I still offer this Pass2PHP script.
Running every 5 minutes with no lock-out
https://github.com/sincze/Domoticz/blob ... verter.php
Python Plugin: Growatt Inverter
- sincze
- Domoticz version: 2024.4
Re: Python Plugin: Growatt Inverter
Pass2php
USB: RFXCom, ZWave, Sonoff 3
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Solar: Omnik, PVOutput
Sensors: You name it I got 1.
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
ravikjab
What if i have 4 pcs power station in account growatt? How configurate this script?
- sincze
That is a good question. I have no such amount of devices so unable to debug this.ravikjab wrote: Thursday 29 February 2024 21:49 What if i have 4 pcs power station in account growatt? How configurate this script?
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
ravikjab
But is it possible to do?
rensbr
I have the same question, but then with 2 inverters.ravikjab wrote: Thursday 29 February 2024 21:49 What if i have 4 pcs power station in account growatt? How configurate this script?
Yesterday I installed a second Growatt inverter into my home and added this to already exsisting account, is there a way to add both inverters to Domoticz? Either trough the plugin or the php scrip.
janvdberg
I use this to sum the totals of multiple inverters:
https://j11g.com/2024/04/01/how-to-add- ... -domoticz/
I have also two Growatt inverters and they are both in my existing account. I would like to see them individually in Domoticz, or the totals for both of them, either way. The current setup with this plugin shows only the numbers for the first plant.rensbr wrote: Monday 22 April 2024 10:01I have the same question, but then with 2 inverters.ravikjab wrote: Thursday 29 February 2024 21:49 What if i have 4 pcs power station in account growatt? How configurate this script?
rensbr
You can't do this with the existing plugin. I have used Grott instead, in combination with NodeRed and that works like a charm.ronzelver wrote: Friday 20 September 2024 9:24I have also two Growatt inverters and they are both in my existing account. I would like to see them individually in Domoticz, or the totals for both of them, either way. The current setup with this plugin shows only the numbers for the first plant.rensbr wrote: Monday 22 April 2024 10:01I have the same question, but then with 2 inverters.ravikjab wrote: Thursday 29 February 2024 21:49 What if i have 4 pcs power station in account growatt? How configurate this script?
