Dashticz - Module - Calendar
Trigun
- Domoticz version: 4.10717
Re: Dashticz - Module - Calendar
Hi EdKo66, is there a chance you can share you full Calendar config? Still working on it
Thnx in advance!
Grove
I have a combined calendar of 2.
I see some strange values in the overview.
The white calendar is giving back the correct values.
But the green has values of 2018?? This are weekday repeated "appointments".
So I should expect to see the values of next monday.
Is there sombody with the same issue?
robgeerts
- Domoticz version: 3.7067
Yes this is a known issue, will try to fix this today!
robgeerts
Please try latest beta!!
Grove
Hi Rob,
almost there.
There is one strange date.
One from 1992. Its a birthday, maybe that this has something to do with it...
But the rest looks a lot better
- EdwinK
- Domoticz version: BETA
I only have it working partly, so can't help you.Trigun wrote:Hi EdKo66, is there a chance you can share you full Calendar config? Still working on itThnx in advance!
- mvveelen
With the latest beta (2 minutes ago) I only see birthdays (with the startdate) and no other appointmentsGrove wrote:Hi Rob,
almost there.
rpwessels
- Domoticz version: V3.5641
I try to configure my config for the calendar. In my config is this part:
var calendars = {}
calendars.private = {icalurl: 'webcal://p32-calendars.icloud.com/published/2/PRIVATE URL'}
var _ICALENDAR_DATEFORMAT = 'DDDD.MM.YYYY HH:mm'; //'friendly', 'MM.DD.YYYY HH:mm', 'DD.MM.YYYY HH:mm', 'YYYY.MM.DD HH:mm'
var _ICALENDAR_LOCALE = 'nl'; //en,hu, etc.
But when i open my dashticz page i get the following error message:
Error: Error: Invalid UNTIL value: 20110720T000001
url: undefined
line: 358
Can you help me to get this great page working.
Thanks Ricardo
var calendars = {}
url: undefined
line: 358
Thanks Ricardo
Ubuntu16.04 LTS | Z-wave | Opentherm | P1 Smartmeter
Trigun
Ok, thnx anyways!EdKo66 wrote:Trigun wrote:Hi EdKo66, is there a chance you can share you full Calendar config? Still working on itThnx in advance!
/quote]
poudenes
- Domoticz version: 3.8993
Seems so much better.robgeerts wrote:Please try latest beta!!
I see only 1 thing: some repeating items are showing 1 hour later than actual is planned.
- mvveelen
Am I the only one with only birthdays in the overview (using combined calendar, didn't change any setting, only updated to the latest beta) ?
robgeerts
Who has problems with the calendar, please send me the full public url via pm. Of course I dont care about your appointments and wont share them. Explain wich appointment gives problems.
- EdwinK
Send
- mvveelen
Sent my info too
- EdwinK
I give up for now. The url I have is correct, but still doesn't show anything on Dashticz. Data shows up on my calendars on Mac and phone from same settings.
- HansieNL
EdKo66, did you copy the url by clicking the ical button in Google Calendar and took that url?EdKo66 wrote:I give up for now. The url I have is correct, but still doesn't show anything on Dashticz. Data shows up on my calendars on Mac and phone from same settings.
Blah blah blah
- EdwinK
Yes, I did.
I even feed it through http://ical-to-json.herokuapp.com/conve ... ATH.TO.ICS
and there I get {"calendars":[],"success":true}
So, it is recognized. But, it doesn't show anything else. With my other account it will spit out all my appointments. Both the business and the private calendar are set to shared.
- HansieNL
I know that ical files can be sometimes a pain in the ass. I had to import my local ical file to a Google agenda, otherwise it wouldn't been shown in Dashticz. Had the same problem with my Homey and local ical files.EdKo66 wrote:Yes, I did.
Maybe you can add a new simple calendar in Google?
Blah blah blah
- EdwinK
Will try this.
- EdwinK
FINALLY!!!!!! Got it to work, somehow. Just created another calendar, copied the link into the private part of CUSTOM.js, and... there was something.Now just to copy all the date from my 'old' private to the new one.
