Page 7 of 10
Re: Dashticz Dial - Features, Fixes & Updates
Posted: Saturday 24 October 2020 23:31
by Lokonli
McMelloW wrote: Saturday 24 October 2020 16:19
Lokonli wrote: Sunday 18 October 2020 18:38
McMelloW wrote: Sunday 18 October 2020 12:19
I have created a P1 Smart Meter with the following block.
blocks['p1'] = {
idx: 37,
title: 'P1 Meter',
type: 'dial',
width: 4,
min: -15,
max: 20,
showring: true,
showunit: true,
shownumbers: true,
last_update: false
It all looks very nice, but the meter is flashing 2-3 times /sec. How can I stop this flashing?
The dials flash when the value is updated. Currently this is hardcoded in creative.css.
I'll make a block parameter for it.
Hi Lokonli,
Any news on this block parameter for the flashing P1 Meter Dial?
I've added the block parameter 'animation' to latest beta. To disable dial animation add the following block parameter:
Posted: Saturday 24 October 2020 23:51
by McMelloW
Lokonli wrote: Saturday 24 October 2020 23:31
Hi Lokonli,
Thanks very much. It stopped flashing.
Posted: Monday 26 October 2020 16:03
by gielie
I can't seem to change the dial color ring primary and secondary if i use some specific code.
If i use the standard code like this i
can change the color in the custom.css
blocks['Gang_boven2'] = {
idx: '335',
title: 'test',
type: 'dial',
width: 6,
showring: true,
temp: 345,
flash: true,
shownumbers: true,
showunit: true,
min: 15,
max: 25,
But if i use this code i can't change the color for primary and secondary , only the primary changes.
blocks['Gang_boven'] = {
title: 'Gang boven',
type: 'dial',
width: 4,
showring: true,
flash: true,
shownumbers: true,
showunit: true,
min: 15,
max: 25,
values : [
value: 'Temp',
idx: 345,
unit: 'ºC'
value: 'SetPoint',
idx: 335,
isSetpoint: true,
icon: 'fas fa-calendar-alt',
unit: 'ºC',
value: 'Level',
idx: 333,
icon: 'fas fa-fire',
unit: '%'
and it would look like this, temp under setpoint is blue above setpoint is red.
Posted: Monday 26 October 2020 20:18
by Arkie
Hi all, i like to combine 2 idx's in a 'normal' thermostat block, is this possible.
i have 2 seperate idx's 1 for measured temperature and 1 for temperature setpoint
regards
Posted: Monday 26 October 2020 22:22
by Lokonli
gielie wrote: Monday 26 October 2020 16:03
idx: '335',
title: 'test',
type: 'dial',
width: 6,
showring: true,
temp: 345,
flash: true,
shownumbers: true,
showunit: true,
min: 15,
max: 25,
type: 'dial',
width: 4,
showring: true,
flash: true,
shownumbers: true,
showunit: true,
min: 15,
max: 25,
values : [
value: 'Temp',
idx: 345,
unit: 'ºC'
value: 'SetPoint',
idx: 335,
isSetpoint: true,
unit: 'ºC',
value: 'Level',
idx: 333,
unit: '%'
Should be fixed in latest beta.
Thanks for testing.
Posted: Monday 26 October 2020 22:36
by Lokonli
Arkie wrote: Monday 26 October 2020 20:18
regards
To understand your request, with a normal thermostat block you mean the following:
- thermostat.jpg (4.8 KiB) Viewed 7296 times
And you would like to get the following:
- thermostattemp.jpg (5.64 KiB) Viewed 7296 times
Is this what you mean?
Posted: Monday 26 October 2020 22:40
by Arkie
That's what i mean, but my setpoint and actual temp has a own idx, would also be nice if the icon color changes when heating.
Heatmiser neo thermostats
idx1 status heating (switch)
idx2 temp
idx3 thermostat
Posted: Saturday 31 October 2020 13:46
by sailmich
cduijker wrote: Wednesday 09 September 2020 11:54
Is it possible to change the icon (power-off) on the on/off switch dial to another icon?
