Controlling Toon [HACKED] from Domoticz
gielie
Domoticz version: latest β
Re: Controlling Toon [HACKED] from Domoticz
Post by gielie »
FunFair wrote: Sunday 12 November 2017 20:30 Not that much, just change the parser to read the value from the correct dev_x and do some editing to the calculations. If you can wait a few days I'll change it for elec and gas aswell.
That would be great, thanks.
One other thing, i do have high and low tariv but i cant figure this out from the output i have created, how do i read this?
- Aeotec MultiSensor 6
- FIBARO FGS223
- FIBARO FGWPE Wall Plug
- Neo CoolCam Power plug
- Popp Smoke Detector
- Toon
- Kodi Media Server
FunFair
Post by FunFair »
gielie wrote: Monday 13 November 2017 8:50
Try the script attached as a file. I've replaced dev_3.3 to dev_3.2 and removed the adding of the 2 tariffs.
If you don't have a smart meter I don't know if it's possible to differentiate between low and normal tariff. Toon does not store these values seperately to my knowledge.
The gas readout script does not have to be altered.
analog_electricity_data_json_v23.zip
(1.48 KiB) Downloaded 214 times
gielie
Post by gielie »
This works perfect, thanks.
I keep wondering how my Toon makes the difference between the high and low tarief, maybe its a time thing.
- FIBARO FGS223
- Toon
- Kodi Media Server
anandus
Post by anandus »
terrorsource wrote: Wednesday 10 May 2017 17:59 [...]
Is working, but gives an error in logs:
Error: EventSystem: in ToonThermostat: [string "-- Script used for Toon Thermostaat utility d..."]:8: bad argument #1 to 'pairs' (table expected, got nil)
Did you find out how to fix this?
gielie
Post by gielie »
Im using the Toon script from the ts and its working great, i only want to add 1 thing and i cant get it to work by myself.
  if currentProgramState == 0 then currentProgramState = '10' -- No
    elseif currentProgramState == 1 then currentProgramState = '20' -- Yes
    elseif currentProgramState == 2 then currentProgramState = '30' -- Temporary
I want to add something to the last rule, when currentProgramState == 2 set currentProgramState ='20' After 30 minutes.
So it goes back to the program after Toon is set manualy.
How can i achieve this, someone here who can help me with this?
- FIBARO FGS223
- Toon
- Kodi Media Server
DennisD
Post by DennisD »
I updated my toon to 4.9.23 and the happ_thermstat did changed somewhat. I used the previous happ_thermstat to see if my boiler was on for my hot water or heating to switch some things (rollerblinds when i was taking a shower, and using dbe on my convector when heating was on), unfortunately this was gone after I upgraded. I therefore made some changes to the original script_toon_time.lua so i have a selector switch which would switch between off, hotwater and heating, in order to get things working again like i wanted.
Add the following user variable UV_ToonBurnerName , type string , name Branderinfo
Add the following selector switch : Name it Branderinfo and change the levels to: 0:OFF 1:CV 2:WW (delete the 3rd)
Now copy and paste the code to a text editor and name it script_time_toon.lua and upload it to your lua folder.
-- Time script runs every minute, intended to sync Domoticz with Toon in case the value is changed on the physical device.
-- Updates Toon Thermostat Sensor to value set on Toon
-- Updates Toon Temperature Sensor to value set on Toon
-- Updates Toon Scenes switch based on program set on Toon
-- Updates Toon Auto Program switch to value set on Toon
-- Updates Toon program information text to value set on Toon
-- Udates Toon Burner status in order to see in domoticz if tyou boiler is on for the hotwater or heating or off (still is a undefined number which i must hunt down)
    ToonThermostatSensorName = uservariables['UV_ToonThermostatSensorName'] -- Sensor showing current setpoint
    ToonTemperatureSensorName = uservariables['UV_ToonTemperatureSensorName'] -- Sensor showing current room temperature
    ToonScenesSensorName  = uservariables['UV_ToonScenesSensorName'] -- Sensor showing current program
    ToonAutoProgramSensorName = uservariables['UV_ToonAutoProgramSensorName'] -- Sensor showing current auto program status
	ToonBurnerName = uservariables['UV_ToonBurnerName']
	ToonProgramInformationSensorName = uservariables['UV_ToonProgramInformationSensorName'] -- Sensor showing displaying program information status
    ToonIP = uservariables['UV_ToonIP']
    DomoticzIP = uservariables['UV_DomoticzIP']
    json = assert(loadfile "/home/pi/domoticz/scripts/lua/JSON.lua")()  -- For Raspberry
local handle = assert(io.popen(string.format('curl http://%s/happ_thermstat?action=getThermostatInfo', ToonIP)))
   local ThermostatInfo = handle:read('*all')
handle:close()
-- JSON data from Toon contains a extra "," which should not be there.
