was 999999999999"
2021-11-20 16:57:19,245,"WARNING","recordSanityOk: Gefaald op piek/dag voor geleverde energie(2.8.2), waarde was 999999999999"
2021-11-20 16:57:19,244,"WARNING","recordSanityOk: Gefaald op dal/nacht voor geleverde energie(2.8.1), waarde was 999999999999"
2021-11-20 16:57:19,242,"WARNING","recordSanityOk: Gefaald op piek/dag voor verbruikte energie(1.8.2), waarde was 999999999999"
2021-11-20 16:57:19,240,"WARNING","recordSanityOk: Gefaald op dal/nacht voor verbruikte energie(1.8.1), waarde was 999999999999"
2021-11-09 20:57:56,339,"INFO","main_prod: P1 poort instelling baudrate=115200 bytesize=8 pariteit=N stopbits=1"
2021-11-09 20:57:56,331,"INFO","checkSerial: serial port /dev/ttyUSB0 succesvol geopend."
2021-11-09 20:57:56,107,"INFO","main_prod: database tabel: faseinformatie succesvol geopend."
2021-11-09 20:57:56,104,"INFO","main_prod: database tabel watermeter succesvol geopend."
2021-11-09 20:57:56,103,"INFO","main_prod: database tabel temperatuur succesvol geopend."
2021-11-09 20:57:56,102,"INFO","main_prod: database tabel config succesvol geopend."
2021-11-09 20:57:56,029,"INFO","main_prod: database tabel: status succesvol geopend."
2021-11-09 20:57:55,949,"INFO","main_prod: database bestand e_serial gedefragmenteerd."
2021-11-09 20:57:55,945,"INFO","main_prod: database tabel: e_serial succesvol geopend."
2021-11-09 20:57:55,484,"INFO","Start van programma."
What can be the problem?
Best regards
Logfile:
Best regards
hokanp
I have now updated to the latest verson for the P1.
I now have; Seriële device in gebruik: /dev/ttyUSB1
But I still get errors.
2021-11-20 17:58:18,292,"ERROR","update_data_set: p1 bericht verworpen wegens fout."
2021-11-20 17:58:18,291,"WARNING","record_sanity_check: Gefaald op dal/nacht voor verbruikte energie(1.8.1), waarde was 999999999999"
2021-11-20 17:58:09,211,"ERROR","update_data_set: p1 bericht verworpen wegens fout."
2021-11-20 17:58:09,210,"WARNING","record_sanity_check: Gefaald op dal/nacht voor verbruikte energie(1.8.1), waarde was 999999999999"
2021-11-20 17:57:58,929,"ERROR","update_data_set: p1 bericht verworpen wegens fout."
2021-11-20 17:57:58,928,"WARNING","record_sanity_check: Gefaald op dal/nacht voor verbruikte energie(1.8.1), waarde was 999999999999"
2021-11-20 17:57:54,787,"ERROR","update_data_set: p1 bericht verworpen wegens fout."
2021-11-20 17:57:54,786,"WARNING","record_sanity_check: Gefaald op dal/nacht voor verbruikte energie(1.8.1), waarde was 999999999999"
2021-11-20 17:57:47,516,"INFO","check_serial: serial port /dev/ttyUSB1 succesvol geopend."
2021-11-20 17:57:47,455,"WARNING","main_prod: fout bij het wachten op seriele gegevens. Error=(5, 'Input/output error')"
2021-11-20 17:57:46,405,"WARNING","main_prod: fout bij het wachten op seriele gegevens. Error=(5, 'Input/output error')"
2021-11-20 17:57:45,361,"WARNING","main_prod: fout bij het wachten op seriele gegevens. Error=(5, 'Input/output error')"
2021-11-20 17:57:44,309,"WARNING","main_prod: fout bij het wachten op seriele gegevens. Error=(5, 'Input/output error')"
2021-11-20 17:57:43,257,"WARNING","main_prod: fout bij het wachten op seriele gegevens. Error=(5, 'Input/output error')"
2021-11-20 17:57:42,231,"WARNING","main_prod: fout bij het wachten op seriele gegevens. Error=(5, 'Input/output error')"
2021-11-20 17:57:41,180,"WARNING","main_prod: fout bij het wachten op seriele gegevens. Error=(5, 'Input/output error')"
2021-11-20 17:57:40,128,"WARNING","main_prod: fout bij het wachten op seriele gegevens. Error=(5, 'Input/output error')"
2021-11-20 17:57:39,073,"WARNING","main_prod: fout bij het wachten op seriele gegevens. Error=(5, 'Input/output error')"
2021-11-20 17:57:38,022,"WARNING","main_prod: fout bij het wachten op seriele gegevens. Error=(5, 'Input/output error')"
2021-11-20 17:57:36,969,"WARNING","main_prod: fout bij het wachten op seriele gegevens. Error=(5, 'Input/output error')"
2021-11-20 17:57:35,932,"WARNING","main_prod: fout bij het wachten op seriele gegevens. Error=(5, 'Input/output error')"
2021-11-20 17:57:28,241,"ERROR","update_data_set: p1 bericht verworpen wegens fout."