Couldn't find an answer. And I have the same question. I would like to have a bulb instead of on/off symbol, so it's clear that the switch is for light.
Any help appreciated!
Posted: Saturday 31 October 2020 15:21
by Lokonli
sailmich wrote: Saturday 31 October 2020 13:46
Currently the icon is hard coded as on/off. I'll make it a block parameter.
Posted: Sunday 01 November 2020 14:06
by sailmich
That would be fantastic! Thx in advance!
Posted: Tuesday 24 November 2020 10:16
by sailmich
I use a dial to regulate volume of my Soundtouch. When turning I get digital points, when finished turning it will rounded up or down. Is it possible to hide the digital points? I would like to see always level without a digital point. Eg 1/2/3/4......
Posted: Tuesday 12 January 2021 1:54
by frnandu
Great work on the dial.
Here's an idea that maybe is worth implementing:
Power meter with switch on/off.
Since there are so many smart plugs with power metering, would be great to be able to combine the function of a dial on/off switch with a power meter showing current wattage and energy in kWh.
So, basically just joining this 2 blocks into one.
blocks['media kwh'] = {
idx: '5', // A General / kWh Type device
title: 'Media Power',
type: 'dial',
min: 0,
max: 100,
last_update: false,
showunit: true,
values: ['Usage','CounterToday'],
width: 3,
showring: true
blocks['media'] = {
idx:6, // A Light/Switch / Switch Type device
title: 'Media',
type: 'dial',
width: 3
- Capture.PNG (147.87 KiB) Viewed 7064 times
What do you guys think about this?
Posted: Saturday 23 January 2021 16:28
by madpatrick
Is it possible to make a dial as button.
I like to have 2 button with a link to a frame or page slide next to the buttons
Posted: Tuesday 26 January 2021 11:29
by Chris12
Hi @Lokonli,
It is possible to have a dial configured with 2 text values in it?
I have a monitored RPi via a dzvents script, which gives a 'status' and a 'monitored status', in 2 separate devices.
Both devices give me the correct values in domoticz, I only cannot combine these (yet) in a single dial.
I tried to configure it like this:
blocks['RPi-status'] = {
title: 'RPi Status',
type: 'dial',
width: 4,
values : [
value: 'Active',
idx: 1032
value: 'Status',
idx: 1031,
Posted: Thursday 28 January 2021 15:39
by Chris12
@lokonli,
Issue also seen in latest beta release.
domoticz:
I expect the text Active and Monitored in the dial.
Posted: Thursday 28 January 2021 17:54
by Lokonli
Currently text devices are not supported in dials.
I'll add that to the feature request list.
Posted: Friday 29 January 2021 7:31
by Chris12
Lokonli wrote: Thursday 28 January 2021 17:54
That would be great! Just let me know when you want me to test something.
Posted: Saturday 30 January 2021 0:20
by csuti
First of all, this Dashticz dial really nice work, and many thanks for it.
I use several years the Dashticz on two old ipad2. I want to upgrade now and would like to use the dial for my thermostats. I have two problems both problem unfortunately related to my old iPad display.
As you can see on the picture, the position of the value of the temp is not central, and the position of the outer ring totally bad, and it is still active when I turn it false. On my pc and newer tablet the visualization is ok.
I try with safari and chrome but the result is the same, I changed the apache2 to nginx but not solved it.
Do you have any suggestions for solving the problem?
- dashticz_problems.jpg (52.37 KiB) Viewed 6954 times
thx
csuti
Posted: Saturday 30 January 2021 7:51
by Lokonli
Which Dashticz version do you use?
There are improvements in latest beta.
Posted: Saturday 30 January 2021 8:01
by csuti
Lokonli wrote: Saturday 30 January 2021 7:51
"version": "3.7",
"branch": "master",
"last_changes": "Master version derived from 3.6.9 beta",
Today I will check it with beta!
THX
