Python Plugin: Growatt Inverter
sincze
Domoticz version: 2024.4
Re: Python Plugin: Growatt Inverter
Post by sincze »
I still offer this Pass2PHP script.
Running every 5 minutes with no lock-out
https://github.com/sincze/Domoticz/blob ... verter.php
Pass2php
USB: RFXCom, ZWave, Sonoff 3
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Solar: Omnik, PVOutput
Sensors: You name it I got 1.
ravikjab
Post by ravikjab »
What if i have 4 pcs power station in account growatt? How configurate this script?
sincze
Post by sincze »
ravikjab wrote: Thursday 29 February 2024 21:49 What if i have 4 pcs power station in account growatt? How configurate this script?
That is a good question. I have no such amount of devices so unable to debug this.
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
ravikjab
Post by ravikjab »
But is it possible to do?
rensbr
Post by rensbr »
I have the same question, but then with 2 inverters.
Yesterday I installed a second Growatt inverter into my home and added this to already exsisting account, is there a way to add both inverters to Domoticz? Either trough the plugin or the php scrip.
janvdberg
Post by janvdberg »
I use this to sum the totals of multiple inverters:
https://j11g.com/2024/04/01/how-to-add- ... -domoticz/
ronzelver
Post by ronzelver »
rensbr wrote: Monday 22 April 2024 10:01
I have also two Growatt inverters and they are both in my existing account. I would like to see them individually in Domoticz, or the totals for both of them, either way. The current setup with this plugin shows only the numbers for the first plant.
rensbr
Post by rensbr »
ronzelver wrote: Friday 20 September 2024 9:24
You can't do this with the existing plugin. I have used Grott instead, in combination with NodeRed and that works like a charm.
