Page 7 of 26
Re: Python Plugin: TUYA
Posted: Thursday 18 March 2021 20:13
by Xenomes
manjh wrote: Wednesday 17 March 2021 22:18
But there is no way to change the color temperature. In the devices tab of Domoticz, the lamps show up as RGB, which is wrong.
Hi Manjh, what is the version of the plug-in you are using?
Posted: Thursday 18 March 2021 21:28
by manjh
How can I find the version number?
Posted: Thursday 18 March 2021 21:30
by manjh
Xenomes wrote: Thursday 18 March 2021 20:13
Ah, found it in the setup. Tuyaha, version 0.0.6. Downloaded yesterday.
Posted: Thursday 18 March 2021 21:33
by Xenomes
OK, then you are using the other plug-in. Can you try
https://github.com/Xenomes/Domoticz-TUYA-Plugin there are more lights selections.
Posted: Thursday 18 March 2021 21:34
by manjh
AH, so I am using the wrong plugin... Should I remove Tuyaha first?
Posted: Thursday 18 March 2021 21:36
by Xenomes
manjh wrote: Thursday 18 March 2021 21:34
the other plug-in has Tuyaha as a git pull, my one has a pip3 install
Posted: Thursday 18 March 2021 21:43
by manjh
Xenomes wrote: Thursday 18 March 2021 21:36
OK, that was easy.
With your plugin, I can now see a color-circle, but a second one with only warm/cold white. So I can now change the color and dimmer level.
One thing: the device still comes up as RGB. Is that how it was meant to be?
Posted: Thursday 18 March 2021 21:47
by Xenomes
manjh wrote: Thursday 18 March 2021 21:43
OK, that was easy.
Can you run the debug_discovery.py from the tools directory?
Posted: Thursday 18 March 2021 21:59
by manjh
Xenomes wrote: Thursday 18 March 2021 21:47
OK, that was easy.
I get:
File "debug_discovery.py", ;ine 2, in <module>
import requests
ImportError: No module named requests
Posted: Thursday 18 March 2021 22:00
by Xenomes
manjh wrote: Thursday 18 March 2021 21:59
I get:
import requests
Did you install requests?
Posted: Thursday 18 March 2021 22:01
by manjh
Xenomes wrote: Thursday 18 March 2021 22:00
I get:
import requests
Yes, I followed the instructions to the letter!
Posted: Thursday 18 March 2021 22:03
by manjh
I re-ran the pip3 command, and get two lines saying "already satisfied".
I should note: the devices work just fine. But it seems funny to get a full color selector for a device that is white-only...
Posted: Thursday 18 March 2021 22:06
by Xenomes
Then you run python ./debug_discovery.py try python3 ./debug_discovery.py
Posted: Thursday 18 March 2021 22:09
by manjh
Xenomes wrote: Thursday 18 March 2021 22:06
Ah, that's different.
Getting credentials
Got credentials
{ 'errorMsg': 'Get accesstoken failed. Invalid parms.',
'responseStatus': 'error'}
File "./debug_discovery.py", line 35, in <module>
payload = {"accessToken": auth_response["access_token"]}
KeyError: 'access_token'
Posted: Thursday 18 March 2021 22:12
by Xenomes
manjh wrote: Thursday 18 March 2021 22:09
Getting credentials
Got credentials
That is better, edit the file and fill in the information between CHANGE THIS
Posted: Thursday 18 March 2021 22:13
by manjh
FYI: in the Domoticz log I can see this:
2021-03-18 22:11:49.254 (Tuya devices) DEV name=LSC 2 state=True id=6276453110521cc9ecd9 online=True
2021-03-18 22:11:49.254 (Tuya devices) DEV name=LSC 1 state=True id=53425342f4cfa209631c online=True
LSC 1 and 2 are the two lamps that I have.
Posted: Thursday 18 March 2021 22:15
by manjh
Xenomes wrote: Thursday 18 March 2021 22:12
Getting credentials
Got credentials
Sorry, I must have missed this in the plugin instructions.
Which file should I edit?
Posted: Thursday 18 March 2021 22:19
by Xenomes
manjh wrote: Thursday 18 March 2021 22:15
debug_discovery.py
the tool gives a json string so i can see the what device outputs, then i can update the plugin so a device without rgb has no colour wheel.
Posted: Thursday 18 March 2021 22:22
by manjh
Xenomes wrote: Thursday 18 March 2021 22:19
debug_discovery.py
OK, got it.
Getting credentials
Got credentials
{ 'access_token': 'EUheu1616000992439YNMrdQKReKU4r4S',
'expires_in': 864000,
'refresh_token': 'EUheu1616000992439YNMrdAFLvKdAtuy',
'token_type': 'bearer'}
Getting devices
Got devices
{ 'header': {'code': 'SUCCESS', 'payloadVersion': 1},
'payload': { 'devices': [ { 'data': { 'brightness': '130',
'color_mode': 'white',
'color_temp': 1000,
'online': True,
'state': 'true'},
'dev_type': 'light',
'ha_type': 'light',
'icon': 'https://images.tuyaeu.com/smart/icon/ay1541056239985fDGjj/15919273389f9d925c99f.png',
'id': '6276453110521cc9ecd9',
'name': 'LSC 2'},
{ 'data': { 'brightness': '10',
'color_temp': 1000,
'online': True,
'state': 'true'},
'ha_type': 'light',
'id': '53425342f4cfa209631c',
'name': 'LSC 1'}],
'scenes': []}}
Posted: Thursday 18 March 2021 22:25
by Xenomes
manjh wrote: Thursday 18 March 2021 22:22
OK, got it. SHould I post the output here, or do you want it some other way?
If you give the device output that is enough, you can mask any info you want.
