Weekly programming
DarkG
Domoticz version: 4.10076
Re: Weekly programming
Post by DarkG »
Will this work with the lastest beta?
RPi4 Shelly1 Shelly2.5 ESPEasy Tuya Domoticz Beta Dashticz 3.6
syrhus
Domoticz version: 2021.1
Post by syrhus »
Absolutely, it does.
Do you have a trouble with it?
DarkG
Post by DarkG »
I ask to be safe. My system is good running. And I dont wanna crash it. So I ask before İ try.
But after Update it get lost or? So everytime I Update my System I must Install it again. İ am on Beta Channel
syrhus
Post by syrhus »
As this is not in the master branch, after each updates, you have to modify the DeviceTimersController.js file to add the 3 parts as explained on my github gist.
EdddieN
Domoticz version: 4.9700
Post by EdddieN »
WoW!
That is great
11101101 - www.machinon.com
syrhus
Post by syrhus »
A new version is released on my github.
This is a "ready to branch" version, easier to integrate with existing code.
I improve performance and fix some issues.
WARNING, planning.js is now on www/app/timers folder
DarkG
Post by DarkG »
Can you please look why there are no icons?
https://www.bilder-upload.eu/bild-ed014 ... 7.jpg.html
syrhus
Post by syrhus »
did you delete the application cache of your web browser?
if you press F12 (to open developpement tools) and go to the console tab, you should see an error. Check it and let me know.
DarkG
Post by DarkG »
syrhus wrote: Saturday 22 December 2018 11:53 did you delete the application cache of your web browser?
Here you can see
https://www.bilder-upload.eu/bild-f4c5e ... 9.jpg.html
syrhus
Post by syrhus »
Could you show your DeviceTimersController.js file?
It seems you have something wrong in this fils in the getTimers function.
DarkG
Post by DarkG »
define(['app', 'timers/factories', 'timers/components','timers/planning' ], function (app) {
    app.controller('DeviceTimersController', function ($scope, $routeParams, deviceApi, deviceLightApi, deviceRegularTimersApi, deviceSetpointTimersApi, deviceTimerOptions, deviceTimerConfigUtils, utils) {
        var vm = this;
        var deviceTimers;
        var deleteConfirmationMessage = $.t('Are you sure to delete this timers?\n\nThis action can not be undone...');
        var clearConfirmationMessage = $.t('Are you sure to delete ALL timers?\n\nThis action can not be undone!');
        vm.addTimer = addTimer;
        vm.updateTimer = updateTimer;
        vm.deleteTimer = utils.confirmDecorator(deleteTimer, deleteConfirmationMessage);
        vm.clearTimers = utils.confirmDecorator(clearTimers, clearConfirmationMessage);
        init();
        function init() {
            vm.deviceIdx = $routeParams.id;
            vm.selectedTimerIdx = null;
            deviceApi.getDeviceInfo(vm.deviceIdx).then(function (device) {
                vm.isLoaded = true;
                vm.itemName = device.Name;
                vm.colorSettingsType = device.SubType;
                vm.dimmerType = device.DimmerType;
                vm.isDimmer = device.isDimmer();
                vm.isSelector = device.isSelector();
                vm.isLED = device.isLED();
                vm.isCommandSelectionDisabled = vm.isSelector && device.LevelOffHidden;
                vm.isSetpointTimers = (device.Type === 'Thermostat' && device.SubType == 'SetPoint') || (device.Type === 'Radiator 1');
                vm.levelOptions = [];
                deviceTimers = vm.isSetpointTimers
                    ? deviceSetpointTimersApi
                    : deviceRegularTimersApi;
                if (vm.isSelector) {
                    vm.levelOptions = device.getSelectorLevelOptions();
                if (vm.isLED) {
                    $scope.$watch(function () {
                        return vm.timerSettings.color + vm.timerSettings.level;
                    }, setDeviceColor);
                if (vm.isDimmer) {
                    vm.levelOptions = device.getDimmerLevelOptions(1);
                if (vm.levelOptions.length > 0) {
                    vm.timerSettings.level = vm.levelOptions[0].value;
                refreshTimers();
            vm.typeOptions = deviceTimerOptions.timerTypes;
            vm.timerSettings = deviceTimerConfigUtils.getTimerDefaultConfig();
			 $( document ).trigger( "timersInitialized", [vm, refreshTimers] );//<===Update for Planning
             refreshTimers();
        function refreshTimers() {
            deviceTimers.getTimers(vm.deviceIdx).then(function (items) {
                vm.timers = items;
				$( document ).trigger( "timersLoaded", [items] );;//<===Update for Planning
        function setDeviceColor() {
            if (!vm.timerSettings.color || !vm.timerSettings.level) {
                return;
            deviceLightApi.setColor(
                vm.deviceIdx,
