Python Plugin: TUYA
Xenomes
Domoticz version: 2025.2
Re: Python Plugin: TUYA
Post by Xenomes »
manjh wrote: Wednesday 17 March 2021 22:18 But there is no way to change the color temperature. In the devices tab of Domoticz, the lamps show up as RGB, which is wrong.
Hi Manjh, what is the version of the plug-in you are using?
HP T630 (256GB SSD/8GB Mem) - Ubuntu 24.04.3 LTS (64Bit) - Domoticz 2025.2 (Docker) Machinon theme - RFLink - KaKu - Sonoff - Tasmota - Shelly - MQTT2Zigbee - OpenTherm Gateway - Tinytuya - IR Blaster - P1 Smart Meter - NPN Watermeter - Google Assistant
manjh
Post by manjh »
How can I find the version number?
Hans
manjh
Post by manjh »
Xenomes wrote: Thursday 18 March 2021 20:13
Ah, found it in the setup. Tuyaha, version 0.0.6. Downloaded yesterday.
Hans
Xenomes
Post by Xenomes »
OK, then you are using the other plug-in. Can you try https://github.com/Xenomes/Domoticz-TUYA-Plugin there are more lights selections.
manjh
Post by manjh »
Xenomes wrote: Thursday 18 March 2021 21:33 OK, then you are using the other plug-in. Can you try https://github.com/Xenomes/Domoticz-TUYA-Plugin there are more lights selections.
AH, so I am using the wrong plugin... Should I remove Tuyaha first?
Hans
Xenomes
Post by Xenomes »
manjh wrote: Thursday 18 March 2021 21:34 AH, so I am using the wrong plugin... Should I remove Tuyaha first?
the other plug-in has Tuyaha as a git pull, my one has a pip3 install
manjh
Post by manjh »
Xenomes wrote: Thursday 18 March 2021 21:36
OK, that was easy.
With your plugin, I can now see a color-circle, but a second one with only warm/cold white. So I can now change the color and dimmer level.
One thing: the device still comes up as RGB. Is that how it was meant to be?
Hans
Xenomes
Post by Xenomes »
manjh wrote: Thursday 18 March 2021 21:43 OK, that was easy.
Can you run the debug_discovery.py from the tools directory?
manjh
Post by manjh »
Xenomes wrote: Thursday 18 March 2021 21:47
I get:
File "debug_discovery.py", ;ine 2, in <module>
import requests
ImportError: No module named requests
Hans
Xenomes
Post by Xenomes »
manjh wrote: Thursday 18 March 2021 21:59 I get:
import requests
Did you install requests?
manjh
Post by manjh »
Xenomes wrote: Thursday 18 March 2021 22:00
import requests
Yes, I followed the instructions to the letter! :D
Hans
manjh
Post by manjh »
I re-ran the pip3 command, and get two lines saying "already satisfied".
I should note: the devices work just fine. But it seems funny to get a full color selector for a device that is white-only... :cry:
Hans
Xenomes
Post by Xenomes »
Then you run python ./debug_discovery.py try python3 ./debug_discovery.py
manjh
Post by manjh »
Xenomes wrote: Thursday 18 March 2021 22:06 Then you run python ./debug_discovery.py try python3 ./debug_discovery.py
Ah, that's different.
Getting credentials
Got credentials
{   'errorMsg': 'Get accesstoken failed. Invalid parms.',
    'responseStatus': 'error'}
  File "./debug_discovery.py", line 35, in <module>
    payload = {"accessToken": auth_response["access_token"]}
KeyError: 'access_token'
Hans
Xenomes
Post by Xenomes »
manjh wrote: Thursday 18 March 2021 22:09 Ah, that's different.
Getting credentials
Got credentials
That is better, edit the file and fill in the information between CHANGE THIS
manjh
Post by manjh »
FYI: in the Domoticz log I can see this:
2021-03-18 22:11:49.254 (Tuya devices) DEV name=LSC 2 state=True id=6276453110521cc9ecd9 online=True
2021-03-18 22:11:49.254 (Tuya devices) DEV name=LSC 1 state=True id=53425342f4cfa209631c online=True
LSC 1 and 2 are the two lamps that I have.
Hans
manjh
Post by manjh »
Xenomes wrote: Thursday 18 March 2021 22:12
Getting credentials
Got credentials
Sorry, I must have missed this in the plugin instructions.
Which file should I edit?
Hans
Xenomes
Post by Xenomes »
manjh wrote: Thursday 18 March 2021 22:15 Sorry, I must have missed this in the plugin instructions.
debug_discovery.py
the tool gives a json string so i can see the what device outputs, then i can update the plugin so a device without rgb has no colour wheel.
manjh
Post by manjh »
Xenomes wrote: Thursday 18 March 2021 22:19
debug_discovery.py
OK, got it.
Getting credentials
Got credentials
{   'access_token': 'EUheu1616000992439YNMrdQKReKU4r4S',
    'expires_in': 864000,
    'refresh_token': 'EUheu1616000992439YNMrdAFLvKdAtuy',
    'token_type': 'bearer'}
Getting devices
Got devices
{   'header': {'code': 'SUCCESS', 'payloadVersion': 1},
    'payload': {   'devices': [   {   'data': {   'brightness': '130',
                                                  'color_mode': 'white',
                                                  'color_temp': 1000,
                                                  'online': True,
                                                  'state': 'true'},
                                      'dev_type': 'light',
                                      'ha_type': 'light',
                                      'icon': 'https://images.tuyaeu.com/smart/icon/ay1541056239985fDGjj/15919273389f9d925c99f.png',
                                      'id': '6276453110521cc9ecd9',
                                      'name': 'LSC 2'},
                                  {   'data': {   'brightness': '10',
                                                  'color_temp': 1000,
                                                  'online': True,
                                                  'state': 'true'},
                                      'ha_type': 'light',
                                      'id': '53425342f4cfa209631c',
                                      'name': 'LSC 1'}],
                   'scenes': []}}
Hans
Xenomes
Post by Xenomes »
manjh wrote: Thursday 18 March 2021 22:22 OK, got it. SHould I post the output here, or do you want it some other way?
If you give the device output that is enough, you can mask any info you want.
Users browsing this forum: PatrickH67 and 1 guest
