Dashticz - Module - Calendar
Trigun
Domoticz version: 4.10717
Re: Dashticz - Module - Calendar
Post by Trigun »
Hi EdKo66, is there a chance you can share you full Calendar config? Still working on it :) Thnx in advance!
Grove
Post by Grove »
I have a combined calendar of 2.
I see some strange values in the overview.
The white calendar is giving back the correct values.
But the green has values of 2018?? This are weekday repeated "appointments".
So I should expect to see the values of next monday.
Is there sombody with the same issue?
robgeerts
Domoticz version: 3.7067
Post by robgeerts »
Yes this is a known issue, will try to fix this today!
robgeerts
Post by robgeerts »
Please try latest beta!!
Grove
Post by Grove »
Hi Rob,
almost there.
There is one strange date.
One from 1992. Its a birthday, maybe that this has something to do with it...
But the rest looks a lot better
EdwinK
Post by EdwinK »
Trigun wrote:Hi EdKo66, is there a chance you can share you full Calendar config? Still working on it :) Thnx in advance!
I only have it working partly, so can't help you.
mvveelen
Post by mvveelen »
Grove wrote:Hi Rob,
almost there.
With the latest beta (2 minutes ago) I only see birthdays (with the startdate) and no other appointments :?:
rpwessels
Domoticz version: V3.5641
Post by rpwessels »
I try to configure my config for the calendar. In my config is this part:
var calendars = {}
calendars.private = {icalurl: 'webcal://p32-calendars.icloud.com/published/2/PRIVATE URL'}
var _ICALENDAR_DATEFORMAT = 'DDDD.MM.YYYY HH:mm'; //'friendly', 'MM.DD.YYYY HH:mm', 'DD.MM.YYYY HH:mm', 'YYYY.MM.DD HH:mm'
var _ICALENDAR_LOCALE = 'nl'; //en,hu, etc.
But when i open my dashticz page i get the following error message:
Error: Error: Invalid UNTIL value: 20110720T000001
url: undefined
line: 358
Can you help me to get this great page working.
Thanks Ricardo
Ubuntu16.04 LTS | Z-wave | Opentherm | P1 Smartmeter
Trigun
Post by Trigun »
/quote]
Ok, thnx anyways!
poudenes
Domoticz version: 3.8993
Post by poudenes »
robgeerts wrote:Please try latest beta!!
Seems so much better. :D good job... To bad i can't program like that ...
I see only 1 thing: some repeating items are showing 1 hour later than actual is planned.
mvveelen
Post by mvveelen »
Am I the only one with only birthdays in the overview (using combined calendar, didn't change any setting, only updated to the latest beta) ?
robgeerts
Post by robgeerts »
Who has problems with the calendar, please send me the full public url via pm. Of course I dont care about your appointments and wont share them. Explain wich appointment gives problems.
EdwinK
Post by EdwinK »
Send
mvveelen
Post by mvveelen »
Sent my info too :)
EdwinK
Post by EdwinK »
I give up for now. The url I have is correct, but still doesn't show anything on Dashticz. Data shows up on my calendars on Mac and phone from same settings.
HansieNL
Post by HansieNL »
EdKo66 wrote:I give up for now. The url I have is correct, but still doesn't show anything on Dashticz. Data shows up on my calendars on Mac and phone from same settings.
EdKo66, did you copy the url by clicking the ical button in Google Calendar and took that url?
Blah blah blah
EdwinK
Post by EdwinK »
Yes, I did.
I even feed it through http://ical-to-json.herokuapp.com/conve ... ATH.TO.ICS
and there I get {"calendars":[],"success":true}
So, it is recognized. But, it doesn't show anything else. With my other account it will spit out all my appointments. Both the business and the private calendar are set to shared.
HansieNL
Post by HansieNL »
EdKo66 wrote:Yes, I did.
I know that ical files can be sometimes a pain in the ass. I had to import my local ical file to a Google agenda, otherwise it wouldn't been shown in Dashticz. Had the same problem with my Homey and local ical files.
Maybe you can add a new simple calendar in Google?
Blah blah blah
EdwinK
Post by EdwinK »
Will try this.
EdwinK
Post by EdwinK »
FINALLY!!!!!! Got it to work, somehow. Just created another calendar, copied the link into the private part of CUSTOM.js, and... there was something.Now just to copy all the date from my 'old' private to the new one.