ThermostatInfo = string.gsub(ThermostatInfo, ",}", "}")
jsonThermostatInfo = json:decode(ThermostatInfo)
    currentSetpoint = tonumber(jsonThermostatInfo.currentSetpoint) / 100
    currentTemperature = tonumber(jsonThermostatInfo.currentTemp) / 100
    currentProgramState = tonumber(jsonThermostatInfo.programState)
    currentActiveState = tonumber(jsonThermostatInfo.activeState)
    currentNextTime = jsonThermostatInfo.nextTime
	currentBurnerInfo = tonumber(jsonThermostatInfo.burnerInfo)
    currentNextSetPoint = tonumber(jsonThermostatInfo.nextSetpoint) / 100
    -- Update the thermostat sensor to current setpoint
    if otherdevices_svalues[ToonThermostatSensorName]*100 ~= currentSetpoint*100 then
        print('Updating thermostat sensor to new set point: ' ..currentSetpoint)
        commandArray[1] = {['Variable:UV_ToonChangedByDomoticz'] = '1'} -- Set variable changed to 1 to prevent script ToonSetPoint from shooting an event at Toon
        commandArray[2] = {['UpdateDevice'] = string.format('%s|0|%s', otherdevices_idx[ToonThermostatSensorName], currentSetpoint)}
    -- Update the temperature sensor to current room temperature
    if otherdevices_svalues[ToonTemperatureSensorName]*100 ~= currentTemperature*100 then
        print('Updating the temperature sensor to new value: ' ..currentTemperature)
        commandArray[3] = {['UpdateDevice'] = string.format('%s|0|%s', otherdevices_idx[ToonTemperatureSensorName], currentTemperature)}
    -- Update the toon scene selector sensor to current program state
    CurrentToonScenesSensorValue = otherdevices_svalues[ToonScenesSensorName]
    if currentActiveState == -1 then currentActiveState = '50' -- Manual
    elseif currentActiveState == 0 then currentActiveState = '40' -- Comfort
    elseif currentActiveState == 1 then currentActiveState = '30' -- Home
    elseif currentActiveState == 2 then currentActiveState = '20' -- Sleep
    elseif currentActiveState == 3 then currentActiveState = '10' -- Away
    if CurrentToonScenesSensorValue ~= currentActiveState then  -- Update toon selector if it has changed
        print ('Updating Toon Scenes selector')
        commandArray[4] = {['UpdateDevice'] = string.format('%s|1|%s', otherdevices_idx[ToonScenesSensorName], currentActiveState)}
    -- Updates the toon auto program switch
    CurrentToonAutoProgramSensorValue = otherdevices_svalues[ToonAutoProgramSensorName]
    if CurrentToonAutoProgramSensorValue ~= currentProgramState then -- Update toon auto program selector if it has changed
        print ('Updating Toon Auto Program selector')
        commandArray[5] = {['UpdateDevice'] = string.format('%s|1|%s', otherdevices_idx[ToonAutoProgramSensorName], currentProgramState)}
    -- Updates the toon program information text box
    CurrentToomProgramInformationSensorValue = otherdevices_svalues[ToonProgramInformationSensorName]
    if currentNextTime == 0 or currentNextSetPoint == 0 then
        ToonProgramInformationSensorValue = 'Op ' ..currentSetpoint.. '°'
        ToonProgramInformationSensorValue = 'Om ' ..os.date('%H:%M', currentNextTime).. ' op ' ..currentNextSetPoint.. '°'
    if CurrentToomProgramInformationSensorValue ~= ToonProgramInformationSensorValue then
        commandArray[6] = {['UpdateDevice'] = string.format('%s|0|%s', otherdevices_idx[ToonProgramInformationSensorName], ToonProgramInformationSensorValue)}
 -- Update the toon burner selector to current program state
    CurrentToonBurnerValue = otherdevices_svalues[ToonBurnerName]
	if currentBurnerInfo == 0 then currentBurnerInfo = '0' -- uit
    elseif currentBurnerInfo == 1 then currentBurnerInfo = '10' -- cv aan
    elseif currentBurnerInfo == 2 then currentBurnerInfo = '20' -- warmwater aan
    if CurrentToonBurnerValue ~= currentBurnerInfo then  -- Update toon burner selector if it has changed
        print ('Updating Toon burner info')
        commandArray[7] = {['UpdateDevice'] = string.format('%s|1|%s', otherdevices_idx[ToonBurnerName], currentBurnerInfo)}
michel30
Post by michel30 »
Hello All,
Thanks for explain how I can connect my Toon in Domoticz this works great :-)
Now I want to add Toon in Siri, I can switch my lights on in Siri with Domoticz, but Toon I don't get in :-(
I see Toon Auto Program as light switch and Toon Scenes as Light switch, I cannot use this in apple home kit so properly I do something wrong.