                vm.timerSettings.color,
        function getTimerConfig() {
            var utils = deviceTimerConfigUtils;
            var config = Object.assign({}, vm.timerSettings);
            if (!utils.isDayScheduleApplicable(config.timertype)) {
                config.days = 0;
            if ([6, 7, 10, 12].includes(config.timertype)) {
                config.days = 0x80;
            if (utils.isOccurrenceApplicable(config.timertype)) {
                config.days = Math.pow(2, config.weekday);
            config = Object.assign({}, config, {
                date: utils.isDateApplicable(config.timertype) ? config.date : undefined,
                mday: utils.isRDaysApplicable(config.timertype) ? config.mday : undefined,
                month: utils.isRMonthsApplicable(config.timertype) ? config.month : undefined,
                occurence: utils.isOccurrenceApplicable(config.timertype) ? config.occurence : undefined,
                weekday: undefined,
                color: vm.isLED ? config.color : undefined,
                tvalue: vm.isSetpointTimers ? config.tvalue : undefined,
                command: vm.isSetpointTimers ? undefined : config.command,
                randomness: vm.isSetpointTimers ? undefined : config.randomness
            var error = deviceTimerConfigUtils.getTimerConfigErrors(config);
            if (error) {
                ShowNotify(error, 2500, true);
                return false;
            var warning = deviceTimerConfigUtils.getTimerConfigWarnings(config);
            if (warning) {
            return config;
        function addTimer() {
            const config = getTimerConfig();
            if (!config) {
                return false;
            deviceTimers
                .addTimer(vm.deviceIdx, config)
                .then(refreshTimers)
                .catch(function () {
                    HideNotify();
                    ShowNotify($.t('Problem adding timer!'), 2500, true);
        function updateTimer(timerIdx) {
            if (!config) {
                return false;
            deviceTimers
                .updateTimer(timerIdx, config)
                    HideNotify();
                    ShowNotify($.t('Problem updating timer!'), 2500, true);
        function deleteTimer(timerIdx) {
            return deviceTimers.deleteTimer(timerIdx)
                    HideNotify();
                    ShowNotify($.t('Problem deleting timer!'), 2500, true);
        function clearTimers() {
            return deviceTimers
                .clearTimers(vm.deviceIdx)
                    HideNotify();
                    ShowNotify($.t('Problem clearing timers!'), 2500, true);
syrhus
Post by syrhus »
Please, check what you have modified, you wrote the wrong for the first trigger:
define(['app', 'timers/factories', 'timers/components','timers/planning'], function (app) {
        var vm = this;
        var deviceTimers;
        init();
        function init() {
                vm.isLoaded = true;
                if (vm.isLED) {
                    }, setDeviceColor);
                if (vm.isDimmer) {
                refreshTimers();
                vm.timers = items;
                return;
                vm.deviceIdx,
                config.days = 0;
                config.days = 0x80;
                weekday: undefined,
            if (error) {
                return false;
            if (warning) {
            return config;
            if (!config) {
                return false;
            deviceTimers
                    HideNotify();
            if (!config) {
                return false;
            deviceTimers
                    HideNotify();
                    HideNotify();
            return deviceTimers
                    HideNotify();
DarkG
Post by DarkG »
syrhus
Post by syrhus »
I changed the previous post to set the entire DeviceTimersController.js file
Please replace it with your one and keep in mind that each time you change a js file, you have to clear your application cache to reload the updated files.
ocean123
Post by ocean123 »
wouw, great tool. Thanks :D
ocean123
Post by ocean123 »
I add the script to Domoticz version 4.10717.
And its not working. After restart also not.
No error, no changes, nothing happens.
:shock:
ocean123
Post by ocean123 »
It has something to do with Safari.
Chrome is working fine, Private browsing in Safari also working fine.
But normale browsing in safari, the scheduler is not showing up.
ocean123
Post by ocean123 »
Now its showing up. :D
Domoticz refreshed the browser cache the next day.
salopette
Post by salopette »
@ syrhus
can you do PR for Domoticz?
https://github.com/domoticz/domoticz/is ... -515738984
salopette
Post by salopette »
salopette wrote: Sunday 28 July 2019 9:36 @ syrhus
:?: :?: :roll:
