MyDomoticz revisited Topic is solved
rgoossens
Domoticz version: 2021.1
Re: MyDomoticz revisited
Post by rgoossens »
SigveM wrote: Friday 04 June 2021 14:37 MyDomoticz finally works again!!! Successfully tested on PC running Chrome and on Android phone today. All is good :)
4 1/2 months without MyDomoticz remote access has actually been quite a nerve-racking experience, not being able to regularly monitor the automated heating during the winter months. Luckily it's worked out OK, with the local instance of Domoticz having done its job. But it sure is nice to finally be able to monitor the behavior remotely again.
Whoever managed to make it work again - thank you so much. And please - if it ain't broke then don't fix it :D
BTW - I am still running Domoticz version 2020.2 as I understand from various posts on this forum that version 2021.1, build 13191, still has several issues.
From a security point off view, you want regular fixes, nobody likes backdoors through which cryptopockers are distributed, so keep installing (security) fixes is always necessary
lukbe
Domoticz version: 3.8153
Post by lukbe »
What is wrong with my.domoticz.com?
I can't open the Web page.
Forbidden
You don't have permission to access this resource.
Apache/2.4.41 (Ubuntu) Server at my.domoticz.com Port 80
It is in this situation for several months now. No reaction from the developer yet so for the time being unfortunately useless.
It is a pity because it was a nice solution.
user4563
Post by user4563 »
Just adding you can easily make your own like I did: viewtopic.php?f=47&t=37305
You can of course open the port on your router and forward to the Domoticz SSL port as well.
Aeotec Z-Stick Gen5+
ZWave-JS-UI / Mosquitto MQTT
Domoticz for Android
Just a reminder also on the wiki.
NOTE: dd 01-01-2022 MyDomoticz has been deprecated, not functional anymore.....
Also the code in Domoticz for MyDomoticz has been removed in latest beta.
Edit: For alternatives in accessing Domoticz from outside your netwerk see https://www.domoticz.com/wiki/Configura ... ote_Access
alfredosc8
Post by alfredosc8 »
Where is the code for myDomoticz, I'm interested to support it and eventually hosting for free if it can run on my servers.
It is very usefull for standard users without ability to open port in their router.
alfredosc8 wrote: Thursday 02 February 2023 14:09 Where is the code for myDomoticz, I'm interested to support it and eventually hosting for free if it can run on my servers.
Contact user chimit or on github rkluwen: https://github.com/rkluwen
alfredosc8
Thanks,
In any case I used Tier-one, it runs the agent in raspberry and other micro or big computer