2021-11-20 17:57:28,240,"WARNING","record_sanity_check: Gefaald op dal/nacht voor verbruikte energie(1.8.1), waarde was 999999999999"
2021-11-20 17:57:19,192,"ERROR","update_data_set: p1 bericht verworpen wegens fout."
2021-11-20 17:57:19,191,"WARNING","record_sanity_check: Gefaald op dal/nacht voor verbruikte energie(1.8.1), waarde was 999999999999"
2021-11-20 17:57:08,892,"WARNING","record_sanity_check: Gefaald op dal/nacht voor verbruikte energie(1.8.1), waarde was 999999999999"
2021-11-20 17:57:08,892,"ERROR","update_data_set: p1 bericht verworpen wegens fout."
2021-11-20 17:56:58,740,"ERROR","update_data_set: p1 bericht verworpen wegens fout."
2021-11-20 17:56:58,739,"WARNING","record_sanity_check: Gefaald op dal/nacht voor verbruikte energie(1.8.1), waarde was 999999999999"
2021-11-20 17:56:48,571,"ERROR","update_data_set: p1 bericht verworpen wegens fout."
2021-11-20 17:56:48,570,"WARNING","record_sanity_check: Gefaald op dal/nacht voor verbruikte energie(1.8.1), waarde was 999999999999"
2021-11-20 17:56:38,382,"ERROR","update_data_set: p1 bericht verworpen wegens fout."
2021-11-20 17:56:38,381,"WARNING","record_sanity_check: Gefaald op dal/nacht voor verbruikte energie(1.8.1), waarde was 999999999999"
2021-11-20 17:56:28,218,"ERROR","update_data_set: p1 bericht verworpen wegens fout."
2021-11-20 17:56:28,217,"WARNING","record_sanity_check: Gefaald op dal/nacht voor verbruikte energie(1.8.1), waarde was 999999999999"
2021-11-20 17:56:19,150,"ERROR","update_data_set: p1 bericht verworpen wegens fout."
2021-11-20 17:56:19,149,"WARNING","record_sanity_check: Gefaald op dal/nacht voor verbruikte energie(1.8.1), waarde was 999999999999"
2021-11-20 17:56:08,901,"ERROR","update_data_set: p1 bericht verworpen wegens fout."
2021-11-20 17:56:08,900,"WARNING","record_sanity_check: Gefaald op dal/nacht voor verbruikte energie(1.8.1), waarde was 999999999999"
2021-11-20 17:55:58,708,"ERROR","update_data_set: p1 bericht verworpen wegens fout."
2021-11-20 17:55:58,707,"WARNING","record_sanity_check: Gefaald op dal/nacht voor verbruikte energie(1.8.1), waarde was 999999999999"
2021-11-20 17:54:40,482,"ERROR","update_data_set: p1 bericht verworpen wegens fout."
2021-11-20 17:54:40,481,"WARNING","record_sanity_check: Gefaald op dal/nacht voor verbruikte energie(1.8.1), waarde was 999999999999"
First post is about /dev/ttyUSB0 second post is about /dev/ttyUSB1
Which is it?
Which is it?
- Domoticz version: 2026.3
What do you see if you use the following command to see the telegram from your smart meter. It should give readable information.
Change /dev/ttyUSB0 to /dev/ttyUSB1 if needed
sudo cu -l /dev/ttyUSB0 -s 115200Domoticz running on Udoo X86 (on Ubuntu)
- FireWizard
In addition to @waltervl 's suggestion stop domoticz before you apply the cu command.
sudo service domoticz stopRe: DIY cheap USB-cable to read P1 port of Dutch smart meter
FYI, I used an Otronic USB-to-Serial adapter with a 16pins CH340G but it did not invert the P1 signal automatically. Therefor I made a little hole in the heat-shrink and connected pin 15 (R232) with pin 16 (Vcc). Problem solved.
repnescasb
I tried making this cable but got no output using either `screen` or python (with the two baud rates and 7/8 bits) for my Iskra AM550 meter.
I thought I didn't have a 10k ohm resistor so I tried with both 15k and 7.5k (two 15k in parallel). This should still be fine, right? After reconnecting the plug a couple of times the transistor died -- twice, as in it would break down and start conducting. I'm not sure what happened, only thing I can think of is reverse voltage, but I think I connected everything correctly. Anyone has an idea?
Oh, and the USB-UART chip I used is a CP2101, is that a problem?
Last edited by repnescasb on Sunday 11 February 2024 1:30, edited 4 times in total.