I also can not see the temperature etc.
This is how I set it up:
My toon set up in domoticz
ronalddehaan
Domoticz version: 2021.1
Post by ronalddehaan »
Hi guys, I've asked this before but unfortunately, there has been no reply yet :oops:
Can someone help me with a 'dummy' manual to add the rooted Toon to Domoticz?
I've tried it with OP's write-up, but I kept running into things that weren't clear to me. I'm no Domoticz guru :oops:
I am running Domoticz on a Windows 7 VM, on an ESXi6 host.
Until now I've been able to get everything up and running, but adding Toon this way is proving to be a bit too technical for me :lol:
If someone can send me clear instructions about the proper steps in the right order, I will happily write down a nice manual for everyone 8-)
michel30
Post by michel30 »
Where are you stuck?
Did install the scrip?
Did you add the variable?
if you did that, than you can add a dummy file.
After that you can edit these dummy files..
I am stuck that I see my dummy file in siri but it a light switch, I also cannot say heee Siri what is the tempature.
Regards,
Michel
michel30
Post by michel30 »
@DennisD
I updated my toon to 4.9.23 but for some how the Toon Temperature does not work anymore it stays on 0
The Toon Program Information stay on hello world
The Toon Thermostat is doing nothing.
I delete these 3 in Domoticz and recreate it again like on the first page.
I upload the script in the LUA directory but nothing happens :-(
The only thing what I can see in the log is:
2017-12-19 21:59:00.678 Error: EventSystem: in /home/pi/domoticz/scripts/lua/script_time_toon.lua: /home/pi/domoticz/scripts/lua/script_time_toon.lua:41: attempt to perform arithmetic on field '?' (a nil value)
In line 41 I see this: if otherdevices_svalues[ToonThermostatSensorName]*100 ~= currentSetpoint*100 then
IPtoon/happ_thermstat?action=getThermostatInfo I see this:
result: "ok",
currentTemp: "2282",
currentSetpoint: "1900",
currentInternalBoilerSetpoint: "6",
programState: "2",
activeState: "-1",
nextProgram: "1",
nextState: "2",
nextTime: "1513719000",
nextSetpoint: "1700",
randomConfigId: "1804289383",
errorFound: "255",
connection: "0",
burnerInfo: "0",
otCommError: "0",
currentModulationLevel: "0"
I don't known why this is not working anymore, I hope you could help me with this one.
Thanks..
Regards,
Michel
Eggybert
Post by Eggybert »
I'm also a new guy who bought an toon on Marktplaats.
I rooted the toon with no trouble but the firmware was really old. (3.0.36 or something)
I successfully update to 4.10.6 and still have root acces. (I couldn't edit the base-qb2-ene_4.10.6-1196-0_qb2 to keep ssh access, encrypted?)
But I have some trouble getting happ_thermstat? to work. (403)
If I understand it correct the way the website works you can only access qmf/www/
In this folder I can acces all the folder without getting the 403 error. (changed the forcedwhitelist=0 for this)
But in this firmware the folder happ_thermstat or anything that has to do with it is missing. (see attachments)
I can only find happ_thermstat in qmf/sbin/happ_thermstat. but this looks like the actual program.
Can anyone show me how the www looks like in older firmware version when the /happ_thermstat?action=getThermostatInfo is working.
Edit:
Never mind, I start to understand the file structure better.
The sbin folder can also be executed (please correct me if I'm wrong)
I get 403 on all files there except hdrv_hue and hdrv_zwave (these are on the whitelist)
So it looks like the whitelist 0 is not working.
I can only find the whitelist in /qmf/etc/qmf_release.xml
I tried without luck:
	<hcb_web>
		<port>10080</port>
		<defaultEntry>/qmf/www/</defaultEntry>
		<enforceWhitelist>0</enforceWhitelist>
		<whitelist>
                       <item>hdrv_zwave</item>
                       <item>hdrv_hue</item>
                       <item>happ_thermstat</item>
		</whitelist>
	</hcb_web>
michel30
Post by michel30 »
:oops: I found my problem :oops:
I had an space after in the user variable at the end of some of these words UV_ToonTemperatureSensorName
So good to know that you always need to check that you don't make an mistake like an space at the end ;)
michel30
Post by michel30 »
FunFair wrote: Monday 13 November 2017 12:30
Do you need to install PHP on the Raspberry pi1 ?
For me it is not working when I try this command: ./analog_electricity_data_json.php I received this error message
-bash: ./analog_electricity_data_json.php: /usr/bin/php: bad interpreter: No such file or directory
When I check the folder /usr/bin there is no map PHP.
On my Raspberry I have Domoticz running.
Eggybert
Post by Eggybert »
Eggybert wrote: Wednesday 20 December 2017 19:37
	<hcb_web>
		<port>10080</port>
		<whitelist>
		</whitelist>
	</hcb_web>
After installing the toon store and change the qmf_release.xml to the following it's working now.
The project
	<hcb_web>
		<defaultEntry>/hdrv_zwave/</defaultEntry>
		<whitelist>
		</whitelist>
	</hcb_web>
michel30
Post by michel30 »
PHP is now working on my raspberry pi and I install the gas_data_json.php and analog_electricity_data_json.php meters.
I changed the IP adress plus IDX.
I had needed also to 3.1 to dev 2.1 and 2.2 because when I open the website of the toon there was no dev 3.1 and I had an error in this scrip.
the only two problem for now is this:
for the gas_data_json.php:
./gas_data_json.php
PHP Notice: Undefined index: result in /home/pi/domoticz/scripts/p1_meter/gas_data_json.php on line 36
Gas Value Domoticz = 0 liters
Gas Value Toon = 7360.00 liters
"status" : "ERR"
and for the analog_electricity_data_json.php:
PHP Notice: Undefined index: result in /home/pi/domoticz/scripts/p1_meter/analog_electricity_data_json.php on line 42
Electricity Counter Domoticz = 0 Wh
Electricity Counter Toon = 123970.00 Wh
Electricity Usage Toon = 743 Watt
"status" : "ERR"
I don't know where this error is comming from so hopefully somebody could help me.
michel30
Post by michel30 »
Finaly I found my issue.
IDX was on hardware not on device now it is working for me also with analog meter.
Does somebody knows how I can get TOON in siri?
glsf91
Post by glsf91 »
Is it possible to switch the Holiday on/off on Toon from domoticz?
If yes, how can I do this?
michel30
Post by michel30 »
Yes you can
Go to setup > more options > events
On the left you will see things what you can conrol so you could say I am on holiday so to this with my Toon. etc.
glsf91
Post by glsf91 »
michel30 wrote: Saturday 30 December 2017 19:59 Yes you can
That is also some solution.
But I was referring to the holiday function in Toon itself.
glsf91
Post by glsf91 »
I have another strange problem with using dzVents on Toon Temperature device:
When I use this code time triggered it works fine:
    active = true,
		timer = {
			'every minute'
	    domoticz.log('Script temp active')
            if ( domoticz.devices('Toon Temperature').temperature >= 19.0  ) then
              domoticz.log('Toon temp te hoog')
But if I do almost the same with device triggered:
    active = true,
		devices = {
			'Toon Temperature'
	    domoticz.log('Script TempKamerTeHoog active')
	    if (device.temperature >= 19.0 ) then
		domoticz.log('Temperatuur kamer is te hoog')
it won't work. It never gets triggered.
I use ToonGetInfo from a few posts https://www.domoticz.com/forum/posting. ... 1#pr161078 above this post.
In the log I see:
2018-01-03 20:02:00.471 LUA: Updating the temperature sensor to new value: 20.26
2018-01-03 20:02:00.471 EventSystem: Script event triggered: ToonGetInfo
but not followed by logging from above script.
So why is updating Toon Temperature not triggering the device script?
I'am using beta V3.8755.
